Re-Bonjour,
J’ai réalisé des tests.
En mettant le Plug 2 et canal1 en effet ça fonctionne MAIS si on remet dans la foulée Plug1 cela ne fonctionne plus. J’ai tenté après de remettre Plug2 et la ça ne fonctionne plus non plus.
En gros si tu changes en mettant PLUG2 et que tu ne touches pas ça marche mais si tu commences à changer ça ne fonctionne plus.
Voici ma log en mode Debug :
[2020-12-10 15:08:14][DEBUG] : Cmd to 127.0.0.1: {"t":"1607609294","devId":"60053804600194cb574a","dps":{"1":true,"2":0},"uid":""} - Try:127.0.0.1 6900 - Connect OK!
[2020-12-10 15:08:16][DEBUG] : Cmd to 127.0.0.1: {"t":"1607609296","devId":"60053804600194cb574a","dps":{"1":true,"2":0},"uid":""} - Try:127.0.0.1 6900 - Connect OK!
[2020-12-10 15:08:25][DEBUG] : >>>>search:SwOnOffGet num: v2:SwOnOffGet
[2020-12-10 15:08:25][DEBUG] : >>>>found:SwOnOffGet
[2020-12-10 15:08:25][DEBUG] : >>>>search:SwOnOffGet num: v2:On
[2020-12-10 15:08:25][DEBUG] : >>>>search:On num: v2:On
[2020-12-10 15:08:25][DEBUG] : >>>>found:On
[2020-12-10 15:08:25][DEBUG] : >>>>search:SwOnOffGet num: v2:Off
[2020-12-10 15:08:25][DEBUG] : >>>>search:On num: v2:Off
[2020-12-10 15:08:25][DEBUG] : >>>>search:Off num: v2:Off
[2020-12-10 15:08:25][DEBUG] : >>>>found:Off
[2020-12-10 15:08:25][DEBUG] : Associate act:On with info:SwOnOffGet dps:
[2020-12-10 15:08:25][DEBUG] : Associate act:Off with info:SwOnOffGet dps:
[2020-12-10 15:08:25][DEBUG] : >>>>Daemon Started
[2020-12-10 15:08:25][DEBUG] : Memory used :1673 ko 112 o
[2020-12-10 15:08:25][DEBUG] : >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Search for devices <<<<<<<<<<<<<<<<<<<<<<<<<<<<<
[2020-12-10 15:08:26][DEBUG] : ****** Channel:1 *****
[2020-12-10 15:08:26][DEBUG] : ****** Device listenable Prise Tablette - Class:Tuya_SW_2_V2 @192.168.0.186 Channel:1 *****
[2020-12-10 15:08:26][DEBUG] : Key not set
[2020-12-10 15:08:26][DEBUG] : Socket created @192.168.0.186
[2020-12-10 15:08:26][DEBUG] : ADD New device @192.168.0.186 channel:1
[2020-12-10 15:08:26][DEBUG] : Device and socket exist : key:0 @192.168.0.186 channel:1 diff:0
[2020-12-10 15:08:26][DEBUG] : ****** Device listenable Prise Aquarium - Class:Tuya_SW_2_V2 @192.168.0.187 Channel:1 *****
[2020-12-10 15:08:26][DEBUG] : Socket created @192.168.0.187
[2020-12-10 15:08:26][DEBUG] : ADD New device @192.168.0.187 channel:1
[2020-12-10 15:08:26][DEBUG] : Device and socket exist : key:1 @192.168.0.187 channel:1 diff:0
[2020-12-10 15:08:26][DEBUG] : ****** Device NOT listenable Prise Camera - Class: Ewelink *****
[2020-12-10 15:08:26][DEBUG] : ****** Channel: *****
[2020-12-10 15:08:26][DEBUG] : ****** Channel:60053804600194cb952f *****
[2020-12-10 15:08:26][DEBUG] : ****** Device listenable Prise Raspberry - Class:Tuya_SW_V2 @192.168.0.184 Channel:60053804600194cb952f *****
[2020-12-10 15:08:26][DEBUG] : Socket created @192.168.0.184
[2020-12-10 15:08:26][DEBUG] : ADD New device @192.168.0.184 channel:60053804600194cb952f
[2020-12-10 15:08:26][DEBUG] : Device and socket exist : key:2 @192.168.0.184 channel:60053804600194cb952f diff:0
[2020-12-10 15:08:26][DEBUG] : ****** Device NOT listenable Prise Sapin - Class: Ewelink *****
[2020-12-10 15:08:26][DEBUG] : ****** Channel:81203815840d8e79fc27 *****
[2020-12-10 15:08:26][DEBUG] : ****** Device listenable Prise Spare2 - Class:Tuya_SW_V2 @192.168.0.189 Channel:81203815840d8e79fc27 *****
[2020-12-10 15:08:26][DEBUG] : Socket created @192.168.0.189
[2020-12-10 15:08:26][DEBUG] : ADD New device @192.168.0.189 channel:81203815840d8e79fc27
[2020-12-10 15:08:26][DEBUG] : Device and socket exist : key:3 @192.168.0.189 channel:81203815840d8e79fc27 diff:0
[2020-12-10 15:08:26][DEBUG] : >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> End <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
[2020-12-10 15:08:26][DEBUG] : Memory used :1744 ko 192 o
[2020-12-10 15:08:26][DEBUG] : Update state @192.168.0.186
[2020-12-10 15:08:26][DEBUG] : Cmd to 192.168.0.186 - Try:192.168.0.186 6668 - Connect OK!
[2020-12-10 15:08:26][DEBUG] : Update other states:
[2020-12-10 15:08:26][DEBUG] : Update state @192.168.0.187
[2020-12-10 15:08:26][DEBUG] : Cmd to 192.168.0.187 - Try:192.168.0.187 6668 - Connect OK!
[2020-12-10 15:08:26][DEBUG] : Update state @192.168.0.184
[2020-12-10 15:08:26][DEBUG] : Cmd to 192.168.0.184 - Try:192.168.0.184 6668 - Connect OK!
[2020-12-10 15:08:26][DEBUG] : Update state @192.168.0.189
[2020-12-10 15:08:26][DEBUG] : Cmd to 192.168.0.189 - Try:192.168.0.189 6668 - Connect OK!
[2020-12-10 15:08:26][DEBUG] : Receive after decode :{"devId":"81203815dc4f22b3c9b1","dps":{"1":false,"9":0}}
[2020-12-10 15:08:26][DEBUG] : Multichanel in state : update all
[2020-12-10 15:08:26][DEBUG] : Multiple device @192.168.0.186 canal:1
[2020-12-10 15:08:26][DEBUG] : CanalDev:1 in MultiC
[2020-12-10 15:08:26][DEBUG] : Found Canal:1 OK
[2020-12-10 15:08:26][DEBUG] : Update other states: - On:0
[2020-12-10 15:08:26][DEBUG] : Receive after decode :{"devId":"60053804600194cb574a","dps":{"1":false,"9":0}}
[2020-12-10 15:08:26][DEBUG] : Multiple device @192.168.0.187 canal:1
[2020-12-10 15:08:26][DEBUG] : Receive after decode :{"devId":"60053804600194cb952f","dps":{"1":true,"9":0}}
[2020-12-10 15:08:26][DEBUG] : Device @192.168.0.184 Monocanal:1
[2020-12-10 15:08:26][DEBUG] : No such device
[2020-12-10 15:08:26][DEBUG] : Receive after decode :{"devId":"81203815840d8e79fc27","dps":{"1":false,"9":0}}
[2020-12-10 15:08:26][DEBUG] : Device @192.168.0.189 Monocanal:1
[2020-12-10 15:08:33][DEBUG] : Cmd to 127.0.0.1: {"t":"1607609313","devId":"60053804600194cb574a","dps":{"1":true},"uid":""} - Try:127.0.0.1 6900 - Connect OK!
[2020-12-10 15:08:33][DEBUG] : Cmd to 192.168.0.187 - Try:192.168.0.187 6668 - Connect OK!
[2020-12-10 15:08:33][DEBUG] : No state update
[2020-12-10 15:08:33][DEBUG] : Receive after decode :{"devId":"60053804600194cb574a","dps":{"1":true},"t":1607609312}
[2020-12-10 15:08:33][DEBUG] : Multichanel in state : update all
[2020-12-10 15:08:33][DEBUG] : Multiple device @192.168.0.187 canal:1
[2020-12-10 15:08:33][DEBUG] : CanalDev:1 in MultiC
[2020-12-10 15:08:33][DEBUG] : Found Canal:1 OK
[2020-12-10 15:08:33][DEBUG] : Update other states: - On:1
[2020-12-10 15:08:39][DEBUG] : Cmd to 127.0.0.1: {"t":"1607609319","devId":"60053804600194cb574a","dps":{"1":false},"uid":""} - Try:127.0.0.1 6900 - Connect OK!
[2020-12-10 15:08:39][DEBUG] : Cmd to 192.168.0.187 - Try:192.168.0.187 6668 - Connect OK!
[2020-12-10 15:08:39][DEBUG] : No state update
[2020-12-10 15:08:39][DEBUG] : Receive after decode :{"devId":"60053804600194cb574a","dps":{"1":false},"t":1607609317}
[2020-12-10 15:08:39][DEBUG] : Multichanel in state : update all
[2020-12-10 15:08:39][DEBUG] : Multiple device @192.168.0.187 canal:1
[2020-12-10 15:08:39][DEBUG] : CanalDev:1 in MultiC
[2020-12-10 15:08:39][DEBUG] : Found Canal:1 OK
[2020-12-10 15:08:39][DEBUG] : Update other states: - On:0
[2020-12-10 15:08:42][DEBUG] : << Ping @192.168.0.186 diff:16
[2020-12-10 15:08:42][DEBUG] : Cmd to 192.168.0.186 - Try:192.168.0.186 6668 - Connect OK!
[2020-12-10 15:08:42][DEBUG] : << Ping @192.168.0.187 diff:16
[2020-12-10 15:08:42][DEBUG] : Cmd to 192.168.0.187 - Try:192.168.0.187 6668 - Connect OK!
[2020-12-10 15:08:42][DEBUG] : << Ping @192.168.0.184 diff:16
[2020-12-10 15:08:42][DEBUG] : Cmd to 192.168.0.184 - Try:192.168.0.184 6668 - Connect OK!
[2020-12-10 15:08:42][DEBUG] : << Ping @192.168.0.189 diff:16
[2020-12-10 15:08:42][DEBUG] : Cmd to 192.168.0.189 - Try:192.168.0.189 6668 - Connect OK!
[2020-12-10 15:08:44][DEBUG] : >>>>search:SwOnOffGet num: v2:On
[2020-12-10 15:08:44][DEBUG] : >>>>search:SwOnOffGet num: v2:Off
[2020-12-10 15:08:44][DEBUG] : >>>>search:On num: v2:Off
[2020-12-10 15:08:44][DEBUG] : Associate act:On with info:SwOnOffGet dps:
[2020-12-10 15:08:44][DEBUG] : Associate act:Off with info:SwOnOffGet dps:
[2020-12-10 15:08:45][DEBUG] : >>>>Daemon Started
[2020-12-10 15:08:45][DEBUG] : Memory used :1673 ko 112 o
[2020-12-10 15:08:45][DEBUG] : >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Search for devices <<<<<<<<<<<<<<<<<<<<<<<<<<<<<
[2020-12-10 15:08:45][DEBUG] : ****** Channel:1 *****
[2020-12-10 15:08:45][DEBUG] : ****** Device listenable Prise Tablette - Class:Tuya_SW_2_V2 @192.168.0.186 Channel:1 *****
[2020-12-10 15:08:45][DEBUG] : Key not set
[2020-12-10 15:08:45][DEBUG] : Socket created @192.168.0.186
[2020-12-10 15:08:45][DEBUG] : ADD New device @192.168.0.186 channel:1
[2020-12-10 15:08:45][DEBUG] : Device and socket exist : key:0 @192.168.0.186 channel:1 diff:0
[2020-12-10 15:08:45][DEBUG] : ****** Device listenable Prise Aquarium - Class:Tuya_SW_V2 @192.168.0.187 Channel:1 *****
[2020-12-10 15:08:45][DEBUG] : Socket created @192.168.0.187
[2020-12-10 15:08:45][DEBUG] : ADD New device @192.168.0.187 channel:1
[2020-12-10 15:08:45][DEBUG] : Device and socket exist : key:1 @192.168.0.187 channel:1 diff:0
[2020-12-10 15:08:45][DEBUG] : ****** Device NOT listenable Prise Camera - Class: Ewelink *****
[2020-12-10 15:08:45][DEBUG] : ****** Channel: *****
[2020-12-10 15:08:45][DEBUG] : ****** Channel:60053804600194cb952f *****
[2020-12-10 15:08:45][DEBUG] : ****** Device listenable Prise Raspberry - Class:Tuya_SW_V2 @192.168.0.184 Channel:60053804600194cb952f *****
[2020-12-10 15:08:45][DEBUG] : Socket created @192.168.0.184
[2020-12-10 15:08:45][DEBUG] : ADD New device @192.168.0.184 channel:60053804600194cb952f
[2020-12-10 15:08:45][DEBUG] : Device and socket exist : key:2 @192.168.0.184 channel:60053804600194cb952f diff:0
[2020-12-10 15:08:45][DEBUG] : ****** Device NOT listenable Prise Sapin - Class: Ewelink *****
[2020-12-10 15:08:45][DEBUG] : ****** Channel:81203815840d8e79fc27 *****
[2020-12-10 15:08:45][DEBUG] : ****** Device listenable Prise Spare2 - Class:Tuya_SW_V2 @192.168.0.189 Channel:81203815840d8e79fc27 *****
[2020-12-10 15:08:45][DEBUG] : Socket created @192.168.0.189
[2020-12-10 15:08:45][DEBUG] : ADD New device @192.168.0.189 channel:81203815840d8e79fc27
[2020-12-10 15:08:45][DEBUG] : Device and socket exist : key:3 @192.168.0.189 channel:81203815840d8e79fc27 diff:0
[2020-12-10 15:08:45][DEBUG] : >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> End <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
[2020-12-10 15:08:45][DEBUG] : Memory used :1818 ko 456 o
[2020-12-10 15:08:45][DEBUG] : Update state @192.168.0.186
[2020-12-10 15:08:45][DEBUG] : Cmd to 192.168.0.186 - Try:192.168.0.186 6668 - Connect OK!
[2020-12-10 15:08:45][DEBUG] : Update other states:
[2020-12-10 15:08:45][DEBUG] : Update state @192.168.0.187
[2020-12-10 15:08:45][DEBUG] : Cmd to 192.168.0.187 - Try:192.168.0.187 6668 - Connect OK!
[2020-12-10 15:08:45][DEBUG] : Update state @192.168.0.184
[2020-12-10 15:08:45][DEBUG] : Cmd to 192.168.0.184 - Try:192.168.0.184 6668 - Connect OK!
[2020-12-10 15:08:45][DEBUG] : Update state @192.168.0.189
[2020-12-10 15:08:45][DEBUG] : Cmd to 192.168.0.189 - Try:192.168.0.189 6668 - Connect OK!
[2020-12-10 15:08:45][DEBUG] : Receive after decode :{"devId":"81203815dc4f22b3c9b1","dps":{"1":false,"9":0}}
[2020-12-10 15:08:45][DEBUG] : Multichanel in state : update all
[2020-12-10 15:08:45][DEBUG] : Multiple device @192.168.0.186 canal:1
[2020-12-10 15:08:45][DEBUG] : CanalDev:1 in MultiC
[2020-12-10 15:08:45][DEBUG] : Found Canal:1 OK
[2020-12-10 15:08:45][DEBUG] : Update other states: - On:0
[2020-12-10 15:08:45][DEBUG] : Receive after decode :{"devId":"60053804600194cb574a","dps":{"1":false,"9":0}}
[2020-12-10 15:08:45][DEBUG] : Device @192.168.0.187 Monocanal:1
[2020-12-10 15:08:45][DEBUG] : Receive after decode :{"devId":"60053804600194cb952f","dps":{"1":true,"9":0}}
[2020-12-10 15:08:45][DEBUG] : Device @192.168.0.184 Monocanal:1
[2020-12-10 15:08:45][DEBUG] : No such device
[2020-12-10 15:08:45][DEBUG] : Receive after decode :{"devId":"81203815840d8e79fc27","dps":{"1":false,"9":0}}
[2020-12-10 15:08:45][DEBUG] : Device @192.168.0.189 Monocanal:1
[2020-12-10 15:08:59][DEBUG] : >>>>search:SwOnOffGet num: v2:On
[2020-12-10 15:08:59][DEBUG] : >>>>search:SwOnOffGet num: v2:Off
[2020-12-10 15:08:59][DEBUG] : >>>>search:On num: v2:Off
[2020-12-10 15:08:59][DEBUG] : Associate act:On with info:SwOnOffGet dps:
[2020-12-10 15:08:59][DEBUG] : Associate act:Off with info:SwOnOffGet dps:
[2020-12-10 15:09:00][DEBUG] : >>>>Daemon Started
[2020-12-10 15:09:00][DEBUG] : Memory used :1673 ko 112 o
[2020-12-10 15:09:00][DEBUG] : >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Search for devices <<<<<<<<<<<<<<<<<<<<<<<<<<<<<
[2020-12-10 15:09:00][DEBUG] : ****** Channel:1 *****
[2020-12-10 15:09:00][DEBUG] : ****** Device listenable Prise Tablette - Class:Tuya_SW_2_V2 @192.168.0.186 Channel:1 *****
[2020-12-10 15:09:00][DEBUG] : Key not set
[2020-12-10 15:09:00][DEBUG] : Socket created @192.168.0.186
[2020-12-10 15:09:00][DEBUG] : ADD New device @192.168.0.186 channel:1
[2020-12-10 15:09:00][DEBUG] : Device and socket exist : key:0 @192.168.0.186 channel:1 diff:0
[2020-12-10 15:09:00][DEBUG] : ****** Device listenable Prise Aquarium - Class:Tuya_SW_2_V2 @192.168.0.187 Channel:1 *****
[2020-12-10 15:09:00][DEBUG] : Socket created @192.168.0.187
[2020-12-10 15:09:00][DEBUG] : ADD New device @192.168.0.187 channel:1
[2020-12-10 15:09:00][DEBUG] : Device and socket exist : key:1 @192.168.0.187 channel:1 diff:0
[2020-12-10 15:09:00][DEBUG] : ****** Device NOT listenable Prise Camera - Class: Ewelink *****
[2020-12-10 15:09:00][DEBUG] : ****** Channel: *****
[2020-12-10 15:09:00][DEBUG] : ****** Channel:60053804600194cb952f *****
[2020-12-10 15:09:00][DEBUG] : ****** Device listenable Prise Raspberry - Class:Tuya_SW_V2 @192.168.0.184 Channel:60053804600194cb952f *****
[2020-12-10 15:09:00][DEBUG] : Socket created @192.168.0.184
[2020-12-10 15:09:00][DEBUG] : ADD New device @192.168.0.184 channel:60053804600194cb952f
[2020-12-10 15:09:00][DEBUG] : Device and socket exist : key:2 @192.168.0.184 channel:60053804600194cb952f diff:0
[2020-12-10 15:09:00][DEBUG] : ****** Device NOT listenable Prise Sapin - Class: Ewelink *****
[2020-12-10 15:09:00][DEBUG] : ****** Channel:81203815840d8e79fc27 *****
[2020-12-10 15:09:00][DEBUG] : ****** Device listenable Prise Spare2 - Class:Tuya_SW_V2 @192.168.0.189 Channel:81203815840d8e79fc27 *****
[2020-12-10 15:09:00][DEBUG] : Socket created @192.168.0.189
[2020-12-10 15:09:00][DEBUG] : ADD New device @192.168.0.189 channel:81203815840d8e79fc27
[2020-12-10 15:09:00][DEBUG] : Device and socket exist : key:3 @192.168.0.189 channel:81203815840d8e79fc27 diff:0
[2020-12-10 15:09:00][DEBUG] : >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> End <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
[2020-12-10 15:09:00][DEBUG] : Memory used :1818 ko 456 o
[2020-12-10 15:09:00][DEBUG] : Update state @192.168.0.186
[2020-12-10 15:09:00][DEBUG] : Cmd to 192.168.0.186 - Try:192.168.0.186 6668 - Connect OK!
[2020-12-10 15:09:00][DEBUG] : Update other states:
[2020-12-10 15:09:00][DEBUG] : Update state @192.168.0.187
[2020-12-10 15:09:00][DEBUG] : Cmd to 192.168.0.187 - Try:192.168.0.187 6668 - Connect OK!
[2020-12-10 15:09:00][DEBUG] : Update state @192.168.0.184
[2020-12-10 15:09:00][DEBUG] : Cmd to 192.168.0.184 - Try:192.168.0.184 6668 - Connect OK!
[2020-12-10 15:09:00][DEBUG] : Update state @192.168.0.189
[2020-12-10 15:09:00][DEBUG] : Cmd to 192.168.0.189 - Try:192.168.0.189 6668 - Connect OK!
[2020-12-10 15:09:00][DEBUG] : Receive after decode :{"devId":"81203815dc4f22b3c9b1","dps":{"1":false,"9":0}}
[2020-12-10 15:09:00][DEBUG] : Multichanel in state : update all
[2020-12-10 15:09:00][DEBUG] : Multiple device @192.168.0.186 canal:1
[2020-12-10 15:09:00][DEBUG] : CanalDev:1 in MultiC
[2020-12-10 15:09:00][DEBUG] : Found Canal:1 OK
[2020-12-10 15:09:00][DEBUG] : Update other states: - On:0
[2020-12-10 15:09:00][DEBUG] : Receive after decode :{"devId":"60053804600194cb574a","dps":{"1":false,"9":0}}
[2020-12-10 15:09:00][DEBUG] : Multiple device @192.168.0.187 canal:1
[2020-12-10 15:09:00][DEBUG] : Receive after decode :{"devId":"60053804600194cb952f","dps":{"1":true,"9":0}}
[2020-12-10 15:09:00][DEBUG] : Device @192.168.0.184 Monocanal:1
[2020-12-10 15:09:00][DEBUG] : No such device
[2020-12-10 15:09:00][DEBUG] : Receive after decode :{"devId":"81203815840d8e79fc27","dps":{"1":false,"9":0}}
[2020-12-10 15:09:00][DEBUG] : Device @192.168.0.189 Monocanal:1
[2020-12-10 15:09:16][DEBUG] : << Ping @192.168.0.186 diff:16
[2020-12-10 15:09:16][DEBUG] : Cmd to 192.168.0.186 - Try:192.168.0.186 6668 - Connect OK!
[2020-12-10 15:09:16][DEBUG] : << Ping @192.168.0.187 diff:16
[2020-12-10 15:09:16][DEBUG] : Cmd to 192.168.0.187 - Try:192.168.0.187 6668 - Connect OK!
[2020-12-10 15:09:16][DEBUG] : << Ping @192.168.0.184 diff:16
[2020-12-10 15:09:16][DEBUG] : Cmd to 192.168.0.184 - Try:192.168.0.184 6668 - Connect OK!
[2020-12-10 15:09:16][DEBUG] : << Ping @192.168.0.189 diff:16
[2020-12-10 15:09:16][DEBUG] : Cmd to 192.168.0.189 - Try:192.168.0.189 6668 - Connect OK!
[2020-12-10 15:09:32][DEBUG] : << Ping @192.168.0.186 diff:16
[2020-12-10 15:09:32][DEBUG] : Cmd to 192.168.0.186 - Try:192.168.0.186 6668 - Connect OK!
[2020-12-10 15:09:32][DEBUG] : << Ping @192.168.0.187 diff:16
[2020-12-10 15:09:32][DEBUG] : Cmd to 192.168.0.187 - Try:192.168.0.187 6668 - Connect OK!
[2020-12-10 15:09:32][DEBUG] : << Ping @192.168.0.184 diff:16
[2020-12-10 15:09:32][DEBUG] : Cmd to 192.168.0.184 - Try:192.168.0.184 6668 - Connect OK!
[2020-12-10 15:09:32][DEBUG] : << Ping @192.168.0.189 diff:16
[2020-12-10 15:09:32][DEBUG] : Cmd to 192.168.0.189 - Try:192.168.0.189 6668 - Connect OK!
