J’ai depuis quelques jours des pb d’intégration de mes appareils. le pb sur les inclusions est-il toujours d’actualité.
Les pbs que je detecte concernent :
- des prises OSRAM Smart + plug
- Un cube Xiaomi
- Un relais contact sec (x3 Orbivo)
un exemple de log d’inclusion
020-12-09 13:39:05][DEBUG] : Frame received: 0x0e1a000700aa00
[2020-12-09 13:39:05][DEBUG] : Device state changed response: [<DeviceState.128|APSDE_DATA_REQUEST_SLOTS_AVAILABLE|APSDE_DATA_INDICATION|2: 170>, 0]
[2020-12-09 13:39:05][DEBUG] : Command Command.aps_data_indication (1, 1)
[2020-12-09 13:39:05][DEBUG] : Send: 0x171a000800010001
[2020-12-09 13:39:05][DEBUG] : Frame received: 0x171a002a0023002202fdff0002dccd00000013000c0000dccde311090aaa3eb07c8e00aff73f2f0020c1
[2020-12-09 13:39:05][DEBUG] : APS data indication response: [35, <DeviceState.APSDE_DATA_REQUEST_SLOTS_AVAILABLE|2: 34>, <DeconzAddress address_mode=ADDRESS_MODE.NWK address=0xfffd>, 0, <DeconzAddress address_mode=ADDRESS_MODE.NWK address=0xcddc>, 0, 0, 19, b'\x00\xdc\xcd\xe3\x11
\xaa>\xb0|\x8e', 0, 175, 247, 63, 47, 0, 32, -63]
[2020-12-09 13:39:05][INFO] : New device joined: 0xcddc, 7c:b0:3e:aa:0a:09:11:e3
[2020-12-09 13:39:05][INFO] : Device 0xcddc (7c:b0:3e:aa:0a:09:11:e3) joined the network
[2020-12-09 13:39:05][INFO] : [7c:b0:3e:aa:0a:09:11:e3][listener.device_joined]
[2020-12-09 13:39:05][DEBUG] : Send to jeedom : {'device_joined': '7c:b0:3e:aa:0a:09:11:e3'}
[2020-12-09 13:39:05][DEBUG] : [0xcddc:zdo] ZDO request ZDOCmd.Device_annce: [0xCDDC, 7c:b0:3e:aa:0a:09:11:e3, 142]
[2020-12-09 13:39:05][DEBUG] : Starting new HTTP connection (1): 127.0.0.1:80
[2020-12-09 13:39:05][INFO] : [0xcddc] Requesting 'Node Descriptor'
[2020-12-09 13:39:05][DEBUG] : Tries remaining: 2
[2020-12-09 13:39:05][DEBUG] : [0xcddc] Extending timeout for 0x03 request
[2020-12-09 13:39:05][DEBUG] : Sending Zigbee request with tsn 3 under 4 request id, data: b'03dccd'
[2020-12-09 13:39:05][DEBUG] : 'aps_data_indication' response from <DeconzAddress address_mode=ADDRESS_MODE.NWK address=0xcddc>, ep: 0, profile: 0x0000, cluster_id: 0x0013, data: b'00dccde311090aaa3eb07c8e'
[2020-12-09 13:39:05][DEBUG] : Command Command.aps_data_request (18, 4, 0, <DeconzAddressEndpoint address_mode=2 address=0xCDDC endpoint=0>, 0, <ZDOCmd.Node_Desc_req: 0x0002>, 0, b'\x03\xdc\xcd', 2, 0)
[2020-12-09 13:39:05][DEBUG] : Send: 0x121b0019001200040002dccd000000020000030003dccd0200
[2020-12-09 13:39:05][DEBUG] : Frame received: 0x121b00090002002204
[2020-12-09 13:39:05][DEBUG] : APS data request response: [2, <DeviceState.APSDE_DATA_REQUEST_SLOTS_AVAILABLE|2: 34>, 4]
[2020-12-09 13:39:05][DEBUG] : http://127.0.0.1:80 "POST /plugins/zigbee/core/php/jeeZigbee.php?apikey=qYPfmQkumhNYZelgrvyhJ2YSSNjPU4CC HTTP/1.1" 200 0
[2020-12-09 13:39:06][DEBUG] : Frame received: 0x0e1c000700a600
[2020-12-09 13:39:06][DEBUG] : Device state changed response: [<DeviceState.128|APSDE_DATA_REQUEST_SLOTS_AVAILABLE|APSDE_DATA_CONFIRM|2: 166>, 0]
[2020-12-09 13:39:06][DEBUG] : Command Command.aps_data_confirm (0,)
[2020-12-09 13:39:06][DEBUG] : Send: 0x041c0007000000
[2020-12-09 13:39:06][DEBUG] : Frame received: 0x041c0013000c00220402dccd0000e100000000
[2020-12-09 13:39:06][DEBUG] : APS data confirm response for request with id 4: e1
[2020-12-09 13:39:06][DEBUG] : Request id: 0x04 'aps_data_confirm' for <DeconzAddressEndpoint address_mode=ADDRESS_MODE.NWK address=0xcddc endpoint=0>, status: 0xe1
[2020-12-09 13:39:06][DEBUG] : Error while sending 4 req id frame: TXStatus.MAC_CHANNEL_ACCESS_FAILURE
[2020-12-09 13:39:06][DEBUG] : [0xcddc] Delivery error for seq # 0x03, on endpoint id 0 cluster 0x0002: message send failure
[2020-12-09 13:39:06][DEBUG] : Tries remaining: 1
[2020-12-09 13:39:06][DEBUG] : [0xcddc] Extending timeout for 0x05 request
[2020-12-09 13:39:06][DEBUG] : Sending Zigbee request with tsn 5 under 6 request id, data: b'05dccd'
[2020-12-09 13:39:06][DEBUG] : Command Command.aps_data_request (18, 6, 0, <DeconzAddressEndpoint address_mode=2 address=0xCDDC endpoint=0>, 0, <ZDOCmd.Node_Desc_req: 0x0002>, 0, b'\x05\xdc\xcd', 2, 0)
[2020-12-09 13:39:06][DEBUG] : Send: 0x121d0019001200060002dccd000000020000030005dccd0200
[2020-12-09 13:39:06][DEBUG] : Frame received: 0x121d00090002002206
[2020-12-09 13:39:06][DEBUG] : APS data request response: [2, <DeviceState.APSDE_DATA_REQUEST_SLOTS_AVAILABLE|2: 34>, 6]
[2020-12-09 13:39:07][DEBUG] : Frame received: 0x0e1e000700a600
[2020-12-09 13:39:07][DEBUG] : Device state changed response: [<DeviceState.128|APSDE_DATA_REQUEST_SLOTS_AVAILABLE|APSDE_DATA_CONFIRM|2: 166>, 0]
[2020-12-09 13:39:07][DEBUG] : Command Command.aps_data_confirm (0,)
[2020-12-09 13:39:07][DEBUG] : Send: 0x041e0007000000
[2020-12-09 13:39:07][DEBUG] : Frame received: 0x041e0013000c00220602dccd0000e100000000
[2020-12-09 13:39:07][DEBUG] : APS data confirm response for request with id 6: e1
[2020-12-09 13:39:07][DEBUG] : Request id: 0x06 'aps_data_confirm' for <DeconzAddressEndpoint address_mode=ADDRESS_MODE.NWK address=0xcddc endpoint=0>, status: 0xe1
[2020-12-09 13:39:07][DEBUG] : Error while sending 6 req id frame: TXStatus.MAC_CHANNEL_ACCESS_FAILURE
[2020-12-09 13:39:07][DEBUG] : [0xcddc] Delivery error for seq # 0x05, on endpoint id 0 cluster 0x0002: message send failure
[2020-12-09 13:39:07][WARNING] : [0xcddc] Requesting Node Descriptor failed
File "/usr/local/lib/python3.7/dist-packages/zigpy/device.py", line 93, in get_node_descriptor
self.nwk, tries=2, delay=0.1
File "/usr/local/lib/python3.7/dist-packages/zigpy/util.py", line 110, in retry
r = await func()
File "/usr/local/lib/python3.7/dist-packages/zigpy/device.py", line 206, in request
self.nwk, dst_ep, cluster
zigpy.exceptions.DeliveryError: [0xcddc:0:0x0002]: Message send failure
[2020-12-09 13:39:07][INFO] : [0xcddc] Discovering endpoints
[2020-12-09 13:39:07][DEBUG] : Tries remaining: 3
[2020-12-09 13:39:07][DEBUG] : [0xcddc] Extending timeout for 0x07 request
[2020-12-09 13:39:07][DEBUG] : Sending Zigbee request with tsn 7 under 8 request id, data: b'07dccd'
[2020-12-09 13:39:07][DEBUG] : Command Command.aps_data_request (18, 8, 0, <DeconzAddressEndpoint address_mode=2 address=0xCDDC endpoint=0>, 0, <ZDOCmd.Active_EP_req: 0x0005>, 0, b'\x07\xdc\xcd', 2, 0)
[2020-12-09 13:39:07][DEBUG] : Send: 0x121f0019001200080002dccd000000050000030007dccd0200
[2020-12-09 13:39:07][DEBUG] : Frame received: 0x121f00090002002208
[2020-12-09 13:39:07][DEBUG] : APS data request response: [2, <DeviceState.APSDE_DATA_REQUEST_SLOTS_AVAILABLE|2: 34>, 8]
[2020-12-09 13:39:07][DEBUG] : Frame received: 0x0e20000700a600
[2020-12-09 13:39:07][DEBUG] : Send: 0x04200007000000
[2020-12-09 13:39:07][DEBUG] : Frame received: 0x04200013000c00220802dccd00000000000000
[2020-12-09 13:39:07][DEBUG] : APS data confirm response for request with id 8: 00
[2020-12-09 13:39:07][DEBUG] : Request id: 0x08 'aps_data_confirm' for <DeconzAddressEndpoint address_mode=ADDRESS_MODE.NWK address=0xcddc endpoint=0>, status: 0x00
[2020-12-09 13:39:07][DEBUG] : Frame received: 0x0e21000700aa00
[2020-12-09 13:39:07][DEBUG] : Device state changed response: [<DeviceState.128|APSDE_DATA_REQUEST_SLOTS_AVAILABLE|APSDE_DATA_INDICATION|2: 170>, 0]
[2020-12-09 13:39:07][DEBUG] : Command Command.aps_data_indication (1, 1)
[2020-12-09 13:39:07][DEBUG] : Send: 0x1721000800010001
[2020-12-09 13:39:07][DEBUG] : Frame received: 0x17210024001d00220200000002dccd000000058006000700dccd010300afff53f50a00ce
[2020-12-09 13:39:07][DEBUG] : APS data indication response: [29, <DeviceState.APSDE_DATA_REQUEST_SLOTS_AVAILABLE|2: 34>, <DeconzAddress address_mode=ADDRESS_MODE.NWK address=0x0000>, 0, <DeconzAddress address_mode=ADDRESS_MODE.NWK address=0xcddc>, 0, 0, 32773, b'\x07\x00\xdc\xcd\x01\x03', 0, 175, 255, 83, 245, 10, 0, -50]
[2020-12-09 13:39:07][DEBUG] : 'aps_data_indication' response from <DeconzAddress address_mode=ADDRESS_MODE.NWK address=0xcddc>, ep: 0, profile: 0x0000, cluster_id: 0x8005, data: b'0700dccd0103'
[2020-12-09 13:39:07][INFO] : [0xcddc] Discovered endpoints: [3]
[2020-12-09 13:39:07][INFO] : [0xcddc:3] Discovering endpoint information
[2020-12-09 13:39:07][DEBUG] : [0xcddc] Extending timeout for 0x09 request
[2020-12-09 13:39:07][DEBUG] : Sending Zigbee request with tsn 9 under 10 request id, data: b'09dccd03'
[2020-12-09 13:39:07][DEBUG] : Command Command.aps_data_request (19, 10, 0, <DeconzAddressEndpoint address_mode=2 address=0xCDDC endpoint=0>, 0, <ZDOCmd.Simple_Desc_req: 0x0004>, 0, b' \xdc\xcd\x03', 2, 0)
[2020-12-09 13:39:07][DEBUG] : Send: 0x1222001a0013000a0002dccd000000040000040009dccd030200
[2020-12-09 13:39:07][DEBUG] : Frame received: 0x12220009000200220a
[2020-12-09 13:39:07][DEBUG] : APS data request response: [2, <DeviceState.APSDE_DATA_REQUEST_SLOTS_AVAILABLE|2: 34>, 10]
[2020-12-09 13:39:07][DEBUG] : Frame received: 0x0e23000700a600
[2020-12-09 13:39:07][DEBUG] : Send: 0x04230007000000
[2020-12-09 13:39:07][DEBUG] : Frame received: 0x04230013000c00220a02dccd0000e100000000
[2020-12-09 13:39:07][DEBUG] : APS data confirm response for request with id 10: e1
[2020-12-09 13:39:07][DEBUG] : Request id: 0x0a 'aps_data_confirm' for <DeconzAddressEndpoint address_mode=ADDRESS_MODE.NWK address=0xcddc endpoint=0>, status: 0xe1
[2020-12-09 13:39:07][DEBUG] : Error while sending 10 req id frame: TXStatus.MAC_CHANNEL_ACCESS_FAILURE
[2020-12-09 13:39:07][DEBUG] : [0xcddc] Delivery error for seq # 0x09, on endpoint id 0 cluster 0x0004: message send failure
[2020-12-09 13:39:09][DEBUG] : Tries remaining: 2
[2020-12-09 13:39:09][DEBUG] : [0xcddc] Extending timeout for 0x0b request
[2020-12-09 13:39:09][DEBUG] : Sending Zigbee request with tsn 11 under 12 request id, data: b'0bdccd03'
[2020-12-09 13:39:09][DEBUG] : Command Command.aps_data_request (19, 12, 0, <DeconzAddressEndpoint address_mode=2 address=0xCDDC endpoint=0>, 0, <ZDOCmd.Simple_Desc_req: 0x0004>, 0, b'\x0b\xdc\xcd\x03', 2, 0)
[2020-12-09 13:39:09][DEBUG] : Send: 0x1224001a0013000c0002dccd00000004000004000bdccd030200
[2020-12-09 13:39:09][DEBUG] : Frame received: 0x12240009000200220c
[2020-12-09 13:39:09][DEBUG] : APS data request response: [2, <DeviceState.APSDE_DATA_REQUEST_SLOTS_AVAILABLE|2: 34>, 12]
[2020-12-09 13:39:09][DEBUG] : Frame received: 0x0e25000700a600
[2020-12-09 13:39:09][DEBUG] : Device state changed response: [<DeviceState.128|APSDE_DATA_REQUEST_SLOTS_AVAILABLE|APSDE_DATA_CONFIRM|2: 166>, 0]
[2020-12-09 13:39:09][DEBUG] : Command Command.aps_data_confirm (0,)
[2020-12-09 13:39:09][DEBUG] : Send: 0x04250007000000
[2020-12-09 13:39:09][DEBUG] : Frame received: 0x04250013000c00220c02dccd0000e100000000
[2020-12-09 13:39:09][DEBUG] : APS data confirm response for request with id 12: e1
[2020-12-09 13:39:09][DEBUG] : Request id: 0x0c 'aps_data_confirm' for <DeconzAddressEndpoint address_mode=ADDRESS_MODE.NWK address=0xcddc endpoint=0>, status: 0xe1
[2020-12-09 13:39:09][DEBUG] : Error while sending 12 req id frame: TXStatus.MAC_CHANNEL_ACCESS_FAILURE
[2020-12-09 13:39:09][DEBUG] : [0xcddc] Delivery error for seq # 0x0b, on endpoint id 0 cluster 0x0004: message send failure
[2020-12-09 13:39:11][DEBUG] : Frame received: 0x0e26000700aa00
[2020-12-09 13:39:11][DEBUG] : Device state changed response: [<DeviceState.128|APSDE_DATA_REQUEST_SLOTS_AVAILABLE|APSDE_DATA_INDICATION|2: 170>, 0]
[2020-12-09 13:39:11][DEBUG] : Command Command.aps_data_indication (1, 1)
[2020-12-09 13:39:11][DEBUG] : Send: 0x1726000800010001
[2020-12-09 13:39:11][DEBUG] : Frame received: 0x1726002a002300220200000102dccd03040119000c00110001000c1127000905020100afff53f50a00ce
[2020-12-09 13:39:11][DEBUG] : APS data indication response: [35, <DeviceState.APSDE_DATA_REQUEST_SLOTS_AVAILABLE|2: 34>, <DeconzAddress address_mode=ADDRESS_MODE.NWK address=0x0000>, 1, <DeconzAddress address_mode=ADDRESS_MODE.NWK address=0xcddc>, 3, 260, 25, b"\x11\x00\x01\x00\x0c\x11'\x00 \x05\x02\x01", 0, 175, 255, 83, 245, 10, 0, -50]
[2020-12-09 13:39:11][DEBUG] : Received frame on uninitialized device 7c:b0:3e:aa:0a:09:11:e3 endpoint 1 for cluster: 25
[2020-12-09 13:39:11][DEBUG] : 'aps_data_indication' response from <DeconzAddress address_mode=ADDRESS_MODE.NWK address=0xcddc>, ep: 3, profile: 0x0104, cluster_id: 0x0019, data: b'110001000c11270009050201'
[2020-12-09 13:39:11][DEBUG] : Tries remaining: 1
[2020-12-09 13:39:11][DEBUG] : [0xcddc] Extending timeout for 0x0d request
[2020-12-09 13:39:11][DEBUG] : Sending Zigbee request with tsn 13 under 14 request id, data: b'0ddccd03'
[2020-12-09 13:39:11][DEBUG] : Command Command.aps_data_request (19, 14, 0, <DeconzAddressEndpoint address_mode=2 address=0xCDDC endpoint=0>, 0, <ZDOCmd.Simple_Desc_req: 0x0004>, 0, b'
[2020-12-09 13:39:11][DEBUG] : Send: 0x1227001a0013000e0002dccd00000004000004000ddccd030200
[2020-12-09 13:39:11][DEBUG] : Frame received: 0x12270009000200220e
[2020-12-09 13:39:11][DEBUG] : APS data request response: [2, <DeviceState.APSDE_DATA_REQUEST_SLOTS_AVAILABLE|2: 34>, 14]
[2020-12-09 13:39:11][DEBUG] : Frame received: 0x0e28000700a600
[2020-12-09 13:39:11][DEBUG] : Device state changed response: [<DeviceState.128|APSDE_DATA_REQUEST_SLOTS_AVAILABLE|APSDE_DATA_CONFIRM|2: 166>, 0]
[2020-12-09 13:39:11][DEBUG] : Command Command.aps_data_confirm (0,)
[2020-12-09 13:39:11][DEBUG] : Send: 0x04280007000000
[2020-12-09 13:39:11][DEBUG] : Frame received: 0x04280013000c00220e02dccd0000e100000000
[2020-12-09 13:39:11][DEBUG] : APS data confirm response for request with id 14: e1
[2020-12-09 13:39:11][DEBUG] : Request id: 0x0e 'aps_data_confirm' for <DeconzAddressEndpoint address_mode=ADDRESS_MODE.NWK address=0xcddc endpoint=0>, status: 0xe1
[2020-12-09 13:39:11][DEBUG] : Error while sending 14 req id frame: TXStatus.MAC_CHANNEL_ACCESS_FAILURE
[2020-12-09 13:39:11][DEBUG] : [0xcddc] Delivery error for seq # 0x0d, on endpoint id 0 cluster 0x0004: message send failure
[2020-12-09 13:39:11][WARNING] : [0xcddc:3] Failed to discover endpoint_id 3
File "/usr/local/lib/python3.7/dist-packages/zigpy/endpoint.py", line 53, in initialize
self._device.nwk, self._endpoint_id, tries=3, delay=2
r = await func()
zigpy.exceptions.DeliveryError: [0xcddc:0:0x0004]: Message send failure
[2020-12-09 13:39:11][INFO] : Removing device 0xcddc (7c:b0:3e:aa:0a:09:11:e3)
[2020-12-09 13:39:11][DEBUG] : [0xcddc] Extending timeout for 0x0f request
[2020-12-09 13:39:11][DEBUG] : Sending Zigbee request with tsn 15 under 16 request id, data: b'0fe311090aaa3eb07c02'
[2020-12-09 13:39:11][DEBUG] : Command Command.aps_data_request (25, 16, 0, <DeconzAddressEndpoint address_mode=2 address=0xCDDC endpoint=0>, 0, <ZDOCmd.Mgmt_Leave_req: 0x0034>, 0, b'\x0f\xe3\x11
\xaa>\xb0|\x02', 2, 0)
[2020-12-09 13:39:11][DEBUG] : Send: 0x12290020001900100002dccd0000003400000a000fe311090aaa3eb07c020200
[2020-12-09 13:39:11][DEBUG] : Frame received: 0x122900090002002210
[2020-12-09 13:39:11][DEBUG] : APS data request response: [2, <DeviceState.APSDE_DATA_REQUEST_SLOTS_AVAILABLE|2: 34>, 16]
[2020-12-09 13:39:11][DEBUG] : Frame received: 0x0e2a000700a600
[2020-12-09 13:39:11][DEBUG] : Send: 0x042a0007000000
[2020-12-09 13:39:11][DEBUG] : Frame received: 0x042a0013000c00221002dccd0000d000000000
[2020-12-09 13:39:11][DEBUG] : APS data confirm response for request with id 16: d0
[2020-12-09 13:39:11][DEBUG] : Request id: 0x10 'aps_data_confirm' for <DeconzAddressEndpoint address_mode=ADDRESS_MODE.NWK address=0xcddc endpoint=0>, status: 0xd0
[2020-12-09 13:39:11][DEBUG] : Error while sending 16 req id frame: TXStatus.NWK_ROUTE_DISCOVERY_FAILED
[2020-12-09 13:39:11][DEBUG] : [0xcddc] Delivery error for seq # 0x0f, on endpoint id 0 cluster 0x0034: message send failure
[2020-12-09 13:39:11][DEBUG] : Sending 'zdo_leave_req' failed: [0xcddc:0:0x0034]: Message send failure
[2020-12-09 13:39:11][INFO] : [7c:b0:3e:aa:0a:09:11:e3][listener.device_removed]
[2020-12-09 13:39:11][DEBUG] : Send to jeedom : {'device_removed': '7c:b0:3e:aa:0a:09:11:e3'}
[2020-12-09 13:39:11][DEBUG] : executing functools.partial(<built-in method execute of sqlite3.Connection object at 0x7fa4ac11f0>, 'DELETE FROM attributes WHERE ieee = ?', (7c:b0:3e:aa:0a:09:11:e3,))
[2020-12-09 13:39:11][DEBUG] : returning <sqlite3.Cursor object at 0x7fa41a4880>
[2020-12-09 13:39:11][DEBUG] : Starting new HTTP connection (1): 127.0.0.1:80
[2020-12-09 13:39:11][DEBUG] : executing functools.partial(<built-in method execute of sqlite3.Connection object at 0x7fa4ac11f0>, 'DELETE FROM neighbors WHERE ieee = ?', (7c:b0:3e:aa:0a:09:11:e3,))
[2020-12-09 13:39:11][DEBUG] : returning <sqlite3.Cursor object at 0x7fa41a4960>
[2020-12-09 13:39:11][DEBUG] : executing functools.partial(<built-in method execute of sqlite3.Connection object at 0x7fa4ac11f0>, 'DELETE FROM node_descriptors WHERE ieee = ?', (7c:b0:3e:aa:0a:09:11:e3,))
[2020-12-09 13:39:11][DEBUG] : executing functools.partial(<built-in method execute of sqlite3.Connection object at 0x7fa4ac11f0>, 'DELETE FROM clusters WHERE ieee = ?', (7c:b0:3e:aa:0a:09:11:e3,))
[2020-12-09 13:39:11][DEBUG] : executing functools.partial(<built-in method execute of sqlite3.Connection object at 0x7fa4ac11f0>, 'DELETE FROM output_clusters WHERE ieee = ?', (7c:b0:3e:aa:0a:09:11:e3,))
[2020-12-09 13:39:11][DEBUG] : executing functools.partial(<built-in method execute of sqlite3.Connection object at 0x7fa4ac11f0>, 'DELETE FROM group_members WHERE ieee = ?', (7c:b0:3e:aa:0a:09:11:e3,))
[2020-12-09 13:39:11][DEBUG] : executing functools.partial(<built-in method execute of sqlite3.Connection object at 0x7fa4ac11f0>, 'DELETE FROM endpoints WHERE ieee = ?', (7c:b0:3e:aa:0a:09:11:e3,))
[2020-12-09 13:39:11][DEBUG] : executing functools.partial(<built-in method execute of sqlite3.Connection object at 0x7fa4ac11f0>, 'DELETE FROM devices WHERE ieee = ?', (7c:b0:3e:aa:0a:09:11:e3,))
[2020-12-09 13:39:11][DEBUG] : executing functools.partial(<built-in method commit of sqlite3.Connection object at 0x7fa4ac11f0>)
[2020-12-09 13:39:11][DEBUG] : returning None
[2020-12-09 13:39:11][DEBUG] : http://127.0.0.1:80 "POST /plugins/zigbee/core/php/jeeZigbee.php?apikey=qYPfmQkumhNYZelgrvyhJ2YSSNjPU4CC HTTP/1.1" 200 0
La plupart du temps , si je clique sur « autoriser join », rien ne se passe
de temps en temps, je vois apparaître appareil blblebala en cours d’inclusion, puis un message dans la foulée appareil blablabla supprimé
de temps en temps, l’appareil est créé mais non fonctionnel avec des données brute très incomplètes (sans endpoints)
clé CONBEE avec la dernière version (mise à jour après l’apparition des pbs)
plugin ZIGBEE Beta en derniere version
test des différents appareils OK sur deconz sous windows, les appareils fonctionnent, maillage réseau OK
Merci du retour
Norbert
