Hello @Loic sur le module TZ3000_wamqdr3f.TS011F (prise Lidl) le endpoint est mal fixé, il faut remplacer 1:: par 11::
{‹ 11 ›: {‹ 6 ›: {‹ 0 ›: {‹ value ›: ‹ Bool.false ›, ‹ cluster_name ›: ‹ On/Off ›}
+1 car c’est une fonction super pratique que j’utilisais avec mes ampoules wifi Meross (remplacées par les zigbee Lidl)
Blanc chaud pour la lecture
Blanc froid pour la TV
peut-on inclure
Prise Lidl SilverCrest modèle HG06337-fr
Matériellement c’est un tuya tz3000 ts011F
Manufacturer: _TZ3000_wamqdr3f
Model: TS011F
[2021-02-02 10:47:49][DEBUG] : {"devices":{"bc:33:ac:ff:fe:59:19:e0":{"11":{"6":[{"value":"Bool.false","cluster_name":"On\/Off"}]}}}}
[2021-02-02 10:47:49][DEBUG] : Search attribut for bc:33:ac:ff:fe:59:19:e0 logicalId : 11::6::0 => Bool.false
[2021-02-02 10:47:54][DEBUG] : {"devices":{"bc:33:ac:ff:fe:59:19:e0":{"11":{"6":[{"value":"Bool.true","cluster_name":"On\/Off"}]}}}}
[2021-02-02 10:47:54][DEBUG] : Search attribut for bc:33:ac:ff:fe:59:19:e0 logicalId : 11::6::0 => Bool.true
https://www.lidl.fr/fr/p/lidl-smart-home/prise-connectee/p56729
"ieee": "bc:33:ac:ff:fe:59:19:e0",
"nwk": 38489,
"status": 2,
"lqi": "255",
"rssi": "-43",
"last_seen": "1612259690.0230744",
"node_descriptor": "01:40:8e:02:10:52:52:00:00:2c:52:00:00",
"endpoints": [
"id": 11,
"status": 1,
"device_type": 266,
"profile_id": 260,
"manufacturer": "_TZ3000_wamqdr3f",
"model": "TS011F",
"output_clusters": [
"id": 25,
"name": "Ota",
"attributes": []
"id": 10,
"name": "Time",
"attributes": []
"input_clusters": [
"id": 0,
"name": "Basic",
"attributes": [
"id": 0,
"name": "zcl_version",
"value": 3
"id": 1,
"name": "app_version",
"value": 66
"id": 2,
"name": "stack_version",
"value": 0
"id": 3,
"name": "hw_version",
"value": 1
"id": 4,
"name": "manufacturer",
"value": "_TZ3000_wamqdr3f"
"id": 5,
"name": "model",
"value": "TS011F"
"id": 6,
"name": "date_code",
"value": ""
"id": 7,
"name": "power_source",
"value": 1
"id": 3,
"name": "Identify",
"attributes": []
"id": 4,
"name": "Groups",
"attributes": []
"id": 5,
"name": "Scenes",
"attributes": []
"id": 6,
"name": "On\/Off",
"attributes": []
"id": 242,
"status": 1,
"device_type": 97,
"profile_id": 41440,
"manufacturer": null,
"model": null,
"id": 33,
"name": "GreenPowerProxy",
"attributes": []
"input_clusters": []
"signature": {
"manufacturer_name": "_TZ3000_wamqdr3f",
"model": "TS011F",
"node_descriptor": {
"byte1": 1,
"byte2": 64,
"mac_capability_flags": 142,
"manufacturer_code": 4098,
"maximum_buffer_size": 82,
"maximum_incoming_transfer_size": 82,
"server_mask": 11264,
"maximum_outgoing_transfer_size": 82,
"11": {
"profileid": 260,
"deviceid": 266,
"in_clusters": [
0,
3,
4,
5,
6
"out_clusters": [
25,
10
"242": {
"profileid": 41440,
"deviceid": 97,
"in_clusters": [],
"out_clusters": [
33
"class": "zigpy.device"
j’avoue que pour 10€ ça ne vaut pas plus
je l’ai ouvert part curiosité
la partie de conversion pour l’alimentation on trouve un KP3211
et pour le tranceiver Zigbee le TYZS6
qui est un EFR32
C’est donc bien un produit tuya
par contre niveau finition du circuit on a un produit soudé à la « j’en ai marre de vivre » avec des boules de soudure et laitier partout sur le circuit ils n’ont pas peur de dysfonctionnement ou départ de feu à cause de ça, mais bon il y a un fusible
La qualité du relais présente un énorme effet rebond, donc de mauvaise qualité
Conclusion finale en plus d’être une fabrication chinoise mal monté avec des bavures d’étain de partout, on a là un produit qui consomme autant qu’une ampoule LED branché en permanence, on est vraiment pas dans l’économie d’énergie mais plutôt dans l’économie de composants on a même le droit à un fusible à souder sur la platine au lieu d’un polyswitch reamorsable
En gros pour 10€ ça vaut pas plus.
mdr
oui on ne peut pas parler de pub mensongère
La langue française est formidable : distinguer le « Vrai » du « Faux » est très subjectif alors je ne parle pas de ce qui est bon ou mauvais.
Si en plus on applique cela à une chose indéterminée alors là niveau engagement on est proche du zéro absolu ou du vide intersidéral (et encore il y a cette fameuse « matière noire »).
Donc on peut interpréter : un prix faible pour un vrai produit de m...e.
Pensez vous que ça vaut le coup de remplacer ses 2/3 Yeelight (légèrement capricieuse avec le wifi 2.4) par les Zigbee de chez Lidl ?
Moi aussi j’ai pris l’initiative de virer mes yeelight car j’en ai une vingtaine et le wifi est capricieux aussi parfois y’a des loupés.
L’idée etait de basculer sur des lampes zigbee pour booster en même temps mon maillage.
Après test de la lampe lidl laisse tomber, tu n’es pas du tout sur le meme niveau d’eclairage (oublies les couleurs c’est une daube), juste blanc OK.
Je me suis dirigé vers les lexman de chez Leroy Merlin (3€ de + que Lidl), après un 1er test ca me semble déjà bien plus proche de mes ex Yeelight.
Ok merci pour ton retour !
Après je ne veux pas influencer, mais je donne un avis personnel,
Le produit de chez Lidl est un « très bon rapport Q…/Prix »
mais je préfère cent fois un produit de chez NODON bien moins gourmand en énergie
ou une prise Philips HUE.
Je vous parle en tant qu’électronicien.
Mais électriquement parlant je ne suis pas rassuré sur le fait de brancher cette prise 24/24 chez moi, la partie transformation 220v vers 3.3v pour alimenter le microcontrolleur Zigbee est vraiment « light »,
Je ne sais pas comment ils ont eu la norme CE
Ah si suis-je bête il y a un fusible soudé
Oui c’est ce que je me suis dit en voyant ta conf. Les chinois ont déjà fait des clones pour leur propre compte
100% d’accord avec l’analyse…
@Loic ,
Concernant le pb des boutton aquara switch rond,
L’appui long ne fonctionne pas, si cela peut aider,voici des logs :
Appui simple :
[2021-02-02 11:45:32][DEBUG] : {"devices":{"00:15:8d:00:01:b1:27:9a":{"1":{"6":{"event":{"click":{"value":{"click_type":"single"},"cluster_name":"On\/Off"}},"0":{"value":"False","cluster_name":"On\/Off"}}}}}}
[2021-02-02 11:45:32][DEBUG] : Search event command for 00:15:8d:00:01:b1:27:9a logicalId : 1::6::event::click::click_type => single
[2021-02-02 11:45:32][DEBUG] : Search attribut for 00:15:8d:00:01:b1:27:9a logicalId : 1::6::0 => False
Appui double :
[2021-02-02 11:46:49][DEBUG] : {"devices":{"00:15:8d:00:01:b1:27:9a":{"1":{"6":{"event":{"click":{"value":{"click_type":"double"},"cluster_name":"On\/Off"}},"32768":{"value":"2","cluster_name":"On\/Off"}}}}}}
[2021-02-02 11:46:49][DEBUG] : Search event command for 00:15:8d:00:01:b1:27:9a logicalId : 1::6::event::click::click_type => double
[2021-02-02 11:46:49][DEBUG] : Search attribut for 00:15:8d:00:01:b1:27:9a logicalId : 1::6::32768 => 2
Appui long:
[2021-02-02 11:47:47][DEBUG] : {"devices":{"00:15:8d:00:01:b1:27:9a":{"1":{"6":{"event":{"click":{"value":{"click_type":"single"},"cluster_name":"On\/Off"}},"0":{"value":"True","cluster_name":"On\/Off"}}}}}}
[2021-02-02 11:47:47][DEBUG] : Search event command for 00:15:8d:00:01:b1:27:9a logicalId : 1::6::event::click::click_type => single
[2021-02-02 11:47:47][DEBUG] : Search attribut for 00:15:8d:00:01:b1:27:9a logicalId : 1::6::0 => True
[2021-02-02 11:47:49][DEBUG] : {"devices":{"00:15:8d:00:01:b1:27:9a":{"1":{"6":[{"value":"False","cluster_name":"On\/Off"}]}}}}
[2021-02-02 11:47:49][DEBUG] : Search attribut for 00:15:8d:00:01:b1:27:9a logicalId : 1::6::0 => False
Mr LIDL n’a pas fait attention? C E => China Export!!
C’est sur le cahier des charges ne doit pas être même, après bon tout vien du même pays lol.
Les HUE ce bien sur la royce et ca se paye très cher…
Parfait, merci Loïc.
en fait je vient de comprendre
le appui loong ne fonctionne pas mais l’applui triple, meme quadruple fonctionne
si on fait 5 c’est « furious » !
[2021-02-02 11:55:04][DEBUG] : {"devices":{"00:15:8d:00:01:b1:27:9a":{"1":{"6":{"event":{"click":{"value":{"click_type":"triple"},"cluster_name":"On\/Off"}},"32768":{"value":"3","cluster_name":"On\/Off"}}}}}}
[2021-02-02 11:55:04][DEBUG] : Search event command for 00:15:8d:00:01:b1:27:9a logicalId : 1::6::event::click::click_type => triple
[2021-02-02 11:55:04][DEBUG] : Search attribut for 00:15:8d:00:01:b1:27:9a logicalId : 1::6::32768 => 3
[2021-02-02 11:55:12][DEBUG] : {"devices":{"00:15:8d:00:01:b1:27:9a":{"1":{"6":{"event":{"click":{"value":{"click_type":"single"},"cluster_name":"On\/Off"}},"0":{"value":"False","cluster_name":"On\/Off"}}}}}}
[2021-02-02 11:55:12][DEBUG] : Search event command for 00:15:8d:00:01:b1:27:9a logicalId : 1::6::event::click::click_type => single
[2021-02-02 11:55:12][DEBUG] : Search attribut for 00:15:8d:00:01:b1:27:9a logicalId : 1::6::0 => False
[2021-02-02 11:55:19][DEBUG] : {"devices":{"00:15:8d:00:01:b1:27:9a":{"1":{"6":{"event":{"click":{"value":{"click_type":"double"},"cluster_name":"On\/Off"}},"32768":{"value":"2","cluster_name":"On\/Off"}}}}}}
[2021-02-02 11:55:19][DEBUG] : Search event command for 00:15:8d:00:01:b1:27:9a logicalId : 1::6::event::click::click_type => double
[2021-02-02 11:55:19][DEBUG] : Search attribut for 00:15:8d:00:01:b1:27:9a logicalId : 1::6::32768 => 2
[2021-02-02 11:55:24][DEBUG] : {"devices":{"00:15:8d:00:01:b1:27:9a":{"1":{"6":{"event":{"click":{"value":{"click_type":"triple"},"cluster_name":"On\/Off"}},"32768":{"value":"3","cluster_name":"On\/Off"}}}}}}
[2021-02-02 11:55:24][DEBUG] : Search event command for 00:15:8d:00:01:b1:27:9a logicalId : 1::6::event::click::click_type => triple
[2021-02-02 11:55:24][DEBUG] : Search attribut for 00:15:8d:00:01:b1:27:9a logicalId : 1::6::32768 => 3
[2021-02-02 11:55:28][DEBUG] : {"devices":{"00:15:8d:00:01:b1:27:9a":{"1":{"6":{"event":{"click":{"value":{"click_type":"quadruple"},"cluster_name":"On\/Off"}},"32768":{"value":"4","cluster_name":"On\/Off"}}}}}}
[2021-02-02 11:55:28][DEBUG] : Search event command for 00:15:8d:00:01:b1:27:9a logicalId : 1::6::event::click::click_type => quadruple
[2021-02-02 11:55:28][DEBUG] : Search attribut for 00:15:8d:00:01:b1:27:9a logicalId : 1::6::32768 => 4
[2021-02-02 11:55:35][DEBUG] : {"devices":{"00:15:8d:00:01:b1:27:9a":{"1":{"6":{"event":{"click":{"value":{"click_type":"furious"},"cluster_name":"On\/Off"}},"32768":{"value":"128","cluster_name":"On\/Off"}}}}}}
[2021-02-02 11:55:35][DEBUG] : Search event command for 00:15:8d:00:01:b1:27:9a logicalId : 1::6::event::click::click_type => furious
[2021-02-02 11:55:35][DEBUG] : Search attribut for 00:15:8d:00:01:b1:27:9a logicalId : 1::6::32768 => 128
Et quand on voit les condos chimiques utilisés… on peut jouer à faire le 14 juillet. Même plus besoin de feux d’artifice.
Vous êtes flippant les gars, moi qui ai acheté 2 prises connectées Lidl (surtout pour accroître mon maillage Zigbee).
