plugin-ZIGBEE Beta
Ne serait il pas possible de créer un tag plugin-zigbee, bien qu’il soit en Beta ?
Cela aurait le mérite de simplifier la multiplication des réponses sur le même post
Ne serait-il pas préférable de créer un post par demande d’intégration ?
Et ne pas mélanger les conversations portant sur différents équipements.
La création d’un tag spécifique pour le plugin-zigbee (beta) faciliterait cette règle d’or, non ?
Bonne journée à tous
@Loic
J’aimerais faire ajouter un détecteur d’ouverture Tuya :
    "ieee": "cc:cc:cc:ff:fe:d8:31:77",
    "nwk": 305,
    "status": 2,
    "lqi": "255",
    "rssi": "-44",
    "last_seen": "1612961878.932954",
    "node_descriptor": "02:40:80:00:00:52:52:00:00:2c:52:00:00",
    "endpoints": [
            "id": 1,
            "status": 1,
            "device_type": 1026,
            "profile_id": 260,
            "manufacturer": "TUYATEC-ydcwf5m2",
            "model": "RH3001",
            "output_clusters": [
                    "id": 3,
                    "name": "Identify",
                    "attributes": []
            "input_clusters": [
                    "id": 0,
                    "name": "Basic",
                    "attributes": [
                            "id": 0,
                            "name": "zcl_version",
                            "value": 2
                            "id": 1,
                            "name": "app_version",
                            "value": 77
                            "id": 2,
                            "name": "stack_version",
                            "value": 0
                            "id": 3,
                            "name": "hw_version",
                            "value": 1
                            "id": 4,
                            "name": "manufacturer",
                            "value": "TUYATEC-ydcwf5m2"
                            "id": 5,
                            "name": "model",
                            "value": "RH3001"
                            "id": 6,
                            "name": "date_code",
                            "value": "20180608"
                            "id": 7,
                            "name": "power_source",
                            "value": 3
                    "id": 1,
                    "name": "Power Configuration",
                    "attributes": [
                            "id": 32,
                            "name": "battery_voltage",
                            "value": 28
                            "id": 33,
                            "name": "battery_percentage_remaining",
                            "value": 136
                    "id": 3,
                    "name": "Identify",
                    "attributes": []
                    "id": 1280,
                    "name": "IAS Zone",
                    "attributes": [
                            "id": 16,
                            "name": "cie_addr",
                            "value": [
                                232,
                                175,
                                6,
                                255,
                                255,
                                46,
                                33,
                                0
    "signature": {
        "model": "RH3001",
        "node_desc": {
            "byte1": 2,
            "byte2": 64,
            "mac_capability_flags": 128,
            "manufacturer_code": 0,
            "maximum_buffer_size": 82,
            "maximum_incoming_transfer_size": 82,
            "server_mask": 11264,
            "maximum_outgoing_transfer_size": 82,
        "endpoints": {
            "1": {
                "profile_id": 260,
                "input_clusters": [
                    0,
                    1,
                    3,
                    1280
                    3
    "class": "zigpy.device"
Il s’agit de ce détecteur d’ouverture de porte ci : https://fr.aliexpress.com/item/1005001845632165.html?spm=a2g0s.9042311.0.0.27426c37U95eNv
Ne pas hésiter si des infos supplémentaires sont nécessaires.
Merci d’avance, bonne journée à tous
Moins de 10 secondes avec l’outil indiqué à la fin du post ici : [Présentation] akenad - #44 par akenad
akenad :slight_smile:
Ca sera disponible demain
Désolé, j’ai essayé de faire ça rapidement sous GIMP et j’arrivais pas à ce que je voulais. C’est vrai que cet outil est super pratique ! je ne l’avais pas vu.
Voici l’image @Loic
Merci :slight_smile:
Merci beaucoup ! Bonne journée
C’est changé merci
@Loic
Suite aux différentes remarques (justifiées :slight_smile: ) concernant le détourage des images des modules,
Voici les images détourées pour les ampoules (non RGB) E27, E14 et la prise connectée de Lidl
E27 :
_TZ3000_49qchf10.TS0502A
E14 :
_TZ3000_oborybow.TS0502A
Prise :
beam
Si tu peux les modifier dans le plugin :slight_smile:
d’abord merci pour le plugin, a priori bien plus simple que Deconz :slight_smile:
Je suis utilisateur des stores Ikea Frytur, qui sont reconnu parfaitement, avec un retour d’état fonctionnel directement, mais inversé :slight_smile:
Alors j’ai bien cherché à cliquer sur le bouton inverser de la commande, mais ca ne change rien.
Une idée?
J’ai un détecteur de fumée « Frient » modèle « SMSZB-120 » qui ne semble pas voir s’afficher toutes ses infos sur ce plugin beta, mais c’est peut-être normal ?
Par défaut je n’ai que l’info de l’état du détecteur (35::15::85). Donc je pense qu’il manque au moins ces quelques infos utiles :
  • température (38::1026::0)
  • niveau de batterie (35::1::32)
  • alarme batterie (35::1::62)
  • intervalle de check (35::32::0) (utile ou pas ? à voir !)
  • statut (35::15::111)
Peut-être aussi des commandes pour déclencher et couper la sirène ?
Il semble également y avoir une histoire de « scene », mais je n’ai pas idée de ce que c’est. Des déclenchements de scénarios peut-être ?
Voici le json qui est retourné dans le plugin par ce module :
    "ieee": "00:15:bc:00:31:00:97:28",
    "nwk": 3775,
    "status": 2,
    "lqi": "255",
    "rssi": "-57",
    "last_seen": "1612973932.000559",
    "node_descriptor": "02:40:00:15:10:50:50:00:00:00:50:00:00",
    "endpoints": [
            "id": 1,
            "status": 1,
            "device_type": 1,
            "profile_id": 49353,
            "manufacturer": null,
            "model": null,
            "output_clusters": [],
            "input_clusters": [
                    "id": 3,
                    "name": "Identify",
                    "attributes": []
                    "id": 5,
                    "name": "Scenes",
                    "attributes": []
                    "id": 6,
                    "name": "On\/Off",
                    "attributes": []
            "id": 35,
            "status": 1,
            "profile_id": 260,
            "manufacturer": "frient A\/S",
            "model": "SMSZB-120",
                    "id": 10,
                    "name": "Time",
                    "attributes": []
                    "id": 25,
                    "name": "Ota",
                    "attributes": []
            "input_clusters": [
                    "id": 0,
                    "name": "Basic",
                    "attributes": [
                            "id": 0,
                            "value": 1
                            "id": 4,
                            "value": "frient A\/S"
                            "id": 5,
                            "name": "model",
                            "value": "SMSZB-120"
                            "id": 6,
                            "value": "2020-08-27 01:10"
                            "id": 7,
                            "value": 3
                    "id": 1,
                    "attributes": [
                            "id": 32,
                            "value": 31
                            "id": 62,
                            "name": "battery_alarm_state",
                            "value": 0
                    "id": 3,
                    "name": "Identify",
                    "attributes": []
                    "id": 15,
                    "name": "Binary Input (Basic)",
                    "attributes": [
                            "id": 85,
                            "name": "present_value",
                            "value": 0
                            "id": 111,
                            "name": "status_flags",
                            "value": 0
                    "id": 32,
                    "name": "Poll Control",
                    "attributes": [
                            "id": 0,
                            "name": "checkin_interval",
                            "value": 13200
                    "id": 1280,
                    "name": "IAS Zone",
                    "attributes": [
                            "id": 16,
                            "name": "cie_addr",
                            "value": [
                                163,
                                153,
                                6,
                                255,
                                255,
                                46,
                                33,
                                0
                    "id": 1282,
                    "name": "IAS Warning Device",
                    "attributes": []
            "id": 38,
            "status": 1,
            "device_type": 770,
            "profile_id": 260,
                    "id": 3,
                    "name": "Identify",
                    "attributes": []
            "input_clusters": [
                    "id": 0,
                    "name": "Basic",
                    "attributes": [
                            "id": 0,
                            "value": 1
                            "id": 4,
                            "id": 5,
                            "name": "model",
                            "id": 6,
                            "id": 7,
                            "value": 3
                    "id": 3,
                    "name": "Identify",
                    "attributes": []
                    "id": 1026,
                    "name": "Temperature Measurement",
                    "attributes": [
                            "id": 0,
                            "name": "measured_value",
                            "value": 2212
    "signature": {
        "node_desc": {
            "byte1": 2,
            "byte2": 64,
            "mac_capability_flags": 0,
            "manufacturer_code": 4117,
            "maximum_buffer_size": 80,
            "maximum_incoming_transfer_size": 80,
            "server_mask": 0,
            "maximum_outgoing_transfer_size": 80,
        "endpoints": {
            "1": {
                "device_type": 1,
                "input_clusters": [
                    3,
                    5,
                    6
            "35": {
                "profile_id": 260,
                "input_clusters": [
                    0,
                    1,
                    3,
                    15,
                    32,
                    1280,
                    1282
                    10,
                    25
            "38": {
                "profile_id": 260,
                "device_type": 770,
                "input_clusters": [
                    0,
                    3,
                    1026
                    3
PS : la photo est la bonne dans le plugin, donc je n’en reposte pas.
@Loic
En complément voici les modèles détourés pour les ampoules RGB Lidl.
La E14
E14-RGB__2_-removebg-preview
La E27
E27-RGB__3_-removebg-preview
Bonjour @Loic ,
Je viens d’essayer l’ajout d’une sonde de température / humidité Tuya qui ne semble pas dans la base de donnée:
Marque: Tuya
Modèle: ST-TH01
HTB13VbdcgaH3KVjSZFjq6AFWpXaw-removebg-preview
    "ieee": "60:a4:23:ff:fe:2d:a8:71",
    "nwk": 45112,
    "status": 2,
    "lqi": "255",
    "rssi": "-62",
    "last_seen": "1612982016.8343213",
    "endpoints": [
            "id": 1,
            "status": 1,
            "device_type": 770,
            "profile_id": 260,
            "manufacturer": "TUYATEC-gqhxixyk",
            "model": "RH3052",
                    "id": 3,
                    "name": "Identify",
                    "attributes": []
                    "id": 1026,
                    "attributes": []
                    "id": 1029,
                    "name": "Relative Humidity Measurement",
                    "attributes": []
            "input_clusters": [
                    "id": 0,
                    "name": "Basic",
                    "attributes": [
                            "id": 0,
                            "value": 3
                            "id": 1,
                            "value": 74
                            "id": 2,
                            "value": 0
                            "id": 3,
                            "value": 1
                            "id": 4,
                            "value": "TUYATEC-gqhxixyk"
                            "id": 5,
                            "name": "model",
                            "value": "RH3052"
                            "id": 6,
                            "value": "20180608"
                            "id": 7,
                            "value": 3
                    "id": 1,
                    "attributes": [
                            "id": 32,
                            "value": 30
                            "id": 33,
                            "value": 200
                    "id": 3,
                    "name": "Identify",
                    "attributes": []
                    "id": 1026,
                    "attributes": [
                            "id": 0,
                            "value": 2101
                    "id": 1029,
                    "attributes": [
                            "id": 0,
                            "value": 4375
    "signature": {
        "model": "RH3052",
        "node_desc": {
            "byte1": 2,
            "byte2": 64,
        "endpoints": {
            "1": {
                "profile_id": 260,
                "device_type": 770,
                "input_clusters": [
                    0,
                    1,
                    3,
                    1026,
                    1029
                    3,
                    1026,
                    1029
Merci d’avance.
En fait je crois que ce n’est pas que l’état mais aussi la commande. Le tout est inversé et d’ailleurs il n’y pas de possibilité d’inverser la commande.
C’était déjà le cas fut un temps sur le plugin Deconz, mais cela avait été corrigé.
Bonjour @Loic,
Un petit nouveau à ajouter :grinning:
CC2530+CC2591 Zigbee Module
Model Z-002 manufactured by WeBee
Source
C’est un router Zigbee avec ampli, exclusivement dédié à améliorer son maillage.
Si cela intéresse certains : Créer son routeur CC2530
    "ieee": "00:12:4b:00:1c:42:fc:fe",
    "nwk": 39399,
    "status": 2,
    "lqi": "131",
    "rssi": "None",
    "last_seen": "1613003162.789952",
    "node_descriptor": "01:40:8e:5f:11:50:a0:00:00:00:a0:00:00",
    "endpoints": [
            "id": 8,
            "status": 1,
            "device_type": 256,
            "profile_id": 260,
            "manufacturer": "LUMI",
            "model": "lumi.router",
                    "id": 0,
                    "name": "Basic",
                    "attributes": []
                    "id": 6,
                    "name": "On\/Off",
                    "attributes": []
            "input_clusters": [
                    "id": 0,
                    "name": "Basic",
                    "attributes": [
                            "id": 0,
                            "value": 1
                            "id": 3,
                            "value": 1
                            "id": 4,
                            "value": "LUMI"
                            "id": 5,
                            "name": "model",
                            "value": "lumi.router"
                            "id": 6,
                            "value": "2018-09-26"
                            "id": 7,
                            "value": 1
                    "id": 6,
                    "name": "On\/Off",
                    "attributes": []
    "signature": {
        "node_desc": {
            "byte1": 1,
            "byte2": 64,
            "mac_capability_flags": 142,
            "manufacturer_code": 4447,
            "maximum_incoming_transfer_size": 160,
            "server_mask": 0,
            "maximum_outgoing_transfer_size": 160,
        "endpoints": {
            "8": {
                "profile_id": 260,
                "device_type": 256,
                "input_clusters": [
                    0,
                    6
                    0,
                    6
WeBee_Z-002_1_-removebg-preview
Je sélectionne une image détourée en png mais l’éditeur me la met en jpeg …
Merci pour les images ca sera dans la beta de demain
Merci pour le retour il manquait effectivement la batterie ca sera corrigé demain. Pour les autres information c’est soit la mais d’une autre maniere soit pas utile
C’est normal que ca soit un truc de marque xiaomi d’après la conf ?
Bah écoutes je pense que c’est Zigpy qui l’a répertorié ainsi …
Je ne pense pas c’est vraiment ce que le module envoi. Ca me gene un peu ce genre de module que je vais classer dans xiaomi alors que ca n’en ai pas… Et surtout ca va pas apparaitre sur le site de compatibilité et donc induire les gens en erreur.
@Loic > en passant du plugin zigate au zigbee, on perd des commandes… Notament celle de la batterie qui est pratique pour historiser et voir la courbe de décharge… Quelque chose est prévu pour ça ?
