Désolé pour le délai de réponse
Non pas comme ça j’aimerais que cela soit un commande de type info comme sur le plugin Xiaomi de Lunarok.
Je pensais que c’était remontés par le capteur directement.
genre #[Garage] [porte] [absence de fermeture]# > 60 par exemple
Je n’arrive pas a utiliser un interrupteur xiaomi double sans fils, voici le log du plugin a l’utilisation (quelque soit l’interrupteur j’ai le même message
[2021-03-24 20:17:06][DEBUG] : {"devices":{"00:15:8d:00:02:38:7e:f0":{"1":{"6":[{"value":"Bool.false","cluster_name":"On\/Off"}]}}}}
[2021-03-24 20:17:06][DEBUG] : Search attribut for 00:15:8d:00:02:38:7e:f0 logicalId : 1::6::0 => Bool.false
Voici les « informations brutes »
"ieee": "00:15:8d:00:02:38:7e:f0",
"nwk": 33461,
"status": 2,
"lqi": "123",
"rssi": "-64",
"last_seen": "1616612526.00447",
"node_descriptor": "02:40:80:37:10:7f:64:00:00:00:64:00:00",
"endpoints": [
"id": 1,
"status": 1,
"device_type": 6,
"profile_id": 260,
"manufacturer": "LUMI",
"model": "lumi.sensor_86sw2",
"output_clusters": [
"id": 0,
"name": "Basic",
"attributes": []
"id": 3,
"name": "Identify",
"attributes": []
"id": 4,
"name": "Groups",
"attributes": []
"id": 5,
"name": "Scenes",
"attributes": []
"id": 25,
"name": "Ota",
"attributes": []
"id": 65535,
"name": "Manufacturer Specific",
"attributes": []
"id": 18,
"name": "MultistateInputCluster",
"attributes": []
"id": 6,
"name": "On\/Off",
"attributes": [
"id": 0,
"name": "on_off",
"value": 0
"input_clusters": [
"id": 0,
"name": "BasicCluster",
"attributes": [
"id": 0,
"name": "zcl_version",
"value": 1
"id": 1,
"name": "app_version",
"value": 5
"id": 2,
"name": "stack_version",
"value": 2
"id": 3,
"name": "hw_version",
"value": 20
"id": 4,
"name": "manufacturer",
"value": "LUMI"
"id": 5,
"name": "model",
"value": "lumi.sensor_86sw2"
"id": 6,
"name": "date_code",
"value": "20170411"
"id": 7,
"name": "power_source",
"value": 3
"id": 16384,
"name": "sw_build_id",
"value": "3000-0001"
"id": 1,
"name": "Power Configuration",
"attributes": [
"id": 32,
"name": "battery_voltage",
"value": 30
"id": 33,
"name": "battery_percentage_remaining",
"value": 139
"id": 3,
"name": "Identify",
"attributes": []
"id": 25,
"name": "Ota",
"attributes": []
"id": 65535,
"attributes": []
"id": 18,
"attributes": []
"id": 2,
"status": 1,
"device_type": 6,
"profile_id": 260,
"manufacturer": null,
"model": null,
"id": 3,
"name": "Identify",
"attributes": []
"id": 4,
"name": "Groups",
"attributes": []
"id": 5,
"name": "Scenes",
"attributes": []
"id": 18,
"attributes": []
"id": 6,
"name": "On\/Off",
"attributes": [
"id": 0,
"name": "on_off",
"value": 0
"input_clusters": [
"id": 3,
"name": "Identify",
"attributes": []
"id": 18,
"attributes": []
"id": 3,
"status": 1,
"device_type": 6,
"profile_id": 260,
"model": null,
"id": 3,
"name": "Identify",
"attributes": []
"id": 4,
"name": "Groups",
"attributes": []
"id": 5,
"name": "Scenes",
"attributes": []
"id": 12,
"name": "AnalogInput",
"attributes": []
"id": 18,
"attributes": []
"id": 6,
"name": "On\/Off",
"attributes": [
"id": 0,
"name": "on_off",
"value": 0
"input_clusters": [
"id": 3,
"name": "Identify",
"attributes": []
"id": 18,
"attributes": []
"signature": {
"node_desc": {
"byte1": 2,
"byte2": 64,
"mac_capability_flags": 128,
"manufacturer_code": 4151,
"maximum_buffer_size": 127,
"maximum_incoming_transfer_size": 100,
"server_mask": 0,
"maximum_outgoing_transfer_size": 100,
"endpoints": {
"1": {
"profile_id": 260,
"device_type": 6,
"input_clusters": [
0,
1,
3,
25,
65535,
18
0,
3,
4,
5,
25,
65535,
18,
6
"2": {
"profile_id": 260,
"device_type": 6,
"input_clusters": [
3,
18
3,
4,
5,
18,
6
"3": {
"profile_id": 260,
"device_type": 6,
"input_clusters": [
3,
18
3,
4,
5,
12,
18,
6
"class": "zhaquirks.xiaomi.aqara.remote_b286acn01"
j’espère que vous avez toutes les infos nécessaire?
Visiblement sur ZigBee Beta tout ce qui est géré nativement par Jeedom n’est pas éligible à devenir une commande spécifique !
Je t’invite à reformuler ta demande voire faire un post spécifique pour obtenir une réponse officielle.
J’ai tester le port usb2 et usb3
La clé est directement sur le RPi
J’ai toujours le statut du demon NOK
Le backup marche chez vous ? Chez moi rien ne se passe…
Aujourd’hui, nous avons 2 fois la référence [067646] dans le menu déroulant
Quelle est celle qui correspond à la commande VR filaire [067726] et celle qui correspond à la commande VR sans fil [067646] demandée par @loic69 ?
Par ailleurs, j’avais proposé une synthèse des références
Il y a effectivement des soucis dans les ref, ca sera corrigé demain merci pour le retour
Oui je viens de voir.
Par contre je n’ai pas vu arriver la commande sans fil eclairage double legrand ni la commande sans fil de volet Legrand. Je ne sais pas si @Loic l’a intégré en parallèle des corrections de references
voila j ai essayer de reinstalée inter double sans fil legrand ref : 067724 et j ai toujours l erreur suivant
Erreur exécution de la commande [entrée][Legrand.Double_gangs_remote_switch 00:04:74:00:00:82:58:bd][On] : Erreur lors de la requete : http://127.0.0.1:8484/device/command(PUT), data : {« ieee »:« 00:04:74:00:00:82:58:bd »,« cmd »:[{« endpoint »:1,« cluster »:« on_off »,« command »:« on »,« await »:1}],« allowQueue »:false} erreur : {« state »:« error »,« result »:« Cluster not found : on_off »,« code »:0}
N’est ce pas celle ci ?
Cela doit être la 2ème ligne ajoutée ce matin
La première doit certainement être celle d’origine et correspondre à la commande VR filaire
Laissons Loic rectifier tranquillement cela.
S’il a besoin d’aide ou plus d’info, il sait ou nous joindre…
Non je peux pas te dire désolé
tu as besoin de plus d’informations pour y parvenir?
MP moi si tu veux.
Cette question ne me semble pas spécifique au #plugin-Zigbee Beta et ne devrait donc pas être dans le présent fil…
Si les modérateurs sont cohérents avec d’autres interventions, ils devraient te demander de créer un sujet pour poser ta question.
Effectivement…
Je sais pas la pour etre honnete j’ai trop de boulot en ce moment et pas vraiment le temps de me pencher la dessus…
Merci LOIC,
Cela me semble beaucoup plus clair ainsi !
Pour être parfait, il y a un 7 de trop dans la référence 067772
et encore quelques incohérences sur les 2 lignes du bas
Enfin, peut-être ajouter « Filaire » pour les commandes VR [067726…]
et « Sans fil » pour les commandes VR [067746…]
ainsi que pour les interrupteurs simple et double.
Hello @MADomotique @Loic
Pour le device 067722/067772/064895 Legrand interrupteur double sans fil c’est ok (hormis la description « sans fil » à rajouter) comme stipulé par @MADomotique
Les 4 boutons marchent. En revanche il y a 4 commandes actions (On et Off pour chaque bouton) qui sont créées et qui n’ont pas lieu d’être. elles génèrent des erreurs si on les utilisent.
Sinon c’est parfait
Pour le device 067646/067647/064897 Legrand volet rouant sans fil
Effecivement i faut rajouter la notion de SANS FIL dans la description.
Idem les commandes actions n’ont pas lieu d’être et il me semble que la commande info Etat ne fonctionne pas. Je pense qu’au niveau du JSON il y a eu copie de la commande filaire qui n’est pas la même niveau endpoint.
