Merci pour ton aide
Depuis que j’ai installé le plugin je trouve que tout jeedom tourne au ralenti également !
Je pense que tu cherche ça :
Launch install of zigbee dependancy
Get:1 http://archive.raspberrypi.org/debian stretch InRelease [25.4 kB]
Hit:2 http://raspbian.raspberrypi.org/raspbian stretch InRelease
Hit:3 https://deb.nodesource.com/node_10.x stretch InRelease
Fetched 25.4 kB in 2s (11.1 kB/s)
Reading package lists...
Cannot uninstall requirement serial, not installed
Building dependency tree...
Reading state information...
Package 'python3-serial' is not installed, so not removed
0 upgraded, 0 newly installed, 0 to remove and 161 not upgraded.
python3 is already the newest version (3.5.3-1).
python3-dev is already the newest version (3.5.3-1).
python3-pyudev is already the newest version (0.21.0-1).
python3-requests is already the newest version (2.12.4-1).
python3-setuptools is already the newest version (33.1.1-1).
python3-pip is already the newest version (9.0.1-2+rpt2).
Requirement already up-to-date: wheel in /usr/local/lib/python3.5/dist-packages
Requirement already up-to-date: pyserial in /usr/local/lib/python3.5/dist-packages
Collecting zigpy
Using cached https://files.pythonhosted.org/packages/d8/09/16db142d487ebab76fc3ee571557f8e24241824094ef73f6ad686d0e36bb/zigpy-0.28.2-py3-none-any.whl
Collecting aiohttp (from zigpy)
Using cached https://www.piwheels.org/simple/aiohttp/aiohttp-3.6.3-cp35-cp35m-linux_armv7l.whl
Collecting crccheck (from zigpy)
Using cached https://files.pythonhosted.org/packages/df/4c/6937c142a315edc436e223aa936a57dd846751b3be37f43da0d9037f630b/crccheck-1.0-py3-none-any.whl
Collecting pycryptodome (from zigpy)
Using cached https://www.piwheels.org/simple/pycryptodome/pycryptodome-3.9.9-cp35-cp35m-linux_armv7l.whl
Collecting aiosqlite>=0.16.0 (from zigpy)
Could not find a version that satisfies the requirement aiosqlite>=0.16.0 (from zigpy) (from versions: 0.1.0, 0.2.0, 0.2.1, 0.2.2, 0.3.0, 0.4.0, 0.5.0, 0.6.0, 0.7.0, 0.8.0, 0.8.1, 0.9.0, 0.10.0, 0.11.0, 0.12.0)
No matching distribution found for aiosqlite>=0.16.0 (from zigpy)
Collecting bellows
Using cached https://files.pythonhosted.org/packages/c3/78/afe23dc270b241eb08ac931af921c27b97bdc5e305bf278f08bda46094bc/bellows-0.21.0-py3-none-any.whl
Collecting voluptuous (from bellows)
Using cached https://files.pythonhosted.org/packages/9c/b9/84f5bd190a7dc234cea2ca1da02c8900ace982e0ad4ae494660585844f04/voluptuous-0.12.1-py3-none-any.whl
Collecting click-log==0.2.0 (from bellows)
Using cached https://files.pythonhosted.org/packages/ed/91/0cdb5d9590e503e97b7a2eaa939f7b4aaaa67b93c859011ea2d7aa63bb87/click_log-0.2.0-py2.py3-none-any.whl
Collecting zigpy>=0.21.0 (from bellows)
Collecting pyserial-asyncio (from bellows)
Using cached https://files.pythonhosted.org/packages/2c/57/4bcdb5937bc57a916d53532d1de1180254b68a7c5559c0984332347ae805/pyserial_asyncio-0.5-py3-none-any.whl
Collecting Click (from bellows)
Using cached https://files.pythonhosted.org/packages/d2/3d/fa76db83bf75c4f8d338c2fd15c8d33fdd7ad23a9b5e57eb6c5de26b430e/click-7.1.2-py2.py3-none-any.whl
Collecting dataclasses; python_version < "3.7" (from bellows)
Using cached https://files.pythonhosted.org/packages/26/2f/1095cdc2868052dd1e64520f7c0d5c8c550ad297e944e641dbf1ffbb9a5d/dataclasses-0.6-py3-none-any.whl
Collecting pure-pcapy3==1.0.1 (from bellows)
Using cached https://www.piwheels.org/simple/pure-pcapy3/pure_pcapy3-1.0.1-py3-none-any.whl
Collecting aiohttp (from zigpy>=0.21.0->bellows)
Collecting pycryptodome (from zigpy>=0.21.0->bellows)
Collecting aiosqlite>=0.16.0 (from zigpy>=0.21.0->bellows)
Could not find a version that satisfies the requirement aiosqlite>=0.16.0 (from zigpy>=0.21.0->bellows) (from versions: 0.1.0, 0.2.0, 0.2.1, 0.2.2, 0.3.0, 0.4.0, 0.5.0, 0.6.0, 0.7.0, 0.8.0, 0.8.1, 0.9.0, 0.10.0, 0.11.0, 0.12.0)
No matching distribution found for aiosqlite>=0.16.0 (from zigpy>=0.21.0->bellows)
Collecting git+https://github.com/jeedom/zha-device-handlers
Cloning https://github.com/jeedom/zha-device-handlers to /tmp/pip-luzqg7s9-build
Collecting zigpy>=0.28.2 (from zha-quirks==0.0.48)
Collecting crccheck (from zigpy>=0.28.2->zha-quirks==0.0.48)
Collecting voluptuous (from zigpy>=0.28.2->zha-quirks==0.0.48)
Collecting aiosqlite>=0.16.0 (from zigpy>=0.28.2->zha-quirks==0.0.48)
Could not find a version that satisfies the requirement aiosqlite>=0.16.0 (from zigpy>=0.28.2->zha-quirks==0.0.48) (from versions: 0.1.0, 0.2.0, 0.2.1, 0.2.2, 0.3.0, 0.4.0, 0.5.0, 0.6.0, 0.7.0, 0.8.0, 0.8.1, 0.9.0, 0.10.0, 0.11.0, 0.12.0)
No matching distribution found for aiosqlite>=0.16.0 (from zigpy>=0.28.2->zha-quirks==0.0.48)
Collecting zigpy_znp
Using cached https://files.pythonhosted.org/packages/34/02/3f51c5071ed3c926a051d2dac0c44525ce7bc0846b2dc40d3f02616485b9/zigpy_znp-0.3.0-py3-none-any.whl
Collecting pyserial-asyncio (from zigpy_znp)
Collecting voluptuous (from zigpy_znp)
Collecting async-timeout (from zigpy_znp)
Using cached https://files.pythonhosted.org/packages/e1/1e/5a4441be21b0726c4464f3f23c8b19628372f606755a9d2e46c187e65ec4/async_timeout-3.0.1-py3-none-any.whl
Collecting zigpy>=0.25.0 (from zigpy_znp)
Collecting coloredlogs (from zigpy_znp)
Using cached https://files.pythonhosted.org/packages/84/a6/837dbf6eac344cb74f0ba86b79e8180855570af3e26bcb1ea5f650cf944c/coloredlogs-15.0-py2.py3-none-any.whl
Requirement already up-to-date: pyserial in /usr/local/lib/python3.5/dist-packages (from pyserial-asyncio->zigpy_znp)
Collecting aiosqlite>=0.16.0 (from zigpy>=0.25.0->zigpy_znp)
Could not find a version that satisfies the requirement aiosqlite>=0.16.0 (from zigpy>=0.25.0->zigpy_znp) (from versions: 0.1.0, 0.2.0, 0.2.1, 0.2.2, 0.3.0, 0.4.0, 0.5.0, 0.6.0, 0.7.0, 0.8.0, 0.8.1, 0.9.0, 0.10.0, 0.11.0, 0.12.0)
No matching distribution found for aiosqlite>=0.16.0 (from zigpy>=0.25.0->zigpy_znp)
Collecting zigpy-xbee
Using cached https://files.pythonhosted.org/packages/e2/11/cfd0d700f21bd0cd0d49bb45e6797712afb45d03365b7d40eab6b226b64e/zigpy_xbee-0.13.0-py3-none-any.whl
Collecting pyserial-asyncio (from zigpy-xbee)
Collecting zigpy>=0.23.0 (from zigpy-xbee)
Requirement already up-to-date: pyserial in /usr/local/lib/python3.5/dist-packages (from pyserial-asyncio->zigpy-xbee)
Collecting aiosqlite>=0.16.0 (from zigpy>=0.23.0->zigpy-xbee)
Could not find a version that satisfies the requirement aiosqlite>=0.16.0 (from zigpy>=0.23.0->zigpy-xbee) (from versions: 0.1.0, 0.2.0, 0.2.1, 0.2.2, 0.3.0, 0.4.0, 0.5.0, 0.6.0, 0.7.0, 0.8.0, 0.8.1, 0.9.0, 0.10.0, 0.11.0, 0.12.0)
No matching distribution found for aiosqlite>=0.16.0 (from zigpy>=0.23.0->zigpy-xbee)
Collecting zigpy-deconz
Using cached https://files.pythonhosted.org/packages/38/8a/991d2c3e41e209fad9debc5d3d8cbb20ab7d70b1d277fdf9269023050703/zigpy_deconz-0.11.0-py3-none-any.whl
Collecting zigpy>=0.24.0 (from zigpy-deconz)
Collecting pyserial-asyncio (from zigpy-deconz)
Collecting voluptuous (from zigpy>=0.24.0->zigpy-deconz)
Collecting aiosqlite>=0.16.0 (from zigpy>=0.24.0->zigpy-deconz)
Could not find a version that satisfies the requirement aiosqlite>=0.16.0 (from zigpy>=0.24.0->zigpy-deconz) (from versions: 0.1.0, 0.2.0, 0.2.1, 0.2.2, 0.3.0, 0.4.0, 0.5.0, 0.6.0, 0.7.0, 0.8.0, 0.8.1, 0.9.0, 0.10.0, 0.11.0, 0.12.0)
No matching distribution found for aiosqlite>=0.16.0 (from zigpy>=0.24.0->zigpy-deconz)
Collecting zigpy-zigate
Using cached https://www.piwheels.org/simple/zigpy-zigate/zigpy_zigate-0.7.4-py3-none-any.whl
Collecting pyusb (from zigpy-zigate)
Using cached https://www.piwheels.org/simple/pyusb/pyusb-1.1.0-py3-none-any.whl
Collecting RPi.GPIO (from zigpy-zigate)
Using cached https://www.piwheels.org/simple/rpi-gpio/RPi.GPIO-0.7.0-cp35-cp35m-linux_armv7l.whl
Collecting pyserial-asyncio (from zigpy-zigate)
Collecting zigpy>=0.22.2 (from zigpy-zigate)
Requirement already up-to-date: pyserial in /usr/local/lib/python3.5/dist-packages (from pyserial-asyncio->zigpy-zigate)
Collecting crccheck (from zigpy>=0.22.2->zigpy-zigate)
Collecting voluptuous (from zigpy>=0.22.2->zigpy-zigate)
Collecting aiohttp (from zigpy>=0.22.2->zigpy-zigate)
Collecting pycryptodome (from zigpy>=0.22.2->zigpy-zigate)
Collecting aiosqlite>=0.16.0 (from zigpy>=0.22.2->zigpy-zigate)
Could not find a version that satisfies the requirement aiosqlite>=0.16.0 (from zigpy>=0.22.2->zigpy-zigate) (from versions: 0.1.0, 0.2.0, 0.2.1, 0.2.2, 0.3.0, 0.4.0, 0.5.0, 0.6.0, 0.7.0, 0.8.0, 0.8.1, 0.9.0, 0.10.0, 0.11.0, 0.12.0)
No matching distribution found for aiosqlite>=0.16.0 (from zigpy>=0.22.2->zigpy-zigate)
Collecting zigpy-cc
Using cached https://files.pythonhosted.org/packages/5e/5a/acd7aa9617e02af8178d54151e384b5f75dd2c56c8ba4c139f1d65d3b033/zigpy_cc-0.5.2-py3-none-any.whl
Collecting zigpy>=0.23.1 (from zigpy-cc)
Collecting pyserial-asyncio (from zigpy-cc)
Collecting aiohttp (from zigpy>=0.23.1->zigpy-cc)
Collecting aiosqlite>=0.16.0 (from zigpy>=0.23.1->zigpy-cc)
Could not find a version that satisfies the requirement aiosqlite>=0.16.0 (from zigpy>=0.23.1->zigpy-cc) (from versions: 0.1.0, 0.2.0, 0.2.1, 0.2.2, 0.3.0, 0.4.0, 0.5.0, 0.6.0, 0.7.0, 0.8.0, 0.8.1, 0.9.0, 0.10.0, 0.11.0, 0.12.0)
No matching distribution found for aiosqlite>=0.16.0 (from zigpy>=0.23.1->zigpy-cc)
Requirement already up-to-date: tornado in /usr/local/lib/python3.5/dist-packages
Everything is successfully installed!
