Bonsoir @Loic,
Peux-tu ajouter ce relai que je viens de recevoir.
Il n’est pas reconnu automatiquement mais il existe déjà dans le plugin un modèle Tuya avec lequel il fonctionne (TZ3000 TS011F) mais avec un seul relai alors que celui-ci en a deux.
En modifiant les commandes, j’arrive bien à contrôler les 2 relais en ajoutant le Endpoints 2, donc ça devrait être ok pour toi.
Modèle : TS011F
Fabricant : _TZ3000_pmz6mjyu
"ieee": "60:a4:23:ff:fe:62:11:ca",
"nwk": 25186,
"status": 2,
"lqi": "132",
"rssi": "-67",
"last_seen": "1615224192.8001544",
"node_descriptor": "01:40:8e:02:10:52:52:00:00:2c:52:00:00",
"endpoints": [
"id": 1,
"status": 1,
"device_type": 9,
"profile_id": 260,
"manufacturer": "_TZ3000_pmz6mjyu",
"model": "TS011F",
"output_clusters": [
"id": 25,
"name": "Ota",
"attributes": []
"id": 10,
"name": "Time",
"attributes": []
"input_clusters": [
"id": 0,
"name": "Basic",
"attributes": [
"id": 0,
"name": "zcl_version",
"value": 3
"id": 1,
"name": "app_version",
"value": 65
"id": 2,
"name": "stack_version",
"value": 0
"id": 3,
"name": "hw_version",
"value": 1
"id": 4,
"name": "manufacturer",
"value": "_TZ3000_pmz6mjyu"
"id": 5,
"name": "model",
"value": "TS011F"
"id": 6,
"name": "date_code",
"value": ""
"id": 7,
"name": "power_source",
"value": 1
"id": 4,
"name": "Groups",
"attributes": []
"id": 5,
"name": "Scenes",
"attributes": []
"id": 6,
"name": "On\/Off",
"attributes": [
"id": 0,
"name": "on_off",
"value": 0
"id": 16385,
"name": "on_time",
"value": 0
"id": 16386,
"name": "off_wait_time",
"value": 0
"id": 2,
"status": 1,
"device_type": 9,
"profile_id": 260,
"manufacturer": null,
"model": null,
"output_clusters": [],
"input_clusters": [
"id": 4,
"name": "Groups",
"attributes": []
"id": 5,
"name": "Scenes",
"attributes": []
"id": 6,
"name": "On\/Off",
"attributes": [
"id": 0,
"name": "on_off",
"value": 0
"id": 16385,
"name": "on_time",
"value": 0
"id": 16386,
"value": 0
"signature": {
"model": "TS011F",
"node_desc": {
"byte1": 1,
"byte2": 64,
"mac_capability_flags": 142,
"manufacturer_code": 4098,
"maximum_buffer_size": 82,
"maximum_incoming_transfer_size": 82,
"server_mask": 11264,
"maximum_outgoing_transfer_size": 82,
"endpoints": {
"1": {
"profile_id": 260,
"device_type": 9,
"input_clusters": [
0,
4,
5,
6
25,
10
"2": {
"profile_id": 260,
"device_type": 9,
"input_clusters": [
4,
5,
6
"class": "zigpy.device"
