Perte du wifi suite coupure alimentation (suite)!
suite
Mar 31 03:09:01 jeedom systemd[1]: Starting Clean php session files...
Mar 31 03:09:02 jeedom systemd[1]: phpsessionclean.service: Succeeded.
Mar 31 03:09:02 jeedom systemd[1]: Finished Clean php session files.
Mar 31 03:10:01 jeedom CRON[1731]: (root) CMD (test -e /run/systemd/system || SERVICE_MODE=1 /sbin/e2scrub_all -A -r)
Mar 31 03:10:01 jeedom CRON[1732]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 03:10:01 jeedom CRON[1730]: (root) CMD (/usr/bin/php /var/www/html/core/php/watchdog.php >> /dev/null)
Mar 31 03:11:01 jeedom CRON[1948]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 03:11:02 jeedom systemd[1]: Starting Online ext4 Metadata Check for All Filesystems...
Mar 31 03:11:02 jeedom systemd[1]: e2scrub_all.service: Succeeded.
Mar 31 03:11:02 jeedom systemd[1]: Finished Online ext4 Metadata Check for All Filesystems.
Mar 31 03:12:01 jeedom CRON[2013]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 03:13:01 jeedom CRON[2092]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 03:14:01 jeedom CRON[2162]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 03:15:01 jeedom CRON[2240]: (root) CMD (/usr/bin/php /var/www/html/core/php/watchdog.php >> /dev/null)
Mar 31 03:15:01 jeedom CRON[2241]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 03:16:01 jeedom CRON[2414]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 03:17:01 jeedom CRON[2479]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 03:17:01 jeedom CRON[2478]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
Mar 31 03:18:01 jeedom CRON[2555]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 03:19:01 jeedom CRON[2629]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 03:20:01 jeedom CRON[2707]: (root) CMD (/usr/bin/php /var/www/html/core/php/watchdog.php >> /dev/null)
Mar 31 03:20:01 jeedom CRON[2708]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 03:21:01 jeedom CRON[2891]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 03:22:01 jeedom CRON[2954]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 03:23:01 jeedom CRON[3022]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 03:24:01 jeedom CRON[3088]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 03:25:01 jeedom CRON[3153]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 03:25:01 jeedom CRON[3154]: (root) CMD (/usr/bin/php /var/www/html/core/php/watchdog.php >> /dev/null)
Mar 31 03:26:01 jeedom CRON[3325]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 03:27:01 jeedom CRON[3401]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 03:28:01 jeedom CRON[3477]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 03:29:01 jeedom CRON[3555]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 03:30:01 jeedom CRON[3633]: (root) CMD (test -e /run/systemd/system || SERVICE_MODE=1 /usr/lib/arm-linux-gnueabihf/e2fsprogs/e2scrub_all_cron)
Mar 31 03:30:01 jeedom CRON[3634]: (root) CMD (/usr/bin/php /var/www/html/core/php/watchdog.php >> /dev/null)
Mar 31 03:30:01 jeedom CRON[3635]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 03:31:01 jeedom CRON[3887]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 03:32:01 jeedom CRON[3964]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 03:33:01 jeedom CRON[4053]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 03:34:00 jeedom rngd[446]: stats: bits received from HRNG source: 220064
Mar 31 03:34:00 jeedom rngd[446]: stats: bits sent to kernel pool: 180000
Mar 31 03:34:00 jeedom rngd[446]: stats: entropy added to kernel pool: 180000
Mar 31 03:34:00 jeedom rngd[446]: stats: FIPS 140-2 successes: 11
Mar 31 03:34:00 jeedom rngd[446]: stats: FIPS 140-2 failures: 0
Mar 31 03:34:00 jeedom rngd[446]: stats: FIPS 140-2(2001-10-10) Monobit: 0
Mar 31 03:34:00 jeedom rngd[446]: stats: FIPS 140-2(2001-10-10) Poker: 0
Mar 31 03:34:00 jeedom rngd[446]: stats: FIPS 140-2(2001-10-10) Runs: 0
Mar 31 03:34:00 jeedom rngd[446]: stats: FIPS 140-2(2001-10-10) Long run: 0
Mar 31 03:34:00 jeedom rngd[446]: stats: FIPS 140-2(2001-10-10) Continuous run: 0
Mar 31 03:34:00 jeedom rngd[446]: stats: HRNG source speed: (min=654.445; avg=838.945; max=974.030)Kibits/s
Mar 31 03:34:00 jeedom rngd[446]: stats: FIPS tests speed: (min=20.960; avg=27.889; max=60.744)Mibits/s
Mar 31 03:34:00 jeedom rngd[446]: stats: Lowest ready-buffers level: 2
Mar 31 03:34:00 jeedom rngd[446]: stats: Entropy starvations: 0
Mar 31 03:34:00 jeedom rngd[446]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us
Mar 31 03:34:01 jeedom CRON[4146]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 03:35:01 jeedom CRON[4238]: (root) CMD (/usr/bin/php /var/www/html/core/php/watchdog.php >> /dev/null)
Mar 31 03:35:01 jeedom CRON[4239]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 03:36:01 jeedom CRON[4425]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 03:37:01 jeedom CRON[4501]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 03:38:01 jeedom CRON[4589]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 03:39:01 jeedom CRON[4670]: (root) CMD (  [ -x /usr/lib/php/sessionclean ] && if [ ! -d /run/systemd/system ]; then /usr/lib/php/sessionclean; fi)
Mar 31 03:39:01 jeedom CRON[4671]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 03:39:01 jeedom systemd[1]: Starting Clean php session files...
Mar 31 03:39:02 jeedom systemd[1]: phpsessionclean.service: Succeeded.
Mar 31 03:39:02 jeedom systemd[1]: Finished Clean php session files.
Mar 31 03:40:01 jeedom CRON[4817]: (root) CMD (/usr/bin/php /var/www/html/core/php/watchdog.php >> /dev/null)
Mar 31 03:40:02 jeedom CRON[4816]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 03:41:01 jeedom CRON[5018]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 03:42:01 jeedom CRON[5093]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 03:43:02 jeedom CRON[5170]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 03:44:01 jeedom CRON[5251]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 03:45:01 jeedom CRON[5328]: (root) CMD (/usr/bin/php /var/www/html/core/php/watchdog.php >> /dev/null)
Mar 31 03:45:01 jeedom CRON[5327]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 03:46:01 jeedom CRON[5532]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 03:47:01 jeedom CRON[5608]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 03:48:01 jeedom CRON[5683]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 03:49:01 jeedom CRON[5765]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 03:50:01 jeedom CRON[5842]: (root) CMD (/usr/bin/php /var/www/html/core/php/watchdog.php >> /dev/null)
Mar 31 03:50:01 jeedom CRON[5843]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 03:51:01 jeedom CRON[6038]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 03:52:01 jeedom CRON[6114]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 03:53:01 jeedom CRON[6204]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 03:54:01 jeedom CRON[6293]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 03:55:01 jeedom CRON[6372]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 03:55:01 jeedom CRON[6373]: (root) CMD (/usr/bin/php /var/www/html/core/php/watchdog.php >> /dev/null)
Mar 31 03:56:01 jeedom CRON[6543]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 03:57:01 jeedom CRON[6619]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 03:58:01 jeedom CRON[6697]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 03:59:01 jeedom CRON[6773]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 04:00:01 jeedom CRON[6844]: (root) CMD (/usr/bin/php /var/www/html/core/php/watchdog.php >> /dev/null)
Mar 31 04:00:01 jeedom CRON[6845]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 04:01:01 jeedom CRON[7097]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 04:02:01 jeedom CRON[7166]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 04:03:01 jeedom CRON[7230]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 04:04:01 jeedom CRON[7324]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 04:05:01 jeedom CRON[7394]: (root) CMD (/usr/bin/php /var/www/html/core/php/watchdog.php >> /dev/null)
Mar 31 04:05:01 jeedom CRON[7395]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 04:06:01 jeedom CRON[7555]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 04:07:01 jeedom CRON[7622]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 04:08:01 jeedom CRON[7696]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 04:09:01 jeedom CRON[7764]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 04:09:01 jeedom CRON[7765]: (root) CMD (  [ -x /usr/lib/php/sessionclean ] && if [ ! -d /run/systemd/system ]; then /usr/lib/php/sessionclean; fi)
Mar 31 04:09:01 jeedom systemd[1]: Starting Clean php session files...
Mar 31 04:09:02 jeedom systemd[1]: phpsessionclean.service: Succeeded.
Mar 31 04:09:02 jeedom systemd[1]: Finished Clean php session files.
Mar 31 04:10:01 jeedom CRON[7883]: (root) CMD (/usr/bin/php /var/www/html/core/php/watchdog.php >> /dev/null)
Mar 31 04:10:01 jeedom CRON[7884]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 04:11:01 jeedom CRON[8072]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 04:12:01 jeedom CRON[8136]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 04:13:01 jeedom CRON[8210]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 04:14:01 jeedom CRON[8278]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 04:15:01 jeedom CRON[8343]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 04:15:01 jeedom CRON[8342]: (root) CMD (/usr/bin/php /var/www/html/core/php/watchdog.php >> /dev/null)
Mar 31 04:16:01 jeedom CRON[8525]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 04:17:01 jeedom CRON[8603]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 04:17:01 jeedom CRON[8602]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
Mar 31 04:18:02 jeedom CRON[8673]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 04:19:02 jeedom CRON[8741]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 04:20:01 jeedom CRON[8806]: (root) CMD (/usr/bin/php /var/www/html/core/php/watchdog.php >> /dev/null)
Mar 31 04:20:01 jeedom CRON[8807]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 04:21:01 jeedom CRON[9001]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 04:22:01 jeedom CRON[9065]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 04:23:01 jeedom CRON[9134]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 04:24:01 jeedom CRON[9203]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 04:25:01 jeedom CRON[9279]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 04:25:01 jeedom CRON[9280]: (root) CMD (/usr/bin/php /var/www/html/core/php/watchdog.php >> /dev/null)
Mar 31 04:26:01 jeedom CRON[9439]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 04:27:01 jeedom CRON[9503]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 04:28:01 jeedom CRON[9568]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 04:29:01 jeedom CRON[9634]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 04:30:01 jeedom CRON[9698]: (root) CMD (/usr/bin/php /var/www/html/core/php/watchdog.php >> /dev/null)
Mar 31 04:30:01 jeedom CRON[9699]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 04:31:01 jeedom CRON[9952]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 04:32:01 jeedom CRON[10015]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 04:33:01 jeedom CRON[10084]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 04:34:00 jeedom rngd[446]: stats: bits received from HRNG source: 260064
Mar 31 04:34:00 jeedom rngd[446]: stats: bits sent to kernel pool: 210240
Mar 31 04:34:00 jeedom rngd[446]: stats: entropy added to kernel pool: 210240
Mar 31 04:34:00 jeedom rngd[446]: stats: FIPS 140-2 successes: 13
Mar 31 04:34:00 jeedom rngd[446]: stats: FIPS 140-2 failures: 0
Mar 31 04:34:00 jeedom rngd[446]: stats: FIPS 140-2(2001-10-10) Monobit: 0
Mar 31 04:34:00 jeedom rngd[446]: stats: FIPS 140-2(2001-10-10) Poker: 0
Mar 31 04:34:00 jeedom rngd[446]: stats: FIPS 140-2(2001-10-10) Runs: 0
Mar 31 04:34:00 jeedom rngd[446]: stats: FIPS 140-2(2001-10-10) Long run: 0
Mar 31 04:34:00 jeedom rngd[446]: stats: FIPS 140-2(2001-10-10) Continuous run: 0
Mar 31 04:34:00 jeedom rngd[446]: stats: HRNG source speed: (min=654.445; avg=843.657; max=974.030)Kibits/s
Mar 31 04:34:00 jeedom rngd[446]: stats: FIPS tests speed: (min=20.960; avg=27.486; max=60.744)Mibits/s
Mar 31 04:34:00 jeedom rngd[446]: stats: Lowest ready-buffers level: 2
Mar 31 04:34:00 jeedom rngd[446]: stats: Entropy starvations: 0
Mar 31 04:34:00 jeedom rngd[446]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us
Mar 31 04:34:01 jeedom CRON[10174]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 04:35:01 jeedom CRON[10240]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 04:35:01 jeedom CRON[10241]: (root) CMD (/usr/bin/php /var/www/html/core/php/watchdog.php >> /dev/null)
Mar 31 04:36:01 jeedom CRON[10402]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 04:37:01 jeedom CRON[10465]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 04:38:01 jeedom CRON[10529]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 04:39:01 jeedom CRON[10609]: (root) CMD (  [ -x /usr/lib/php/sessionclean ] && if [ ! -d /run/systemd/system ]; then /usr/lib/php/sessionclean; fi)
Suite
Mar 31 04:39:01 jeedom CRON[10610]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 04:39:01 jeedom systemd[1]: Starting Clean php session files...
Mar 31 04:39:02 jeedom systemd[1]: phpsessionclean.service: Succeeded.
Mar 31 04:39:02 jeedom systemd[1]: Finished Clean php session files.
Mar 31 04:40:01 jeedom CRON[10729]: (root) CMD (/usr/bin/php /var/www/html/core/php/watchdog.php >> /dev/null)
Mar 31 04:40:01 jeedom CRON[10730]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 04:41:01 jeedom CRON[10923]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 04:42:01 jeedom CRON[10988]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 04:43:01 jeedom CRON[11051]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 04:44:01 jeedom CRON[11123]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 04:45:01 jeedom CRON[11188]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 04:45:01 jeedom CRON[11189]: (root) CMD (/usr/bin/php /var/www/html/core/php/watchdog.php >> /dev/null)
Mar 31 04:46:01 jeedom CRON[11361]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 04:47:01 jeedom CRON[11436]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 04:48:01 jeedom CRON[11499]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 04:49:01 jeedom CRON[11580]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 04:50:01 jeedom CRON[11644]: (root) CMD (/usr/bin/php /var/www/html/core/php/watchdog.php >> /dev/null)
Mar 31 04:50:01 jeedom CRON[11645]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 04:51:01 jeedom CRON[11843]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 04:52:01 jeedom CRON[11909]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 04:53:01 jeedom CRON[11972]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 04:54:01 jeedom CRON[12040]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 04:55:01 jeedom CRON[12105]: (root) CMD (/usr/bin/php /var/www/html/core/php/watchdog.php >> /dev/null)
Mar 31 04:55:01 jeedom CRON[12104]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 04:56:01 jeedom CRON[12276]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 04:57:01 jeedom CRON[12344]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 04:58:01 jeedom CRON[12432]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 04:59:01 jeedom CRON[12499]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 05:00:01 jeedom CRON[12567]: (root) CMD (/usr/bin/php /var/www/html/core/php/watchdog.php >> /dev/null)
Mar 31 05:00:01 jeedom CRON[12568]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 05:01:01 jeedom CRON[12847]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 05:02:01 jeedom CRON[12911]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 05:03:01 jeedom CRON[12980]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 05:04:01 jeedom CRON[13048]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 05:05:01 jeedom CRON[13125]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 05:05:01 jeedom CRON[13126]: (root) CMD (/usr/bin/php /var/www/html/core/php/watchdog.php >> /dev/null)
Mar 31 05:06:01 jeedom CRON[13286]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 05:07:01 jeedom CRON[13350]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 05:08:01 jeedom CRON[13414]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 05:09:02 jeedom CRON[13495]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 05:09:02 jeedom CRON[13496]: (root) CMD (  [ -x /usr/lib/php/sessionclean ] && if [ ! -d /run/systemd/system ]; then /usr/lib/php/sessionclean; fi)
Mar 31 05:09:02 jeedom systemd[1]: Starting Clean php session files...
Mar 31 05:09:02 jeedom systemd[1]: phpsessionclean.service: Succeeded.
Mar 31 05:09:02 jeedom systemd[1]: Finished Clean php session files.
Mar 31 05:10:01 jeedom CRON[13613]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 05:10:01 jeedom CRON[13614]: (root) CMD (/usr/bin/php /var/www/html/core/php/watchdog.php >> /dev/null)
Mar 31 05:11:01 jeedom CRON[13801]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 05:12:01 jeedom CRON[13865]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 05:13:01 jeedom CRON[13929]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 05:14:01 jeedom CRON[14022]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 05:15:01 jeedom CRON[14087]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 05:15:01 jeedom CRON[14086]: (root) CMD (/usr/bin/php /var/www/html/core/php/watchdog.php >> /dev/null)
Mar 31 05:16:01 jeedom CRON[14257]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 05:17:01 jeedom CRON[14333]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 05:17:01 jeedom CRON[14334]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
Mar 31 05:18:02 jeedom CRON[14415]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 05:19:01 jeedom CRON[14487]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 05:20:01 jeedom CRON[14551]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 05:20:01 jeedom CRON[14552]: (root) CMD (/usr/bin/php /var/www/html/core/php/watchdog.php >> /dev/null)
Mar 31 05:21:01 jeedom CRON[14734]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 05:22:01 jeedom CRON[14798]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 05:23:01 jeedom CRON[14865]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 05:24:01 jeedom CRON[14943]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 05:25:01 jeedom CRON[15010]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 05:25:01 jeedom CRON[15011]: (root) CMD (/usr/bin/php /var/www/html/core/php/watchdog.php >> /dev/null)
Mar 31 05:26:01 jeedom CRON[15169]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 05:27:01 jeedom CRON[15232]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 05:28:01 jeedom CRON[15307]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 05:29:01 jeedom CRON[15374]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 05:30:01 jeedom CRON[15451]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 05:30:01 jeedom CRON[15452]: (root) CMD (/usr/bin/php /var/www/html/core/php/watchdog.php >> /dev/null)
Mar 31 05:31:01 jeedom CRON[15704]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 05:32:01 jeedom CRON[15768]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 05:33:01 jeedom CRON[15833]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 05:34:00 jeedom rngd[446]: stats: bits received from HRNG source: 280064
Mar 31 05:34:00 jeedom rngd[446]: stats: bits sent to kernel pool: 240000
Mar 31 05:34:00 jeedom rngd[446]: stats: entropy added to kernel pool: 240000
Mar 31 05:34:00 jeedom rngd[446]: stats: FIPS 140-2 successes: 14
Mar 31 05:34:00 jeedom rngd[446]: stats: FIPS 140-2 failures: 0
Mar 31 05:34:00 jeedom rngd[446]: stats: FIPS 140-2(2001-10-10) Monobit: 0
Mar 31 05:34:00 jeedom rngd[446]: stats: FIPS 140-2(2001-10-10) Poker: 0
Mar 31 05:34:00 jeedom rngd[446]: stats: FIPS 140-2(2001-10-10) Runs: 0
Mar 31 05:34:00 jeedom rngd[446]: stats: FIPS 140-2(2001-10-10) Long run: 0
Mar 31 05:34:00 jeedom rngd[446]: stats: FIPS 140-2(2001-10-10) Continuous run: 0
Mar 31 05:34:00 jeedom rngd[446]: stats: HRNG source speed: (min=654.445; avg=845.477; max=974.030)Kibits/s
Mar 31 05:34:00 jeedom rngd[446]: stats: FIPS tests speed: (min=20.960; avg=27.343; max=60.744)Mibits/s
Mar 31 05:34:00 jeedom rngd[446]: stats: Lowest ready-buffers level: 2
Mar 31 05:34:00 jeedom rngd[446]: stats: Entropy starvations: 0
Mar 31 05:34:00 jeedom rngd[446]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us
Mar 31 05:34:01 jeedom CRON[15908]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 05:35:01 jeedom CRON[15975]: (root) CMD (/usr/bin/php /var/www/html/core/php/watchdog.php >> /dev/null)
Mar 31 05:35:01 jeedom CRON[15976]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 05:36:01 jeedom CRON[16151]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 05:37:01 jeedom CRON[16222]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 05:38:01 jeedom CRON[16297]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 05:39:02 jeedom CRON[16366]: (root) CMD (  [ -x /usr/lib/php/sessionclean ] && if [ ! -d /run/systemd/system ]; then /usr/lib/php/sessionclean; fi)
Mar 31 05:39:02 jeedom CRON[16367]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 05:39:03 jeedom systemd[1]: Starting Clean php session files...
Mar 31 05:39:03 jeedom systemd[1]: phpsessionclean.service: Succeeded.
Mar 31 05:39:03 jeedom systemd[1]: Finished Clean php session files.
Mar 31 05:40:01 jeedom CRON[16495]: (root) CMD (/usr/bin/php /var/www/html/core/php/watchdog.php >> /dev/null)
Mar 31 05:40:01 jeedom CRON[16496]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 05:41:01 jeedom CRON[16680]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 05:42:01 jeedom CRON[16749]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 05:43:01 jeedom CRON[16812]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 05:44:01 jeedom CRON[16885]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 05:45:01 jeedom CRON[16961]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 05:45:01 jeedom CRON[16962]: (root) CMD (/usr/bin/php /var/www/html/core/php/watchdog.php >> /dev/null)
Mar 31 05:46:01 jeedom CRON[17147]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 05:47:01 jeedom CRON[17212]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 05:48:01 jeedom CRON[17275]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 05:49:01 jeedom CRON[17355]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 05:50:01 jeedom CRON[17420]: (root) CMD (/usr/bin/php /var/www/html/core/php/watchdog.php >> /dev/null)
Mar 31 05:50:01 jeedom CRON[17421]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 05:51:01 jeedom CRON[17608]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 05:52:02 jeedom CRON[17682]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 05:53:01 jeedom CRON[17747]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 05:54:01 jeedom CRON[17813]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 05:55:01 jeedom CRON[17890]: (root) CMD (/usr/bin/php /var/www/html/core/php/watchdog.php >> /dev/null)
Mar 31 05:55:01 jeedom CRON[17889]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 05:56:01 jeedom CRON[18050]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 05:57:01 jeedom CRON[18113]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 05:58:01 jeedom CRON[18201]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 05:59:01 jeedom CRON[18268]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 06:00:01 jeedom CRON[18334]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 06:00:01 jeedom CRON[18335]: (root) CMD (/usr/bin/php /var/www/html/core/php/watchdog.php >> /dev/null)
Mar 31 06:01:01 jeedom CRON[18596]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 06:02:01 jeedom CRON[18682]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 06:03:01 jeedom CRON[18746]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 06:04:01 jeedom CRON[18816]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 06:05:01 jeedom CRON[18897]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 06:05:01 jeedom CRON[18898]: (root) CMD (/usr/bin/php /var/www/html/core/php/watchdog.php >> /dev/null)
Mar 31 06:06:01 jeedom CRON[19057]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 06:07:01 jeedom CRON[19120]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 06:08:02 jeedom CRON[19184]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 06:09:01 jeedom CRON[19264]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 06:09:01 jeedom CRON[19265]: (root) CMD (  [ -x /usr/lib/php/sessionclean ] && if [ ! -d /run/systemd/system ]; then /usr/lib/php/sessionclean; fi)
Mar 31 06:09:01 jeedom systemd[1]: Starting Clean php session files...
Mar 31 06:09:01 jeedom systemd[1]: phpsessionclean.service: Succeeded.
Mar 31 06:09:01 jeedom systemd[1]: Finished Clean php session files.
Mar 31 06:10:01 jeedom CRON[19384]: (root) CMD (/usr/bin/php /var/www/html/core/php/watchdog.php >> /dev/null)
Mar 31 06:10:01 jeedom CRON[19383]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 06:11:01 jeedom CRON[19580]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 06:11:02 jeedom systemd[1]: Starting Daily apt upgrade and clean activities...
Mar 31 06:11:13 jeedom systemd[1]: apt-daily-upgrade.service: Succeeded.
Mar 31 06:11:13 jeedom systemd[1]: Finished Daily apt upgrade and clean activities.
Mar 31 06:11:13 jeedom systemd[1]: apt-daily-upgrade.service: Consumed 10.588s CPU time.
Mar 31 06:12:01 jeedom CRON[19704]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 06:13:01 jeedom CRON[19771]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 06:14:01 jeedom CRON[19839]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 06:15:01 jeedom CRON[19904]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 06:15:02 jeedom CRON[19903]: (root) CMD (/usr/bin/php /var/www/html/core/php/watchdog.php >> /dev/null)
Mar 31 06:16:01 jeedom CRON[20100]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 06:17:01 jeedom CRON[20166]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
Mar 31 06:17:01 jeedom CRON[20165]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 06:18:01 jeedom CRON[20235]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 06:19:01 jeedom CRON[20302]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 06:20:01 jeedom CRON[20366]: (root) CMD (/usr/bin/php /var/www/html/core/php/watchdog.php >> /dev/null)
Mar 31 06:20:01 jeedom CRON[20367]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 06:21:01 jeedom CRON[20567]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 06:22:01 jeedom CRON[20646]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 06:23:01 jeedom CRON[20709]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 06:24:01 jeedom CRON[20778]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 06:25:01 jeedom CRON[20854]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 06:25:01 jeedom CRON[20855]: (root) CMD (/usr/bin/php /var/www/html/core/php/watchdog.php >> /dev/null)
Mar 31 06:25:01 jeedom CRON[20856]: (root) CMD (test -x /usr/sbin/anacron || ( cd / && run-parts --report /etc/cron.daily ))
Mar 31 06:25:01 jeedom systemd[1]: Created slice User Slice of UID 65534.
Mar 31 06:25:01 jeedom systemd[1]: Starting User Runtime Directory /run/user/65534...
Mar 31 06:25:01 jeedom systemd[1]: Finished User Runtime Directory /run/user/65534.
Mar 31 06:25:01 jeedom systemd[1]: Starting User Manager for UID 65534...
Mar 31 06:25:02 jeedom systemd[20953]: Queued start job for default target Main User Target.
Mar 31 06:25:02 jeedom systemd[20953]: Created slice User Application Slice.
Mar 31 06:25:02 jeedom systemd[20953]: Reached target Paths.
Mar 31 06:25:02 jeedom systemd[20953]: Reached target Timers.
Mar 31 06:25:02 jeedom systemd[20953]: Starting D-Bus User Message Bus Socket.
Mar 31 06:25:02 jeedom systemd[20953]: Listening on GnuPG network certificate management daemon.
Mar 31 06:25:02 jeedom systemd[20953]: Listening on GnuPG cryptographic agent and passphrase cache (access for web browsers).
Mar 31 06:25:02 jeedom systemd[20953]: Listening on GnuPG cryptographic agent and passphrase cache (restricted).
Mar 31 06:25:02 jeedom systemd[20953]: Listening on GnuPG cryptographic agent (ssh-agent emulation).
Mar 31 06:25:02 jeedom systemd[20953]: Listening on GnuPG cryptographic agent and passphrase cache.
Mar 31 06:25:02 jeedom systemd[20953]: Listening on debconf communication socket.
Mar 31 06:25:02 jeedom systemd[20953]: Listening on D-Bus User Message Bus Socket.
Mar 31 06:25:02 jeedom systemd[20953]: Reached target Sockets.
Mar 31 06:25:02 jeedom systemd[20953]: Reached target Basic System.
Mar 31 06:25:02 jeedom systemd[20953]: Reached target Main User Target.
Mar 31 06:25:02 jeedom systemd[20953]: Startup finished in 702ms.
Mar 31 06:25:02 jeedom systemd[1]: Started User Manager for UID 65534.
Mar 31 06:25:02 jeedom systemd[1]: Started Session 672 of user nobody.
Mar 31 06:25:02 jeedom systemd[1]: session-672.scope: Succeeded.
Mar 31 06:25:10 jeedom systemd[1]: session-672.scope: Succeeded.
Mar 31 06:25:10 jeedom systemd[1]: session-672.scope: Consumed 3.980s CPU time.
Mar 31 06:25:20 jeedom systemd[1]: Stopping User Manager for UID 65534...
Mar 31 06:25:20 jeedom systemd[20953]: Stopped target Main User Target.
Mar 31 06:25:20 jeedom systemd[20953]: Stopped target Basic System.
Mar 31 06:25:20 jeedom systemd[20953]: Stopped target Paths.
Mar 31 06:25:20 jeedom systemd[20953]: Stopped target Sockets.
Mar 31 06:25:20 jeedom systemd[20953]: Stopped target Timers.
Mar 31 06:25:20 jeedom systemd[20953]: dbus.socket: Succeeded.
Mar 31 06:25:20 jeedom systemd[20953]: Closed D-Bus User Message Bus Socket.
Mar 31 06:25:20 jeedom systemd[20953]: dirmngr.socket: Succeeded.
Mar 31 06:25:20 jeedom systemd[20953]: Closed GnuPG network certificate management daemon.
Mar 31 06:25:20 jeedom systemd[20953]: gpg-agent-browser.socket: Succeeded.
Mar 31 06:25:20 jeedom systemd[20953]: Closed GnuPG cryptographic agent and passphrase cache (access for web browsers).
Mar 31 06:25:20 jeedom systemd[20953]: gpg-agent-extra.socket: Succeeded.
Mar 31 06:25:20 jeedom systemd[20953]: Closed GnuPG cryptographic agent and passphrase cache (restricted).
Mar 31 06:25:20 jeedom systemd[20953]: gpg-agent-ssh.socket: Succeeded.
Mar 31 06:25:20 jeedom systemd[20953]: Closed GnuPG cryptographic agent (ssh-agent emulation).
Mar 31 06:25:20 jeedom systemd[20953]: gpg-agent.socket: Succeeded.
Mar 31 06:25:20 jeedom systemd[20953]: Closed GnuPG cryptographic agent and passphrase cache.
Mar 31 06:25:20 jeedom systemd[20953]: pk-debconf-helper.socket: Succeeded.
Mar 31 06:25:20 jeedom systemd[20953]: Closed debconf communication socket.
Mar 31 06:25:20 jeedom systemd[20953]: Removed slice User Application Slice.
Mar 31 06:25:20 jeedom systemd[20953]: Reached target Shutdown.
Mar 31 06:25:20 jeedom systemd[20953]: systemd-exit.service: Succeeded.
Mar 31 06:25:20 jeedom systemd[20953]: Finished Exit the Session.
Mar 31 06:25:20 jeedom systemd[20953]: Reached target Exit the Session.
Mar 31 06:25:20 jeedom systemd[1]: user@65534.service: Succeeded.
Mar 31 06:25:20 jeedom systemd[1]: Stopped User Manager for UID 65534.
Mar 31 06:25:20 jeedom systemd[1]: Stopping User Runtime Directory /run/user/65534...
Mar 31 06:25:20 jeedom systemd[1]: run-user-65534.mount: Succeeded.
Mar 31 06:25:20 jeedom systemd[1]: user-runtime-dir@65534.service: Succeeded.
Mar 31 06:25:20 jeedom systemd[1]: Stopped User Runtime Directory /run/user/65534.
Mar 31 06:25:20 jeedom systemd[1]: Removed slice User Slice of UID 65534.
Mar 31 06:25:20 jeedom systemd[1]: user-65534.slice: Consumed 4.809s CPU time.
Mar 31 06:26:01 jeedom CRON[21115]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 06:27:01 jeedom CRON[21189]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 06:28:01 jeedom CRON[21253]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 06:29:01 jeedom CRON[21321]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 06:30:01 jeedom CRON[21385]: (root) CMD (/usr/bin/php /var/www/html/core/php/watchdog.php >> /dev/null)
Mar 31 06:30:01 jeedom CRON[21386]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 06:31:01 jeedom CRON[21632]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 06:32:01 jeedom CRON[21708]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 06:33:01 jeedom CRON[21772]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 06:34:00 jeedom rngd[446]: stats: bits received from HRNG source: 320064
Mar 31 06:34:00 jeedom rngd[446]: stats: bits sent to kernel pool: 270240
Mar 31 06:34:00 jeedom rngd[446]: stats: entropy added to kernel pool: 270240
Mar 31 06:34:00 jeedom rngd[446]: stats: FIPS 140-2 successes: 16
Mar 31 06:34:00 jeedom rngd[446]: stats: FIPS 140-2 failures: 0
Mar 31 06:34:00 jeedom rngd[446]: stats: FIPS 140-2(2001-10-10) Monobit: 0
Mar 31 06:34:00 jeedom rngd[446]: stats: FIPS 140-2(2001-10-10) Poker: 0
Mar 31 06:34:00 jeedom rngd[446]: stats: FIPS 140-2(2001-10-10) Runs: 0
Mar 31 06:34:00 jeedom rngd[446]: stats: FIPS 140-2(2001-10-10) Long run: 0
Mar 31 06:34:00 jeedom rngd[446]: stats: FIPS 140-2(2001-10-10) Continuous run: 0
Mar 31 06:34:00 jeedom rngd[446]: stats: HRNG source speed: (min=654.445; avg=848.779; max=974.030)Kibits/s
Mar 31 06:34:00 jeedom rngd[446]: stats: FIPS tests speed: (min=20.960; avg=27.093; max=60.744)Mibits/s
Mar 31 06:34:00 jeedom rngd[446]: stats: Lowest ready-buffers level: 2
Mar 31 06:34:00 jeedom rngd[446]: stats: Entropy starvations: 0
Mar 31 06:34:00 jeedom rngd[446]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us
Mar 31 06:34:01 jeedom CRON[21840]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 06:35:02 jeedom CRON[21906]: (root) CMD (/usr/bin/php /var/www/html/core/php/watchdog.php >> /dev/null)
Mar 31 06:35:02 jeedom CRON[21907]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 06:36:01 jeedom CRON[22080]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 06:37:02 jeedom CRON[22146]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 06:38:01 jeedom CRON[22221]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 06:39:01 jeedom CRON[22287]: (root) CMD (  [ -x /usr/lib/php/sessionclean ] && if [ ! -d /run/systemd/system ]; then /usr/lib/php/sessionclean; fi)
Suite …
Mar 31 06:39:01 jeedom CRON[22288]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 06:39:01 jeedom systemd[1]: Starting Clean php session files...
Mar 31 06:39:01 jeedom systemd[1]: phpsessionclean.service: Succeeded.
Mar 31 06:39:01 jeedom systemd[1]: Finished Clean php session files.
Mar 31 06:40:01 jeedom CRON[22406]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 06:40:01 jeedom CRON[22407]: (root) CMD (/usr/bin/php /var/www/html/core/php/watchdog.php >> /dev/null)
Mar 31 06:41:01 jeedom CRON[22594]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 06:42:01 jeedom CRON[22658]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 06:43:01 jeedom CRON[22745]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 06:44:01 jeedom CRON[22810]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 06:45:01 jeedom CRON[22875]: (root) CMD (/usr/bin/php /var/www/html/core/php/watchdog.php >> /dev/null)
Mar 31 06:45:01 jeedom CRON[22876]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 06:46:01 jeedom CRON[23050]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 06:47:01 jeedom CRON[23115]: (root) CMD (test -x /usr/sbin/anacron || ( cd / && run-parts --report /etc/cron.weekly ))
Mar 31 06:47:01 jeedom CRON[23116]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 06:48:01 jeedom CRON[23182]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 06:49:01 jeedom CRON[23254]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 06:50:01 jeedom CRON[23329]: (root) CMD (/usr/bin/php /var/www/html/core/php/watchdog.php >> /dev/null)
Mar 31 06:50:01 jeedom CRON[23330]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 06:51:01 jeedom CRON[23512]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 06:52:01 jeedom CRON[23581]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 06:53:01 jeedom CRON[23657]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 06:54:01 jeedom CRON[23737]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 06:55:01 jeedom CRON[23801]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 06:55:01 jeedom CRON[23802]: (root) CMD (/usr/bin/php /var/www/html/core/php/watchdog.php >> /dev/null)
Mar 31 06:56:01 jeedom CRON[23960]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 06:57:01 jeedom CRON[24046]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 06:58:01 jeedom CRON[24122]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 06:59:01 jeedom CRON[24192]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 07:00:02 jeedom CRON[24256]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 07:00:02 jeedom CRON[24257]: (root) CMD (/usr/bin/php /var/www/html/core/php/watchdog.php >> /dev/null)
Mar 31 07:01:01 jeedom CRON[24520]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 07:02:01 jeedom CRON[24595]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 07:03:01 jeedom CRON[24663]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 07:04:01 jeedom CRON[24732]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 07:05:01 jeedom CRON[24811]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 07:05:01 jeedom CRON[24812]: (root) CMD (/usr/bin/php /var/www/html/core/php/watchdog.php >> /dev/null)
Mar 31 07:06:01 jeedom CRON[24981]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 07:07:01 jeedom CRON[25044]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 07:08:01 jeedom CRON[25109]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 07:09:02 jeedom CRON[25178]: (root) CMD (  [ -x /usr/lib/php/sessionclean ] && if [ ! -d /run/systemd/system ]; then /usr/lib/php/sessionclean; fi)
Mar 31 07:09:02 jeedom CRON[25179]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 07:09:02 jeedom systemd[1]: Starting Clean php session files...
Mar 31 07:09:02 jeedom systemd[1]: phpsessionclean.service: Succeeded.
Mar 31 07:09:02 jeedom systemd[1]: Finished Clean php session files.
Mar 31 07:10:01 jeedom CRON[25299]: (root) CMD (/usr/bin/php /var/www/html/core/php/watchdog.php >> /dev/null)
Mar 31 07:10:01 jeedom CRON[25300]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 07:11:01 jeedom CRON[25493]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 07:12:01 jeedom CRON[25560]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 07:13:01 jeedom CRON[25623]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 07:14:01 jeedom CRON[25703]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 07:15:01 jeedom CRON[25769]: (root) CMD (/usr/bin/php /var/www/html/core/php/watchdog.php >> /dev/null)
Mar 31 07:15:01 jeedom CRON[25770]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 07:16:01 jeedom CRON[25941]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 07:17:01 jeedom CRON[26005]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
Mar 31 07:17:01 jeedom CRON[26006]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 07:18:01 jeedom CRON[26075]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 07:19:01 jeedom CRON[26155]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 07:20:01 jeedom CRON[26221]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 07:20:01 jeedom CRON[26222]: (root) CMD (/usr/bin/php /var/www/html/core/php/watchdog.php >> /dev/null)
Mar 31 07:21:01 jeedom CRON[26421]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 07:22:01 jeedom CRON[26506]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 07:23:01 jeedom CRON[26569]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 07:24:01 jeedom CRON[26660]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 07:25:02 jeedom CRON[26726]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 07:25:02 jeedom CRON[26727]: (root) CMD (/usr/bin/php /var/www/html/core/php/watchdog.php >> /dev/null)
Mar 31 07:26:01 jeedom CRON[26886]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 07:27:01 jeedom CRON[26950]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 07:28:02 jeedom CRON[27013]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 07:29:01 jeedom CRON[27081]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 07:30:01 jeedom CRON[27171]: (root) CMD (/usr/bin/php /var/www/html/core/php/watchdog.php >> /dev/null)
Mar 31 07:30:01 jeedom CRON[27170]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 07:31:01 jeedom CRON[27411]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 07:32:01 jeedom CRON[27474]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 07:33:01 jeedom CRON[27539]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 07:34:00 jeedom rngd[446]: stats: bits received from HRNG source: 340064
Mar 31 07:34:00 jeedom rngd[446]: stats: bits sent to kernel pool: 300000
Mar 31 07:34:00 jeedom rngd[446]: stats: entropy added to kernel pool: 300000
Mar 31 07:34:00 jeedom rngd[446]: stats: FIPS 140-2 successes: 17
Mar 31 07:34:00 jeedom rngd[446]: stats: FIPS 140-2 failures: 0
Mar 31 07:34:00 jeedom rngd[446]: stats: FIPS 140-2(2001-10-10) Monobit: 0
Mar 31 07:34:00 jeedom rngd[446]: stats: FIPS 140-2(2001-10-10) Poker: 0
Mar 31 07:34:00 jeedom rngd[446]: stats: FIPS 140-2(2001-10-10) Runs: 0
Mar 31 07:34:00 jeedom rngd[446]: stats: FIPS 140-2(2001-10-10) Long run: 0
Mar 31 07:34:00 jeedom rngd[446]: stats: FIPS 140-2(2001-10-10) Continuous run: 0
Mar 31 07:34:00 jeedom rngd[446]: stats: HRNG source speed: (min=654.445; avg=850.335; max=974.030)Kibits/s
Mar 31 07:34:00 jeedom rngd[446]: stats: FIPS tests speed: (min=20.960; avg=26.940; max=60.744)Mibits/s
Mar 31 07:34:00 jeedom rngd[446]: stats: Lowest ready-buffers level: 2
Mar 31 07:34:00 jeedom rngd[446]: stats: Entropy starvations: 0
Mar 31 07:34:00 jeedom rngd[446]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us
Mar 31 07:34:01 jeedom CRON[27614]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 07:35:01 jeedom CRON[27695]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 07:35:01 jeedom CRON[27694]: (root) CMD (/usr/bin/php /var/www/html/core/php/watchdog.php >> /dev/null)
Mar 31 07:36:01 jeedom CRON[27854]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 07:37:01 jeedom CRON[27928]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 07:38:01 jeedom CRON[27991]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 07:39:01 jeedom CRON[28058]: (root) CMD (  [ -x /usr/lib/php/sessionclean ] && if [ ! -d /run/systemd/system ]; then /usr/lib/php/sessionclean; fi)
Mar 31 07:39:01 jeedom CRON[28059]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 07:39:02 jeedom systemd[1]: Starting Clean php session files...
Mar 31 07:39:03 jeedom systemd[1]: phpsessionclean.service: Succeeded.
Mar 31 07:39:03 jeedom systemd[1]: Finished Clean php session files.
Mar 31 07:40:01 jeedom CRON[28201]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 07:40:01 jeedom CRON[28202]: (root) CMD (/usr/bin/php /var/www/html/core/php/watchdog.php >> /dev/null)
Mar 31 07:41:01 jeedom CRON[28386]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 07:42:01 jeedom CRON[28449]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 07:43:01 jeedom CRON[28516]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 07:44:01 jeedom CRON[28594]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 07:45:01 jeedom CRON[28659]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 07:45:01 jeedom CRON[28660]: (root) CMD (/usr/bin/php /var/www/html/core/php/watchdog.php >> /dev/null)
Mar 31 07:46:01 jeedom CRON[28844]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 07:47:01 jeedom CRON[28907]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 07:48:01 jeedom CRON[28971]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 07:49:01 jeedom CRON[29038]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 07:50:01 jeedom CRON[29104]: (root) CMD (/usr/bin/php /var/www/html/core/php/watchdog.php >> /dev/null)
Mar 31 07:50:01 jeedom CRON[29103]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 07:51:01 jeedom CRON[29310]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 07:52:01 jeedom CRON[29374]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 07:53:01 jeedom CRON[29442]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 07:54:01 jeedom CRON[29510]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 07:55:01 jeedom CRON[29585]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 07:55:01 jeedom CRON[29586]: (root) CMD (/usr/bin/php /var/www/html/core/php/watchdog.php >> /dev/null)
Mar 31 07:56:01 jeedom CRON[29746]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 07:57:01 jeedom CRON[29822]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 07:58:01 jeedom CRON[29906]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 07:59:01 jeedom CRON[29971]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 08:00:01 jeedom CRON[30046]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 08:00:01 jeedom CRON[30047]: (root) CMD (/usr/bin/php /var/www/html/core/php/watchdog.php >> /dev/null)
Mar 31 08:01:01 jeedom CRON[30304]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 08:02:01 jeedom CRON[30376]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 08:03:01 jeedom CRON[30441]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 08:04:01 jeedom CRON[30521]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 08:05:01 jeedom CRON[30588]: (root) CMD (/usr/bin/php /var/www/html/core/php/watchdog.php >> /dev/null)
Mar 31 08:05:01 jeedom CRON[30589]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 08:06:01 jeedom CRON[30748]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 08:07:01 jeedom CRON[30815]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 08:08:01 jeedom CRON[30879]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 08:09:01 jeedom CRON[30958]: (root) CMD (  [ -x /usr/lib/php/sessionclean ] && if [ ! -d /run/systemd/system ]; then /usr/lib/php/sessionclean; fi)
Mar 31 08:09:01 jeedom CRON[30959]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 08:09:01 jeedom systemd[1]: Starting Clean php session files...
Mar 31 08:09:01 jeedom systemd[1]: phpsessionclean.service: Succeeded.
Mar 31 08:09:01 jeedom systemd[1]: Finished Clean php session files.
Mar 31 08:10:01 jeedom CRON[31089]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 08:10:01 jeedom CRON[31090]: (root) CMD (/usr/bin/php /var/www/html/core/php/watchdog.php >> /dev/null)
Mar 31 08:11:01 jeedom CRON[31272]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 08:12:01 jeedom CRON[31337]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 08:13:01 jeedom CRON[31408]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 08:14:01 jeedom CRON[31473]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 08:15:01 jeedom CRON[31549]: (root) CMD (/usr/bin/php /var/www/html/core/php/watchdog.php >> /dev/null)
Mar 31 08:15:01 jeedom CRON[31550]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 08:16:01 jeedom CRON[31732]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 08:17:01 jeedom CRON[31797]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 08:17:01 jeedom CRON[31798]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
Mar 31 08:18:01 jeedom CRON[31869]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 08:19:01 jeedom CRON[31947]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 08:20:01 jeedom CRON[32012]: (root) CMD (/usr/bin/php /var/www/html/core/php/watchdog.php >> /dev/null)
Mar 31 08:20:01 jeedom CRON[32013]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 08:21:01 jeedom CRON[32200]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 08:22:01 jeedom CRON[32274]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 08:23:01 jeedom CRON[32339]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 08:24:01 jeedom CRON[32408]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 08:25:01 jeedom CRON[32473]: (root) CMD (/usr/bin/php /var/www/html/core/php/watchdog.php >> /dev/null)
Mar 31 08:25:01 jeedom CRON[32472]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 08:26:01 jeedom CRON[32642]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 08:27:01 jeedom CRON[32706]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 08:28:01 jeedom CRON[303]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 08:29:01 jeedom CRON[398]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 08:30:01 jeedom CRON[1022]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 08:30:01 jeedom CRON[1023]: (root) CMD (/usr/bin/php /var/www/html/core/php/watchdog.php >> /dev/null)
Mar 31 08:31:01 jeedom CRON[1370]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 08:32:01 jeedom CRON[1439]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 08:33:01 jeedom CRON[1506]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Suite et fin
Mar 31 08:34:00 jeedom rngd[446]: stats: bits received from HRNG source: 380064
Mar 31 08:34:00 jeedom rngd[446]: stats: bits sent to kernel pool: 330240
Mar 31 08:34:00 jeedom rngd[446]: stats: entropy added to kernel pool: 330240
Mar 31 08:34:00 jeedom rngd[446]: stats: FIPS 140-2 successes: 19
Mar 31 08:34:00 jeedom rngd[446]: stats: FIPS 140-2 failures: 0
Mar 31 08:34:00 jeedom rngd[446]: stats: FIPS 140-2(2001-10-10) Monobit: 0
Mar 31 08:34:00 jeedom rngd[446]: stats: FIPS 140-2(2001-10-10) Poker: 0
Mar 31 08:34:00 jeedom rngd[446]: stats: FIPS 140-2(2001-10-10) Runs: 0
Mar 31 08:34:00 jeedom rngd[446]: stats: FIPS 140-2(2001-10-10) Long run: 0
Mar 31 08:34:00 jeedom rngd[446]: stats: FIPS 140-2(2001-10-10) Continuous run: 0
Mar 31 08:34:00 jeedom rngd[446]: stats: HRNG source speed: (min=654.445; avg=853.034; max=974.030)Kibits/s
Mar 31 08:34:00 jeedom rngd[446]: stats: FIPS tests speed: (min=20.960; avg=26.777; max=60.744)Mibits/s
Mar 31 08:34:00 jeedom rngd[446]: stats: Lowest ready-buffers level: 2
Mar 31 08:34:00 jeedom rngd[446]: stats: Entropy starvations: 0
Mar 31 08:34:00 jeedom rngd[446]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us
Mar 31 08:34:01 jeedom CRON[1588]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 08:35:01 jeedom CRON[1657]: (root) CMD (/usr/bin/php /var/www/html/core/php/watchdog.php >> /dev/null)
Mar 31 08:35:01 jeedom CRON[1658]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 08:36:01 jeedom CRON[1885]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 08:37:01 jeedom CRON[1949]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 08:38:01 jeedom CRON[2032]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 08:39:01 jeedom CRON[2113]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 08:39:01 jeedom CRON[2112]: (root) CMD (  [ -x /usr/lib/php/sessionclean ] && if [ ! -d /run/systemd/system ]; then /usr/lib/php/sessionclean; fi)
Mar 31 08:39:03 jeedom systemd[1]: Starting Clean php session files...
Mar 31 08:39:03 jeedom systemd[1]: phpsessionclean.service: Succeeded.
Mar 31 08:39:03 jeedom systemd[1]: Finished Clean php session files.
Mar 31 08:40:01 jeedom CRON[2233]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 08:40:01 jeedom CRON[2234]: (root) CMD (/usr/bin/php /var/www/html/core/php/watchdog.php >> /dev/null)
Mar 31 08:41:01 jeedom CRON[2454]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 08:42:01 jeedom CRON[2527]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 08:43:01 jeedom CRON[2605]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 08:44:01 jeedom CRON[2675]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 08:45:01 jeedom CRON[2739]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 08:45:01 jeedom CRON[2740]: (root) CMD (/usr/bin/php /var/www/html/core/php/watchdog.php >> /dev/null)
Mar 31 08:46:02 jeedom CRON[2943]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 08:47:01 jeedom CRON[3018]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 08:48:01 jeedom CRON[3092]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 08:49:01 jeedom CRON[3161]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 08:50:01 jeedom CRON[3227]: (root) CMD (/usr/bin/php /var/www/html/core/php/watchdog.php >> /dev/null)
Mar 31 08:50:01 jeedom CRON[3228]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 08:51:01 jeedom CRON[3443]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 08:52:01 jeedom CRON[3507]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 08:53:01 jeedom CRON[3570]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 08:54:02 jeedom CRON[3654]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 08:55:01 jeedom CRON[3720]: (root) CMD (/usr/bin/php /var/www/html/core/php/watchdog.php >> /dev/null)
Mar 31 08:55:01 jeedom CRON[3721]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 08:56:01 jeedom CRON[3923]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 08:57:01 jeedom CRON[3987]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 08:58:01 jeedom CRON[4065]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 08:59:01 jeedom CRON[4144]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 09:00:01 jeedom CRON[4216]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 09:00:01 jeedom CRON[4215]: (root) CMD (/usr/bin/php /var/www/html/core/php/watchdog.php >> /dev/null)
Mar 31 09:01:01 jeedom CRON[4506]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 09:02:01 jeedom CRON[4571]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 09:03:01 jeedom CRON[4650]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 09:04:01 jeedom CRON[4728]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 09:05:01 jeedom CRON[4796]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 09:05:01 jeedom CRON[4797]: (root) CMD (/usr/bin/php /var/www/html/core/php/watchdog.php >> /dev/null)
Mar 31 09:06:01 jeedom CRON[4992]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 09:07:01 jeedom CRON[5056]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 09:08:01 jeedom CRON[5120]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 09:09:01 jeedom CRON[5187]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 09:09:01 jeedom CRON[5188]: (root) CMD (  [ -x /usr/lib/php/sessionclean ] && if [ ! -d /run/systemd/system ]; then /usr/lib/php/sessionclean; fi)
Mar 31 09:09:01 jeedom systemd[1]: Starting Clean php session files...
Mar 31 09:09:02 jeedom systemd[1]: phpsessionclean.service: Succeeded.
Mar 31 09:09:02 jeedom systemd[1]: Finished Clean php session files.
Mar 31 09:10:01 jeedom CRON[5318]: (root) CMD (/usr/bin/php /var/www/html/core/php/watchdog.php >> /dev/null)
Mar 31 09:10:01 jeedom CRON[5319]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 09:11:01 jeedom CRON[5536]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 09:12:01 jeedom CRON[5611]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 09:13:01 jeedom CRON[5677]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 09:14:01 jeedom CRON[5749]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 09:15:01 jeedom CRON[5825]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 09:15:01 jeedom CRON[5826]: (root) CMD (/usr/bin/php /var/www/html/core/php/watchdog.php >> /dev/null)
Mar 31 09:16:01 jeedom CRON[6041]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 09:17:01 jeedom CRON[6107]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
Mar 31 09:17:01 jeedom CRON[6108]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 09:18:01 jeedom CRON[6177]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 09:19:01 jeedom CRON[6246]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 09:20:02 jeedom CRON[6312]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 09:20:02 jeedom CRON[6313]: (root) CMD (/usr/bin/php /var/www/html/core/php/watchdog.php >> /dev/null)
Mar 31 09:21:01 jeedom CRON[6535]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 09:22:01 jeedom CRON[6600]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 09:23:01 jeedom CRON[6674]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 09:24:01 jeedom CRON[6753]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 09:25:01 jeedom CRON[6818]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 09:25:01 jeedom CRON[6817]: (root) CMD (/usr/bin/php /var/www/html/core/php/watchdog.php >> /dev/null)
Mar 31 09:26:01 jeedom CRON[7011]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 09:27:01 jeedom CRON[7074]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 09:28:01 jeedom CRON[7138]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 09:29:01 jeedom CRON[7230]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 09:30:02 jeedom CRON[7294]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 09:30:02 jeedom CRON[7295]: (root) CMD (/usr/bin/php /var/www/html/core/php/watchdog.php >> /dev/null)
Mar 31 09:31:01 jeedom CRON[7581]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 09:32:01 jeedom CRON[7667]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 09:33:01 jeedom CRON[7736]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 09:34:00 jeedom rngd[446]: stats: bits received from HRNG source: 400064
Mar 31 09:34:00 jeedom rngd[446]: stats: bits sent to kernel pool: 360000
Mar 31 09:34:00 jeedom rngd[446]: stats: entropy added to kernel pool: 360000
Mar 31 09:34:00 jeedom rngd[446]: stats: FIPS 140-2 successes: 20
Mar 31 09:34:00 jeedom rngd[446]: stats: FIPS 140-2 failures: 0
Mar 31 09:34:00 jeedom rngd[446]: stats: FIPS 140-2(2001-10-10) Monobit: 0
Mar 31 09:34:00 jeedom rngd[446]: stats: FIPS 140-2(2001-10-10) Poker: 0
Mar 31 09:34:00 jeedom rngd[446]: stats: FIPS 140-2(2001-10-10) Runs: 0
Mar 31 09:34:00 jeedom rngd[446]: stats: FIPS 140-2(2001-10-10) Long run: 0
Mar 31 09:34:00 jeedom rngd[446]: stats: FIPS 140-2(2001-10-10) Continuous run: 0
Mar 31 09:34:00 jeedom rngd[446]: stats: HRNG source speed: (min=654.445; avg=854.189; max=974.030)Kibits/s
Mar 31 09:34:00 jeedom rngd[446]: stats: FIPS tests speed: (min=20.960; avg=26.678; max=60.744)Mibits/s
Mar 31 09:34:00 jeedom rngd[446]: stats: Lowest ready-buffers level: 2
Mar 31 09:34:00 jeedom rngd[446]: stats: Entropy starvations: 0
Mar 31 09:34:00 jeedom rngd[446]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us
Mar 31 09:34:01 jeedom CRON[7803]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 09:35:01 jeedom CRON[7881]: (root) CMD (/usr/bin/php /var/www/html/core/php/watchdog.php >> /dev/null)
Mar 31 09:35:01 jeedom CRON[7882]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 09:36:01 jeedom CRON[8075]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 09:37:01 jeedom CRON[8151]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 09:38:01 jeedom CRON[8216]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 09:39:01 jeedom CRON[8282]: (root) CMD (  [ -x /usr/lib/php/sessionclean ] && if [ ! -d /run/systemd/system ]; then /usr/lib/php/sessionclean; fi)
Mar 31 09:39:02 jeedom CRON[8283]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 09:39:02 jeedom systemd[1]: Starting Clean php session files...
Mar 31 09:39:02 jeedom systemd[1]: phpsessionclean.service: Succeeded.
Mar 31 09:39:02 jeedom systemd[1]: Finished Clean php session files.
Mar 31 09:40:01 jeedom CRON[8413]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 09:40:01 jeedom CRON[8414]: (root) CMD (/usr/bin/php /var/www/html/core/php/watchdog.php >> /dev/null)
Mar 31 09:41:01 jeedom CRON[8633]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 09:42:01 jeedom CRON[8713]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 09:43:01 jeedom CRON[8778]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 09:44:01 jeedom CRON[8842]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 09:45:01 jeedom CRON[8919]: (root) CMD (/usr/bin/php /var/www/html/core/php/watchdog.php >> /dev/null)
Mar 31 09:45:01 jeedom CRON[8918]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 09:46:02 jeedom CRON[9134]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 09:47:01 jeedom CRON[9198]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Mar 31 09:48:01 jeedom CRON[9273]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
A+ pour les logs en Wifi Freebox.
Salutations
Jean-Paul
/var/log/syslog a probablement été tronqué par la rotation des fichierrs journaux. De ce fait on ne voit pas la séquence de démarrage. On verra plus tard si elle peut être utile pour comprendre ce qui se passe. Pour l’instant, on voit un système bien géré, fonctionnant correctement. À voir ce que la suite va nous apprendre.
Dès que possible je re connecte mon RPI3B+ sur le Wifi de ma Freebox Révolution et j’envoie les logs.
Merci pour la réponse.
Salutations
Jean-Paul
Me revoilà
Je me suis connecté sans aucun Pb en Wifi sur ma Box Free.
Pour la configuration du Wifi je suis passé par « raspi-config » :
TimeZone > Europe/Paris
Wlan country > FR/France
Wireless Lan > SSID > « xxxxxx » (8 caractères) > MP > « xxxxx » (14 caractères)
Reboot et OK pour le Wifi.
Je me connecte à l’application Jeedom en Wifi depuis ma tablette et mon Pc portable et aussi après avoir éteins Jeedom et redémarré le RPI (Super).
Les logs demandés avec le Wifi à partir de ma Freebox Révolution sont énormes, le post limite à 32.0000 caractères et les gros logs font plus de 52.000.
Je ne sais pas comment faire sans « tronquer » les fichiers.
Salutations
Jean-Paul
Bonjour @pommedapi
Voila des logs demandés :
sudo journalctl -u NetworkManager :
-- Journal begins at Tue 2024-03-12 02:14:28 CET, ends at Mon 2024-04-01 11:08:35 CEST. --
-- No entries --
sudo journalctl -u dhcpcd : (Fichier énorme j’ai pris uniquement la date du 1er avril et déja pas mal).
-- Boot dfbac8836ed24ef8a83fc9833c57e072 --
Apr 01 09:20:16 jeedom systemd[1]: Starting DHCP Client Daemon...
Apr 01 09:20:16 jeedom dhcpcd[365]: dev: loaded udev
Apr 01 09:20:17 jeedom dhcpcd[451]: wlan0: starting wpa_supplicant
Apr 01 09:20:18 jeedom dhcpcd[365]: wlan0: connected to Access Point `'
Apr 01 09:20:18 jeedom dhcpcd[365]: eth0: waiting for carrier
Apr 01 09:20:18 jeedom dhcpcd[365]: wlan0: waiting for carrier
Apr 01 09:20:18 jeedom dhcpcd[365]: eth0: carrier acquired
Apr 01 09:20:18 jeedom dhcpcd[365]: DUID 00:01:00:01:2d:82:69:fc:b8:27:eb:2f:f0:21
Apr 01 09:20:18 jeedom dhcpcd[365]: eth0: IAID eb:2f:f0:21
Apr 01 09:20:18 jeedom dhcpcd[365]: eth0: adding address fe80::54b2:650d:d182:18cb
Apr 01 09:20:18 jeedom dhcpcd[365]: eth0: soliciting an IPv6 router
Apr 01 09:20:18 jeedom dhcpcd[365]: eth0: rebinding lease of 192.168.0.17
Apr 01 09:20:18 jeedom dhcpcd[365]: eth0: probing address 192.168.0.17/24
Apr 01 09:20:19 jeedom dhcpcd[365]: eth0: Router Advertisement from fe80::72fc:8fff:fe42:e786
Apr 01 09:20:19 jeedom dhcpcd[365]: eth0: adding address 2a01:e0a:376:2760:73e2:116a:acc3:1ab7/64
Apr 01 09:20:19 jeedom dhcpcd[365]: eth0: adding route to 2a01:e0a:376:2760::/64
Apr 01 09:20:19 jeedom dhcpcd[365]: eth0: adding default route via fe80::72fc:8fff:fe42:e786
Apr 01 09:20:20 jeedom dhcpcd[365]: eth0: Router Advertisement from fe80::8628:59ff:feee:184e
Apr 01 09:20:23 jeedom dhcpcd[365]: wlan0: carrier acquired
Apr 01 09:20:23 jeedom dhcpcd[365]: wlan0: connected to Access Point `Cidex816'
Apr 01 09:20:23 jeedom dhcpcd[365]: wlan0: IAID eb:7a:a5:74
Apr 01 09:20:23 jeedom dhcpcd[365]: wlan0: adding address fe80::ee82:6aac:9f9a:2bda
Apr 01 09:20:23 jeedom dhcpcd[365]: eth0: leased 192.168.0.17 for 43200 seconds
Apr 01 09:20:23 jeedom dhcpcd[365]: eth0: adding route to 192.168.0.0/24
Apr 01 09:20:23 jeedom dhcpcd[365]: eth0: adding default route via 192.168.0.254
Apr 01 09:20:23 jeedom dhcpcd[365]: forked to background, child pid 801
Apr 01 09:20:23 jeedom systemd[1]: Started DHCP Client Daemon.
Apr 01 09:20:24 jeedom dhcpcd[801]: wlan0: rebinding lease of 192.168.0.157
Apr 01 09:20:24 jeedom dhcpcd[801]: wlan0: soliciting an IPv6 router
Apr 01 09:20:26 jeedom dhcpcd[801]: wlan0: Router Advertisement from fe80::8628:59ff:feee:184e
Apr 01 09:20:28 jeedom dhcpcd[801]: wlan0: NAK: from 192.168.0.254
Apr 01 09:20:28 jeedom dhcpcd[801]: wlan0: soliciting a DHCP lease
Apr 01 09:20:32 jeedom dhcpcd[801]: wlan0: offered 192.168.0.157 from 192.168.0.254
Apr 01 09:20:33 jeedom dhcpcd[801]: wlan0: probing for an IPv4LL address
Apr 01 09:20:34 jeedom dhcpcd[801]: wlan0: probing address 192.168.0.157/24
Apr 01 09:20:38 jeedom dhcpcd[801]: wlan0: using IPv4LL address 169.254.45.138
Apr 01 09:20:38 jeedom dhcpcd[801]: wlan0: adding route to 169.254.0.0/16
Apr 01 09:20:39 jeedom dhcpcd[801]: wlan0: leased 192.168.0.157 for 43200 seconds
Apr 01 09:20:39 jeedom dhcpcd[801]: wlan0: adding route to 192.168.0.0/24
Apr 01 09:20:39 jeedom dhcpcd[801]: wlan0: adding default route via 192.168.0.254
Apr 01 09:20:40 jeedom dhcpcd[801]: wlan0: deleting route to 169.254.0.0/16
Apr 01 09:28:03 jeedom dhcpcd[801]: eth0: Router Advertisement from fe80::72fc:8fff:fe42:e786
Apr 01 09:29:27 jeedom dhcpcd[801]: wlan0: carrier lost
Apr 01 09:29:27 jeedom dhcpcd[801]: wlan0: deleting address fe80::ee82:6aac:9f9a:2bda
Apr 01 09:29:27 jeedom dhcpcd[801]: wlan0: deleting route to 192.168.0.0/24
Apr 01 09:29:27 jeedom dhcpcd[801]: wlan0: deleting default route via 192.168.0.254
Apr 01 09:29:27 jeedom dhcpcd[801]: wlan0: carrier acquired
Apr 01 09:29:27 jeedom dhcpcd[801]: wlan0: IAID eb:7a:a5:74
Apr 01 09:29:27 jeedom dhcpcd[801]: wlan0: adding address fe80::ee82:6aac:9f9a:2bda
Apr 01 09:29:28 jeedom dhcpcd[801]: wlan0: soliciting an IPv6 router
Apr 01 09:29:28 jeedom dhcpcd[801]: wlan0: rebinding lease of 192.168.0.157
Apr 01 09:29:28 jeedom dhcpcd[801]: wlan0: probing address 192.168.0.157/24
Apr 01 09:29:33 jeedom dhcpcd[801]: wlan0: leased 192.168.0.157 for 43200 seconds
Apr 01 09:29:33 jeedom dhcpcd[801]: wlan0: adding route to 192.168.0.0/24
Apr 01 09:29:33 jeedom dhcpcd[801]: wlan0: adding default route via 192.168.0.254
Apr 01 09:29:39 jeedom dhcpcd[801]: wlan0: Router Advertisement from fe80::72fc:8fff:fe42:e786
Apr 01 09:29:39 jeedom dhcpcd[801]: wlan0: adding address 2a01:e0a:376:2760:218f:433b:2c2f:d3e2/64
Apr 01 09:29:39 jeedom dhcpcd[801]: wlan0: adding route to 2a01:e0a:376:2760::/64
Apr 01 09:29:39 jeedom dhcpcd[801]: wlan0: adding default route via fe80::72fc:8fff:fe42:e786
Apr 01 09:29:39 jeedom dhcpcd[801]: wlan0: Router Advertisement from fe80::8628:59ff:feee:184e
Apr 01 09:41:52 jeedom dhcpcd[801]: wlan0: carrier lost
Apr 01 09:41:53 jeedom dhcpcd[801]: wlan0: deleting address 2a01:e0a:376:2760:218f:433b:2c2f:d3e2/64
Apr 01 09:41:53 jeedom dhcpcd[801]: wlan0: deleting route to 2a01:e0a:376:2760::/64
Apr 01 09:41:53 jeedom dhcpcd[801]: wlan0: deleting default route via fe80::72fc:8fff:fe42:e786
Apr 01 09:41:53 jeedom dhcpcd[801]: wlan0: deleting address fe80::ee82:6aac:9f9a:2bda
Apr 01 09:41:53 jeedom dhcpcd[801]: wlan0: deleting route to 192.168.0.0/24
Apr 01 09:41:53 jeedom dhcpcd[801]: wlan0: deleting default route via 192.168.0.254
Apr 01 09:41:53 jeedom dhcpcd[801]: wlan0: carrier acquired
Apr 01 09:41:53 jeedom dhcpcd[801]: wlan0: IAID eb:7a:a5:74
Apr 01 09:41:53 jeedom dhcpcd[801]: wlan0: adding address fe80::ee82:6aac:9f9a:2bda
Apr 01 09:41:54 jeedom dhcpcd[801]: wlan0: rebinding lease of 192.168.0.157
Apr 01 09:41:54 jeedom dhcpcd[801]: wlan0: soliciting an IPv6 router
Apr 01 09:41:59 jeedom dhcpcd[801]: wlan0: probing for an IPv4LL address
Apr 01 09:41:59 jeedom dhcpcd[801]: wlan0: DHCP lease expired
Apr 01 09:41:59 jeedom dhcpcd[801]: wlan0: soliciting a DHCP lease
Apr 01 09:42:02 jeedom dhcpcd[801]: wlan0: offered 192.168.0.157 from 192.168.0.254
Apr 01 09:42:04 jeedom dhcpcd[801]: wlan0: using IPv4LL address 169.254.45.138
Apr 01 09:42:04 jeedom dhcpcd[801]: wlan0: adding route to 169.254.0.0/16
Apr 01 09:42:04 jeedom dhcpcd[801]: wlan0: Router Advertisement from fe80::72fc:8fff:fe42:e786
Apr 01 09:42:04 jeedom dhcpcd[801]: wlan0: adding address 2a01:e0a:376:2760:218f:433b:2c2f:d3e2/64
Apr 01 09:42:04 jeedom dhcpcd[801]: wlan0: adding route to 2a01:e0a:376:2760::/64
Apr 01 09:42:04 jeedom dhcpcd[801]: wlan0: adding default route via fe80::72fc:8fff:fe42:e786
Apr 01 09:42:04 jeedom dhcpcd[801]: wlan0: probing address 192.168.0.157/24
Apr 01 09:42:05 jeedom dhcpcd[801]: wlan0: Router Advertisement from fe80::8628:59ff:feee:184e
Apr 01 09:42:09 jeedom dhcpcd[801]: wlan0: leased 192.168.0.157 for 43200 seconds
Apr 01 09:42:09 jeedom dhcpcd[801]: wlan0: adding route to 192.168.0.0/24
Apr 01 09:42:09 jeedom dhcpcd[801]: wlan0: adding default route via 192.168.0.254
Apr 01 09:42:09 jeedom dhcpcd[801]: wlan0: deleting route to 169.254.0.0/16
Apr 01 09:42:26 jeedom dhcpcd[801]: wlan0: Router Advertisement from fe80::72fc:8fff:fe42:e786
Apr 01 10:05:45 jeedom systemd[1]: Stopping DHCP Client Daemon...
Apr 01 10:05:45 jeedom dhcpcd[801]: received SIGTERM, stopping
Apr 01 10:05:45 jeedom dhcpcd[801]: wlan0: removing interface
Apr 01 10:05:45 jeedom dhcpcd[801]: eth0: removing interface
Apr 01 10:05:45 jeedom dhcpcd[801]: dhcpcd exited
Apr 01 10:05:45 jeedom systemd[1]: dhcpcd.service: Succeeded.
Apr 01 10:05:45 jeedom systemd[1]: Stopped DHCP Client Daemon.
Apr 01 10:05:45 jeedom systemd[1]: dhcpcd.service: Consumed 3.849s CPU time.
-- Boot 647d335a0a9d4e55999a6a5c435aa758 --
Apr 01 10:05:50 jeedom systemd[1]: Starting DHCP Client Daemon...
Apr 01 10:05:50 jeedom dhcpcd[365]: dev: loaded udev
Apr 01 10:05:51 jeedom dhcpcd[451]: wlan0: starting wpa_supplicant
Apr 01 10:05:51 jeedom dhcpcd-run-hooks[460]: wlan0: starting wpa_supplicant
Apr 01 10:05:52 jeedom dhcpcd[365]: wlan0: connected to Access Point `'
Apr 01 10:05:52 jeedom dhcpcd[365]: eth0: waiting for carrier
Apr 01 10:05:52 jeedom dhcpcd[365]: wlan0: waiting for carrier
Apr 01 10:05:52 jeedom dhcpcd[365]: eth0: carrier acquired
Apr 01 10:05:52 jeedom dhcpcd[365]: DUID 00:01:00:01:2d:82:69:fc:b8:27:eb:2f:f0:21
Apr 01 10:05:52 jeedom dhcpcd[365]: eth0: IAID eb:2f:f0:21
Apr 01 10:05:52 jeedom dhcpcd[365]: eth0: adding address fe80::54b2:650d:d182:18cb
Apr 01 10:05:52 jeedom dhcpcd[365]: eth0: rebinding lease of 192.168.0.17
Apr 01 10:05:52 jeedom dhcpcd[365]: eth0: probing address 192.168.0.17/24
Apr 01 10:05:53 jeedom dhcpcd[365]: eth0: soliciting an IPv6 router
Apr 01 10:05:53 jeedom dhcpcd[365]: eth0: Router Advertisement from fe80::72fc:8fff:fe42:e786
Apr 01 10:05:53 jeedom dhcpcd[365]: eth0: adding address 2a01:e0a:376:2760:73e2:116a:acc3:1ab7/64
Apr 01 10:05:53 jeedom dhcpcd[365]: eth0: adding route to 2a01:e0a:376:2760::/64
Apr 01 10:05:53 jeedom dhcpcd[365]: eth0: adding default route via fe80::72fc:8fff:fe42:e786
Apr 01 10:05:57 jeedom dhcpcd[365]: eth0: leased 192.168.0.17 for 43200 seconds
Apr 01 10:05:57 jeedom dhcpcd[365]: eth0: adding route to 192.168.0.0/24
Apr 01 10:05:57 jeedom dhcpcd[365]: eth0: adding default route via 192.168.0.254
Apr 01 10:05:57 jeedom dhcpcd[365]: forked to background, child pid 738
Apr 01 10:05:57 jeedom systemd[1]: Started DHCP Client Daemon.
Apr 01 10:05:57 jeedom dhcpcd[738]: wlan0: carrier acquired
Apr 01 10:05:57 jeedom dhcpcd[738]: wlan0: connected to Access Point `Cidex816'
Apr 01 10:05:57 jeedom dhcpcd[738]: wlan0: IAID eb:7a:a5:74
Apr 01 10:05:57 jeedom dhcpcd[738]: wlan0: adding address fe80::ee82:6aac:9f9a:2bda
Apr 01 10:05:58 jeedom dhcpcd[738]: wlan0: soliciting an IPv6 router
Apr 01 10:05:58 jeedom dhcpcd[738]: wlan0: rebinding lease of 192.168.0.157
Apr 01 10:05:58 jeedom dhcpcd[738]: wlan0: probing address 192.168.0.157/24
Apr 01 10:05:59 jeedom dhcpcd[738]: wlan0: Router Advertisement from fe80::72fc:8fff:fe42:e786
Apr 01 10:05:59 jeedom dhcpcd[738]: wlan0: adding address 2a01:e0a:376:2760:218f:433b:2c2f:d3e2/64
Apr 01 10:05:59 jeedom dhcpcd[738]: wlan0: adding route to 2a01:e0a:376:2760::/64
Apr 01 10:05:59 jeedom dhcpcd[738]: wlan0: adding default route via fe80::72fc:8fff:fe42:e786
Apr 01 10:05:59 jeedom dhcpcd[738]: eth0: Router Advertisement from fe80::8628:59ff:feee:184e
Apr 01 10:05:59 jeedom dhcpcd[738]: wlan0: Router Advertisement from fe80::8628:59ff:feee:184e
Apr 01 10:06:00 jeedom dhcpcd[738]: eth0: Router Advertisement from fe80::72fc:8fff:fe42:e786
Apr 01 10:06:03 jeedom dhcpcd[738]: wlan0: leased 192.168.0.157 for 43200 seconds
Apr 01 10:06:03 jeedom dhcpcd[738]: wlan0: adding route to 192.168.0.0/24
Apr 01 10:06:03 jeedom dhcpcd[738]: wlan0: adding default route via 192.168.0.254
Apr 01 10:15:16 jeedom dhcpcd[738]: wlan0: Router Advertisement from fe80::72fc:8fff:fe42:e786
Apr 01 10:16:46 jeedom systemd[1]: Stopping DHCP Client Daemon...
Apr 01 10:16:46 jeedom dhcpcd[738]: received SIGTERM, stopping
Apr 01 10:16:46 jeedom dhcpcd[738]: wlan0: removing interface
Apr 01 10:16:46 jeedom dhcpcd[738]: eth0: removing interface
Apr 01 10:16:46 jeedom dhcpcd[738]: dhcpcd exited
Apr 01 10:16:47 jeedom systemd[1]: dhcpcd.service: Succeeded.
Apr 01 10:16:47 jeedom systemd[1]: Stopped DHCP Client Daemon.
Apr 01 10:16:47 jeedom systemd[1]: dhcpcd.service: Consumed 1.528s CPU time.
-- Boot d3f5d2d6f3b749b59ab14e6a13cd32f0 --
Apr 01 10:16:52 jeedom systemd[1]: Starting DHCP Client Daemon...
Apr 01 10:16:52 jeedom dhcpcd[366]: dev: loaded udev
Apr 01 10:16:53 jeedom dhcpcd[451]: wlan0: starting wpa_supplicant
Apr 01 10:16:53 jeedom dhcpcd-run-hooks[462]: wlan0: starting wpa_supplicant
Apr 01 10:16:54 jeedom dhcpcd[366]: wlan0: connected to Access Point `'
Apr 01 10:16:54 jeedom dhcpcd[366]: eth0: waiting for carrier
Apr 01 10:16:54 jeedom dhcpcd[366]: wlan0: waiting for carrier
Apr 01 10:16:54 jeedom dhcpcd[366]: eth0: carrier acquired
Apr 01 10:16:54 jeedom dhcpcd[366]: DUID 00:01:00:01:2d:82:69:fc:b8:27:eb:2f:f0:21
Apr 01 10:16:54 jeedom dhcpcd[366]: eth0: IAID eb:2f:f0:21
Apr 01 10:16:54 jeedom dhcpcd[366]: eth0: adding address fe80::54b2:650d:d182:18cb
Apr 01 10:16:54 jeedom dhcpcd[366]: eth0: rebinding lease of 192.168.0.17
Apr 01 10:16:54 jeedom dhcpcd[366]: eth0: probing address 192.168.0.17/24
Apr 01 10:16:54 jeedom dhcpcd[366]: eth0: soliciting an IPv6 router
Apr 01 10:16:55 jeedom dhcpcd[366]: eth0: Router Advertisement from fe80::72fc:8fff:fe42:e786
Apr 01 10:16:55 jeedom dhcpcd[366]: eth0: adding address 2a01:e0a:376:2760:73e2:116a:acc3:1ab7/64
Apr 01 10:16:55 jeedom dhcpcd[366]: eth0: adding route to 2a01:e0a:376:2760::/64
Apr 01 10:16:55 jeedom dhcpcd[366]: eth0: adding default route via fe80::72fc:8fff:fe42:e786
Apr 01 10:16:56 jeedom dhcpcd[366]: eth0: Router Advertisement from fe80::8628:59ff:feee:184e
Apr 01 10:16:59 jeedom dhcpcd[366]: eth0: leased 192.168.0.17 for 43200 seconds
Apr 01 10:16:59 jeedom dhcpcd[366]: eth0: adding route to 192.168.0.0/24
Apr 01 10:16:59 jeedom dhcpcd[366]: eth0: adding default route via 192.168.0.254
Apr 01 10:17:00 jeedom dhcpcd[366]: forked to background, child pid 798
Apr 01 10:17:00 jeedom systemd[1]: Started DHCP Client Daemon.
Apr 01 10:17:10 jeedom dhcpcd[798]: wlan0: carrier acquired
Apr 01 10:17:10 jeedom dhcpcd[798]: wlan0: connected to Access Point `Cidex816'
Apr 01 10:17:10 jeedom dhcpcd[798]: wlan0: IAID eb:7a:a5:74
Apr 01 10:17:10 jeedom dhcpcd[798]: wlan0: adding address fe80::ee82:6aac:9f9a:2bda
Apr 01 10:17:11 jeedom dhcpcd[798]: wlan0: soliciting an IPv6 router
Apr 01 10:17:11 jeedom dhcpcd[798]: wlan0: rebinding lease of 192.168.0.157
Apr 01 10:17:16 jeedom dhcpcd[798]: wlan0: Router Advertisement from fe80::72fc:8fff:fe42:e786
Apr 01 10:17:16 jeedom dhcpcd[798]: wlan0: adding address 2a01:e0a:376:2760:218f:433b:2c2f:d3e2/64
Apr 01 10:17:16 jeedom dhcpcd[798]: wlan0: adding route to 2a01:e0a:376:2760::/64
Apr 01 10:17:16 jeedom dhcpcd[798]: wlan0: adding default route via fe80::72fc:8fff:fe42:e786
Apr 01 10:17:16 jeedom dhcpcd[798]: wlan0: probing for an IPv4LL address
Apr 01 10:17:16 jeedom dhcpcd[798]: wlan0: DHCP lease expired
Apr 01 10:17:16 jeedom dhcpcd[798]: wlan0: soliciting a DHCP lease
Apr 01 10:17:16 jeedom dhcpcd[798]: wlan0: offered 192.168.0.157 from 192.168.0.254
Apr 01 10:17:17 jeedom dhcpcd[798]: wlan0: Router Advertisement from fe80::8628:59ff:feee:184e
Apr 01 10:17:19 jeedom dhcpcd[798]: wlan0: probing address 192.168.0.157/24
Apr 01 10:17:21 jeedom dhcpcd[798]: wlan0: using IPv4LL address 169.254.45.138
Apr 01 10:17:21 jeedom dhcpcd[798]: wlan0: adding route to 169.254.0.0/16
Apr 01 10:17:24 jeedom dhcpcd[798]: wlan0: leased 192.168.0.157 for 43200 seconds
Apr 01 10:17:24 jeedom dhcpcd[798]: wlan0: adding route to 192.168.0.0/24
Apr 01 10:17:24 jeedom dhcpcd[798]: wlan0: adding default route via 192.168.0.254
Apr 01 10:17:24 jeedom dhcpcd[798]: wlan0: deleting route to 169.254.0.0/16
Apr 01 10:20:53 jeedom dhcpcd[798]: eth0: Router Advertisement from fe80::72fc:8fff:fe42:e786
Apr 01 10:20:53 jeedom dhcpcd[798]: wlan0: Router Advertisement from fe80::72fc:8fff:fe42:e786
Apr 01 10:22:02 jeedom dhcpcd[798]: wlan0: carrier lost
Apr 01 10:22:03 jeedom dhcpcd[798]: wlan0: deleting address 2a01:e0a:376:2760:218f:433b:2c2f:d3e2/64
Apr 01 10:22:03 jeedom dhcpcd[798]: wlan0: deleting route to 2a01:e0a:376:2760::/64
Apr 01 10:22:03 jeedom dhcpcd[798]: wlan0: deleting default route via fe80::72fc:8fff:fe42:e786
Apr 01 10:22:03 jeedom dhcpcd[798]: wlan0: deleting address fe80::ee82:6aac:9f9a:2bda
Apr 01 10:22:03 jeedom dhcpcd[798]: wlan0: deleting route to 192.168.0.0/24
Apr 01 10:22:03 jeedom dhcpcd[798]: wlan0: deleting default route via 192.168.0.254
Apr 01 10:22:03 jeedom dhcpcd[798]: wlan0: carrier acquired
Apr 01 10:22:03 jeedom dhcpcd[798]: wlan0: IAID eb:7a:a5:74
Apr 01 10:22:03 jeedom dhcpcd[798]: wlan0: adding address fe80::ee82:6aac:9f9a:2bda
Apr 01 10:22:04 jeedom dhcpcd[798]: wlan0: rebinding lease of 192.168.0.157
Apr 01 10:22:04 jeedom dhcpcd[798]: wlan0: soliciting an IPv6 router
Apr 01 10:22:04 jeedom dhcpcd[798]: wlan0: probing address 192.168.0.157/24
Apr 01 10:22:09 jeedom dhcpcd[798]: wlan0: leased 192.168.0.157 for 43200 seconds
Apr 01 10:22:09 jeedom dhcpcd[798]: wlan0: adding route to 192.168.0.0/24
Apr 01 10:22:09 jeedom dhcpcd[798]: wlan0: adding default route via 192.168.0.254
Apr 01 10:22:14 jeedom dhcpcd[798]: wlan0: Router Advertisement from fe80::72fc:8fff:fe42:e786
Apr 01 10:22:14 jeedom dhcpcd[798]: wlan0: adding address 2a01:e0a:376:2760:218f:433b:2c2f:d3e2/64
Apr 01 10:22:14 jeedom dhcpcd[798]: wlan0: adding route to 2a01:e0a:376:2760::/64
Apr 01 10:22:14 jeedom dhcpcd[798]: wlan0: adding default route via fe80::72fc:8fff:fe42:e786
Apr 01 10:22:15 jeedom dhcpcd[798]: wlan0: Router Advertisement from fe80::8628:59ff:feee:184e
Apr 01 10:24:54 jeedom dhcpcd[798]: eth0: fe80::72fc:8fff:fe42:e786 is unreachable
Apr 01 10:24:54 jeedom dhcpcd[798]: wlan0: carrier lost
Apr 01 10:24:54 jeedom dhcpcd[798]: wlan0: deleting address 2a01:e0a:376:2760:218f:433b:2c2f:d3e2/64
Apr 01 10:24:54 jeedom dhcpcd[798]: wlan0: deleting route to 2a01:e0a:376:2760::/64
Apr 01 10:24:54 jeedom dhcpcd[798]: wlan0: deleting default route via fe80::72fc:8fff:fe42:e786
Apr 01 10:24:54 jeedom dhcpcd[798]: wlan0: deleting address fe80::ee82:6aac:9f9a:2bda
Apr 01 10:24:54 jeedom dhcpcd[798]: wlan0: deleting route to 192.168.0.0/24
Apr 01 10:24:54 jeedom dhcpcd[798]: wlan0: deleting default route via 192.168.0.254
Apr 01 10:24:54 jeedom dhcpcd[798]: eth0: soliciting an IPv6 router
Apr 01 10:24:54 jeedom dhcpcd[798]: eth0: Router Advertisement from fe80::72fc:8fff:fe42:e786
Apr 01 10:25:11 jeedom dhcpcd[798]: wlan0: carrier acquired
Apr 01 10:25:11 jeedom dhcpcd[798]: wlan0: IAID eb:7a:a5:74
Apr 01 10:25:11 jeedom dhcpcd[798]: wlan0: adding address fe80::ee82:6aac:9f9a:2bda
Apr 01 10:25:11 jeedom dhcpcd[798]: wlan0: rebinding lease of 192.168.0.157
Apr 01 10:25:12 jeedom dhcpcd[798]: wlan0: soliciting an IPv6 router
Apr 01 10:25:16 jeedom dhcpcd[798]: wlan0: probing for an IPv4LL address
Apr 01 10:25:16 jeedom dhcpcd[798]: wlan0: DHCP lease expired
Apr 01 10:25:16 jeedom dhcpcd[798]: wlan0: soliciting a DHCP lease
Apr 01 10:25:21 jeedom dhcpcd[798]: wlan0: using IPv4LL address 169.254.45.138
Apr 01 10:25:21 jeedom dhcpcd[798]: wlan0: adding route to 169.254.0.0/16
Apr 01 10:25:22 jeedom dhcpcd[798]: wlan0: Router Advertisement from fe80::72fc:8fff:fe42:e786
Apr 01 10:25:22 jeedom dhcpcd[798]: wlan0: adding address 2a01:e0a:376:2760:218f:433b:2c2f:d3e2/64
Apr 01 10:25:22 jeedom dhcpcd[798]: wlan0: adding route to 2a01:e0a:376:2760::/64
Apr 01 10:25:22 jeedom dhcpcd[798]: wlan0: adding default route via fe80::72fc:8fff:fe42:e786
Apr 01 10:25:28 jeedom dhcpcd[798]: wlan0: offered 192.168.0.157 from 192.168.0.254
Apr 01 10:25:30 jeedom dhcpcd[798]: wlan0: probing address 192.168.0.157/24
Apr 01 10:25:36 jeedom dhcpcd[798]: wlan0: leased 192.168.0.157 for 43200 seconds
Apr 01 10:25:36 jeedom dhcpcd[798]: wlan0: adding route to 192.168.0.0/24
Apr 01 10:25:36 jeedom dhcpcd[798]: wlan0: adding default route via 192.168.0.254
Apr 01 10:25:36 jeedom dhcpcd[798]: wlan0: deleting route to 169.254.0.0/16
Apr 01 10:25:45 jeedom dhcpcd[798]: received SIGTERM, stopping
Apr 01 10:25:45 jeedom dhcpcd[798]: wlan0: removing interface
Apr 01 10:25:45 jeedom systemd[1]: Stopping DHCP Client Daemon...
Apr 01 10:25:46 jeedom dhcpcd[798]: eth0: removing interface
Apr 01 10:25:46 jeedom dhcpcd[798]: dhcpcd exited
Apr 01 10:25:46 jeedom systemd[1]: dhcpcd.service: Succeeded.
Apr 01 10:25:46 jeedom systemd[1]: Stopped DHCP Client Daemon.
Apr 01 10:25:46 jeedom systemd[1]: dhcpcd.service: Consumed 3.468s CPU time.
-- Boot 845541647d834a7787fdab939a12b1f9 --
Apr 01 10:25:51 jeedom systemd[1]: Starting DHCP Client Daemon...
Apr 01 10:25:52 jeedom dhcpcd[367]: dev: loaded udev
Apr 01 10:25:52 jeedom dhcpcd[445]: wlan0: starting wpa_supplicant
Apr 01 10:25:52 jeedom dhcpcd-run-hooks[458]: wlan0: starting wpa_supplicant
Apr 01 10:25:53 jeedom dhcpcd[367]: wlan0: connected to Access Point `'
Apr 01 10:25:53 jeedom dhcpcd[367]: eth0: waiting for carrier
Apr 01 10:25:53 jeedom dhcpcd[367]: wlan0: waiting for carrier
Apr 01 10:25:53 jeedom dhcpcd[367]: eth0: carrier acquired
Apr 01 10:25:53 jeedom dhcpcd[367]: DUID 00:01:00:01:2d:82:69:fc:b8:27:eb:2f:f0:21
Apr 01 10:25:53 jeedom dhcpcd[367]: eth0: IAID eb:2f:f0:21
Apr 01 10:25:53 jeedom dhcpcd[367]: eth0: adding address fe80::54b2:650d:d182:18cb
Apr 01 10:25:53 jeedom dhcpcd[367]: eth0: rebinding lease of 192.168.0.17
Apr 01 10:25:53 jeedom dhcpcd[367]: eth0: probing address 192.168.0.17/24
Apr 01 10:25:53 jeedom dhcpcd[367]: eth0: soliciting an IPv6 router
Apr 01 10:25:55 jeedom dhcpcd[367]: eth0: Router Advertisement from fe80::72fc:8fff:fe42:e786
Apr 01 10:25:55 jeedom dhcpcd[367]: eth0: adding address 2a01:e0a:376:2760:73e2:116a:acc3:1ab7/64
Apr 01 10:25:55 jeedom dhcpcd[367]: eth0: adding route to 2a01:e0a:376:2760::/64
Apr 01 10:25:55 jeedom dhcpcd[367]: eth0: adding default route via fe80::72fc:8fff:fe42:e786
Apr 01 10:25:58 jeedom dhcpcd[367]: eth0: leased 192.168.0.17 for 43200 seconds
Apr 01 10:25:58 jeedom dhcpcd[367]: eth0: adding route to 192.168.0.0/24
Apr 01 10:25:58 jeedom dhcpcd[367]: eth0: adding default route via 192.168.0.254
Apr 01 10:25:58 jeedom dhcpcd[367]: forked to background, child pid 738
Apr 01 10:25:58 jeedom systemd[1]: Started DHCP Client Daemon.
Apr 01 10:26:13 jeedom dhcpcd[738]: eth0: Router Advertisement from fe80::72fc:8fff:fe42:e786
Apr 01 10:30:45 jeedom dhcpcd[738]: received SIGTERM, stopping
Apr 01 10:30:45 jeedom dhcpcd[738]: wlan0: removing interface
Apr 01 10:30:45 jeedom systemd[1]: Stopping DHCP Client Daemon...
Apr 01 10:30:45 jeedom dhcpcd[738]: script_runreason: /lib/dhcpcd/dhcpcd-run-hooks: Terminated
Apr 01 10:30:45 jeedom dhcpcd[738]: eth0: removing interface
Apr 01 10:30:45 jeedom dhcpcd[738]: dhcpcd exited
Apr 01 10:30:46 jeedom systemd[1]: dhcpcd.service: Succeeded.
Apr 01 10:30:46 jeedom systemd[1]: Stopped DHCP Client Daemon.
-- Boot b9d9fb1270a04a1fa5ccadc8e32189ae --
Apr 01 10:30:51 jeedom systemd[1]: Starting DHCP Client Daemon...
Apr 01 10:30:51 jeedom dhcpcd[364]: dev: loaded udev
Apr 01 10:30:52 jeedom dhcpcd[450]: wlan0: starting wpa_supplicant
Apr 01 10:30:53 jeedom dhcpcd[364]: wlan0: connected to Access Point `'
Apr 01 10:30:53 jeedom dhcpcd[364]: eth0: waiting for carrier
Apr 01 10:30:53 jeedom dhcpcd[364]: wlan0: waiting for carrier
Apr 01 10:30:53 jeedom dhcpcd[364]: eth0: carrier acquired
Apr 01 10:30:53 jeedom dhcpcd[364]: DUID 00:01:00:01:2d:82:69:fc:b8:27:eb:2f:f0:21
Apr 01 10:30:53 jeedom dhcpcd[364]: eth0: IAID eb:2f:f0:21
Apr 01 10:30:53 jeedom dhcpcd[364]: eth0: adding address fe80::54b2:650d:d182:18cb
Apr 01 10:30:53 jeedom dhcpcd[364]: eth0: rebinding lease of 192.168.0.17
Apr 01 10:30:53 jeedom dhcpcd[364]: eth0: probing address 192.168.0.17/24
Apr 01 10:30:53 jeedom dhcpcd[364]: eth0: soliciting an IPv6 router
Apr 01 10:30:54 jeedom dhcpcd[364]: eth0: Router Advertisement from fe80::72fc:8fff:fe42:e786
Apr 01 10:30:54 jeedom dhcpcd[364]: eth0: adding address 2a01:e0a:376:2760:73e2:116a:acc3:1ab7/64
Apr 01 10:30:54 jeedom dhcpcd[364]: eth0: adding route to 2a01:e0a:376:2760::/64
Apr 01 10:30:54 jeedom dhcpcd[364]: eth0: adding default route via fe80::72fc:8fff:fe42:e786
Apr 01 10:30:55 jeedom dhcpcd[364]: eth0: Router Advertisement from fe80::8628:59ff:feee:184e
Apr 01 10:30:58 jeedom dhcpcd[364]: eth0: leased 192.168.0.17 for 43200 seconds
Apr 01 10:30:58 jeedom dhcpcd[364]: eth0: adding route to 192.168.0.0/24
Apr 01 10:30:58 jeedom dhcpcd[364]: eth0: adding default route via 192.168.0.254
Apr 01 10:30:58 jeedom dhcpcd[364]: forked to background, child pid 798
Apr 01 10:30:58 jeedom systemd[1]: Started DHCP Client Daemon.
Apr 01 10:35:29 jeedom dhcpcd[798]: eth0: Router Advertisement from fe80::72fc:8fff:fe42:e786
Apr 01 10:39:34 jeedom dhcpcd[798]: received SIGTERM, stopping
Apr 01 10:39:34 jeedom dhcpcd[798]: wlan0: removing interface
Apr 01 10:39:34 jeedom dhcpcd[798]: eth0: removing interface
Apr 01 10:39:34 jeedom systemd[1]: Stopping DHCP Client Daemon...
Apr 01 10:39:34 jeedom dhcpcd[798]: dhcpcd exited
Apr 01 10:39:34 jeedom systemd[1]: dhcpcd.service: Succeeded.
Apr 01 10:39:34 jeedom systemd[1]: Stopped DHCP Client Daemon.
Apr 01 10:39:34 jeedom systemd[1]: dhcpcd.service: Consumed 1.117s CPU time.
-- Boot 2ae60eb95bde488599eb70529043063e --
Apr 01 10:39:39 jeedom systemd[1]: Starting DHCP Client Daemon...
Apr 01 10:39:39 jeedom dhcpcd[365]: dev: loaded udev
Apr 01 10:39:40 jeedom dhcpcd[454]: wlan0: starting wpa_supplicant
Apr 01 10:39:40 jeedom dhcpcd-run-hooks[462]: wlan0: starting wpa_supplicant
Apr 01 10:39:41 jeedom dhcpcd[365]: wlan0: connected to Access Point `'
Apr 01 10:39:41 jeedom dhcpcd[365]: eth0: waiting for carrier
Apr 01 10:39:41 jeedom dhcpcd[365]: wlan0: waiting for carrier
Apr 01 10:39:41 jeedom dhcpcd[365]: eth0: carrier acquired
Apr 01 10:39:41 jeedom dhcpcd[365]: DUID 00:01:00:01:2d:82:69:fc:b8:27:eb:2f:f0:21
Apr 01 10:39:41 jeedom dhcpcd[365]: eth0: IAID eb:2f:f0:21
Apr 01 10:39:41 jeedom dhcpcd[365]: eth0: adding address fe80::54b2:650d:d182:18cb
Apr 01 10:39:41 jeedom dhcpcd[365]: eth0: soliciting an IPv6 router
Apr 01 10:39:42 jeedom dhcpcd[365]: eth0: rebinding lease of 192.168.0.17
Apr 01 10:39:42 jeedom dhcpcd[365]: eth0: probing address 192.168.0.17/24
Apr 01 10:39:42 jeedom dhcpcd[365]: eth0: Router Advertisement from fe80::72fc:8fff:fe42:e786
Apr 01 10:39:42 jeedom dhcpcd[365]: eth0: adding address 2a01:e0a:376:2760:73e2:116a:acc3:1ab7/64
Apr 01 10:39:42 jeedom dhcpcd[365]: eth0: adding route to 2a01:e0a:376:2760::/64
Apr 01 10:39:42 jeedom dhcpcd[365]: eth0: adding default route via fe80::72fc:8fff:fe42:e786
Apr 01 10:39:43 jeedom dhcpcd[365]: eth0: Router Advertisement from fe80::8628:59ff:feee:184e
Apr 01 10:39:47 jeedom dhcpcd[365]: eth0: leased 192.168.0.17 for 43200 seconds
Apr 01 10:39:47 jeedom dhcpcd[365]: eth0: adding route to 192.168.0.0/24
Apr 01 10:39:47 jeedom dhcpcd[365]: eth0: adding default route via 192.168.0.254
Apr 01 10:39:47 jeedom dhcpcd[365]: forked to background, child pid 798
Apr 01 10:39:47 jeedom systemd[1]: Started DHCP Client Daemon.
Apr 01 10:41:52 jeedom dhcpcd[798]: eth0: Router Advertisement from fe80::72fc:8fff:fe42:e786
Apr 01 10:57:53 jeedom dhcpcd[798]: received SIGTERM, stopping
Apr 01 10:57:53 jeedom dhcpcd[798]: wlan0: removing interface
Apr 01 10:57:53 jeedom dhcpcd[798]: eth0: removing interface
Apr 01 10:57:53 jeedom systemd[1]: Stopping DHCP Client Daemon...
Apr 01 10:57:53 jeedom dhcpcd[798]: dhcpcd exited
Apr 01 10:57:54 jeedom systemd[1]: dhcpcd.service: Succeeded.
Apr 01 10:57:54 jeedom systemd[1]: Stopped DHCP Client Daemon.
Apr 01 10:57:54 jeedom systemd[1]: dhcpcd.service: Consumed 1.339s CPU time.
-- Boot 804ff2d14de24df2b986fa8ba91cadfa --
Apr 01 10:57:58 jeedom systemd[1]: Starting DHCP Client Daemon...
Apr 01 10:57:59 jeedom dhcpcd[365]: dev: loaded udev
Apr 01 10:57:59 jeedom dhcpcd[451]: wlan0: starting wpa_supplicant
Apr 01 10:57:59 jeedom dhcpcd-run-hooks[459]: wlan0: starting wpa_supplicant
Apr 01 10:58:00 jeedom dhcpcd[365]: wlan0: connected to Access Point `'
Apr 01 10:58:00 jeedom dhcpcd[365]: eth0: waiting for carrier
Apr 01 10:58:00 jeedom dhcpcd[365]: wlan0: waiting for carrier
Apr 01 10:58:00 jeedom dhcpcd[365]: eth0: carrier acquired
Apr 01 10:58:00 jeedom dhcpcd[365]: DUID 00:01:00:01:2d:82:69:fc:b8:27:eb:2f:f0:21
Apr 01 10:58:00 jeedom dhcpcd[365]: eth0: IAID eb:2f:f0:21
Apr 01 10:58:00 jeedom dhcpcd[365]: eth0: adding address fe80::54b2:650d:d182:18cb
Apr 01 10:58:00 jeedom dhcpcd[365]: eth0: rebinding lease of 192.168.0.17
Apr 01 10:58:00 jeedom dhcpcd[365]: eth0: probing address 192.168.0.17/24
Apr 01 10:58:01 jeedom dhcpcd[365]: eth0: soliciting an IPv6 router
Apr 01 10:58:02 jeedom dhcpcd[365]: eth0: Router Advertisement from fe80::72fc:8fff:fe42:e786
Apr 01 10:58:02 jeedom dhcpcd[365]: eth0: adding address 2a01:e0a:376:2760:73e2:116a:acc3:1ab7/64
Apr 01 10:58:02 jeedom dhcpcd[365]: eth0: adding route to 2a01:e0a:376:2760::/64
Apr 01 10:58:02 jeedom dhcpcd[365]: eth0: adding default route via fe80::72fc:8fff:fe42:e786
Apr 01 10:58:03 jeedom dhcpcd[365]: eth0: Router Advertisement from fe80::8628:59ff:feee:184e
Apr 01 10:58:05 jeedom dhcpcd[365]: eth0: leased 192.168.0.17 for 43200 seconds
Apr 01 10:58:05 jeedom dhcpcd[365]: eth0: adding route to 192.168.0.0/24
Apr 01 10:58:05 jeedom dhcpcd[365]: eth0: adding default route via 192.168.0.254
Apr 01 10:58:05 jeedom dhcpcd[365]: forked to background, child pid 906
Apr 01 10:58:05 jeedom systemd[1]: Started DHCP Client Daemon.
Apr 01 10:58:06 jeedom dhcpcd[906]: wlan0: carrier acquired
Apr 01 10:58:06 jeedom dhcpcd[906]: wlan0: connected to Access Point `Cidex816'
Apr 01 10:58:06 jeedom dhcpcd[906]: wlan0: IAID eb:7a:a5:74
Apr 01 10:58:06 jeedom dhcpcd[906]: wlan0: adding address fe80::ee82:6aac:9f9a:2bda
Apr 01 10:58:06 jeedom dhcpcd[906]: wlan0: rebinding lease of 192.168.0.157
Apr 01 10:58:06 jeedom dhcpcd[906]: wlan0: probing address 192.168.0.157/24
Apr 01 10:58:06 jeedom dhcpcd[906]: wlan0: soliciting an IPv6 router
Apr 01 10:58:07 jeedom dhcpcd[906]: wlan0: Router Advertisement from fe80::72fc:8fff:fe42:e786
Apr 01 10:58:07 jeedom dhcpcd[906]: wlan0: adding address 2a01:e0a:376:2760:218f:433b:2c2f:d3e2/64
Apr 01 10:58:07 jeedom dhcpcd[906]: wlan0: adding route to 2a01:e0a:376:2760::/64
Apr 01 10:58:07 jeedom dhcpcd[906]: wlan0: adding default route via fe80::72fc:8fff:fe42:e786
Apr 01 10:58:08 jeedom dhcpcd[906]: wlan0: Router Advertisement from fe80::8628:59ff:feee:184e
Apr 01 10:58:10 jeedom dhcpcd[906]: wlan0: leased 192.168.0.157 for 43200 seconds
Apr 01 10:58:10 jeedom dhcpcd[906]: wlan0: adding route to 192.168.0.0/24
Apr 01 10:58:10 jeedom dhcpcd[906]: wlan0: adding default route via 192.168.0.254
Apr 01 10:58:20 jeedom dhcpcd[906]: eth0: Router Advertisement from fe80::72fc:8fff:fe42:e786
Apr 01 10:58:20 jeedom dhcpcd[906]: wlan0: Router Advertisement from fe80::72fc:8fff:fe42:e786
Apr 01 10:59:15 jeedom dhcpcd[906]: wlan0: carrier lost
Apr 01 10:59:15 jeedom dhcpcd[906]: wlan0: deleting address 2a01:e0a:376:2760:218f:433b:2c2f:d3e2/64
Apr 01 10:59:15 jeedom dhcpcd[906]: wlan0: deleting route to 2a01:e0a:376:2760::/64
Apr 01 10:59:15 jeedom dhcpcd[906]: wlan0: deleting default route via fe80::72fc:8fff:fe42:e786
Apr 01 10:59:15 jeedom dhcpcd[906]: wlan0: deleting address fe80::ee82:6aac:9f9a:2bda
Apr 01 10:59:15 jeedom dhcpcd[906]: wlan0: deleting route to 192.168.0.0/24
Apr 01 10:59:15 jeedom dhcpcd[906]: wlan0: deleting default route via 192.168.0.254
Apr 01 10:59:15 jeedom dhcpcd[906]: wlan0: carrier acquired
Apr 01 10:59:15 jeedom dhcpcd[906]: wlan0: IAID eb:7a:a5:74
Apr 01 10:59:15 jeedom dhcpcd[906]: wlan0: adding address fe80::ee82:6aac:9f9a:2bda
Apr 01 10:59:15 jeedom dhcpcd[906]: wlan0: rebinding lease of 192.168.0.157
Apr 01 10:59:16 jeedom dhcpcd[906]: wlan0: soliciting an IPv6 router
Apr 01 10:59:46 jeedom dhcpcd[906]: wlan0: probing address 192.168.0.157/24
Apr 01 10:59:52 jeedom dhcpcd[906]: wlan0: leased 192.168.0.157 for 43200 seconds
Apr 01 10:59:52 jeedom dhcpcd[906]: wlan0: adding route to 192.168.0.0/24
Apr 01 10:59:52 jeedom dhcpcd[906]: wlan0: adding default route via 192.168.0.254
Apr 01 10:59:53 jeedom dhcpcd[906]: wlan0: Router Advertisement from fe80::72fc:8fff:fe42:e786
Apr 01 10:59:53 jeedom dhcpcd[906]: wlan0: adding address 2a01:e0a:376:2760:218f:433b:2c2f:d3e2/64
Apr 01 10:59:53 jeedom dhcpcd[906]: wlan0: adding route to 2a01:e0a:376:2760::/64
Apr 01 10:59:53 jeedom dhcpcd[906]: wlan0: adding default route via fe80::72fc:8fff:fe42:e786
Apr 01 11:03:10 jeedom dhcpcd[906]: wlan0: Router Advertisement from fe80::8628:59ff:feee:184e
Suite …
sudo cat /etc/wpa_supplicant/wpa_supplicant.conf : (j’ai caché le SSID et MP)
ctrl_interface=DIR=/var/run/wpa_supplicant GROUP=netdev
update_config=1
country=FR
network={
	ssid="xxxxxxxx"
	psk="xxxxxxxxl"
sudo ip addr :
1: lo:  mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
       valid_lft forever preferred_lft forever
    inet6 ::1/128 scope host
2: eth0:  mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
    link/ether b8:27:eb:2f:f0:21 brd ff:ff:ff:ff:ff:ff
    inet 192.168.0.17/24 brd 192.168.0.255 scope global dynamic noprefixroute eth0
       valid_lft 41817sec preferred_lft 36417sec
    inet6 2a01:e0a:376:2760:73e2:116a:acc3:1ab7/64 scope global dynamic mngtmpaddr noprefixroute
       valid_lft 85917sec preferred_lft 85917sec
    inet6 fe80::54b2:650d:d182:18cb/64 scope link
3: wlan0:  mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
    link/ether b8:27:eb:7a:a5:74 brd ff:ff:ff:ff:ff:ff
    inet 192.168.0.157/24 brd 192.168.0.255 scope global dynamic noprefixroute wlan0
       valid_lft 43056sec preferred_lft 37656sec
    inet6 2a01:e0a:376:2760:218f:433b:2c2f:d3e2/64 scope global dynamic mngtmpaddr noprefixroute
       valid_lft 86251sec preferred_lft 86251sec
    inet6 fe80::ee82:6aac:9f9a:2bda/64 scope link
4: tun0:  mtu 1500 qdisc pfifo_fast state UNKNOWN group default qlen 500
    link/none
    inet 10.12.12.78 peer 10.12.12.77/32 scope global tun0
    inet6 fe80::50e8:2823:f8db:bbed/64 scope link stable-privacy
sudo iw dev :
phy#0
	Unnamed/non-netdev interface
		wdev 0x2
		addr ba:27:eb:7a:a5:74
		type P2P-device
		txpower 31.00 dBm
	Interface wlan0
		ifindex 3
		wdev 0x1
		addr b8:27:eb:7a:a5:74
		ssid Cidex816
		type managed
		channel 44 (5220 MHz), width: 80 MHz, center1: 5210 MHz
		txpower 31.00 dBm
sudo iw wlan0 scan :
BSS 8c:97:ea:ad:45:4c(on wlan0) -- associated
	last seen: 1613.526s [boottime]
	TSF: 0 usec (0d, 00:00:00)
	freq: 5220
	beacon interval: 120 TUs
	capability: ESS Privacy RadioMeasure (0x1011)
	signal: -73.00 dBm
	last seen: 0 ms ago
	SSID: xxxxxxxx
	Supported rates: 6.0* 9.0 12.0* 18.0 24.0* 36.0 48.0 54.0
	DS Parameter set: channel 44
	TIM: DTIM Count 1 DTIM Period 2 Bitmap Control 0x0 Bitmap[0] 0x0
	Country: FR	Environment: Indoor/Outdoor
		Channels [36 - 64] @ 23 dBm
		Channels [100 - 140] @ 30 dBm
	RSN:	 * Version: 1
		 * Group cipher: CCMP
		 * Pairwise ciphers: CCMP
		 * Authentication suites: PSK
		 * Capabilities: 16-PTKSA-RC 1-GTKSA-RC (0x000c)
	BSS Load:
		 * station count: 2
		 * channel utilisation: 8/255
		 * available admission capacity: 0 [*32us]
	RM enabled capabilities:
		Capabilities: 0x72 0x00 0x00 0x00 0x00
			Neighbor Report
			Beacon Passive Measurement
			Beacon Active Measurement
			Beacon Table Measurement
		Nonoperating Channel Max Measurement Duration: 0
		Measurement Pilot Capability: 0
	Supported operating classes:
		 * current operating class: 128
	HT capabilities:
		Capabilities: 0xef
			RX LDPC
			HT20/HT40
			SM Power Save disabled
			RX HT20 SGI
			RX HT40 SGI
			TX STBC
			No RX STBC
			Max AMSDU length: 3839 bytes
			No DSSS/CCK HT40
		Maximum RX AMPDU length 65535 bytes (exponent: 0x003)
		Minimum RX AMPDU time spacing: 8 usec (0x06)
		HT TX/RX MCS rate indexes supported: 0-15
	HT operation:
		 * primary channel: 44
		 * secondary channel offset: above
		 * STA channel width: any
		 * RIFS: 0
		 * HT protection: no
		 * non-GF present: 1
		 * OBSS non-GF present: 0
		 * dual beacon: 0
		 * dual CTS protection: 0
		 * STBC beacon: 0
		 * L-SIG TXOP Prot: 0
		 * PCO active: 0
		 * PCO phase: 0
	Extended capabilities:
		 * Extended Channel Switching
		 * BSS Transition
		 * SSID List
		 * Operating Mode Notification
		 * Max Number Of MSDUs In A-MSDU is unlimited
	VHT capabilities:
		VHT Capabilities (0x338979f2):
			Max MPDU length: 11454
			Supported Channel Width: neither 160 nor 80+80
			RX LDPC
			short GI (80 MHz)
			short GI (160/80+80 MHz)
			TX STBC
			SU Beamformer
			SU Beamformee
			MU Beamformer
			RX antenna pattern consistency
			TX antenna pattern consistency
		VHT RX MCS set:
			1 streams: MCS 0-9
			2 streams: MCS 0-9
			3 streams: not supported
			4 streams: not supported
			5 streams: not supported
			6 streams: not supported
			7 streams: not supported
			8 streams: not supported
		VHT RX highest supported: 0 Mbps
		VHT TX MCS set:
			1 streams: MCS 0-9
			2 streams: MCS 0-9
		VHT TX highest supported: 0 Mbps
	VHT operation:
		 * channel width: 1 (80 MHz)
		 * center freq segment 1: 42
		 * center freq segment 2: 0
		 * VHT basic MCS set: 0xfffc
	Transmit Power Envelope:
		 * Local Maximum Transmit Power For 20 MHz: 23 dBm
		 * Local Maximum Transmit Power For 40 MHz: 23 dBm
		 * Local Maximum Transmit Power For 80 MHz: 23 dBm
	WMM:	 * Parameter version 1
		 * BE: CW 15-1023, AIFSN 3
		 * BK: CW 15-1023, AIFSN 7
		 * VI: CW 7-15, AIFSN 2, TXOP 3008 usec
		 * VO: CW 3-7, AIFSN 2, TXOP 1504 usec
BSS 34:27:92:68:42:c8(on wlan0)
	freq: 5220
	signal: -76.00 dBm
	last seen: 0 ms ago
	SSID: Cidex816
	RSN:	 * Version: 1
	BSS Load:
		 * station count: 4
			Neighbor Report
	HT capabilities:
		Capabilities: 0xef
			RX LDPC
			HT20/HT40
			RX HT20 SGI
			RX HT40 SGI
			TX STBC
			No RX STBC
			No DSSS/CCK HT40
		HT TX/RX MCS rate indexes supported: 0-23
	HT operation:
		 * RIFS: 0
		 * HT protection: no
		 * non-GF present: 1
		 * dual beacon: 0
		 * STBC beacon: 0
		 * PCO active: 0
		 * PCO phase: 0
		 * BSS Transition
		 * SSID List
	VHT capabilities:
		VHT Capabilities (0x300001b2):
			RX LDPC
			short GI (80 MHz)
			TX STBC
		VHT RX MCS set:
			1 streams: MCS 0-9
			2 streams: MCS 0-9
			3 streams: MCS 0-9
		VHT TX MCS set:
			1 streams: MCS 0-9
			2 streams: MCS 0-9
			3 streams: MCS 0-9
	VHT operation:
sudo iwconfig :
lo        no wireless extensions.
eth0      no wireless extensions.
tun0      no wireless extensions.
wlan0     IEEE 802.11  ESSID:"xxxxxx"
          Mode:Managed  Frequency:5.22 GHz  Access Point: 8C:97:EA:AD:45:4C
          Bit Rate=12 Mb/s   Tx-Power=31 dBm
          Retry short limit:7   RTS thr:off   Fragment thr:off
          Encryption key:off
          Power Management:on
          Link Quality=35/70  Signal level=-75 dBm
          Rx invalid nwid:0  Rx invalid crypt:0  Rx invalid frag:0
          Tx excessive retries:54  Invalid misc:0   Missed beacon:0
sudo arp -a :
? (192.168.0.29) at 1c:1b:0d:e0:02:03 [ether] on eth0
? (192.168.0.254) at 70:fc:8f:42:e7:86 [ether] on eth0
? (192.168.0.254) at 70:fc:8f:42:e7:86 [ether] on wlan0
dpkg -l | grep raspberrypi-ui-mods :
Suite …
pour les logs /var/log/daemon.log et /var/log/syslog ils sont énormes et je ne vois pas comment faire sans les tronquer ! !
Salutations
Je vois dans les logs et dans l’administration Freebox que la carte Wifi du RPI est en 5Ghz ?
Bonjour.
Non, la carte Raspberry fait les deux bandes. L’indication doit dire que la connexion établie est en 5ghz
OK pour les deux bandes, mais c’est automatique le choix d’une bande ou l’autre, car moi je n’ai rien indiqué à la Freebox (5Ghz) et mon routeur 4G ainsi que le point d’acces mobile sont en 2,4 Ghz
Salutations
C’est automatique quand le SSID à le même nom.
Pour vos Smartphones et votre routeur, vous avez un SSID, saisissez le dans raspi-config, ainsi que le mot de passe. Si vous avez plusieurs SSID (mauvaise pratique, mais certain aime avoir un réseau pour le 2.4G et un pour le 5g ou 6g. Si cela fonctionne, jusqu’au redémarrage, c’est que cela n’est pas le problème.
Attention, un truc vous échappe peut être, le Jeedom en question, quand il passe d’un réseau à un autre, il a une adresse IP différente. Peut être que le problème ne vient que de là. Et les réseaux privés des Smartphones ne sont pas forcement sur votre réseau privé à vous.
Idéalement, pour imager tout cela, il faut connecter une autre machine sur ce même réseau (votre PC) et voir si vous ne voyez pas le Pi tout simplement.
SSID pour routeur 4G > Lucette
SSID pour point d’accès mobile > Lucette2
SSID pour Freebox révolution > Cixxxxxx
Pour moi un seul à la fois (vérification sudo nano /etc/wpa_supplicant/wpa_supplicant.conf) après chaque raspi-config).
Je suis conscient que le RPI a une adresse IP différente selon le routeur utilisé et qu’ils ne sont pas forcement sur mon réseau privé.
IP Freebox > 192.168.0.1xx
IP 4G > 192.168.1.1xx (administration du routeur 4G > 192.168.1.1)
IP point d’accès > 192.168.43.8x
Je fais cette manip chaque fois que je tente de connecter le RPI sur le réseau en question, et je ne vois pas de RPI !
Salutations
Jean-Paul
J’ai trouvé cette commande : sudo iwlist wlan0 scan
pi@jeedom:~ $ sudo iwlist wlan0 scan
wlan0     Scan completed :
          Cell 01 - Address: C8:2A:F1:B9:D6:C4
                    Channel:1
                    Frequency:2.412 GHz (Channel 1)
                    Quality=70/70  Signal level=-24 dBm
                    Encryption key:on
                    ESSID:"Lucette"
                    Bit Rates:1 Mb/s; 2 Mb/s; 5.5 Mb/s; 11 Mb/s; 6 Mb/s
                              9 Mb/s; 12 Mb/s; 18 Mb/s
                    Bit Rates:24 Mb/s; 36 Mb/s; 48 Mb/s; 54 Mb/s
                    Mode:Master
                    Extra:tsf=0000000000000000
                    Extra: Last beacon: 100ms ago
                    IE: Unknown: 00074C756365747465
                    IE: Unknown: 010882848B960C121824
                    IE: Unknown: 030101
                    IE: Unknown: 050400010000
                    IE: Unknown: 0706555320010B1E
                    IE: Unknown: 2A0104
                    IE: Unknown: 32043048606C
                    IE: Unknown: 2D1AEE111FFFFF000000000000000000000000000000000000000000
                    IE: Unknown: 3D1601050000000000000000000000000000000000000000
                    IE: Unknown: 4A0E14000A00B400C800140005001900
                    IE: Unknown: 7F0101
                    IE: WPA Version 1
                        Group Cipher : TKIP
                        Pairwise Ciphers (2) : TKIP CCMP
                        Authentication Suites (1) : PSK
                    IE: Unknown: DD180050F2020101000003A4000027A4000042435E0062322F00
                    IE: Unknown: DD0600E04C020160
          Cell 02 - Address: 8C:97:EA:AD:45:48
                    Channel:1
                    Quality=51/70  Signal level=-59 dBm
                    Encryption key:on
                    ESSID:"Cidex816"
                    Mode:Master
                    Extra: Last beacon: 26910ms ago
                    IE: Unknown: 00084369646578383136
                    IE: Unknown: 030101
                    IE: Unknown: 050400020000
                    IE: Unknown: 2A0104
                    IE: IEEE 802.11i/WPA2 Version 1
                        Group Cipher : CCMP
                        Pairwise Ciphers (1) : CCMP
                    IE: Unknown: 0B0500002F0000
                    IE: Unknown: 46057200000000
                    IE: Unknown: 3B025100
                    IE: Unknown: 2D1AEC001BFFFF000000000000000000000100000000000000000000
                    IE: Unknown: 3D1601000000000000000000000000000000000000000000
                    IE: Unknown: 7F080400080200000040
                    IE: Unknown: DD180050F2020101010003A4000027A4000042435E0062322F00
          Cell 03 - Address: 8C:97:EA:AD:45:4C
                    Channel:44
                    Frequency:5.22 GHz (Channel 44)
                    Quality=34/70  Signal level=-76 dBm
                    Encryption key:on
                    ESSID:"Cidex816"
                    Bit Rates:6 Mb/s; 9 Mb/s; 12 Mb/s; 18 Mb/s; 24 Mb/s
                    Mode:Master
                    Extra: Last beacon: 11730ms ago
                    IE: Unknown: 01088C129824B048606C
                    IE: Unknown: 03012C
                    IE: Unknown: 070A465220240817640B1E00
                        Group Cipher : CCMP
                    IE: Unknown: 0B050000030000
                    IE: Unknown: 3B028000
                    IE: Unknown: 2D1AEF001BFFFF000000000000000000000100000000000000000000
                    IE: Unknown: 3D162C050000000000000000000000000000000000000000
                    IE: Unknown: BF0CF2798933FAFF0000FAFF0020
                    IE: Unknown: C005012A00FCFF
                    IE: Unknown: C304022E2E2E
          Cell 04 - Address: 34:27:92:68:42:C8
                    Channel:44
                    Quality=33/70  Signal level=-77 dBm
                    Encryption key:on
                    ESSID:"Cidex816"
                    Mode:Master
                    IE: Unknown: 03012C
                        Group Cipher : CCMP
                    IE: Unknown: 0B050100030000
                    IE: Unknown: 2D1AEF001BFFFFFF0000000000000000000100000000000000000000
                    IE: Unknown: 3D162C050400000000000000000000000000000000000000
                    IE: Unknown: BF0CB2010030EAFF0000EAFF0020
                    IE: Unknown: DD0C0007CB010201000000000000
          Cell 05 - Address: 8E:97:EA:AD:45:49
                    Channel:1
                    Quality=52/70  Signal level=-58 dBm
                    Encryption key:on
                    ESSID:""
                    ESSID:"bh-ssid-742002A192722048"
                    Extra:Mesh Network Path Selection Protocol ID: 0x01
                    Extra:Path Selection Metric ID: 0x01
                    Extra:Congestion Control Mode ID: 0x00
                    Extra:Synchronization ID: 0x01
                    Extra:Authentication ID: 0x01
                    Extra:Formation Info: 0x02
                    Extra:Capabilities: 0x09
                    Mode:Unknown/bug
                    IE: Unknown: 0000
                    IE: Unknown: 010882848B968C129824
                    IE: Unknown: 030101
                    IE: Unknown: 050401020000
                    IE: Unknown: 3204B048606C
                        Group Cipher : CCMP
                        Authentication Suites (1) : unknown (8)
                    IE: Unknown: 2D1AEF111BFFFF000000000000000000000100000000000000000000
                    IE: Unknown: 3D16010004000000FFFF0000000000000000000000000000
                    IE: Unknown: 721862682D737369642D37343230303241313932373232303438
                    IE: Unknown: 710701010001010209
                    IE: Unknown: DD32C0FFEE01010063499000000000000000000000000000000000000000000000000000000000000000000000002FFCFF8F6229
                    IE: Unknown: DD14C0FFEE0270FC8F42E78A70FC8F42E78A9702DF14
          Cell 06 - Address: 46:91:60:55:23:B0
                    Channel:1
                    Quality=70/70  Signal level=-35 dBm
                    Encryption key:on
                    ESSID:"Lucette2"
                    Bit Rates:1 Mb/s; 2 Mb/s; 5.5 Mb/s; 11 Mb/s; 18 Mb/s
                              24 Mb/s; 36 Mb/s; 54 Mb/s
                    Bit Rates:6 Mb/s; 9 Mb/s; 12 Mb/s; 48 Mb/s
                    Mode:Master
                    IE: Unknown: 00084C75636574746532
                    IE: Unknown: 010882848B962430486C
                    IE: Unknown: 030101
                    IE: Unknown: 0706465220010D14
                    IE: Unknown: 200100
                    IE: Unknown: 23021400
                    IE: Unknown: 2A0100
                    IE: Unknown: 32040C121860
                        Group Cipher : CCMP
                    IE: Unknown: 2D1AAD011BFFFF000000000000000000000000000000000000000000
                    IE: Unknown: 3D1601080000000000000000000000000000000000000000
                    IE: Unknown: 7F080400080000000040
                    IE: Unknown: DD050016328000
                    IE: Unknown: DD080050F21102000000
                    IE: Unknown: DD1E00904C0408BF0CB279810FFAFF0000FAFF0000C0050001000000C3020006
                    IE: Unknown: DD090010180200001C0000
                    IE: Unknown: DD1D00904C5C02010A000807010F0000000000010A010101010F0000000000
pi@jeedom:~ $
Le RPI voit bien « Lucette » (routeur 4G), « Lucette2 » (point d’accès mobile) et « Cidex 816 » (Freebox révolution).
Je me connecte bien sur la Freebox mais impossible sur les deux autres (un seul à la fois bien sur) ! !
J’ai réinstallé l’OS plusieurs fois avec Raspberry Pi Imager et les paramètres wifi, raspi-config.
Il y a vraiment quelque chose qui m’échappe.
Pour info : C’est un RPI 3B+ (première génération) !
Salutations
Jean-Paul
