Pour le volets roulants Wifi Teekar Teepao
https://fr.aliexpress.com/item/4000384210012.html?spm=a2g0o.productlist.0.0.23677058J8baEI&algo_pvid=aa87d5c0-9b7b-4a3a-9b8e-6794b5a3f025&algo_expid=aa87d5c0-9b7b-4a3a-9b8e-6794b5a3f025-21&btsid=0b0a0ae216025919895763259ea8fb&ws_ab_test=searchweb0_0,searchweb201602_,searchweb201603_
ou
https://www.amazon.fr/gp/product/B07H9PSQCN/ref=ppx_yo_dt_b_asin_title_o03_s01?ie=UTF8&psc=1
Cela fonctionne
J’ai tenté un paramétrage de mon premier équipement en suivant le paragraphe 15.5 de la documentation:
Voici les logs après jouer la fermeture, l’arrêt et la réouverture du volet roulant:
Receive after decode :q
[2020-10-29 09:42:22][DEBUG] : Receive after decode :{"devId":"76367038f4cfa25407b7","dps":{"1":"close"},"t":1603960942}
[2020-10-29 09:42:22][DEBUG] : dps:
[2020-10-29 09:42:22][DEBUG] : Read Json OK
[2020-10-29 09:42:22][DEBUG] : Tuya Device or Yeelight Bulb
[2020-10-29 09:42:22][DEBUG] : Update state - Dps1:close - Dps1:close - Dps1:close - Dps1:close
[2020-10-29 09:42:30][DEBUG] : Receive after decode :{"devId":"76367038f4cfa25407b7","dps":{"1":"stop"},"t":1603960949}
[2020-10-29 09:42:30][DEBUG] : dps:
[2020-10-29 09:42:30][DEBUG] : Read Json OK
[2020-10-29 09:42:30][DEBUG] : Tuya Device or Yeelight Bulb
[2020-10-29 09:42:30][DEBUG] : Update state - Dps1:stop - Dps1:stop - Dps1:stop - Dps1:stop
[2020-10-29 09:42:34][DEBUG] : << Ping @192.168.0.149 diff:16
[2020-10-29 09:42:34][DEBUG] : Cmd to 192.168.0.149 - Try:192.168.0.149 6668 - Connect OK!
[2020-10-29 09:42:34][DEBUG] : Receive after decode :q
[2020-10-29 09:42:34][DEBUG] : Receive after decode :{"devId":"76367038f4cfa25407b7","dps":{"1":"open"},"t":1603960954}
[2020-10-29 09:42:34][DEBUG] : dps:
[2020-10-29 09:42:34][DEBUG] : Read Json OK
[2020-10-29 09:42:34][DEBUG] : Tuya Device or Yeelight Bulb
[2020-10-29 09:42:34][DEBUG] : Update state - Dps1:open - Dps1:open - Dps1:open - Dps1:open
J’ai ensuite configuré l’équipement dans le plug-in comme suit:
Par contre, lorsque je teste les commandes, j"ai des retours d’état à 0 pour toutes les commandes, le volet ne bouge pas et pas plus de traces dans ce cas dans les logs du plug-in:
2020-10-29 09:51:11][DEBUG] : >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Search for devices <<<<<<<<<<<<<<<<<<<<<<<<<<<<<
[2020-10-29 09:51:11][DEBUG] : ****** Device listenable Volet roulant Salon petite baie - Class:TuyaCustom_V2 @192.168.0.149Chanel:1 *****
[2020-10-29 09:51:11][DEBUG] : Device and socket exist : key:0 @192.168.0.149 channel:1 diff:4
[2020-10-29 09:51:11][DEBUG] : >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> End <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
[2020-10-29 09:51:11][DEBUG] : Memory used :2337 ko 128 o
[2020-10-29 09:51:23][DEBUG] : << Ping @192.168.0.149 diff:16
[2020-10-29 09:51:23][DEBUG] : Cmd to 192.168.0.149 - Try:192.168.0.149 6668 - Connect OK!
[2020-10-29 09:51:23][DEBUG] : Receive after decode :q
[2020-10-29 09:51:39][DEBUG] : << Ping @192.168.0.149 diff:16
[2020-10-29 09:51:39][DEBUG] : Cmd to 192.168.0.149 - Try:192.168.0.149 6668 - Connect OK!
[2020-10-29 09:51:39][DEBUG] : Receive after decode :q
[2020-10-29 09:51:55][DEBUG] : << Ping @192.168.0.149 diff:16
[2020-10-29 09:51:55][DEBUG] : Cmd to 192.168.0.149 - Try:192.168.0.149 6668 - Connect OK!
[2020-10-29 09:51:55][DEBUG] : Receive after decode :q
[2020-10-29 09:52:11][DEBUG] : << Ping @192.168.0.149 diff:16
[2020-10-29 09:52:11][DEBUG] : Cmd to 192.168.0.149 - Try:192.168.0.149 6668 - Connect OK!
[2020-10-29 09:52:11][DEBUG] : Receive after decode :q
[2020-10-29 09:52:12][DEBUG] : >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Search for devices <<<<<<<<<<<<<<<<<<<<<<<<<<<<<
[2020-10-29 09:52:12][DEBUG] : ****** Device listenable Volet roulant Salon petite baie - Class:TuyaCustom_V2 @192.168.0.149Chanel:1 *****
[2020-10-29 09:52:12][DEBUG] : Device and socket exist : key:0 @192.168.0.149 channel:1 diff:1
[2020-10-29 09:52:12][DEBUG] : >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> End <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
[2020-10-29 09:52:12][DEBUG] : Memory used :2337 ko 128 o
[2020-10-29 09:52:27][DEBUG] : << Ping @192.168.0.149 diff:16
[2020-10-29 09:52:27][DEBUG] : Cmd to 192.168.0.149 - Try:192.168.0.149 6668 - Connect OK!
[2020-10-29 09:52:27][DEBUG] : Receive after decode :q
Une idée?
Merci d’avance
EDIT: erreur, j"ai voulu trop suivre à la lettre la documentation.
les commandes internes sont close et open pour mon équipement et pas on et off.
que dois-je mettre dans le paramètre Id unique?
CLOSE et OPEN? ou je laisse ON et OOF comme nom de commande interne?
Je retrouve régulièrement dans les logs la ligne qui apparait j’imagine lorsque le plug-in souhaite récupéré l’état du périphérique:
Receive after decode :{"devId":"76367038f4cfa25407b7","dps":{"1":"stop","101":false,"102":false,"103":true}}
Je crois comprendre la signification du premier retour « 1 »:« stop » qui remonte l’état ou la dernière commande?
Mais à quoi correspondent les 3 retours suivants?
My bad encore, je n’avais pas mis les action en type Action, elles étaient restées en info…
J’ai maintenant ces traces dans les logs:
2020-10-29 10:19:09][DEBUG] : Cmd to 127.0.0.1: {"t":"1603963149","devId":"76367038f4cfa25407b7","dps":{"1":"close"},"uid":""} - Try:127.0.0.1 6900 - Time out - socket_connect failed: Connection refused
[2020-10-29 10:19:20][DEBUG] : Cmd to 127.0.0.1: {"t":"1603963160","devId":"76367038f4cfa25407b7","dps":{"1":"stop"},"uid":""} - Try:127.0.0.1 6900 - Time out - socket_connect failed: Connection refused
Ok c’est juste que le démon n’était pas redémarré
Cmd to 127.0.0.1: {"t":"1603963243","devId":"76367038f4cfa25407b7","dps":{"1":"close"},"uid":""} - Try:127.0.0.1 6900 - Connect OK!
[2020-10-29 10:20:55][DEBUG] : Cmd to 127.0.0.1: {"t":"1603963255","devId":"76367038f4cfa25407b7","dps":{"1":"stop"},"uid":""} - Try:127.0.0.1 6900 - Connect OK!
C’est bon cela marche!!
[2020-10-29 10:23:04][DEBUG] : Receive after decode :{"devId":"76367038f4cfa25407b7","dps":{"1":"stop"},"t":1603963383}
[2020-10-29 10:23:04][DEBUG] : dps:
[2020-10-29 10:23:04][DEBUG] : Read Json OK
[2020-10-29 10:23:04][DEBUG] : Tuya Device or Yeelight Bulb
[2020-10-29 10:23:04][DEBUG] : Update state - Dps1:stop
[2020-10-29 10:23:05][DEBUG] : << Ping @192.168.0.149 diff:16
[2020-10-29 10:23:05][DEBUG] : Cmd to 192.168.0.149 - Try:192.168.0.149 6668 - Connect OK!
[2020-10-29 10:23:05][DEBUG] : Receive after decode :q
[2020-10-29 10:23:10][DEBUG] : Cmd to 127.0.0.1: {"t":"1603963390","devId":"76367038f4cfa25407b7","dps":{"1":"open"},"uid":""} - Try:127.0.0.1 6900 - Connect OK!
[2020-10-29 10:23:10][DEBUG] : Cmd to 192.168.0.149 - Try:192.168.0.149 6668 - Connect OK!
[2020-10-29 10:23:10][DEBUG] : No state update
[2020-10-29 10:23:10][DEBUG] : Receive after decode :q
[2020-10-29 10:23:10][DEBUG] : Receive after decode :{"devId":"76367038f4cfa25407b7","dps":{"1":"open"},"t":1603963390}
Attention pour les commandes de volet roulant Teekar Teepao de 3ième génération (et non 4ième comme l’exemple ci-dessus) ont les commandes « on » et « off » au lieu de « open » et « close »
Je vais pouvoir géréraliser à mes autres volets roulants!
Merci pour ce plug-in
