Bonjour @Loic,
depuis quelques semaines, j’ai de nouveau des plantages journaliers de la box (qui ne se sont plus présentés au début du remake du plugin).
difficile d’estimer à quel moment c’est arrivé car j’ai un peu décroché quand j’ai vu que c’était fonctionnel, je dirais plus ou moins au moment ou tu es passé du package.json à l’installation manuelle des modules.
voici mon retour dans les logs :
[2019-11-01 19:15:24][DEBUG] : Send data to jeedom : {"devices":{"65555":{"id":65555,"name":"Plafond Cafe","firmwareVersion":"1.2.221","model":"TRADFRI bulb GU10 WS 400lm","alive":true,"type":"light","color":"f1e0b5","onOff":false,"dimmer":79.9,"colorTemperature":58.8}}}
[2019-11-01 20:15:24][DEBUG] : Received message : {"devices":{"65555":{"id":65555,"name":"Plafond Cafe","firmwareVersion":"1.2.221","model":"TRADFRI bulb GU10 WS 400lm","alive":true,"type":"light","color":"f1e0b5","onOff":false,"dimmer":79.9,"colorTemperature":58.8}}}
[2019-11-01 19:15:29][DEBUG] : Send data to jeedom : {"devices":{"65556":{"id":65556,"name":"Plafond Taque","firmwareVersion":"1.2.221","model":"TRADFRI bulb GU10 WS 400lm","alive":true,"type":"light","color":"f1e0b5","onOff":false,"dimmer":79.9,"colorTemperature":58.8}}}
[2019-11-01 20:15:29][DEBUG] : Received message : {"devices":{"65556":{"id":65556,"name":"Plafond Taque","firmwareVersion":"1.2.221","model":"TRADFRI bulb GU10 WS 400lm","alive":true,"type":"light","color":"f1e0b5","onOff":false,"dimmer":79.9,"colorTemperature":58.8}}}
[2019-11-01 19:15:40][DEBUG] : Send data to jeedom : {"devices":{"65538":{"id":65538,"name":"Pres de la fenetre","firmwareVersion":"1.2.217","model":"TRADFRI bulb E27 WS opal 980lm","alive":true,"type":"light","color":"f1e0b5","onOff":false,"dimmer":79.9,"colorTemperature":57.4}}}
[2019-11-01 20:15:40][DEBUG] : Received message : {"devices":{"65538":{"id":65538,"name":"Pres de la fenetre","firmwareVersion":"1.2.217","model":"TRADFRI bulb E27 WS opal 980lm","alive":true,"type":"light","color":"f1e0b5","onOff":false,"dimmer":79.9,"colorTemperature":57.4}}}
[2019-11-01 19:16:24][DEBUG] : Send data to jeedom : {"devices":{"65541":{"id":65541,"name":"Triple Haut","firmwareVersion":"1.2.221","model":"TRADFRI bulb E14 WS opal 400lm","alive":true,"type":"light","color":"f1e0b5","onOff":false,"dimmer":79.9,"colorTemperature":58.8}}}
[2019-11-01 20:16:24][DEBUG] : Received message : {"devices":{"65541":{"id":65541,"name":"Triple Haut","firmwareVersion":"1.2.221","model":"TRADFRI bulb E14 WS opal 400lm","alive":true,"type":"light","color":"f1e0b5","onOff":false,"dimmer":79.9,"colorTemperature":58.8}}}
[2019-11-01 19:26:29][DEBUG] : Send data to jeedom : {"devices":{"65549":{"id":65549,"name":"Plafond Cheminee","firmwareVersion":"1.2.214","model":"TRADFRI bulb GU10 W 400lm","alive":true,"type":"light","color":"f1e0b5","onOff":false,"dimmer":100}}}
[2019-11-01 20:26:29][DEBUG] : Received message : {"devices":{"65549":{"id":65549,"name":"Plafond Cheminee","firmwareVersion":"1.2.214","model":"TRADFRI bulb GU10 W 400lm","alive":true,"type":"light","color":"f1e0b5","onOff":false,"dimmer":100}}}
[2019-11-01 19:40:59][DEBUG] : Send data to jeedom : {"devices":{"65545":{"id":65545,"name":"Plafond Buffet","firmwareVersion":"1.2.214","model":"TRADFRI bulb GU10 W 400lm","alive":true,"type":"light","color":"f1e0b5","onOff":true,"dimmer":63}}}
[2019-11-01 20:40:59][DEBUG] : Received message : {"devices":{"65545":{"id":65545,"name":"Plafond Buffet","firmwareVersion":"1.2.214","model":"TRADFRI bulb GU10 W 400lm","alive":true,"type":"light","color":"f1e0b5","onOff":true,"dimmer":63}}}
[2019-11-01 19:41:37][DEBUG] : Device id : 65565
[2019-11-01 19:41:37][DEBUG] : Type id : light
[2019-11-01 19:41:37][DEBUG] : Operation : {"dimmer":"127"}
[2019-11-01 19:41:41][DEBUG] : Device id : 65566
[2019-11-01 19:41:41][DEBUG] : Type id : light
[2019-11-01 19:41:41][DEBUG] : Operation : {"dimmer":"127"}
[2019-11-01 19:41:57][ERROR] : Error on operation : {}
[2019-11-01 20:41:57][ERROR] : Erreur exécution de la commande [Escalier][Plafond Escaliers][Intensité] : {}
[2019-11-01 19:41:57][DEBUG] : Device id : 65565
[2019-11-01 19:41:57][DEBUG] : Type id : light
[2019-11-01 19:41:57][DEBUG] : Operation : {"onOff":true}
[2019-11-01 19:42:11][ERROR] : Error on operation : {}
[2019-11-01 20:42:11][ERROR] : Erreur exécution de la commande [Palier][Plafond Palier][Intensité] : {}
[2019-11-01 19:42:11][DEBUG] : Device id : 65566
[2019-11-01 19:42:11][DEBUG] : Type id : light
[2019-11-01 19:42:11][DEBUG] : Operation : {"onOff":true}
(node:18924) UnhandledPromiseRejectionWarning: Error: The network stack was reset. Pending promises will not be fulfilled.
at TradfriClient.<anonymous> (/var/www/html/plugins/ikealight/resources/ikealightd/node_modules/node-tradfri-client/build/tradfri-client.js:921:40)
at Generator.throw (<anonymous>)
at rejected (/var/www/html/plugins/ikealight/resources/ikealightd/node_modules/node-tradfri-client/build/tradfri-client.js:6:65)
(node:18924) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 21)
(node:18924) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 22)
après j’ai redémarré la passerelle et c’est revenu (gros message avec toutes les lampes)
je ne le signale que maintenant car je n’ai pas pu capturer les logs exact du moment ou ca buggait avant aujourd’hui (ici c’est à 19:41:37 (ou 20:41:37 si c’est le demon ou jeedom))
je ne pense pas que ca te servira car ce n’est que la conséquence du plantage de la box… et aucun message probant juste avant… mais tu es au courant
Nebz
