Je fais appelle à vos expériences… connaissez vous un bon digidpad zigbee pour l’extérieur.
Bonjour apres maj plugin et reboot jeedom et réactivation des sorties cable lorsque que je teste à distance que ce soit
2021-02-26 11:38:40][DEBUG] : [DeviceHandler.prepare] Json arg : {'ieee': '00:04:74:00:00:0e:eb:c7', 'cmd': [{'endpoint': 1, 'cluster': 'on_off', 'command': 'on', 'await': 1}], 'allowQueue': False}
[2021-02-26 11:38:40][DEBUG] : Sending Zigbee request with tsn 1 under 2 request id, data: b'010101'
[2021-02-26 11:38:40][DEBUG] : Command Command.aps_data_request (18, 2, 0, <DeconzAddressEndpoint address_mode=2 address=0x8E67 endpoint=1>, 260, 6, 1, b'\x01\x01\x01', 2, 0)
[2021-02-26 11:38:40][DEBUG] : Send: 0x12130019001200020002678e01040106000103000101010200
[2021-02-26 11:38:40][DEBUG] : Frame received: 0x121300090002002202
[2021-02-26 11:38:40][DEBUG] : APS data request response: [2, <DeviceState.APSDE_DATA_REQUEST_SLOTS_AVAILABLE|2: 34>, 2]
[2021-02-26 11:38:41][DEBUG] : Frame received: 0x0e14000700a600
[2021-02-26 11:38:41][DEBUG] : Device state changed response: [<DeviceState.128|APSDE_DATA_REQUEST_SLOTS_AVAILABLE|APSDE_DATA_CONFIRM|2: 166>, 0]
[2021-02-26 11:38:41][DEBUG] : Command Command.aps_data_confirm (0,)
[2021-02-26 11:38:41][DEBUG] : Send: 0x04140007000000
[2021-02-26 11:38:41][DEBUG] : Frame received: 0x04140013000c00220202678e0101e100000000
[2021-02-26 11:38:41][DEBUG] : APS data confirm response for request with id 2: e1
[2021-02-26 11:38:41][DEBUG] : Request id: 0x02 'aps_data_confirm' for <DeconzAddressEndpoint address_mode=ADDRESS_MODE.NWK address=0x8e67 endpoint=1>, status: 0xe1
[2021-02-26 11:38:41][DEBUG] : Error while sending 2 req id frame: TXStatus.MAC_CHANNEL_ACCESS_FAILURE
[2021-02-26 11:38:41][DEBUG] : [0x8e67] Delivery error for seq # 0x01, on endpoint id 1 cluster 0x0006: message send failure
[2021-02-26 11:38:41][DEBUG] : Traceback (most recent call last):
File "/var/www/html/plugins/zigbee/resources/zigbeed/restServer.py", line 237, in put
await zdevices.command(self.json_args)
File "/var/www/html/plugins/zigbee/resources/zigbeed/zdevices.py", line 69, in command
await command()
File "/usr/local/lib/python3.7/dist-packages/zigpy/device.py", line 216, in request
self.nwk, dst_ep, cluster
zigpy.exceptions.DeliveryError: [0x8e67:1:0x0006]: Message send failure
[2021-02-26 11:38:41][INFO] : 200 PUT /device/command (127.0.0.1) 1087.58ms
Heureusement par défaut la prise est configurée en « on » et fil pilote desactivé ou en mode confort car j’ai du 0V dedans. Donc a minima j’arrive a utiliser le chauffage via son reglage en propre.
Est ce que @Loic si je prends une GW legrand et y connecte une sortie cablée ( que j’ai en rab) et arrive a sniffer les messages entre gw et la prise lorsque je la commande depuis l’appli legrand et par ex change sa config , la passe en fil pilote cela t’aiderait a mieux la gérér ?
Ce que je ne sais pas c’est si c’est crypté par défaut depuis la GW legrand , je dosi recevoir bientot une clé 2531 pour sniffer via PC + wireshark cela doit etre possible avec un peu d’huile de coude non ?
je me met à fond sur le zigbee , j’ai déjà récupéré les normes ZCL et une autre pour comprendre, et regardé ce post sur les failles mais qui montre comment sniffer en fait https://connect.ed-diamond.com/MISC/MISC-086/Tout-tout-tout-vous-saurez-tout-sur-le-ZigBee
Est ce que cela vous semble réaliste et utile ?
Pour sniffer voir ici par exemple : [Tuto] Sniffer un réseau Zigbee
Les trames sont cryptées par la Gateway Legrand, donc il faudra récupérer la clef réseau et la clef TC Link qqpart et c’est là que tout va se jouer.
Pas sur (euphémisme) que le sniffage serve à qqch pour ton problème
Malheureusement meme si tu arrive a sniffer et que c’est en clair j’ai pas le niveau pour le comprendre et encore moins pour l’adapter au plugin…
OK merci pour vos retours
Bonsoir @ludoviclt, je viens de tenter une solution pour faire fonctionner les groupes sur le deamon 1. Pour rappel j’ai créer un groupe sur le deamon 2 sans aucun problème suite à une correction de Loic.
En fait tu crées un premier groupe sur le deamon 1 (test), ce dernier ne va pas remonter. Puis tu crées un deuxième groupe (test2) et normalement il va apparaitre dans « Mes groupes Zigbee », voir imprim écran ci-dessous.
Deamon 1
Deamon 2
Mes groupes Zigbee
Je précise que mon groupe 1 est sur le deamon 2, et je pense qu’on ne peut pas avoir deux groupes 1 sur les deux deamons.
juste une confirmation, j’ai déjà un groupe d’existant. on peux bien créer plusieurs groupe sur une meme clef
actuellement moi je ne peu plus créer aucun groupe sur ma clef
Moi je peux en créer plusieurs sur les 2 clés mais il ne faut pas qu’ils aient le même numéros de groupe
Deamon 1
Deamon 2
Mes groupes Zigbee
Seul ceux qui ont le même « nom » et « nom jeedom » fonctionnent, pour les autres ils sont fantôme car les numéros de groupe sont identiques sur les deux deamon.
Montre un imprim écran de tes groupes zigbee pour voir. (clé, pas jeedom)
j’ai que cela moi
j’ai pas en amont de mon nom le groupe xx:
impossible d’en créer plus
je vais rebrancher ma deuxième clef pour voir ce que cela donne
peut etre que je devrais supprimer mon groupe actuel pour voir ce que cela donne
@Loic @Yves19 en cherchant sur mon sujet de sniffer legrand , forcément d’autres l’avaient fait avant moi je suis tombé sur ce post qui donne des infos sur les 2 cluster proprietaire de la prise :
cela ne résout pas encore les pb déja notés mais permet de voir un peu mieux comment piloter correctement ce device et ses différentes possibilités
le cluster 0xFC01 (64513) qui pour ce device permet de gérér la configuration de sortie cable en on/off ou en mode fil pilote
|Device|Attribute|Values|Data Type|
|Fil Pilote|0x0000|0x0001/0x0002 enable/disable fil pilote|0x0x09 (16 bit data)|
et le cluster 0XFC40(64576) gère la sortie fil pilote
il y a plus d’info au global sur le fil j’ai juste tiré les quelques points ci dessus.
https://github.com/pipiche38/Domoticz-Zigate-Wiki/blob/master/en-eng/Legrand-Netatmo-corner.md
Est ce que cela te permet de compléter la config du module, à défaut de régler le pb des commandes etat ou on /off que l’on arrive pas à faire fonctionner encore ?
Tiens ca me rappelle quelquechose
@Rizzo94 tiens bon, tu vas y arriver…
Pour l’instant je lache un peu l’affaire, car j’ai planté mes clés ConBee dans la bataille Deconz vs ZigBee.
Yes j y compte bien et c est en grande partie aussi grâce à toi ! Je rentre dimanche j essaierai de bricoler aussi via un fil sur ma 3eme sortie en rab vu que je vais pas l installer tant que cela marche pas celle la.
Bonjour @Loic
Suite à ma demande ici Liste de matériel compatible Jeedom
J’ai retrouvé la liste (uniquement zigbee) qui permet de filtrer le matériel par marque (ce qui est pratique) :
https://doc.jeedom.com/fr_FR/zigbee/equipement.compatible
et l’autre liste (plus générale) qui ne permet pas ce trie par marque:
https://compatibility.jeedom.com/index.php?p=home&lang=fr_FR&page=1
Il y a donc bien 2 présentations différentes.
Cordialement, Gilles
tu as deux fois le même lien. tu as du faire un mauvais copier coller
petite erreur de retour suite a un arret/marche suite a un scénario
lorsque je force manuellement via jeedom le on - off, il n’y a pas d’erreur
l’action se fait bien mais il y a tout de même une remonté d’erreur lors du lancement de l’action
voici le produit
et voici l’erreur que j’ai
voici le scenario
si quelqu’un a une idée du problème je suis preneur
@Kazymir, suite au démontage de la prise connectée de LIDL plugin-ZIGBEE Beta - #1069 par anon39781406 vous auriez un modèle plus qualitatif et économique en énergie à proposer en restant dans une gamme de entre 10 et 20€?
il y a des promos chez Amazon sur des OSRAM Smart Prises Connectées Zigbee Compatible Android & Amazon Alexa, Blanc/Gris, Lot de 4 à 32€ les 4
Ce qui est bête c’est qu’il y a encore quelques jours c’était à 25€
Je suis parti sur celle là :
j’ai cette référence, avec ma clef combee2 la puissance ne remonte pas, mais il semblerait que cela remonte bien avec la clef elelabs que je devrais bientôt recevoir pour valider
Je ne connais pas la consommation de celles de chez LIDL mais les OSRAM c’est 4W en veille ! (4,74W en marche sans charge).
C’est énorme je trouve, surtout quand c’est pour commander une guirlande LED qui consomme 10W!
