Ca n’a rien changé à la problématique.
Voila le log otp
File "/var/www/html/plugins/peugeotcars/core/ajax/../../3rdparty/psa_jeedom_daemon/jeedom_otp.py", line 16, in
from psa_car_controller.psacc.application.car_controller import PSACarController
File "/var/www/html/plugins/peugeotcars/3rdparty/psa_jeedom_daemon/psa_car_controller/psacc/application/car_controller.py", line 10, in
from .charge_control import ChargeControls
File "/var/www/html/plugins/peugeotcars/3rdparty/psa_jeedom_daemon/psa_car_controller/psacc/application/charge_control.py", line 13, in
from .psa_client import PSAClient
File "/var/www/html/plugins/peugeotcars/3rdparty/psa_jeedom_daemon/psa_car_controller/psacc/application/psa_client.py", line 13, in
from psa_car_controller.psacc.application.charging import Charging
File "/var/www/html/plugins/peugeotcars/3rdparty/psa_jeedom_daemon/psa_car_controller/psacc/application/charging.py", line 8, in
from .ecomix import Ecomix
File "/var/www/html/plugins/peugeotcars/3rdparty/psa_jeedom_daemon/psa_car_controller/psacc/application/ecomix.py", line 9, in
import reverse_geocode
File "/usr/local/lib/python3.7/dist-packages/reverse_geocode/__init__.py", line 12, in
from scipy.spatial import cKDTree as KDTree
File "/usr/local/lib/python3.7/dist-packages/scipy/spatial/__init__.py", line 96, in
from .kdtree import *
File "/usr/local/lib/python3.7/dist-packages/scipy/spatial/kdtree.py", line 5, in
from .ckdtree import cKDTree, cKDTreeNode
File "ckdtree.pyx", line 1, in init scipy.spatial.ckdtree
ValueError: numpy.ndarray size changed, may indicate binary incompatibility. Expected 44 from C header, got 40 from PyObject
/usr/local/lib/python3.7/dist-packages/scipy/__init__.py:149: UserWarning: A NumPy version >=1.16.5 and <1.23.0 is required for this version of SciPy (detected version 1.16.2
UserWarning)
Par contre, le retour de cette commande m’a un peu chagriné j’avoue, j’ai préféré remettre la version précedente
sudo pip install --upgrade numpy==1.16.2
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Collecting numpy==1.16.2
Downloading https://www.piwheels.org/simple/numpy/numpy-1.16.2-cp37-cp37m-linux_armv7l.whl (7.4 MB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 7.4/7.4 MB 2.9 MB/s eta 0:00:00
Installing collected packages: numpy
Attempting uninstall: numpy
Found existing installation: numpy 1.19.1
Uninstalling numpy-1.19.1:
Successfully uninstalled numpy-1.19.1
ERROR: pip's dependency resolver does not currently take into account all the packages that are installed. This behaviour is the source of the following dependency conflicts.
scipy 1.7.3 requires numpy<1.23.0,>=1.16.5, but you have numpy 1.16.2 which is incompatible.
pandas 1.3.5 requires numpy>=1.17.3; platform_machine != "aarch64" and platform_machine != "arm64" and python_version < "3.10", but you have numpy 1.16.2 which is incompatible.
matplotlib 3.5.2 requires numpy>=1.17, but you have numpy 1.16.2 which is incompatible.
Successfully installed numpy-1.16.2
WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv
