Ca sera disponible dans la beta de demain, merci pour la configuration
[quote=« Rabie, post:1801, topic:40301 »]
@Loic,
Bonjour Loic ,
Voici les infos pour la telecommande Lidl
"ieee": "bc:33:ac:ff:fe:5e:59:27",
"nwk": 30430,
"status": 2,
"lqi": "116",
"rssi": "-71",
"last_seen": "1615542586.877416",
"node_descriptor": "02:40:80:02:10:52:52:00:00:2c:52:00:00",
"endpoints": [
"id": 1,
"status": 1,
"device_type": 260,
"profile_id": 260,
"manufacturer": "_TYZB01_bngwdjsr",
"model": "TS1001",
"output_clusters": [
"id": 25,
"name": "Ota",
"attributes": []
"id": 10,
"name": "Time",
"attributes": []
"id": 3,
"name": "Identify",
"attributes": []
"id": 4,
"name": "Groups",
"attributes": []
"id": 5,
"name": "Scenes",
"attributes": []
"id": 6,
"name": "On\/Off",
"attributes": []
"id": 8,
"name": "Level control",
"attributes": []
"id": 4096,
"name": "LightLink",
"attributes": []
"input_clusters": [
"id": 0,
"name": "Basic",
"attributes": [
"id": 1,
"name": "app_version",
"value": 81
"id": 4,
"name": "manufacturer",
"value": "_TYZB01_bngwdjsr"
"id": 5,
"name": "model",
"value": "TS1001"
"id": 1,
"name": "Power Configuration",
"attributes": [
"id": 32,
"name": "battery_voltage",
"value": 30
"id": 33,
"name": "battery_percentage_remaining",
"value": 200
"id": 3,
"name": "Identify",
"attributes": []
"id": 4,
"name": "Groups",
"attributes": []
"id": 4096,
"attributes": []
"signature": {
"model": "TS1001",
"node_desc": {
"byte1": 2,
"byte2": 64,
"mac_capability_flags": 128,
"manufacturer_code": 4098,
"maximum_buffer_size": 82,
"maximum_incoming_transfer_size": 82,
"server_mask": 11264,
"maximum_outgoing_transfer_size": 82,
"endpoints": {
"1": {
"profile_id": 260,
"device_type": 260,
"input_clusters": [
0,
1,
3,
4,
4096
25,
10,
3,
4,
5,
6,
8,
4096
"class": "zigpy.device"
Il me semble que cela a déjà été demandé au post:
Citation
Apepis85
Pour que je puisse l’ajouter il faudrait m’envoyer le log zigbee (tout court) après appui sur les boutons
@Bercolly voilà ce qu’il te reste a faire
Voilà le log.
Il semble que seule la commande On/Off est reçue par le plugin.
Les 3 autres boutons n’ont apparemment aucune action !
A+
[2021-03-12 13:13:28][DEBUG] : {"devices":{"bc:33:ac:ff:fe:5e:59:27":{"1":{"6":{"cmd":[{"value":"253","cluster_name":"On\/Off"},{"value":"2","cluster_name":"On\/Off"}]}}}}}
[2021-03-12 13:13:28][DEBUG] : Search command for bc:33:ac:ff:fe:5e:59:27 logicalId : 1::6::cmd::0 => 253
[2021-03-12 13:13:28][DEBUG] : Search command for bc:33:ac:ff:fe:5e:59:27 logicalId : 1::6::cmd::1 => 2
[2021-03-12 13:13:29][DEBUG] : {"devices":{"bc:33:ac:ff:fe:5e:59:27":{"1":{"6":{"cmd":[{"value":"253","cluster_name":"On\/Off"},{"value":"2","cluster_name":"On\/Off"}]}}}}}
[2021-03-12 13:13:29][DEBUG] : Search command for bc:33:ac:ff:fe:5e:59:27 logicalId : 1::6::cmd::0 => 253
[2021-03-12 13:13:29][DEBUG] : Search command for bc:33:ac:ff:fe:5e:59:27 logicalId : 1::6::cmd::1 => 2
[2021-03-12 13:13:30][DEBUG] : {"devices":{"bc:33:ac:ff:fe:5e:59:27":{"1":{"6":{"cmd":[{"value":"253","cluster_name":"On\/Off"},{"value":"2","cluster_name":"On\/Off"}]}}}}}
[2021-03-12 13:13:30][DEBUG] : Search command for bc:33:ac:ff:fe:5e:59:27 logicalId : 1::6::cmd::0 => 253
[2021-03-12 13:13:30][DEBUG] : Search command for bc:33:ac:ff:fe:5e:59:27 logicalId : 1::6::cmd::1 => 2
[2021-03-12 13:13:36][DEBUG] : {"devices":{"bc:33:ac:ff:fe:5e:59:27":{"1":{"1":{"33":{"value":"200","cluster_name":"Power Configuration"},"32":{"value":"30","cluster_name":"Power Configuration"}}}}}}
[2021-03-12 13:14:03][DEBUG] : {"devices":{"bc:33:ac:ff:fe:5e:59:27":{"1":{"6":{"cmd":[{"value":"253","cluster_name":"On\/Off"},{"value":"0","cluster_name":"On\/Off"}]}}}}}
[2021-03-12 13:14:03][DEBUG] : Search command for bc:33:ac:ff:fe:5e:59:27 logicalId : 1::6::cmd::0 => 253
[2021-03-12 13:14:03][DEBUG] : Search command for bc:33:ac:ff:fe:5e:59:27 logicalId : 1::6::cmd::1 => 0
[2021-03-12 13:14:04][DEBUG] : {"devices":{"bc:33:ac:ff:fe:5e:59:27":{"1":{"6":{"cmd":[{"value":"253","cluster_name":"On\/Off"},{"value":"0","cluster_name":"On\/Off"}]}}}}}
[2021-03-12 13:14:04][DEBUG] : Search command for bc:33:ac:ff:fe:5e:59:27 logicalId : 1::6::cmd::0 => 253
[2021-03-12 13:14:04][DEBUG] : Search command for bc:33:ac:ff:fe:5e:59:27 logicalId : 1::6::cmd::1 => 0
[2021-03-12 13:14:05][DEBUG] : {"devices":{"bc:33:ac:ff:fe:5e:59:27":{"1":{"6":{"cmd":[{"value":"253","cluster_name":"On\/Off"},{"value":"0","cluster_name":"On\/Off"}]}}}}}
[2021-03-12 13:14:05][DEBUG] : Search command for bc:33:ac:ff:fe:5e:59:27 logicalId : 1::6::cmd::0 => 253
[2021-03-12 13:14:05][DEBUG] : Search command for bc:33:ac:ff:fe:5e:59:27 logicalId : 1::6::cmd::1 => 0
[2021-03-12 13:14:06][DEBUG] : {"devices":{"bc:33:ac:ff:fe:5e:59:27":{"1":{"6":{"cmd":[{"value":"253","cluster_name":"On\/Off"},{"value":"0","cluster_name":"On\/Off"}]}}}}}
[2021-03-12 13:14:06][DEBUG] : Search command for bc:33:ac:ff:fe:5e:59:27 logicalId : 1::6::cmd::0 => 253
[2021-03-12 13:14:06][DEBUG] : Search command for bc:33:ac:ff:fe:5e:59:27 logicalId : 1::6::cmd::1 => 0
Merci @Loic
J’ai testé le profil généré par @sodaveli, à savoir le modèle TS0503B que tu as mis à jour aujourd’hui : ça fonctionne très bien sauf la gestion du blanc chaud et froid dans le cadre d’une bande LED RGBW.
Je pense que le modèle que je t’ai fourni doit gérer en plus le « W ».
Pour la photo, l’idéal est de reprendre celle de @sodaveli car cela concerne le petit controleur et pas le package bande LED + controleur.
Merci d’avance pour ton support et pour ton investissement.
Effectivement la a part le on/off je vais pas pouvoir mettre grand chose d’autre…
Pour l’image c’est bon pour l’histoire de température de couleur j’ai pas tout compris il faut supprimer les commandes car le bandeau ne le fait pas ?
En fait il faudrait que tu compares les informations brutes du TS0503B avec le TS0504B pour etre sûr que le TS0504B inclut bien la gestion des leds de couleur blanches que tu trouves dans un RGBWW et non dans un RGB simple.
S’il y a une différence dans les modèles alors il te faut bien 2 profils différents.
S’il n’y a pas de différence, les 2 modèles peuvent être gérés par le même profil … dans ce cas, il y doit avoir une commande manquante pour gérer les leds blanches WW.
En faite avec le json je ne peux avoir ce genre d’information seul l’utilisateur qui a le module en question peut me dire si il fait la partie température de couleur ou non
En jouant sur la température couleur, j’ai l’impression que ça ne change pas :
Peut etre que le modèle TS0504B est légèrement différent que le TS0503B.
Bonjour.
@iPapy @Loic @Bercolly
Ci dessous ma réponse à la demande de Loïc.
Dans ma réflexion, un log zigbee tout court n’est ni débug et doit comporter au moins les références ID de l’équipement d’où ma réponse (et dans la mesure où la télécommande arrive à piloter l’ampoule cela me satisfait …).
Reprise de l’essai en log débug et ci-dessous résultat détaillé.
Bonsoir.
Aucun log après appui sur les touches et en log débug pas plus concernant cette télécommande.
Par contre en appuyant sur le second bouton de la télécommande jusqu’au clignotement de la led d’association, l’ampoule incluse dans jeedom a été associée à la télécommande.
Pilotage possible de l’ampoule soit du plugin (toutes commandes) soit de la télécommande (on/off/augmenter et diminuer la luminosité) avec dans ce cas mise à jour de l’équipement ampoule.
Lors de l’Installation à venir des deux ampoules restantes du pack Lidl je tenterai le même processus de double association.
Deuxieme bouton: allumer l'ampoule (1 seule incluse reglee sur intensite minimale)
[2021-03-12 14:49:59][DEBUG] : {"devices":{"bc:33:ac:ff:fe:e9:4e:07":{"1":{"6":[{"value":"Bool.true","cluster_name":"On\/Off"}]}}}}
[2021-03-12 14:49:59][DEBUG] : Search attribut for bc:33:ac:ff:fe:e9:4e:07 logicalId : 1::6::0 => Bool.true
Troisieme bouton: augmenter intensite en cinq appuis successifs
[2021-03-12 14:50:02][DEBUG] : {"devices":{"bc:33:ac:ff:fe:e9:4e:07":{"1":{"8":[{"value":"54","cluster_name":"Level control"}]}}}}
[2021-03-12 14:50:02][DEBUG] : Search attribut for bc:33:ac:ff:fe:e9:4e:07 logicalId : 1::8::0 => 54
[2021-03-12 14:50:04][DEBUG] : {"devices":{"bc:33:ac:ff:fe:e9:4e:07":{"1":{"8":[{"value":"105","cluster_name":"Level control"}]}}}}
[2021-03-12 14:50:04][DEBUG] : Search attribut for bc:33:ac:ff:fe:e9:4e:07 logicalId : 1::8::0 => 105
[2021-03-12 14:50:06][DEBUG] : {"devices":{"bc:33:ac:ff:fe:e9:4e:07":{"1":{"8":[{"value":"156","cluster_name":"Level control"}]}}}}
[2021-03-12 14:50:06][DEBUG] : Search attribut for bc:33:ac:ff:fe:e9:4e:07 logicalId : 1::8::0 => 156
[2021-03-12 14:50:08][DEBUG] : {"devices":{"bc:33:ac:ff:fe:e9:4e:07":{"1":{"8":[{"value":"207","cluster_name":"Level control"}]}}}}
[2021-03-12 14:50:08][DEBUG] : Search attribut for bc:33:ac:ff:fe:e9:4e:07 logicalId : 1::8::0 => 207
[2021-03-12 14:50:10][DEBUG] : {"devices":{"bc:33:ac:ff:fe:e9:4e:07":{"1":{"8":[{"value":"255","cluster_name":"Level control"}]}}}}
[2021-03-12 14:50:10][DEBUG] : Search attribut for bc:33:ac:ff:fe:e9:4e:07 logicalId : 1::8::0 => 255
Quatrieme bouton: baisse intensite en quatre appuis successifs
[2021-03-12 14:50:16][DEBUG] : {"devices":{"bc:33:ac:ff:fe:e9:4e:07":{"1":{"8":[{"value":"204","cluster_name":"Level control"}]}}}}
[2021-03-12 14:50:16][DEBUG] : Search attribut for bc:33:ac:ff:fe:e9:4e:07 logicalId : 1::8::0 => 204
[2021-03-12 14:50:18][DEBUG] : {"devices":{"bc:33:ac:ff:fe:e9:4e:07":{"1":{"8":[{"value":"153","cluster_name":"Level control"}]}}}}
[2021-03-12 14:50:18][DEBUG] : Search attribut for bc:33:ac:ff:fe:e9:4e:07 logicalId : 1::8::0 => 153
[2021-03-12 14:50:19][DEBUG] : {"devices":{"bc:33:ac:ff:fe:e9:4e:07":{"1":{"8":[{"value":"102","cluster_name":"Level control"}]}}}}
[2021-03-12 14:50:19][DEBUG] : Search attribut for bc:33:ac:ff:fe:e9:4e:07 logicalId : 1::8::0 => 102
[2021-03-12 14:50:21][DEBUG] : {"devices":{"bc:33:ac:ff:fe:e9:4e:07":{"1":{"8":[{"value":"51","cluster_name":"Level control"}]}}}}
[2021-03-12 14:50:21][DEBUG] : Search attribut for bc:33:ac:ff:fe:e9:4e:07 logicalId : 1::8::0 => 51
Ces deux actions enregistrees sans toucher a la telecommande
[2021-03-12 14:50:22][DEBUG] : {"devices":{"bc:33:ac:ff:fe:e9:4e:07":{"1":[{"1":{"value":"80","cluster_name":"Basic"}}]}}}
[2021-03-12 14:50:22][DEBUG] : Search attribut for bc:33:ac:ff:fe:e9:4e:07 logicalId : 1::0::1 => 80
[2021-03-12 14:50:25][DEBUG] : {"devices":{"bc:33:ac:ff:fe:e9:4e:07":{"1":{"8":[{"value":"3","cluster_name":"Level control"}]}}}}
[2021-03-12 14:50:25][DEBUG] : Search attribut for bc:33:ac:ff:fe:e9:4e:07 logicalId : 1::8::0 => 3
Premier bouton: eteindre l'ampoule
[2021-03-12 14:50:40][DEBUG] : {"devices":{"bc:33:ac:ff:fe:e9:4e:07":{"1":{"6":[{"value":"Bool.false","cluster_name":"On\/Off"}]}}}}
[2021-03-12 14:50:40][DEBUG] : Search attribut for bc:33:ac:ff:fe:e9:4e:07 logicalId : 1::6::0 => Bool.false
Hello
Pas sûr de comprendre, chez moi les 3 prises sont bien fonctionnelles.
Par contre ce matin curieusement j ai eu ce message sur les 3 prises et il se trouve que la multi prise était desassociée de la gateway lidl (hackee). J’ai reinclu et les 3 prises sont à nouveau fonctionnelles.
Je pense le soucis vient du min/max essaye de le changer a mon avis ca doit aller de 153 à 254
Merci, ça fonctionne nickel !
Hello, mon zigbee ne fonctionne pas depuis la dernière mise à jour, j’ai la clé elelabs. Que faire ?
Pour information il y a un bug dans le plugin zigbee actuel au niveau de tous ce qui est scene ca sera corrigé dans la beta de demain (il faudra bien relancer le démon).
Ok donc c’est pour cela que mon zigbee ne répond plus, j’ai qu’un seul capteur aqara reconnu sur mes 15
Mon information est général (pas forcement une réponse à ton message) et ne concerne que la partie cluster scene.
Ok donc je comprend pas mon problème depuis la dernière mise à jour.
