Je rencontre un soucis avec le plugin Surveillance Station, en effet, après avoir configuré mon NAS dans la page de config du plugin, lorsque je vais sur la page du plugin, j’ai une page complètement blanche, rien du tout de marqué dedans !
Voici ce que j’ai dans les logs lorsque j’active le plugin :
[2020-03-07 22:53:45][DEBUG] : Lancement de : /var/www/html/core/class/../../core/php/jeePlugin.php plugin_id=surveillanceStation function=remove callInstallFunction=1
[2020-03-07 22:53:53][INFO] : Début d'activation du plugin
[2020-03-07 22:53:54][INFO] : Info sur le démon : Array ( [launchable_message] => [launchable] => nok [state] => nok [log] => nok [auto] => 0 )
[2020-03-07 22:53:54][DEBUG] : Lancement de : /var/www/html/core/class/../../core/php/jeePlugin.php plugin_id=surveillanceStation function=install callInstallFunction=1
Et sinon, une requête sur les caméra qui a l’air de fonctionner :
[2020-03-07 22:50:12][DEBUG] : résultat API Statut Caméra -> Array ( [cameras] => Array ( [0] => Array ( [DINum] => 0 [DONum] => 0 [audioCodec] => 6 [channel] => 1 [dsId] => 0 [enableLowProfile] => 1 [enableRecordingKeepDays] => 1 [enableRecordingKeepSize] => [fov] => [highProfileStreamNo] => 1 [id] => 1 [idOnRecServer] => 0 [ip] => 192.168.x.x [lowProfileStreamNo] => 1 [mediumProfileStreamNo] => 1 [model] => Define [newName] => Cam a [port] => 554 [postRecordTime] => 15 [preRecordTime] => 15 [recordTime] => 30 [recordingKeepDays] => 60 [recordingKeepSize] => 10 [status] => 1 [stream1] => Array ( [bitrateCtrl] => 0 [constantBitrate] => 0 [fps] => 0 [quality] => [resolution] => 1280x720 ) [tvStandard] => 0 [vendor] => User [videoCodec] => 3 [videoMode] => ) [1] => Array ( [DINum] => 0 [DONum] => 0 [audioCodec] => 6 [channel] => 1 [dsId] => 0 [enableLowProfile] => 1 [enableRecordingKeepDays] => 1 [enableRecordingKeepSize] => [fov] => [highProfileStreamNo] => 1 [id] => 2 [idOnRecServer] => 0 [ip] => 192.168.x.x [lowProfileStreamNo] => 1 [mediumProfileStreamNo] => 1 [model] => Define [newName] => Cam b [port] => 554 [postRecordTime] => 15 [preRecordTime] => 15 [recordTime] => 30 [recordingKeepDays] => 60 [recordingKeepSize] => 10 [status] => 1 [stream1] => Array ( [bitrateCtrl] => 0 [constantBitrate] => 0 [fps] => 0 [quality] => [resolution] => 1280x720 ) [tvStandard] => 0 [vendor] => User [videoCodec] => 3 [videoMode] => ) [2] => Array ( [DINum] => 0 [DONum] => 0 [audioCodec] => 6 [channel] => 1 [dsId] => 0 [enableLowProfile] => 1 [enableRecordingKeepDays] => 1 [enableRecordingKeepSize] => [fov] => [highProfileStreamNo] => 1 [id] => 3 [idOnRecServer] => 0 [ip] => 192.168.x.x [lowProfileStreamNo] => 1 [mediumProfileStreamNo] => 1 [model] => Define [newName] => Cam c [port] => 554 [postRecordTime] => 15 [preRecordTime] => 15 [recordTime] => 30 [recordingKeepDays] => 60 [recordingKeepSize] => 10 [status] => 1 [stream1] => Array ( [bitrateCtrl] => 0 [constantBitrate] => 0 [fps] => 0 [quality] => [resolution] => 1280x720 ) [tvStandard] => 0 [vendor] => User [videoCodec] => 3 [videoMode] => ) [3] => Array ( [DINum] => 0 [DONum] => 0 [audioCodec] => 6 [channel] => 1 [dsId] => 0 [enableLowProfile] => 1 [enableRecordingKeepDays] => 1 [enableRecordingKeepSize] => [fov] => [highProfileStreamNo] => 1 [id] => 4 [idOnRecServer] => 0 [ip] => 192.168.x.x [lowProfileStreamNo] => 1 [mediumProfileStreamNo] => 1 [model] => Define [newName] => Cam d [port] => 554 [postRecordTime] => 15 [preRecordTime] => 15 [recordTime] => 30 [recordingKeepDays] => 60 [recordingKeepSize] => 10 [status] => 1 [stream1] => Array ( [bitrateCtrl] => 0 [constantBitrate] => 0 [fps] => 0 [quality] => [resolution] => 1280x720 ) [tvStandard] => 0 [vendor] => User [videoCodec] => 3 [videoMode] => ) [4] => Array ( [DINum] => 0 [DONum] => 0 [audioCodec] => 6 [channel] => 1 [dsId] => 0 [enableLowProfile] => 1 [enableRecordingKeepDays] => 1 [enableRecordingKeepSize] => [fov] => [highProfileStreamNo] => 1 [id] => 5 [idOnRecServer] => 0 [ip] => 192.168.x.x [lowProfileStreamNo] => 1 [mediumProfileStreamNo] => 1 [model] => Define [newName] => Cam e [port] => 554 [postRecordTime] => 15 [preRecordTime] => 15 [recordTime] => 30 [recordingKeepDays] => 60 [recordingKeepSize] => 10 [status] => 1 [stream1] => Array ( [bitrateCtrl] => 0 [constantBitrate] => 0 [fps] => 0 [quality] => [resolution] => 1280x720 ) [tvStandard] => 0 [vendor] => User [videoCodec] => 3 [videoMode] => ) [5] => Array ( [DINum] => 0 [DONum] => 0 [audioCodec] => 6 [channel] => 1 [dsId] => 0 [enableLowProfile] => 1 [enableRecordingKeepDays] => 1 [enableRecordingKeepSize] => [fov] => [highProfileStreamNo] => 1 [id] => 6 [idOnRecServer] => 0 [ip] => 192.168.x.x [lowProfileStreamNo] => 1 [mediumProfileStreamNo] => 1 [model] => Define [newName] => Cam f [port] => 554 [postRecordTime] => 15 [preRecordTime] => 15 [recordTime] => 30 [recordingKeepDays] => 60 [recordingKeepSize] => 10 [status] => 1 [stream1] => Array ( [bitrateCtrl] => 0 [constantBitrate] => 0 [fps] => 0 [quality] => [resolution] => 1280x720 ) [tvStandard] => 0 [vendor] => User [videoCodec] => 3 [videoMode] => ) [6] => Array ( [DINum] => 0 [DONum] => 1 [audioCodec] => 6 [channel] => 1 [dsId] => 0 [enableLowProfile] => 1 [enableRecordingKeepDays] => 1 [enableRecordingKeepSize] => [fov] => [highProfileStreamNo] => 1 [id] => 7 [idOnRecServer] => 0 [ip] => 192.168.x.x [lowProfileStreamNo] => 1 [mediumProfileStreamNo] => 1 [model] => Generic_ONVIF [newName] => Cam g [port] => 80 [postRecordTime] => 5 [preRecordTime] => 5 [recordTime] => 30 [recordingKeepDays] => 60 [recordingKeepSize] => 10 [status] => 1 [stream1] => Array ( [bitrateCtrl] => 1 [constantBitrate] => 0 [fps] => 10 [quality] => 5 [resolution] => 1280x720 ) [tvStandard] => 0 [vendor] => ONVIF [videoCodec] => 3 [videoMode] => ) [7] => Array ( [DINum] => 0 [DONum] => 0 [audioCodec] => 4 [channel] => 1 [dsId] => 0 [enableLowProfile] => 1 [enableRecordingKeepDays] => 1 [enableRecordingKeepSize] => [fov] => [highProfileStreamNo] => 1 [id] => 8 [idOnRecServer] => 0 [ip] => 192.168.x.x [lowProfileStreamNo] => 1 [mediumProfileStreamNo] => 1 [model] => RLC-420-5MP [newName] => Cam h [port] => 80 [postRecordTime] => 15 [preRecordTime] => 15 [recordTime] => 30 [recordingKeepDays] => 60 [recordingKeepSize] => 10 [status] => 1 [stream1] => Array ( [bitrateCtrl] => 2 [constantBitrate] => 1024 [fps] => 4 [quality] => [resolution] => 2304x1296 ) [tvStandard] => 1 [vendor] => Reolink [videoCodec] => 3 [videoMode] => ) ) )
