PHP notice quand la hauteur ou le débit d’eau n’est pas disponible
Bonjour @jpty
J’ai vu le changelog du 09 octobre
qui concerne le post suivant :
Malheureusement, j’ai toujours la même « erreur »
0000|PHP Notice:  Trying to access array offset on value of type bool in /var/www/html/plugins/vigilancemeteo/core/class/vigilancemeteo.class.php on line 778
0001|PHP Notice:  Trying to access array offset on value of type bool in /var/www/html/plugins/vigilancemeteo/core/class/vigilancemeteo.class.php on line 779
0002|PHP Notice:  Trying to access array offset on value of type bool in /var/www/html/plugins/vigilancemeteo/core/class/vigilancemeteo.class.php on line 778
0003|PHP Notice:  Trying to access array offset on value of type bool in /var/www/html/plugins/vigilancemeteo/core/class/vigilancemeteo.class.php on line 779
0004|PHP Notice:  Trying to access array offset on value of type bool in /var/www/html/plugins/vigilancemeteo/core/class/vigilancemeteo.class.php on line 778
0005|PHP Notice:  Trying to access array offset on value of type bool in /var/www/html/plugins/vigilancemeteo/core/class/vigilancemeteo.class.php on line 779
0006|PHP Notice:  Trying to access array offset on value of type bool in /var/www/html/plugins/vigilancemeteo/core/class/vigilancemeteo.class.php on line 778
0007|PHP Notice:  Trying to access array offset on value of type bool in /var/www/html/plugins/vigilancemeteo/core/class/vigilancemeteo.class.php on line 779
0008|PHP Notice:  Trying to access array offset on value of type bool in /var/www/html/plugins/vigilancemeteo/core/class/vigilancemeteo.class.php on line 778
0009|PHP Notice:  Trying to access array offset on value of type bool in /var/www/html/plugins/vigilancemeteo/core/class/vigilancemeteo.class.php on line 779
0010|PHP Notice:  Trying to access array offset on value of type bool in /var/www/html/plugins/vigilancemeteo/core/class/vigilancemeteo.class.php on line 778
0011|PHP Notice:  Trying to access array offset on value of type bool in /var/www/html/plugins/vigilancemeteo/core/class/vigilancemeteo.class.php on line 779
0012|PHP Notice:  Trying to access array offset on value of type bool in /var/www/html/plugins/vigilancemeteo/core/class/vigilancemeteo.class.php on line 778
0013|PHP Notice:  Trying to access array offset on value of type bool in /var/www/html/plugins/vigilancemeteo/core/class/vigilancemeteo.class.php on line 779
0014|PHP Notice:  Trying to access array offset on value of type bool in /var/www/html/plugins/vigilancemeteo/core/class/vigilancemeteo.class.php on line 778
0015|PHP Notice:  Trying to access array offset on value of type bool in /var/www/html/plugins/vigilancemeteo/core/class/vigilancemeteo.class.php on line 779
0016|PHP Notice:  Trying to access array offset on value of type bool in /var/www/html/plugins/vigilancemeteo/core/class/vigilancemeteo.class.php on line 778
0017|PHP Notice:  Trying to access array offset on value of type bool in /var/www/html/plugins/vigilancemeteo/core/class/vigilancemeteo.class.php on line 779
0018|PHP Notice:  Trying to access array offset on value of type bool in /var/www/html/plugins/vigilancemeteo/core/class/vigilancemeteo.class.php on line 778
0019|PHP Notice:  Trying to access array offset on value of type bool in /var/www/html/plugins/vigilancemeteo/core/class/vigilancemeteo.class.php on line 779
0020|PHP Notice:  Trying to access array offset on value of type bool in /var/www/html/plugins/vigilancemeteo/core/class/vigilancemeteo.class.php on line 778
0021|PHP Notice:  Trying to access array offset on value of type bool in /var/www/html/plugins/vigilancemeteo/core/class/vigilancemeteo.class.php on line 779
0022|PHP Notice:  Trying to access array offset on value of type bool in /var/www/html/plugins/vigilancemeteo/core/class/vigilancemeteo.class.php on line 778
0023|PHP Notice:  Trying to access array offset on value of type bool in /var/www/html/plugins/vigilancemeteo/core/class/vigilancemeteo.class.php on line 779
Je pense que la correction n’est pas passée car la mise à jour date du 02 sept version du 29 juin
Informations Jeedom
Core : 4.4.19 (master)
DNS Jeedom : oui
Plugin : Vigilance Météo
Version : 2024-06-29 01:24:28 (stable)
La correction a été faite dans la version beta.
Quand il y aura des retours positifs sur cette beta, la modification sera reportée dans la version stable.
Je l’utilise depuis cette correction sans souci.
Lunarok, est-il possible de diffuser une version stable ?
J’ai fini par installer la beta car j’ai trop de lignes dans les log
Résultat ok pour moi
Bon pour stable dans mon cas
