Peux tu ajouter la commande :
Nom : Rafraîchir
Type : Action, Défaut
Logical ID : refresh
Tester on
Tester rafraichir
Tester puissance
Tester off
Tester rafraichir
Tester puissance
akenad
Nom : Rafraîchir
Tester on
Tester rafraichir
Tester puissance
Tester off
Tester rafraichir
Tester puissance
akenad
avec le refresh, cela passe bien de zero a la valeur de puissance oui
je viens de lancer un post spe pour la suite
Effectivement, il suffisait de savoir où chercher…
Merci beaucoup !
Bonjour @Loic
Pour ajout Gledopto GL-C-006S
Donnée brutes:
"ieee": "60:a4:23:ff:fe:04:1c:0c",
"nwk": 54231,
"status": 2,
"lqi": "167",
"rssi": "-73",
"last_seen": "1616350332.7480373",
"node_descriptor": "01:40:8e:4f:12:52:52:00:00:2c:52:00:00",
"endpoints": [
"id": 11,
"status": 1,
"device_type": 268,
"profile_id": 260,
"manufacturer": "GLEDOPTO",
"model": "GL-C-006P",
"output_clusters": [
"id": 25,
"name": "Ota",
"attributes": []
"input_clusters": [
"id": 0,
"name": "Basic",
"attributes": [
"id": 0,
"name": "zcl_version",
"value": 3
"id": 1,
"name": "app_version",
"value": 0
"id": 2,
"name": "stack_version",
"value": 0
"id": 3,
"name": "hw_version",
"value": 2
"id": 4,
"name": "manufacturer",
"value": "GLEDOPTO"
"id": 5,
"name": "model",
"value": "GL-C-006P"
"id": 6,
"name": "date_code",
"value": ""
"id": 7,
"name": "power_source",
"value": 0
"id": 16384,
"name": "sw_build_id",
"value": "V1.0.1"
"id": 3,
"name": "Identify",
"attributes": []
"id": 4,
"name": "Groups",
"attributes": []
"id": 5,
"name": "Scenes",
"attributes": []
"id": 6,
"name": "On\/Off",
"attributes": [
"id": 0,
"name": "on_off",
"value": 0
"id": 8,
"name": "Level control",
"attributes": [
"id": 0,
"name": "current_level",
"value": 90
"id": 768,
"name": "Color Control",
"attributes": [
"id": 0,
"name": "current_hue",
"value": 0
"id": 1,
"name": "current_saturation",
"value": 0
"id": 3,
"name": "current_x",
"value": 17623
"id": 4,
"name": "current_y",
"value": 43739
"id": 7,
"name": "color_temperature",
"value": 495
"id": 4096,
"name": "LightLink",
"attributes": []
"id": 242,
"status": 1,
"device_type": 97,
"profile_id": 41440,
"manufacturer": null,
"model": null,
"id": 33,
"name": "GreenPowerProxy",
"attributes": []
"input_clusters": []
"signature": {
"node_desc": {
"byte1": 1,
"byte2": 64,
"mac_capability_flags": 142,
"manufacturer_code": 4687,
"maximum_buffer_size": 82,
"maximum_incoming_transfer_size": 82,
"server_mask": 11264,
"maximum_outgoing_transfer_size": 82,
"endpoints": {
"11": {
"profile_id": 260,
"device_type": 268,
"input_clusters": [
0,
3,
4,
5,
6,
8,
768,
4096
25
"242": {
"device_type": 97,
"input_clusters": [],
33
"class": "zigpy.device"
Merci d’utiliser les balises </> pour tes log
Desolé message rectifier
J’ai changé les piles sur les 7 télécommandes Ikéa hier samedi matin.
Ce soir, ce dimanche, les 3 télécommandes 5 boutons sont HS, et 3 télécommandes 2 boutons sont mortes sur les 4.
J’ai mis 1160 sur le longpool depuis le début, ça ne change apparemment rien du tout.
bonjour
est ce qu’il est possible de rajouter cette interrupteur de volet roulant
zemismart
"ieee": "bc:33:ac:ff:fe:17:05:31",
"nwk": 18383,
"status": 2,
"lqi": "191",
"rssi": "-70",
"last_seen": "1616354250.8249214",
"node_descriptor": "01:40:8e:02:10:52:00:02:00:2c:00:02:00",
"endpoints": [
"id": 1,
"status": 1,
"device_type": 514,
"profile_id": 260,
"manufacturer": "_TYZB01_dazsid15",
"model": "TS0302",
"id": 25,
"name": "Ota",
"attributes": []
"input_clusters": [
"id": 4,
"name": "Groups",
"attributes": []
"id": 5,
"name": "Scenes",
"attributes": []
"id": 258,
"name": "Window Covering",
"attributes": []
"id": 0,
"name": "Basic",
"attributes": [
"id": 0,
"value": 3
"id": 1,
"value": 66
"id": 2,
"value": 0
"id": 3,
"value": 1
"id": 4,
"value": "_TYZB01_dazsid15"
"id": 5,
"name": "model",
"value": "TS0302"
"id": 6,
"value": ""
"id": 7,
"value": 1
"signature": {
"model": "TS0302",
"node_desc": {
"byte1": 1,
"byte2": 64,
"manufacturer_code": 4098,
"maximum_incoming_transfer_size": 512,
"maximum_outgoing_transfer_size": 512,
"endpoints": {
"1": {
"profile_id": 260,
"device_type": 514,
"input_clusters": [
4,
5,
258,
0
25
merci
Soit tu c’est encore une nouvelle version de la prise xiaomi soit ton firmware est pas a jour malheureusement xioami ne les fait fournis pas donc pas possible de le mettre à jour par le plugin
Ca sera disponible dans la beta de demain
Pourtant @zoulou13 dit que ca marche après modification des valeurs comme indiqué
Ca j’ai vu mais après yen a qui disent que ca remonte pas tout seul… Après si avec 21::12::85 ca marche alors oui je change la conf mais le soucis c’est que d’autre génération du module utilise pas cet attribut la… Donc je vais reperarer pour certain et casser pour d’autre…
Ou mettre 2 fois la commande ?
Visiblement selon les modèles ou version la commande n’est pas la même.
C’est l’autre possibilité mais j’ai peur de perdre les utilisateurs et d’avoir encore plus de question… Faut je vois avec jeedom SAS
Bonjour, avez-vous un lien du plugin dans le market, en tapant Jeedom Market je ne le trouve pas
Il est en version beta pour le moment
Je viens d’installer le plugin pour connecter mes têtes Danfoss Ally.
c’est parfait pour la consigne et température.
A quoi correspond les valeurs « Fenêtre » et « Puissance » ?
J’aimerais par contre récupérer l’information de niveau de batterie.
As-tu un lien pour l’installer correctement ?
