voici le retour du shell apres avoir lancé la commande :
Setting up php7.0-cli (7.0.33-0+deb9u6) …
debconf: unable to initialize frontend: Dialog
debconf: (Dialog frontend will not work on a dumb terminal, an emacs shell buffer, or without a controlling terminal.)
debconf: falling back to frontend: Readline
debconf: unable to initialize frontend: Readline
debconf: (This frontend requires a controlling tty.)
debconf: falling back to frontend: Teletype
Modified configuration file
A new version (/usr/lib/php/7.0/php.ini-production.cli) of configuration file
/etc/php/7.0/cli/php.ini is available, but the version installed currently has
been locally modified.
- install the package maintainer’s version
- keep the local version currently installed
- show the differences between the versions
- show a side-by-side difference between the versions
- start a new shell to examine the situation
What do you want to do about modified configuration file php.ini?
Use of uninitialized value $_[1] in join or string at /usr/share/perl5/Debconf/DbDriver/Stack.pm line 111.
Use of uninitialized value $val in substitution (s///) at /usr/share/perl5/Debconf/Format/822.pm line 83, line 10.
Use of uninitialized value $val in concatenation (.) or string at /usr/share/perl5/Debconf/Format/822.pm line 84, line 10.
Setting up php7.0-dev (7.0.33-0+deb9u6) …
Setting up libapache2-mod-php7.0 (7.0.33-0+deb9u6) …
A new version (/usr/lib/php/7.0/php.ini-production) of configuration file
/etc/php/7.0/apache2/php.ini is available, but the version installed currently
has been locally modified.
libapache2-mod-php7.0: not switching MPM - already enabled
PS : la relance des dependances fonctionne à nouveau
Autre question, je voudrais repasser en mode stable du plugin. Comment je peux le faire sans perdre toute ma configuration des modules ?
