du coup , Logs plugins :
[2020-03-21 09:30:03][DEBUG] : tableau from JSON: Array
[2020-03-21 09:30:04][DEBUG] : ['{"password_type": "4", "extern_password_type": "1", "history_login_flag": "0", "State": "0", "lockstatus": "0", "password_rule": "0", "accounts_number": "1", "rsapadingtype": "1", "remainwaittime": "0", "wifipwdsamewithwebpwd": "0", "Username": "admin", "firstlogin": "1", "userlevel": "2"}', '{"CurrentConnectTime": "58574", "CurrentUpload": "591821779", "CurrentDownload": "12627917145", "CurrentDownloadRate": "216", "CurrentUploadRate": "271", "TotalUpload": "9645986284", "TotalDownload": "357909130705", "TotalConnectTime": "748447", "showtraffic": "1"}', '{"State": "0", "FullName": "Bouygues Telecom", "ShortName": "Bouygues Telecom", "Numeric": "20820", "Rat": "7", "Spn": null}', '{"productfamily": "LTE", "classify": "cpe", "multimode": "0", "restore_default_status": "0", "sim_save_pin_enable": "2", "devicename": "B528s-23a", "SoftwareVersion": "81.195.03.00.309", "WebUIVersion": "81.100.33.00.309", "iniversion": "B528s-23aCUST-B00C309", "spreadname_en": null, "spreadname_zh": null}', '{"DeviceName": "B528s-23a", "SerialNumber": "DNLDW19220001530", "Imei": "863769036974927", "Imsi": "208201010368182", "Iccid": "8933201019103681822", "Msisdn": null, "HardwareVersion": "WL1B520FM02", "SoftwareVersion": "81.195.03.00.309", "WebUIVersion": "81.100.33.00.309", "MacAddress1": "DC:90:88:1E:19:7D", "MacAddress2": null, "WanIPAddress": "176.177.126.175", "wan_dns_address": "62.201.129.99,62.201.159.99", "WanIPv6Address": null, "wan_ipv6_dns_address": null, "ProductFamily": "LTE", "Classify": "cpe", "supportmode": "LTE|WCDMA|GSM", "workmode": "LTE", "submask": "255.255.255.255", "Mccmnc": "20820", "iniversion": "B528s-23aCUST-B00C309", "uptime": "58594", "ImeiSvn": "01", "WifiMacAddrWl0": "DC:90:88:1E:19:7E", "WifiMacAddrWl1": "DC:90:88:1E:19:80", "spreadname_en": null, "spreadname_zh": null}', '{"pci": "351", "sc": null, "cell_id": "157550860", "rsrq": "-8.0dB", "rsrp": "-102dBm", "rssi": "-73dBm", "sinr": "5dB", "rscp": null, "ecio": null, "mode": "7", "ulbandwidth": "20MHz", "dlbandwidth": "20MHz", "txpower": "PPusch:21dBm PPucch:0dBm PSrs:23dBm PPrach:16dBm", "tdd": null, "ul_mcs": "mcsUpCarrier1:17", "dl_mcs": "mcsDownCarrier1Code0:2 mcsDownCarrier1Code1:13", "earfcn": "DL:1850 UL:19850", "rrc_status": "1", "rac": null, "lac": null, "tac": "59205", "band": "3", "nei_cellid": "No1:352", "plmn": "20820", "ims": "0", "wdlfreq": null, "lteulfreq": "17750", "ltedlfreq": "18700", "transmode": "TM[4]", "enodeb_id": "0615433", "cqi0": "11", "cqi1": "127", "ulfrequency": "1775000kHz", "dlfrequency": "1870000kHz", "arfcn": null, "bsic": null, "rxlev": null}', (<class 'huawei_lte_api.exceptions.ResponseErrorNotSupportedException'>, ResponseErrorNotSupportedException('100002: No support'), <traceback object at 0xffff9370e448>)]
[2020-03-21 09:30:04][DEBUG] : PreOutput:
[2020-03-21 09:30:04][DEBUG] : PostOutput:
[2020-03-21 09:30:04][DEBUG] : 0: {"password_type": "4", "extern_password_type": "1", "history_login_flag": "0", "State": "0", "lockstatus": "0", "password_rule": "0", "accounts_number": "1", "rsapadingtype": "1", "remainwaittime": "0", "wifipwdsamewithwebpwd": "0", "Username": "admin", "firstlogin": "1", "userlevel": "2"}
[2020-03-21 09:30:04][DEBUG] : - Aucune erreur
[2020-03-21 09:30:04][DEBUG] : 1: {"CurrentConnectTime": "58574", "CurrentUpload": "591821779", "CurrentDownload": "12627917145", "CurrentDownloadRate": "216", "CurrentUploadRate": "271", "TotalUpload": "9645986284", "TotalDownload": "357909130705", "TotalConnectTime": "748447", "showtraffic": "1"}
[2020-03-21 09:30:04][DEBUG] : 2: {"State": "0", "FullName": "Bouygues Telecom", "ShortName": "Bouygues Telecom", "Numeric": "20820", "Rat": "7", "Spn": null}
[2020-03-21 09:30:04][DEBUG] : 3: {"productfamily": "LTE", "classify": "cpe", "multimode": "0", "restore_default_status": "0", "sim_save_pin_enable": "2", "devicename": "B528s-23a", "SoftwareVersion": "81.195.03.00.309", "WebUIVersion": "81.100.33.00.309", "iniversion": "B528s-23aCUST-B00C309", "spreadname_en": null, "spreadname_zh": null}
[2020-03-21 09:30:04][DEBUG] : 4: {"DeviceName": "B528s-23a", "SerialNumber": "DNLDW19220001530", "Imei": "863769036974927", "Imsi": "208201010368182", "Iccid": "8933201019103681822", "Msisdn": null, "HardwareVersion": "WL1B520FM02", "SoftwareVersion": "81.195.03.00.309", "WebUIVersion": "81.100.33.00.309", "MacAddress1": "DC:90:88:1E:19:7D", "MacAddress2": null, "WanIPAddress": "176.177.126.175", "wan_dns_address": "62.201.129.99,62.201.159.99", "WanIPv6Address": null, "wan_ipv6_dns_address": null, "ProductFamily": "LTE", "Classify": "cpe", "supportmode": "LTE|WCDMA|GSM", "workmode": "LTE", "submask": "255.255.255.255", "Mccmnc": "20820", "iniversion": "B528s-23aCUST-B00C309", "uptime": "58594", "ImeiSvn": "01", "WifiMacAddrWl0": "DC:90:88:1E:19:7E", "WifiMacAddrWl1": "DC:90:88:1E:19:80", "spreadname_en": null, "spreadname_zh": null}
[2020-03-21 09:30:04][DEBUG] : 5: {"pci": "351", "sc": null, "cell_id": "157550860", "rsrq": "-8.0dB", "rsrp": "-102dBm", "rssi": "-73dBm", "sinr": "5dB", "rscp": null, "ecio": null, "mode": "7", "ulbandwidth": "20MHz", "dlbandwidth": "20MHz", "txpower": "PPusch:21dBm PPucch:0dBm PSrs:23dBm PPrach:16dBm", "tdd": null, "ul_mcs": "mcsUpCarrier1:17", "dl_mcs": "mcsDownCarrier1Code0:2 mcsDownCarrier1Code1:13", "earfcn": "DL:1850 UL:19850", "rrc_status": "1", "rac": null, "lac": null, "tac": "59205", "band": "3", "nei_cellid": "No1:352", "plmn": "20820", "ims": "0", "wdlfreq": null, "lteulfreq": "17750", "ltedlfreq": "18700", "transmode": "TM[4]", "enodeb_id": "0615433", "cqi0": "11", "cqi1": "127", "ulfrequency": "1775000kHz", "dlfrequency": "1870000kHz", "arfcn": null, "bsic": null, "rxlev": null}', (<class 'huawei_lte_api.exceptions.ResponseErrorNotSupportedException'>, ResponseErrorNotSupportedException('100002: No support'), <traceback object at 0xffff9370e448>}
[2020-03-21 09:30:04][DEBUG] : - Erreur de syntaxe ; JSON malformé
[2020-03-21 09:30:04][DEBUG] : State: 0
[2020-03-21 09:30:04][DEBUG] : Up
[2020-03-21 09:30:04][DEBUG] : key:CurrentConnectTime value:58574
[2020-03-21 09:30:04][DEBUG] : key:CurrentUpload value:591821779
[2020-03-21 09:30:04][DEBUG] : key:CurrentDownload value:12627917145
[2020-03-21 09:30:04][DEBUG] : key:CurrentDownloadRate value:216
[2020-03-21 09:30:04][DEBUG] : key:CurrentUploadRate value:271
[2020-03-21 09:30:04][DEBUG] : key:TotalUpload value:9645986284
[2020-03-21 09:30:04][DEBUG] : key:TotalDownload value:357909130705
[2020-03-21 09:30:04][DEBUG] : key:TotalConnectTime value:748447
[2020-03-21 09:30:04][DEBUG] : key:showtraffic value:1
[2020-03-21 09:30:04][DEBUG] : key:State value:0
[2020-03-21 09:30:04][DEBUG] : key:FullName value:Bouygues Telecom
[2020-03-21 09:30:04][DEBUG] : key:ShortName value:Bouygues Telecom
[2020-03-21 09:30:04][DEBUG] : key:Numeric value:20820
[2020-03-21 09:30:04][DEBUG] : key:Rat value:7
[2020-03-21 09:30:04][DEBUG] : key:Spn value:
[2020-03-21 09:30:04][DEBUG] : key:productfamily value:LTE
[2020-03-21 09:30:04][DEBUG] : key:classify value:cpe
[2020-03-21 09:30:04][DEBUG] : key:multimode value:0
[2020-03-21 09:30:04][DEBUG] : key:restore_default_status value:0
[2020-03-21 09:30:04][DEBUG] : key:sim_save_pin_enable value:2
[2020-03-21 09:30:04][DEBUG] : key:devicename value:B528s-23a
[2020-03-21 09:30:04][DEBUG] : key:SoftwareVersion value:81.195.03.00.309
[2020-03-21 09:30:04][DEBUG] : key:WebUIVersion value:81.100.33.00.309
[2020-03-21 09:30:04][DEBUG] : key:iniversion value:B528s-23aCUST-B00C309
[2020-03-21 09:30:04][DEBUG] : key:spreadname_en value:
[2020-03-21 09:30:04][DEBUG] : key:spreadname_zh value:
[2020-03-21 09:30:04][DEBUG] : key:DeviceName value:B528s-23a
[2020-03-21 09:30:04][DEBUG] : key:SerialNumber value:DNLDW19220001530
[2020-03-21 09:30:04][DEBUG] : key:Imei value:863769036974927
[2020-03-21 09:30:04][DEBUG] : key:Imsi value:208201010368182
[2020-03-21 09:30:04][DEBUG] : key:Iccid value:8933201019103681822
[2020-03-21 09:30:04][DEBUG] : key:Msisdn value:
[2020-03-21 09:30:04][DEBUG] : key:HardwareVersion value:WL1B520FM02
[2020-03-21 09:30:04][DEBUG] : key:MacAddress1 value:DC:90:88:1E:19:7D
[2020-03-21 09:30:04][DEBUG] : key:MacAddress2 value:
[2020-03-21 09:30:04][DEBUG] : key:WanIPAddress value:176.177.126.175
[2020-03-21 09:30:04][DEBUG] : key:wan_dns_address value:62.201.129.99,62.201.159.99
[2020-03-21 09:30:04][DEBUG] : key:WanIPv6Address value:
[2020-03-21 09:30:04][DEBUG] : key:wan_ipv6_dns_address value:
[2020-03-21 09:30:04][DEBUG] : key:ProductFamily value:LTE
[2020-03-21 09:30:04][DEBUG] : key:Classify value:cpe
[2020-03-21 09:30:04][DEBUG] : key:supportmode value:LTE|WCDMA|GSM
[2020-03-21 09:30:04][DEBUG] : key:workmode value:LTE
[2020-03-21 09:30:04][DEBUG] : key:submask value:255.255.255.255
[2020-03-21 09:30:04][DEBUG] : key:Mccmnc value:20820
[2020-03-21 09:30:04][DEBUG] : key:uptime value:58594
[2020-03-21 09:30:04][DEBUG] : key:ImeiSvn value:01
[2020-03-21 09:30:04][DEBUG] : key:WifiMacAddrWl0 value:DC:90:88:1E:19:7E
[2020-03-21 09:30:04][DEBUG] : key:WifiMacAddrWl1 value:DC:90:88:1E:19:80
[2020-03-21 09:30:04][DEBUG] : function setInfo has a NULL parameter
[2020-03-21 09:30:04][DEBUG] : freq band:
[2020-03-21 09:30:04][DEBUG] : liste: Array
[2020-03-21 09:30:04][DEBUG] : jsonKey:
[2020-03-21 09:30:04][DEBUG] : Freq Name: FDD 2100
[2020-03-21 09:30:04][DEBUG] : freq ndl:
[2020-03-21 09:30:04][DEBUG] : freq nul:
[2020-03-21 09:30:04][DEBUG] : NDL_Off: 0
[2020-03-21 09:30:04][DEBUG] : FDL_Low: 2110
[2020-03-21 09:30:04][DEBUG] : NUL_Off: 18000
[2020-03-21 09:30:04][DEBUG] : FUL_Low: 1920
[2020-03-21 09:30:04][DEBUG] : key FullName valeur Bouygues Telecom
[2020-03-21 09:30:04][DEBUG] : key status valeur Up
[2020-03-21 09:30:05][DEBUG] : key CurrentConnectTime valeur 58574
[2020-03-21 09:30:05][DEBUG] : key CurrentDownloadRate valeur 216
[2020-03-21 09:30:05][DEBUG] : key CurrentUploadRate valeur 271
[2020-03-21 09:30:05][DEBUG] : key CurrentDownload valeur 12627917145
[2020-03-21 09:30:05][DEBUG] : key CurrentUpload valeur 591821779
[2020-03-21 09:30:05][DEBUG] : key TotalConnectTime valeur 748447
[2020-03-21 09:30:05][DEBUG] : key TotalDownload valeur 357909130705
[2020-03-21 09:30:05][DEBUG] : key devicename valeur B528s-23a
[2020-03-21 09:30:05][DEBUG] : key TotalUpload valeur 9645986284
[2020-03-21 09:30:05][DEBUG] : key SoftwareVersion valeur 81.195.03.00.309
[2020-03-21 09:30:05][DEBUG] : key WanIPAddress valeur 176.177.126.175
[2020-03-21 09:30:05][DEBUG] : key cell_id valeur
[2020-03-21 09:30:05][DEBUG] : key WebUIVersion valeur 81.100.33.00.309
[2020-03-21 09:30:05][DEBUG] : key Imei valeur 863769036974927
[2020-03-21 09:30:05][DEBUG] : key rsrp valeur
[2020-03-21 09:30:05][DEBUG] : key rssi valeur
[2020-03-21 09:30:05][DEBUG] : key workmode valeur LTE
[2020-03-21 09:30:05][DEBUG] : key sinr valeur
[2020-03-21 09:30:05][DEBUG] : key frq valeur FDD 2100
[2020-03-21 09:30:05][DEBUG] : key fdl valeur 2110
[2020-03-21 09:30:05][DEBUG] : key ful valeur 120
[2020-03-21 09:30:05][DEBUG] : key Msisdn valeur
[2020-03-21 09:30:05][DEBUG] : key Count valeur
[2020-03-21 09:30:05][DEBUG] : key Messages valeur
[2020-03-21 09:30:05][DEBUG] : refresh [Information][BBOX][Rafraîchir]
Logs HTTP:
[Sat Mar 21 05:40:25.577321 2020] [mpm_prefork:notice] [pid 354] AH00169: caught SIGTERM, shutting down
[Sat Mar 21 05:40:25.799742 2020] [mpm_prefork:notice] [pid 8670] AH00163: Apache/2.4.38 (Debian) configured -- resuming normal operations
[Sat Mar 21 05:40:25.799876 2020] [core:notice] [pid 8670] AH00094: Command line: '/usr/sbin/apache2'
[Sat Mar 21 05:45:26.567861 2020] [core:notice] [pid 8670] AH00052: child pid 13832 exit signal Segmentation fault (11)
[Sat Mar 21 05:45:26.634044 2020] [mpm_prefork:notice] [pid 8670] AH00169: caught SIGTERM, shutting down
[Sat Mar 21 05:45:26.854969 2020] [mpm_prefork:notice] [pid 17586] AH00163: Apache/2.4.38 (Debian) configured -- resuming normal operations
[Sat Mar 21 05:45:26.855105 2020] [core:notice] [pid 17586] AH00094: Command line: '/usr/sbin/apache2'
[Sat Mar 21 05:49:31.805283 2020] [core:notice] [pid 17586] AH00052: child pid 17592 exit signal Segmentation fault (11)
[Sat Mar 21 05:49:31.871535 2020] [core:notice] [pid 17586] AH00052: child pid 17627 exit signal Segmentation fault (11)
[Sat Mar 21 05:49:31.871816 2020] [core:notice] [pid 17586] AH00052: child pid 20602 exit signal Segmentation fault (11)
[Sat Mar 21 05:49:31.872006 2020] [core:notice] [pid 17586] AH00052: child pid 21956 exit signal Segmentation fault (11)
[Sat Mar 21 05:49:32.134790 2020] [mpm_prefork:notice] [pid 17586] AH00169: caught SIGTERM, shutting down
[Sat Mar 21 05:49:39.136571 2020] [mpm_prefork:notice] [pid 2243] AH00163: Apache/2.4.38 (Debian) configured -- resuming normal operations
[Sat Mar 21 05:49:39.137111 2020] [core:notice] [pid 2243] AH00094: Command line: '/usr/sbin/apache2'
Logs cron :
PHP Warning: Use of undefined constant LOGGED_IN - assumed 'LOGGED_IN' (this will throw an Error in a future version of PHP) in /var/www/html/plugins/huawei4g/core/class/router.class.php on line 50
PHP Warning: Use of undefined constant hc - assumed 'hc' (this will throw an Error in a future version of PHP) in /var/www/html/plugins/conso/core/class/conso.class.php on line 73
PHP Warning: Use of undefined constant hp - assumed 'hp' (this will throw an Error in a future version of PHP) in /var/www/html/plugins/conso/core/class/conso.class.php on line 73
Logs Update plugins :
* Installation des dépendances *
Atteint :1 http://security.debian.org buster/updates InRelease
Atteint :2 http://httpredir.debian.org/debian buster InRelease
Atteint :3 http://httpredir.debian.org/debian buster-updates InRelease
Atteint :5 http://httpredir.debian.org/debian buster-backports InRelease
Atteint :6 https://deb.nodesource.com/node_12.x buster InRelease
Atteint :4 https://apt.armbian.com buster InRelease
Lecture des listes de paquets…
Construction de l'arbre des dépendances…
Lecture des informations d'état…
python3-pip est déjà la version la plus récente (18.1-5).
0 mis à jour, 0 nouvellement installés, 0 à enlever et 0 non mis à jour.
python3-setuptools est déjà la version la plus récente (40.8.0-1).
Requirement already satisfied: typing in /usr/local/lib/python3.7/dist-packages (3.7.4.1)
Requirement already satisfied: huawei-lte-api in /usr/local/lib/python3.7/dist-packages (1.4.10)
Requirement already satisfied: dicttoxml in /usr/local/lib/python3.7/dist-packages (from huawei-lte-api) (1.7.4)
Requirement already satisfied: requests in /usr/lib/python3/dist-packages (from huawei-lte-api) (2.21.0)
Requirement already satisfied: xmltodict in /usr/local/lib/python3.7/dist-packages (from huawei-lte-api) (0.12.0)
* Installation terminée *
