Version : 4.3.17
Source : default
Branche : V4-stable
SystĂšme : Atlas
market / plugin : philipsHue stable 2023-08-03 01:05:58 2023-08-03 01:05:58 2023-08-03 19:28:31
Le plugin PhilipsHue semble encore avoir son cron qui part en vrille. Le process est dĂ©marrĂ© depuis longtemps et jâai eu des alertes de surchauffe de mon Atlas:
VoilĂ les derniers logs:
0106|[2023-05-05 15:52:51][DEBUG] : No configuration found for sensor : HueEssentialsEffect_State => {"id":"237","attributes":{"state":{"status":0,"lastupdated":"2020-02-11T22:31:27"},"config":{"on":true,"reachable":true},"name":"HueEssentialsEffect","type":"CLIPGenericStatus","modelid":"HueEssentialsEffect_State","manufacturername":"Hue Essentials","swversion":"1.0","uniqueid":"rA5BUt5zQkx5bzpdSHKJd1o2wgxtoio8","recycle":true},"client":{}}
0107|[2023-05-05 15:52:51][DEBUG] : Found sensor model : HueEssentialsEffect_State
0108|[2023-05-05 15:52:51][DEBUG] : No configuration found for sensor : HueEssentialsEffect_State => {"id":"238","attributes":{"state":{"status":0,"lastupdated":"2020-02-11T22:31:48"},"config":{"on":true,"reachable":true},"name":"HueEssentialsEffect","type":"CLIPGenericStatus","modelid":"HueEssentialsEffect_State","manufacturername":"Hue Essentials","swversion":"1.0","uniqueid":"zu22nwqsl2hr1RpeAYFKnZyhlU0R0Bbp","recycle":true},"client":{}}
0109|[2023-08-03 19:28:28][DEBUG] : Lancement de : /var/www/html/core/class/../../core/php/jeePlugin.php plugin_id=philipsHue function=pre_update callInstallFunction=1
0110|[2023-08-03 19:28:29][INFO] : Début d'activation du plugin
0111|[2023-08-03 19:28:31][INFO] : Info sur le démon : {"log":"","state":"nok","launchable":"nok","launchable_message":"Les crons et d\u00e9mons sont d\u00e9sactiv\u00e9s","auto":"0","last_launch":"2023-08-03 00:00:15"}
0112|[2023-08-03 19:28:31][DEBUG] : Lancement de : /var/www/html/core/class/../../core/php/jeePlugin.php plugin_id=philipsHue function=update callInstallFunction=1
Evidemment face Ă lâurgence de la situation je tue le dĂ©mon, je ne peux pas laisser ma plateforme dans cet Ă©tat.
Ce sera probablement plus complexe Ă analyser.
Aucune mise Ă jour depuis bien longtemps, je pense donc que câest une nouvelle occurence du vieux bug que jâavais saisi il y a longtemps.
