* Installation des dépendances *
--2020-03-22 12:40:11-- https://repository.salamek.cz/deb/salamek.gpg.key
Résolution de repository.salamek.cz (repository.salamek.cz)… 78.80.161.207
Connexion à repository.salamek.cz (repository.salamek.cz)|78.80.161.207|:443… Warning: apt-key output should not be parsed (stdout is not a terminal)
connecté.
requête HTTP transmise, en attente de la réponse… 200 OK
Taille : 1715 (1.7K) [application/octet-stream]
Sauvegarde en : « STDOUT »
0K . 100% 43.4M=0s
2020-03-22 12:40:12 (43.4 MB/s) — envoi vers sortie standard [1715/1715]
OK
deb https://repository.salamek.cz/deb/pub all main
Atteint :1 http://httpredir.debian.org/debian buster InRelease
Réception de :3 http://security.debian.org buster/updates InRelease [65.4 kB]
Réception de :4 http://httpredir.debian.org/debian buster-updates InRelease [49.3 kB]
Atteint :5 https://deb.nodesource.com/node_12.x buster InRelease
Réception de :6 https://repository.salamek.cz/deb/pub all InRelease [2940 B]
Réception de :7 http://httpredir.debian.org/debian buster-backports InRelease [46.7 kB]
Réception de :2 https://apt.armbian.com buster InRelease [18.3 kB]
Réception de :8 https://repository.salamek.cz/deb/pub all/main armhf Packages [10.7 kB]
Réception de :9 http://httpredir.debian.org/debian buster-backports/main arm64 Packages.diff/Index [27.8 kB]
Réception de :10 http://httpredir.debian.org/debian buster-backports/main armhf Packages.diff/Index [27.8 kB]
Réception de :11 http://httpredir.debian.org/debian buster-backports/main arm64 Packages 2020-03-21-2021.59.pdiff [405 B]
Réception de :12 http://httpredir.debian.org/debian buster-backports/main armhf Packages 2020-03-21-2021.59.pdiff [414 B]
Réception de :13 https://apt.armbian.com buster/main armhf Packages [127 kB]
Réception de :14 https://apt.armbian.com buster/main arm64 Packages [127 kB]
Réception de :15 https://apt.armbian.com buster/main arm64 Contents (deb) [5255 kB]
Réception de :16 https://apt.armbian.com buster/main armhf Contents (deb) [6009 kB]
11.8 Mo réceptionnés en 19s (631 ko/s)
Lecture des listes de paquets…
Construction de l'arbre des dépendances…
Lecture des informations d'état…
4 paquets peuvent être mis à jour. Exécutez « apt list --upgradable » pour les voir.
Les paquets supplémentaires suivants seront installés :
python3-dicttoxml python3-xmltodict
Les NOUVEAUX paquets suivants seront installés :
python3-dicttoxml python3-huawei-lte-api python3-xmltodict
0 mis à jour, 3 nouvellement installés, 0 à enlever et 4 non mis à jour.
Il est nécessaire de prendre 44.6 ko dans les archives.
Après cette opération, 258 ko d'espace disque supplémentaires seront utilisés.
Souhaitez-vous continuer ? [O/n] Annulation.
* Installation terminée *
après avoir install les dépendance a la mano :
--2020-03-22 13:08:33-- https://repository.salamek.cz/deb/salamek.gpg.key
Connexion à repository.salamek.cz (repository.salamek.cz)|78.80.161.207|:443… connecté.
0K . 100% 44.7M=0s
2020-03-22 13:08:34 (44.7 MB/s) — envoi vers sortie standard [1715/1715]
OK
Atteint :2 http://security.debian.org buster/updates InRelease
Atteint :4 http://httpredir.debian.org/debian buster-updates InRelease
Atteint :5 http://httpredir.debian.org/debian buster-backports InRelease
Atteint :6 https://deb.nodesource.com/node_12.x buster InRelease
Atteint :7 https://repository.salamek.cz/deb/pub all InRelease
Atteint :3 https://apt.armbian.com buster InRelease
python3-huawei-lte-api est déjà la version la plus récente (1.4.11-1).
0 mis à jour, 0 nouvellement installés, 0 à enlever et 4 non mis à jour.
[2020-03-22 13:10:28][DEBUG] : tableau from JSON: Array
[2020-03-22 13:10:29][DEBUG] : ['{"password_type": "4", "extern_password_type": "1", "history_login_flag": "0", "State": "0", "lockstatus": "0", "password_rule": "0", "accounts_number": "1", "rsapadingtype": "1", "remainwaittime": "0", "wifipwdsamewithwebpwd": "0", "Username": "admin", "firstlogin": "1", "userlevel": "2"}', '{"CurrentConnectTime": "71798", "CurrentUpload": "959792790", "CurrentDownload": "32744890632", "CurrentDownloadRate": "15764", "CurrentUploadRate": "14109", "TotalUpload": "11180109021", "TotalDownload": "408044801726", "TotalConnectTime": "848069", "showtraffic": "1"}', '{"State": "0", "FullName": "Bouygues Telecom", "ShortName": "Bouygues Telecom", "Numeric": "20820", "Rat": "7", "Spn": null}', '{"productfamily": "LTE", "classify": "cpe", "multimode": "0", "restore_default_status": "0", "sim_save_pin_enable": "2", "devicename": "B528s-23a", "SoftwareVersion": "81.195.03.00.309", "WebUIVersion": "81.100.33.00.309", "iniversion": "B528s-23aCUST-B00C309", "spreadname_en": null, "spreadname_zh": null}', '{"DeviceName": "B528s-23a", "SerialNumber": "DNLDW19220001530", "Imei": "863769036974927", "Imsi": "208201010368182", "Iccid": "8933201019103681822", "Msisdn": null, "HardwareVersion": "WL1B520FM02", "SoftwareVersion": "81.195.03.00.309", "WebUIVersion": "81.100.33.00.309", "MacAddress1": "DC:90:88:1E:19:7D", "MacAddress2": null, "WanIPAddress": "89.83.254.189", "wan_dns_address": "62.201.129.99,62.201.159.99", "WanIPv6Address": null, "wan_ipv6_dns_address": null, "ProductFamily": "LTE", "Classify": "cpe", "supportmode": "LTE|WCDMA|GSM", "workmode": "LTE", "submask": "255.255.255.255", "Mccmnc": "20820", "iniversion": "B528s-23aCUST-B00C309", "uptime": "158218", "ImeiSvn": "01", "WifiMacAddrWl0": "DC:90:88:1E:19:7E", "WifiMacAddrWl1": "DC:90:88:1E:19:80", "spreadname_en": null, "spreadname_zh": null}', '{"pci": "351", "sc": null, "cell_id": "157550860", "rsrq": "-13.0dB", "rsrp": "-103dBm", "rssi": "-69dBm", "sinr": "3dB", "rscp": null, "ecio": null, "mode": "7", "ulbandwidth": "20MHz", "dlbandwidth": "20MHz", "txpower": "PPusch:21dBm PPucch:3dBm PSrs:23dBm PPrach:17dBm", "tdd": null, "ul_mcs": "mcsUpCarrier1:17", "dl_mcs": "mcsDownCarrier1Code0:18 mcsDownCarrier1Code1:9", "earfcn": "DL:1850 UL:19850", "rrc_status": "1", "rac": null, "lac": null, "tac": "59205", "band": "3", "nei_cellid": "No1:352", "plmn": "20820", "ims": "0", "wdlfreq": null, "lteulfreq": "17750", "ltedlfreq": "18700", "transmode": "TM[4]", "enodeb_id": "0615433", "cqi0": "6", "cqi1": "7", "ulfrequency": "1775000kHz", "dlfrequency": "1870000kHz", "arfcn": null, "bsic": null, "rxlev": null}', {'get_sms_list()': 'Not supported'}]
[2020-03-22 13:10:29][DEBUG] : PreOutput:
[2020-03-22 13:10:29][DEBUG] : PostOutput:
[2020-03-22 13:10:29][DEBUG] : 0: {"password_type": "4", "extern_password_type": "1", "history_login_flag": "0", "State": "0", "lockstatus": "0", "password_rule": "0", "accounts_number": "1", "rsapadingtype": "1", "remainwaittime": "0", "wifipwdsamewithwebpwd": "0", "Username": "admin", "firstlogin": "1", "userlevel": "2"}
[2020-03-22 13:10:29][DEBUG] : - Aucune erreur
[2020-03-22 13:10:29][DEBUG] : 1: {"CurrentConnectTime": "71798", "CurrentUpload": "959792790", "CurrentDownload": "32744890632", "CurrentDownloadRate": "15764", "CurrentUploadRate": "14109", "TotalUpload": "11180109021", "TotalDownload": "408044801726", "TotalConnectTime": "848069", "showtraffic": "1"}
[2020-03-22 13:10:29][DEBUG] : 2: {"State": "0", "FullName": "Bouygues Telecom", "ShortName": "Bouygues Telecom", "Numeric": "20820", "Rat": "7", "Spn": null}
[2020-03-22 13:10:29][DEBUG] : 3: {"productfamily": "LTE", "classify": "cpe", "multimode": "0", "restore_default_status": "0", "sim_save_pin_enable": "2", "devicename": "B528s-23a", "SoftwareVersion": "81.195.03.00.309", "WebUIVersion": "81.100.33.00.309", "iniversion": "B528s-23aCUST-B00C309", "spreadname_en": null, "spreadname_zh": null}
[2020-03-22 13:10:29][DEBUG] : 4: {"DeviceName": "B528s-23a", "SerialNumber": "DNLDW19220001530", "Imei": "863769036974927", "Imsi": "208201010368182", "Iccid": "8933201019103681822", "Msisdn": null, "HardwareVersion": "WL1B520FM02", "SoftwareVersion": "81.195.03.00.309", "WebUIVersion": "81.100.33.00.309", "MacAddress1": "DC:90:88:1E:19:7D", "MacAddress2": null, "WanIPAddress": "89.83.254.189", "wan_dns_address": "62.201.129.99,62.201.159.99", "WanIPv6Address": null, "wan_ipv6_dns_address": null, "ProductFamily": "LTE", "Classify": "cpe", "supportmode": "LTE|WCDMA|GSM", "workmode": "LTE", "submask": "255.255.255.255", "Mccmnc": "20820", "iniversion": "B528s-23aCUST-B00C309", "uptime": "158218", "ImeiSvn": "01", "WifiMacAddrWl0": "DC:90:88:1E:19:7E", "WifiMacAddrWl1": "DC:90:88:1E:19:80", "spreadname_en": null, "spreadname_zh": null}
[2020-03-22 13:10:29][DEBUG] : 5: {"pci": "351", "sc": null, "cell_id": "157550860", "rsrq": "-13.0dB", "rsrp": "-103dBm", "rssi": "-69dBm", "sinr": "3dB", "rscp": null, "ecio": null, "mode": "7", "ulbandwidth": "20MHz", "dlbandwidth": "20MHz", "txpower": "PPusch:21dBm PPucch:3dBm PSrs:23dBm PPrach:17dBm", "tdd": null, "ul_mcs": "mcsUpCarrier1:17", "dl_mcs": "mcsDownCarrier1Code0:18 mcsDownCarrier1Code1:9", "earfcn": "DL:1850 UL:19850", "rrc_status": "1", "rac": null, "lac": null, "tac": "59205", "band": "3", "nei_cellid": "No1:352", "plmn": "20820", "ims": "0", "wdlfreq": null, "lteulfreq": "17750", "ltedlfreq": "18700", "transmode": "TM[4]", "enodeb_id": "0615433", "cqi0": "6", "cqi1": "7", "ulfrequency": "1775000kHz", "dlfrequency": "1870000kHz", "arfcn": null, "bsic": null, "rxlev": null}', {'get_sms_list()': 'Not supported'}
[2020-03-22 13:10:29][DEBUG] : - Erreur de syntaxe ; JSON malformé
[2020-03-22 13:10:29][DEBUG] : State: 0
[2020-03-22 13:10:29][DEBUG] : Up
[2020-03-22 13:10:29][DEBUG] : key:CurrentConnectTime value:71798
[2020-03-22 13:10:29][DEBUG] : key:CurrentUpload value:959792790
[2020-03-22 13:10:29][DEBUG] : key:CurrentDownload value:32744890632
[2020-03-22 13:10:29][DEBUG] : key:CurrentDownloadRate value:15764
[2020-03-22 13:10:29][DEBUG] : key:CurrentUploadRate value:14109
[2020-03-22 13:10:29][DEBUG] : key:TotalUpload value:11180109021
[2020-03-22 13:10:29][DEBUG] : key:TotalDownload value:408044801726
[2020-03-22 13:10:29][DEBUG] : key:TotalConnectTime value:848069
[2020-03-22 13:10:29][DEBUG] : key:showtraffic value:1
[2020-03-22 13:10:29][DEBUG] : key:State value:0
[2020-03-22 13:10:29][DEBUG] : key:FullName value:Bouygues Telecom
[2020-03-22 13:10:29][DEBUG] : key:ShortName value:Bouygues Telecom
[2020-03-22 13:10:29][DEBUG] : key:Numeric value:20820
[2020-03-22 13:10:29][DEBUG] : key:Rat value:7
[2020-03-22 13:10:29][DEBUG] : key:Spn value:
[2020-03-22 13:10:29][DEBUG] : key:productfamily value:LTE
[2020-03-22 13:10:29][DEBUG] : key:classify value:cpe
[2020-03-22 13:10:29][DEBUG] : key:multimode value:0
[2020-03-22 13:10:29][DEBUG] : key:restore_default_status value:0
[2020-03-22 13:10:29][DEBUG] : key:sim_save_pin_enable value:2
[2020-03-22 13:10:29][DEBUG] : key:devicename value:B528s-23a
[2020-03-22 13:10:29][DEBUG] : key:SoftwareVersion value:81.195.03.00.309
[2020-03-22 13:10:29][DEBUG] : key:WebUIVersion value:81.100.33.00.309
[2020-03-22 13:10:29][DEBUG] : key:iniversion value:B528s-23aCUST-B00C309
[2020-03-22 13:10:29][DEBUG] : key:spreadname_en value:
[2020-03-22 13:10:29][DEBUG] : key:spreadname_zh value:
[2020-03-22 13:10:29][DEBUG] : key:DeviceName value:B528s-23a
[2020-03-22 13:10:29][DEBUG] : key:SerialNumber value:DNLDW19220001530
[2020-03-22 13:10:29][DEBUG] : key:Imei value:863769036974927
[2020-03-22 13:10:29][DEBUG] : key:Imsi value:208201010368182
[2020-03-22 13:10:29][DEBUG] : key:Iccid value:8933201019103681822
[2020-03-22 13:10:29][DEBUG] : key:Msisdn value:
[2020-03-22 13:10:29][DEBUG] : key:HardwareVersion value:WL1B520FM02
[2020-03-22 13:10:29][DEBUG] : key:MacAddress1 value:DC:90:88:1E:19:7D
[2020-03-22 13:10:29][DEBUG] : key:MacAddress2 value:
[2020-03-22 13:10:29][DEBUG] : key:WanIPAddress value:89.83.254.189
[2020-03-22 13:10:29][DEBUG] : key:wan_dns_address value:62.201.129.99,62.201.159.99
[2020-03-22 13:10:29][DEBUG] : key:WanIPv6Address value:
[2020-03-22 13:10:29][DEBUG] : key:wan_ipv6_dns_address value:
[2020-03-22 13:10:29][DEBUG] : key:ProductFamily value:LTE
[2020-03-22 13:10:29][DEBUG] : key:Classify value:cpe
[2020-03-22 13:10:29][DEBUG] : key:supportmode value:LTE|WCDMA|GSM
[2020-03-22 13:10:29][DEBUG] : key:workmode value:LTE
[2020-03-22 13:10:29][DEBUG] : key:submask value:255.255.255.255
[2020-03-22 13:10:29][DEBUG] : key:Mccmnc value:20820
[2020-03-22 13:10:29][DEBUG] : key:uptime value:158218
[2020-03-22 13:10:29][DEBUG] : key:ImeiSvn value:01
[2020-03-22 13:10:29][DEBUG] : key:WifiMacAddrWl0 value:DC:90:88:1E:19:7E
[2020-03-22 13:10:29][DEBUG] : key:WifiMacAddrWl1 value:DC:90:88:1E:19:80
[2020-03-22 13:10:29][DEBUG] : function setInfo has a NULL parameter
[2020-03-22 13:10:29][DEBUG] : freq band:
[2020-03-22 13:10:29][DEBUG] : liste: Array
[2020-03-22 13:10:29][DEBUG] : jsonKey:
[2020-03-22 13:10:29][DEBUG] : Freq Name: FDD 2100
[2020-03-22 13:10:29][DEBUG] : freq ndl:
[2020-03-22 13:10:29][DEBUG] : freq nul:
[2020-03-22 13:10:29][DEBUG] : NDL_Off: 0
[2020-03-22 13:10:29][DEBUG] : FDL_Low: 2110
[2020-03-22 13:10:29][DEBUG] : NUL_Off: 18000
[2020-03-22 13:10:29][DEBUG] : FUL_Low: 1920
[2020-03-22 13:10:29][DEBUG] : key FullName valeur Bouygues Telecom
[2020-03-22 13:10:29][DEBUG] : key status valeur Up
[2020-03-22 13:10:29][DEBUG] : key CurrentConnectTime valeur 71798
[2020-03-22 13:10:29][DEBUG] : key CurrentDownloadRate valeur 15764
[2020-03-22 13:10:29][DEBUG] : key CurrentUploadRate valeur 14109
[2020-03-22 13:10:29][DEBUG] : key CurrentDownload valeur 32744890632
[2020-03-22 13:10:29][DEBUG] : key CurrentUpload valeur 959792790
[2020-03-22 13:10:29][DEBUG] : key TotalConnectTime valeur 848069
[2020-03-22 13:10:29][DEBUG] : key devicename valeur B528s-23a
[2020-03-22 13:10:29][DEBUG] : key TotalDownload valeur 408044801726
[2020-03-22 13:10:29][DEBUG] : key TotalUpload valeur 11180109021
[2020-03-22 13:10:29][DEBUG] : key SoftwareVersion valeur 81.195.03.00.309
[2020-03-22 13:10:29][DEBUG] : key WanIPAddress valeur 89.83.254.189
[2020-03-22 13:10:29][DEBUG] : key cell_id valeur
[2020-03-22 13:10:29][DEBUG] : key rsrp valeur
[2020-03-22 13:10:29][DEBUG] : key rssi valeur
[2020-03-22 13:10:29][DEBUG] : key WebUIVersion valeur 81.100.33.00.309
[2020-03-22 13:10:29][DEBUG] : key Imei valeur 863769036974927
[2020-03-22 13:10:29][DEBUG] : key sinr valeur
[2020-03-22 13:10:29][DEBUG] : key frq valeur FDD 2100
[2020-03-22 13:10:29][DEBUG] : key fdl valeur 2110
[2020-03-22 13:10:29][DEBUG] : key ful valeur 120
[2020-03-22 13:10:29][DEBUG] : key workmode valeur LTE
[2020-03-22 13:10:29][DEBUG] : key Msisdn valeur
[2020-03-22 13:10:29][DEBUG] : key Count valeur
[2020-03-22 13:10:29][DEBUG] : key Messages valeur
[2020-03-22 13:10:29][DEBUG] : refresh [Information][BBOX][Rafraîchir]
