je te conseille plutôt un truc du genre :
Merci pour la suggestion, mais je veux avoir ça que pendant la période hivernale en été je laisse mes fenêtres ouvertes + de 5 mins
Je vais plutot essayer avec la commande lastChangeStateDuration dans le scenaio
Bref c’est pas le sujet du topic
la flèche sur Vcc
Configuration :
- Jeedom sur VirtualBox - Debian 10.7 uptodate
- Clef CC2531 (CC2531ZNP-Prod.hex 20190608)
- Jeedom version V4.1.19
- Plugin Beta ZIGBEE version du 21.01.30 01:06:35
Acquis chez AliExpress : https://www.aliexpress.com/item/1005001687942333.html?spm=a2g0s.9042311.0.0.def94c4dv0BSIK
[TS0043] Interrupteur de scène 3 boutons
de chez Lonsoho.
"ieee": "bc:33:ac:ff:fe:57:0e:cb",
"nwk": 41393,
"status": 2,
"lqi": "47",
"rssi": "0",
"last_seen": "1612188403.8437054",
"node_descriptor": "02:40:80:02:10:52:52:00:00:2c:52:00:00",
"endpoints": [
"id": 1,
"status": 1,
"device_type": 6,
"profile_id": 260,
"manufacturer": "_TZ3400_key8kk7r",
"model": "TS0043",
"output_clusters": [
"id": 10,
"name": "Time",
"attributes": []
"id": 25,
"name": "Ota",
"attributes": []
"input_clusters": [
"id": 0,
"name": "Basic",
"attributes": [
"id": 1,
"name": "app_version",
"value": 72
"id": 4,
"name": "manufacturer",
"value": "_TZ3400_key8kk7r"
"id": 5,
"name": "model",
"value": "TS0043"
"id": 1,
"name": "Power Configuration",
"attributes": [
"id": 32,
"name": "battery_voltage",
"value": 30
"id": 33,
"name": "battery_percentage_remaining",
"value": 200
"id": 6,
"name": "TS004X_cluster",
"attributes": []
"id": 2,
"status": 1,
"device_type": 6,
"profile_id": 260,
"manufacturer": null,
"model": null,
"output_clusters": [],
"input_clusters": [
"id": 1,
"attributes": []
"id": 6,
"attributes": []
"id": 3,
"status": 1,
"device_type": 6,
"profile_id": 260,
"model": null,
"input_clusters": [
"id": 1,
"attributes": []
"id": 6,
"attributes": []
"signature": {
"model": "TS0043",
"node_desc": {
"byte1": 2,
"byte2": 64,
"mac_capability_flags": 128,
"manufacturer_code": 4098,
"maximum_buffer_size": 82,
"maximum_incoming_transfer_size": 82,
"server_mask": 11264,
"maximum_outgoing_transfer_size": 82,
"endpoints": {
"1": {
"profile_id": 260,
"device_type": 6,
"input_clusters": [
0,
1,
6
10,
25
"2": {
"profile_id": 260,
"device_type": 6,
"input_clusters": [
1,
6
"3": {
"profile_id": 260,
"device_type": 6,
"input_clusters": [
1,
6
"class": "zhaquirks.tuya.ts0043"
Avec mes remerciements, en espérant que cela correspond à ce qui doit être fait.
Cordialement.
Re,
Tiens j’ai remarqué que mes volets Profalux ne sont pas reconnus automatiquement ?
Quand je les « force » en volet Profalux, ils fonctionnent néanmoins très bien.
Voici « mon » JSON :
"ieee": "20:91:8a:00:00:06:b4:b2",
"nwk": 4055,
"status": 2,
"lqi": "255",
"rssi": "-55",
"last_seen": "1612189401.6834018",
"node_descriptor": "01:40:8e:10:11:52:52:00:00:00:52:00:00",
"endpoints": [
"id": 1,
"status": 1,
"device_type": 512,
"profile_id": 260,
"model": null,
"id": 3,
"name": "Identify",
"attributes": []
"id": 64544,
"name": "Manufacturer Specific",
"attributes": []
"input_clusters": [
"id": 0,
"name": "Basic",
"attributes": [
"id": 0,
"name": "zcl_version",
"value": 1
"id": 6,
"name": "date_code",
"value": "20170602102b100"
"id": 7,
"name": "power_source",
"value": 1
"id": 3,
"name": "Identify",
"attributes": []
"id": 4,
"name": "Groups",
"attributes": []
"id": 5,
"name": "Scenes",
"attributes": []
"id": 6,
"name": "On\/Off",
"attributes": [
"id": 0,
"name": "on_off",
"value": 1
"id": 8,
"name": "Level control",
"attributes": [
"id": 0,
"name": "current_level",
"value": 254
"id": 10,
"name": "Time",
"attributes": []
"id": 21,
"name": "Commissioning",
"attributes": []
"id": 256,
"name": "Shade Configuration",
"attributes": []
"id": 64544,
"attributes": []
"id": 64545,
"attributes": []
"signature": {
"node_desc": {
"byte1": 1,
"byte2": 64,
"mac_capability_flags": 142,
"manufacturer_code": 4368,
"server_mask": 0,
"endpoints": {
"1": {
"profile_id": 260,
"device_type": 512,
"input_clusters": [
0,
3,
4,
5,
6,
8,
10,
21,
256,
64544,
64545
3,
64544
"class": "zigpy.device"
@Loic
En migrant mes modules xiaomi vers le plugin Zigbee, Je viens de voir que les « switch » ronds ne semblent pas êtres reconnus automatiquement, bien que je les retrouve dans la liste des devices possible sur le plugin : « Xiaomi Aquara Switch »
Données Brutes :
"ieee": "00:15:8d:00:01:b1:27:9a",
"nwk": 61230,
"status": 2,
"lqi": "255",
"rssi": "-49",
"last_seen": "1612191925.4366858",
"node_descriptor": "02:40:80:37:10:7f:64:00:00:00:64:00:00",
"endpoints": [
"id": 1,
"status": 1,
"device_type": 6,
"profile_id": 260,
"model": null,
"id": 0,
"name": "BasicCluster",
"attributes": []
"id": 5,
"name": "Scenes",
"attributes": []
"id": 4,
"name": "Groups",
"attributes": []
"id": 6,
"name": "On\/Off",
"attributes": [
"id": 0,
"name": "on_off",
"value": false
"id": 8,
"attributes": []
"id": 25,
"name": "Ota",
"attributes": []
"input_clusters": [
"id": 3,
"name": "Identify",
"attributes": []
"id": 0,
"attributes": [
"id": 1,
"value": 10
"id": 1,
"attributes": []
"signature": {
"manufacturer": "LUMI",
"model": "lumi.sensor_switch",
"node_desc": {
"byte1": 2,
"byte2": 64,
"manufacturer_code": 4151,
"maximum_buffer_size": 127,
"maximum_incoming_transfer_size": 100,
"server_mask": 0,
"maximum_outgoing_transfer_size": 100,
"endpoints": {
"1": {
"profile_id": 260,
"device_type": 6,
"input_clusters": [
3,
0,
1
0,
5,
4,
6,
8,
25
"class": "zhaquirks.xiaomi.mija.sensor_switch"
C’est normal il n’envoi pas d’info sur qui ils sont donc pas de reconnaissance auto possible
Effectivement il y avait un soucis dans la conf ca sera corrigé demain
Alors pour lui va falloir appuyer sur les boutons et m’envoyer la log zigbee
Premièrement, je tenais à vous remercier pour ce plugin qui fonctionne parfaitement chez moi depuis plus de 2 mois.
Seul problème, c’est la commande Etat(1::6::0) de la prise Ikea qui ne fonctionne pas. Elle renvoie toujours 1.Et ne remonte rien dans les logs.
"ieee": "00:0d:6f:ff:fe:ba:97:f6",
"nwk": 55383,
"status": 2,
"lqi": "255",
"rssi": "-53",
"last_seen": "1612192998.1005409",
"node_descriptor": "01:40:8e:7c:11:52:52:00:00:2c:52:00:00",
"endpoints": [
"id": 1,
"status": 1,
"device_type": 266,
"profile_id": 260,
"manufacturer": "IKEA of Sweden",
"model": "TRADFRI control outlet",
"id": 5,
"name": "Scenes",
"attributes": []
"id": 25,
"name": "Ota",
"attributes": []
"id": 32,
"name": "Poll Control",
"attributes": []
"id": 4096,
"name": "LightLink",
"attributes": []
"input_clusters": [
"id": 0,
"name": "Basic",
"attributes": [
"id": 0,
"value": 3
"id": 1,
"value": 32
"id": 2,
"name": "stack_version",
"value": 98
"id": 3,
"name": "hw_version",
"value": 1
"id": 4,
"value": "IKEA of Sweden"
"id": 5,
"name": "model",
"value": "TRADFRI control outlet"
"id": 6,
"value": "20180828"
"id": 7,
"value": 1
"id": 16384,
"name": "sw_build_id",
"value": "2.0.019"
"id": 3,
"name": "Identify",
"attributes": []
"id": 4,
"name": "Groups",
"attributes": []
"id": 5,
"name": "Scenes",
"attributes": []
"id": 6,
"name": "On\/Off",
"attributes": [
"id": 0,
"name": "on_off",
"value": 1
"id": 8,
"attributes": []
"id": 4096,
"attributes": []
"id": 64636,
"attributes": []
"id": 242,
"status": 1,
"device_type": 97,
"profile_id": 41440,
"model": null,
"id": 33,
"name": "GreenPowerProxy",
"attributes": []
"input_clusters": [
"id": 33,
"attributes": []
"signature": {
"node_desc": {
"byte1": 1,
"byte2": 64,
"manufacturer_code": 4476,
"endpoints": {
"1": {
"profile_id": 260,
"device_type": 266,
"input_clusters": [
0,
3,
4,
5,
6,
8,
4096,
64636
5,
25,
32,
4096
"242": {
"device_type": 97,
"input_clusters": [
33
33
Je suis sur la dernière version de Jeedom et la dernière version du plugin.
@Loic une idée ?
Merci @Loic
Peux tu me dire ce qu’on est censé avoir comme valeur pour les commandes « Etat », « Type » et « Event » ?
dans mon cas « Etat » reste toujours à 0
« Type » reste toujours vide
« Event » = « Single » quand simple clic
= « double » quand double clic
= « single » quand appui long ?
Salut Loïc,
Voilà les log ZigBee que j’ai obtenues :
Bouton1- 1 appui
[2021-02-01 16:26:13][INFO] : handle_message incomingMsg
[2021-02-01 16:26:13][INFO] : [bc:33:ac:ff:fe:57:0e:cb][listener.zha_send_event] Received an event update remote_button_short_press=[] on cluster 6
[2021-02-01 16:26:13][INFO] : [bc:33:ac:ff:fe:57:0e:cb][listener.cluster_command] Cluster: <zhaquirks.tuya.TuyaSmartRemoteOnOffCluster object at 0x7f69182c0080> ClusterId: 0x0006 tsn: 18 args: (253, [0])
Bouton2- 1 appui
Bouton3- 1 appui
[2021-02-01 16:28:44][INFO] : handle_message incomingMsg
[2021-02-01 16:28:44][INFO] : [bc:33:ac:ff:fe:57:0e:cb][listener.zha_send_event] Received an event update remote_button_short_press=[] on cluster 6
[2021-02-01 16:28:44][INFO] : [bc:33:ac:ff:fe:57:0e:cb][listener.cluster_command] Cluster: <zhaquirks.tuya.TuyaSmartRemoteOnOffCluster object at 0x7f6918aff6d8> ClusterId: 0x0006 tsn: 24 args: (253, [0])
[2021-02-01 16:28:45][INFO] : handle_message incomingMsg
[2021-02-01 16:28:45][INFO] : [bc:33:ac:ff:fe:57:0e:cb][listener.cluster_command] Cluster: <zhaquirks.tuya.TuyaSmartRemoteOnOffCluster object at 0x7f6918aff6d8> ClusterId: 0x0006 tsn: 24 args: (253, [0])
Bouton1- 2 appuis
[2021-02-01 16:27:25][INFO] : handle_message incomingMsg
[2021-02-01 16:27:25][INFO] : [bc:33:ac:ff:fe:57:0e:cb][listener.zha_send_event] Received an event update remote_button_short_press=[] on cluster 6
[2021-02-01 16:27:25][INFO] : [bc:33:ac:ff:fe:57:0e:cb][listener.cluster_command] Cluster: <zhaquirks.tuya.TuyaSmartRemoteOnOffCluster object at 0x7f69182c0080> ClusterId: 0x0006 tsn: 19 args: (253, [0])
[2021-02-01 16:27:26][INFO] : handle_message incomingMsg
[2021-02-01 16:27:26][INFO] : [bc:33:ac:ff:fe:57:0e:cb][listener.zha_send_event] Received an event update remote_button_short_press=[] on cluster 6
[2021-02-01 16:27:26][INFO] : [bc:33:ac:ff:fe:57:0e:cb][listener.cluster_command] Cluster: <zhaquirks.tuya.TuyaSmartRemoteOnOffCluster object at 0x7f69182c0080> ClusterId: 0x0006 tsn: 20 args: (253, [0])
Bouton2- 2 appuis
[2021-02-01 16:28:13][INFO] : handle_message incomingMsg
[2021-02-01 16:28:13][INFO] : [bc:33:ac:ff:fe:57:0e:cb][listener.zha_send_event] Received an event update remote_button_short_press=[] on cluster 6
[2021-02-01 16:28:13][INFO] : [bc:33:ac:ff:fe:57:0e:cb][listener.cluster_command] Cluster: <zhaquirks.tuya.TuyaSmartRemoteOnOffCluster object at 0x7f6918aff7b8> ClusterId: 0x0006 tsn: 22 args: (253, [0])
[2021-02-01 16:28:14][INFO] : handle_message incomingMsg
[2021-02-01 16:28:14][INFO] : [bc:33:ac:ff:fe:57:0e:cb][listener.cluster_command] Cluster: <zhaquirks.tuya.TuyaSmartRemoteOnOffCluster object at 0x7f6918aff7b8> ClusterId: 0x0006 tsn: 22 args: (253, [0])
[2021-02-01 16:28:16][INFO] : handle_message incomingMsg
[2021-02-01 16:28:16][INFO] : [bc:33:ac:ff:fe:57:0e:cb][listener.zha_send_event] Received an event update remote_button_short_press=[] on cluster 6
[2021-02-01 16:28:16][INFO] : [bc:33:ac:ff:fe:57:0e:cb][listener.cluster_command] Cluster: <zhaquirks.tuya.TuyaSmartRemoteOnOffCluster object at 0x7f6918aff7b8> ClusterId: 0x0006 tsn: 23 args: (253, [0])
Bouton3- 2 appuis
[2021-02-01 16:29:08][INFO] : handle_message incomingMsg
[2021-02-01 16:29:08][INFO] : [bc:33:ac:ff:fe:57:0e:cb][listener.zha_send_event] Received an event update remote_button_short_press=[] on cluster 6
[2021-02-01 16:29:08][INFO] : [bc:33:ac:ff:fe:57:0e:cb][listener.cluster_command] Cluster: <zhaquirks.tuya.TuyaSmartRemoteOnOffCluster object at 0x7f6918aff6d8> ClusterId: 0x0006 tsn: 25 args: (253, [0])
[2021-02-01 16:29:09][INFO] : handle_message incomingMsg
[2021-02-01 16:29:09][INFO] : [bc:33:ac:ff:fe:57:0e:cb][listener.cluster_command] Cluster: <zhaquirks.tuya.TuyaSmartRemoteOnOffCluster object at 0x7f6918aff6d8> ClusterId: 0x0006 tsn: 25 args: (253, [0])
[2021-02-01 16:29:11][INFO] : handle_message incomingMsg
[2021-02-01 16:29:11][INFO] : [bc:33:ac:ff:fe:57:0e:cb][listener.zha_send_event] Received an event update remote_button_short_press=[] on cluster 6
[2021-02-01 16:29:11][INFO] : [bc:33:ac:ff:fe:57:0e:cb][listener.cluster_command] Cluster: <zhaquirks.tuya.TuyaSmartRemoteOnOffCluster object at 0x7f6918aff6d8> ClusterId: 0x0006 tsn: 26 args: (253, [0])
Je ne suis pas persuadé que cela permettra de configurer ces équipements !!!
Encore merci pour la qualité et la quantité du travail accompli.
Cordialement,
Pas trop non j’ai pas le module donc je l’ajoute a l’aveugle après la signification des trucs…
C’est pas le bon log ca il me faut l’autre.
Je me disais bien !
J’ai (enfin trouvé) l’autre log.
Bouton1 - single
[2021-02-01 17:02:14][DEBUG] : {"devices":{"bc:33:ac:ff:fe:57:0e:cb":{"1":{"6":{"event":{"remote_button_short_press":{"value":[],"cluster_name":"TS004X_cluster"}},"cmd":[{"value":"253","cluster_name":"TS004X_cluster"},{"value":"0","cluster_name":"TS004X_cluster"}]}}}}}
[2021-02-01 17:02:14][DEBUG] : Search command for bc:33:ac:ff:fe:57:0e:cb logicalId : 1::6::cmd::0 => 253
[2021-02-01 17:02:14][DEBUG] : Search command for bc:33:ac:ff:fe:57:0e:cb logicalId : 1::6::cmd::1 => 0
Bouton2 - single
[2021-02-01 16:51:48][DEBUG] : {"devices":{"bc:33:ac:ff:fe:57:0e:cb":{"2":{"6":{"event":{"remote_button_short_press":{"value":[],"cluster_name":"TS004X_cluster"}},"cmd":[{"value":"253","cluster_name":"TS004X_cluster"},{"value":"0","cluster_name":"TS004X_cluster"}]}}}}}
[2021-02-01 16:51:48][DEBUG] : Search command for bc:33:ac:ff:fe:57:0e:cb logicalId : 2::6::cmd::0 => 253
[2021-02-01 16:51:48][DEBUG] : Search command for bc:33:ac:ff:fe:57:0e:cb logicalId : 2::6::cmd::1 => 0
[2021-02-01 16:51:49][DEBUG] : {"devices":{"bc:33:ac:ff:fe:57:0e:cb":{"2":{"6":{"cmd":[{"value":"253","cluster_name":"TS004X_cluster"},{"value":"0","cluster_name":"TS004X_cluster"}]}}}}}
[2021-02-01 16:51:49][DEBUG] : Search command for bc:33:ac:ff:fe:57:0e:cb logicalId : 2::6::cmd::0 => 253
[2021-02-01 16:51:49][DEBUG] : Search command for bc:33:ac:ff:fe:57:0e:cb logicalId : 2::6::cmd::1 => 0
Bouton3 - single
[2021-02-01 16:52:22][DEBUG] : {"devices":{"bc:33:ac:ff:fe:57:0e:cb":{"3":{"6":{"event":{"remote_button_short_press":{"value":[],"cluster_name":"TS004X_cluster"}},"cmd":[{"value":"253","cluster_name":"TS004X_cluster"},{"value":"0","cluster_name":"TS004X_cluster"}]}}}}}
[2021-02-01 16:52:22][DEBUG] : Search command for bc:33:ac:ff:fe:57:0e:cb logicalId : 3::6::cmd::0 => 253
[2021-02-01 16:52:22][DEBUG] : Search command for bc:33:ac:ff:fe:57:0e:cb logicalId : 3::6::cmd::1 => 0
[2021-02-01 16:52:23][DEBUG] : {"devices":{"bc:33:ac:ff:fe:57:0e:cb":{"3":{"6":{"cmd":[{"value":"253","cluster_name":"TS004X_cluster"},{"value":"0","cluster_name":"TS004X_cluster"}]}}}}}
[2021-02-01 16:52:23][DEBUG] : Search command for bc:33:ac:ff:fe:57:0e:cb logicalId : 3::6::cmd::0 => 253
[2021-02-01 16:52:23][DEBUG] : Search command for bc:33:ac:ff:fe:57:0e:cb logicalId : 3::6::cmd::1 => 0
Bouton1 - double
[2021-02-01 16:50:55][DEBUG] : {"devices":{"bc:33:ac:ff:fe:57:0e:cb":{"1":{"6":{"event":{"remote_button_double_press":{"value":[],"cluster_name":"TS004X_cluster"}},"cmd":[{"value":"253","cluster_name":"TS004X_cluster"},{"value":"1","cluster_name":"TS004X_cluster"}]}}}}}
[2021-02-01 16:50:55][DEBUG] : Search command for bc:33:ac:ff:fe:57:0e:cb logicalId : 1::6::cmd::0 => 253
[2021-02-01 16:50:55][DEBUG] : Search command for bc:33:ac:ff:fe:57:0e:cb logicalId : 1::6::cmd::1 => 1
Bouton2 - double
[2021-02-01 16:52:51][DEBUG] : {"devices":{"bc:33:ac:ff:fe:57:0e:cb":{"2":{"6":{"event":{"remote_button_double_press":{"value":[],"cluster_name":"TS004X_cluster"}},"cmd":[{"value":"253","cluster_name":"TS004X_cluster"},{"value":"1","cluster_name":"TS004X_cluster"}]}}}}}
[2021-02-01 16:52:51][DEBUG] : Search command for bc:33:ac:ff:fe:57:0e:cb logicalId : 2::6::cmd::0 => 253
[2021-02-01 16:52:51][DEBUG] : Search command for bc:33:ac:ff:fe:57:0e:cb logicalId : 2::6::cmd::1 => 1
[2021-02-01 16:52:52][DEBUG] : {"devices":{"bc:33:ac:ff:fe:57:0e:cb":{"2":{"6":{"cmd":[{"value":"253","cluster_name":"TS004X_cluster"},{"value":"1","cluster_name":"TS004X_cluster"}]}}}}}
[2021-02-01 16:52:52][DEBUG] : Search command for bc:33:ac:ff:fe:57:0e:cb logicalId : 2::6::cmd::0 => 253
[2021-02-01 16:52:52][DEBUG] : Search command for bc:33:ac:ff:fe:57:0e:cb logicalId : 2::6::cmd::1 => 1
Bouton3 - double
[2021-02-01 16:53:22][DEBUG] : {"devices":{"bc:33:ac:ff:fe:57:0e:cb":{"3":{"6":{"event":{"remote_button_short_press":{"value":[],"cluster_name":"TS004X_cluster"}},"cmd":[{"value":"253","cluster_name":"TS004X_cluster"},{"value":"0","cluster_name":"TS004X_cluster"}]}}}}}
[2021-02-01 16:53:22][DEBUG] : Search command for bc:33:ac:ff:fe:57:0e:cb logicalId : 3::6::cmd::0 => 253
[2021-02-01 16:53:22][DEBUG] : Search command for bc:33:ac:ff:fe:57:0e:cb logicalId : 3::6::cmd::1 => 0
[2021-02-01 16:53:23][DEBUG] : {"devices":{"bc:33:ac:ff:fe:57:0e:cb":{"3":{"6":{"cmd":[{"value":"253","cluster_name":"TS004X_cluster"},{"value":"0","cluster_name":"TS004X_cluster"}]}}}}}
[2021-02-01 16:53:23][DEBUG] : Search command for bc:33:ac:ff:fe:57:0e:cb logicalId : 3::6::cmd::0 => 253
[2021-02-01 16:53:23][DEBUG] : Search command for bc:33:ac:ff:fe:57:0e:cb logicalId : 3::6::cmd::1 => 0
J’espère que cela convient mieux, mais pas certain …
OK compris : merci !
Install faite sur mon jeedom slave : Conbee + 2 aquara pour tester.
Il parait super, je découvre.
Le commissioning est il l’équivalent de l’ajout par serial number sur l’appli hue ?
Le détecteur de mouvement Xiaomi motion.aq2 n’est pas détecté automatiquement bien que présent dans la liste des devices connus du plugin.
Voici les données brutes :
"ieee": "00:15:8d:00:01:6d:b7:47",
"nwk": 58663,
"status": 2,
"lqi": "42",
"rssi": "-86",
"last_seen": "1612216545.8163962",
"endpoints": [
"id": 1,
"status": 1,
"device_type": 263,
"profile_id": 260,
"model": "lumi.sensor_motion.aq2",
"id": 0,
"name": "Basic",
"attributes": []
"id": 25,
"name": "Ota",
"attributes": []
"input_clusters": [
"id": 0,
"attributes": [
"id": 4,
"value": "LUMI"
"id": 5,
"name": "model",
"value": "lumi.sensor_motion.aq2"
"id": 1,
"attributes": [
"id": 32,
"value": 30
"id": 33,
"value": 132
"id": 3,
"name": "Identify",
"attributes": []
"id": 1024,
"name": "Illuminance Measurement",
"attributes": [
"id": 0,
"name": "measured_value",
"value": 13803.112417116059
"id": 1030,
"name": "Occupancy Sensing",
"attributes": [
"id": 0,
"name": "occupancy",
"value": 1
"id": 1280,
"name": "IAS Zone",
"attributes": [
"id": 0,
"name": "zone_state",
"value": 1
"id": 16,
"name": "cie_addr",
"value": [
89,
171,
6,
255,
255,
46,
33,
0
"id": 65535,
"attributes": []
"signature": {
"node_desc": {
"byte1": 2,
"byte2": 64,
"server_mask": 0,
"endpoints": {
"1": {
"profile_id": 260,
"device_type": 263,
"input_clusters": [
0,
1,
3,
1024,
1030,
1280,
65535
0,
25
"class": "zhaquirks.xiaomi.aqara.motion_aq2"
Je vois aucun soucis sur sa conf et j’en ai un chez moi aucun soucis de detection automatique…
Toujours pas bon il y a un log zigbee tout simple
