Pb installation plugin jeedore
Je n’arrive pas a installer mon application, j’ai choisi un mot de passe sans caractère special et c’est le mot de passe dont je me sers pour accéder à mon compte;
L’installeur m’indique qu’il n’y avait pas de MDP lors de l’initialisation de la Box,
voici ma config du plugin
ainsi que les logs que j’obtiens
Un grand merci pour votre aide
Log en debug et copié intégralement ici entre balises.
La sur portable c’est pas exploitable.
11/14/2023 21:20:04 - Hello DeltaDore! <3
11/14/2023 21:20:04 - Unix 5.10.43.64
11/14/2023 21:20:04 - pid: 26277
11/14/2023 21:20:04 - pidFilename: /tmp/jeedom/jeedore/jeedoredaemon.pid
11/14/2023 21:20:04 - Starting with 26277
11/14/2023 21:20:05 - Jeedore Daemon is starting in local network mode...
11/14/2023 21:20:05 - Websocket connection initialization....
11/14/2023 21:20:05 - Connecting to '192.168.1.31'
11/14/2023 21:20:16 - Websocket connection has been closed with code:1015 reason:'An exception has occurred while connecting.'
11/14/2023 21:20:16 - Jeedore Daemon connection has been closed...
11/14/2023 21:20:16 - Connection to DeltaDore server has been closed...
11/14/2023 21:20:16 - Server started. Listening to TCP clients at 127.0.0.1:13666
11/14/2023 21:20:16 - Starting timer Info
11/14/2023 21:20:46 - Websocket connection initialization....
11/14/2023 21:20:46 - Connecting to '192.168.1.31'
11/14/2023 21:20:58 - Websocket connection has been closed with code:1015 reason:'An exception has occurred while connecting.'
11/14/2023 21:20:58 - Jeedore Daemon connection has been closed...
11/14/2023 21:20:58 - Connection to DeltaDore server has been closed...
11/14/2023 21:21:16 - Websocket connection initialization....
11/14/2023 21:21:16 - Connecting to '192.168.1.31'
11/14/2023 21:21:28 - Websocket connection has been closed with code:1015 reason:'An exception has occurred while connecting.'
11/14/2023 21:21:28 - Jeedore Daemon connection has been closed...
11/14/2023 21:21:28 - Connection to DeltaDore server has been closed...
11/14/2023 21:21:46 - Websocket connection initialization....
11/14/2023 21:21:46 - Connecting to '192.168.1.31'
11/14/2023 21:21:58 - Websocket connection has been closed with code:1015 reason:'An exception has occurred while connecting.'
11/14/2023 21:21:58 - Jeedore Daemon connection has been closed...
11/14/2023 21:21:58 - Connection to DeltaDore server has been closed...
11/14/2023 21:22:16 - Websocket connection initialization....
11/14/2023 21:22:16 - Connecting to '192.168.1.31'
11/14/2023 21:22:28 - Websocket connection has been closed with code:1015 reason:'An exception has occurred while connecting.'
11/14/2023 21:22:28 - Jeedore Daemon connection has been closed...
11/14/2023 21:22:28 - Connection to DeltaDore server has been closed...
11/14/2023 21:22:46 - Websocket connection initialization....
11/14/2023 21:22:46 - Connecting to '192.168.1.31'
11/14/2023 21:22:58 - Websocket connection has been closed with code:1015 reason:'An exception has occurred while connecting.'
11/14/2023 21:22:58 - Jeedore Daemon connection has been closed...
11/14/2023 21:22:58 - Connection to DeltaDore server has been closed...
11/14/2023 21:23:16 - Websocket connection initialization....
11/14/2023 21:23:16 - Connecting to '192.168.1.31'
11/14/2023 21:23:28 - Websocket connection has been closed with code:1015 reason:'An exception has occurred while connecting.'
11/14/2023 21:23:28 - Jeedore Daemon connection has been closed...
11/14/2023 21:23:28 - Connection to DeltaDore server has been closed...
11/14/2023 21:23:46 - Websocket connection initialization....
11/14/2023 21:23:46 - Connecting to '192.168.1.31'
11/14/2023 21:23:58 - Websocket connection has been closed with code:1015 reason:'An exception has occurred while connecting.'
11/14/2023 21:23:58 - Jeedore Daemon connection has been closed...
11/14/2023 21:23:58 - Connection to DeltaDore server has been closed...
11/14/2023 21:24:16 - Websocket connection initialization....
11/14/2023 21:24:16 - Connecting to '192.168.1.31'
11/14/2023 21:24:28 - Websocket connection has been closed with code:1015 reason:'An exception has occurred while connecting.'
11/14/2023 21:24:28 - Jeedore Daemon connection has been closed...
11/14/2023 21:24:28 - Connection to DeltaDore server has been closed...
11/14/2023 21:24:46 - Websocket connection initialization....
11/14/2023 21:24:46 - Connecting to '192.168.1.31'
11/14/2023 21:24:58 - Websocket connection has been closed with code:1015 reason:'An exception has occurred while connecting.'
11/14/2023 21:24:58 - Jeedore Daemon connection has been closed...
11/14/2023 21:24:58 - Connection to DeltaDore server has been closed...
11/14/2023 21:25:16 - Websocket connection initialization....
11/14/2023 21:25:16 - Connecting to '192.168.1.31'
11/14/2023 21:25:28 - Websocket connection has been closed with code:1015 reason:'An exception has occurred while connecting.'
11/14/2023 21:25:28 - Jeedore Daemon connection has been closed...
11/14/2023 21:25:28 - Connection to DeltaDore server has been closed...
11/14/2023 21:25:46 - Websocket connection initialization....
11/14/2023 21:25:46 - Connecting to '192.168.1.31'
11/14/2023 21:25:58 - Websocket connection has been closed with code:1015 reason:'An exception has occurred while connecting.'
11/14/2023 21:25:58 - Jeedore Daemon connection has been closed...
11/14/2023 21:25:58 - Connection to DeltaDore server has been closed...
11/14/2023 21:26:16 - Websocket connection initialization....
11/14/2023 21:26:16 - Connecting to '192.168.1.31'
11/14/2023 21:26:28 - Websocket connection has been closed with code:1015 reason:'An exception has occurred while connecting.'
11/14/2023 21:26:28 - Jeedore Daemon connection has been closed...
11/14/2023 21:26:28 - Connection to DeltaDore server has been closed...
11/14/2023 21:26:46 - Websocket connection initialization....
11/14/2023 21:26:46 - Connecting to '192.168.1.31'
11/14/2023 21:26:58 - Websocket connection has been closed with code:1015 reason:'An exception has occurred while connecting.'
11/14/2023 21:26:58 - Jeedore Daemon connection has been closed...
11/14/2023 21:26:58 - Connection to DeltaDore server has been closed...
11/14/2023 21:27:16 - Websocket connection initialization....
11/14/2023 21:27:16 - Connecting to '192.168.1.31'
11/14/2023 21:27:28 - Websocket connection has been closed with code:1015 reason:'An exception has occurred while connecting.'
11/14/2023 21:27:28 - Jeedore Daemon connection has been closed...
11/14/2023 21:27:28 - Connection to DeltaDore server has been closed...
11/14/2023 21:27:46 - Websocket connection initialization....
11/14/2023 21:27:46 - Connecting to '192.168.1.31'
11/14/2023 21:27:58 - Websocket connection has been closed with code:1015 reason:'An exception has occurred while connecting.'
11/14/2023 21:27:58 - Jeedore Daemon connection has been closed...
11/14/2023 21:27:58 - Connection to DeltaDore server has been closed...
11/14/2023 21:28:16 - Websocket connection initialization....
11/14/2023 21:28:16 - Connecting to '192.168.1.31'
11/14/2023 21:28:28 - Websocket connection has been closed with code:1015 reason:'An exception has occurred while connecting.'
11/14/2023 21:28:28 - Jeedore Daemon connection has been closed...
11/14/2023 21:28:28 - Connection to DeltaDore server has been closed...
11/14/2023 21:28:46 - Websocket connection initialization....
11/14/2023 21:28:46 - Connecting to '192.168.1.31'
11/14/2023 21:28:58 - Websocket connection has been closed with code:1015 reason:'An exception has occurred while connecting.'
11/14/2023 21:28:58 - Jeedore Daemon connection has been closed...
11/14/2023 21:28:58 - Connection to DeltaDore server has been closed...
11/14/2023 21:29:16 - Websocket connection initialization....
11/14/2023 21:29:16 - Connecting to '192.168.1.31'
11/14/2023 21:29:28 - Websocket connection has been closed with code:1015 reason:'An exception has occurred while connecting.'
11/14/2023 21:29:28 - Jeedore Daemon connection has been closed...
11/14/2023 21:29:28 - Connection to DeltaDore server has been closed...
11/14/2023 21:29:46 - Websocket connection initialization....
11/14/2023 21:29:46 - Connecting to '192.168.1.31'
11/14/2023 21:29:58 - Websocket connection has been closed with code:1015 reason:'An exception has occurred while connecting.'
11/14/2023 21:29:58 - Jeedore Daemon connection has been closed...
11/14/2023 21:29:58 - Connection to DeltaDore server has been closed...
11/14/2023 21:30:16 - Websocket connection initialization....
11/14/2023 21:30:16 - Connecting to '192.168.1.31'
11/14/2023 21:30:16 - Websocket connection has been closed with code:1015 reason:'An exception has occurred while connecting.'
11/14/2023 21:30:16 - Jeedore Daemon connection has been closed...
11/14/2023 21:30:16 - Connection to DeltaDore server has been closed...
11/14/2023 21:30:46 - Websocket connection initialization....
11/14/2023 21:30:46 - Connecting to '192.168.1.31'
11/14/2023 21:30:46 - Websocket connection has been closed with code:1015 reason:'An exception has occurred while connecting.'
11/14/2023 21:30:46 - Jeedore Daemon connection has been closed...
11/14/2023 21:30:46 - Connection to DeltaDore server has been closed...
11/14/2023 21:31:16 - Websocket connection initialization....
11/14/2023 21:31:16 - Connecting to '192.168.1.31'
11/14/2023 21:31:28 - Websocket connection has been closed with code:1015 reason:'An exception has occurred while connecting.'
11/14/2023 21:31:28 - Jeedore Daemon connection has been closed...
11/14/2023 21:31:28 - Connection to DeltaDore server has been closed...
11/14/2023 21:31:46 - Websocket connection initialization....
11/14/2023 21:31:46 - Connecting to '192.168.1.31'
11/14/2023 21:31:58 - Websocket connection has been closed with code:1015 reason:'An exception has occurred while connecting.'
11/14/2023 21:31:58 - Jeedore Daemon connection has been closed...
11/14/2023 21:31:58 - Connection to DeltaDore server has been closed...
11/14/2023 21:32:16 - Websocket connection initialization....
11/14/2023 21:32:16 - Connecting to '192.168.1.31'
11/14/2023 21:32:28 - Websocket connection has been closed with code:1015 reason:'An exception has occurred while connecting.'
11/14/2023 21:32:28 - Jeedore Daemon connection has been closed...
11/14/2023 21:32:28 - Connection to DeltaDore server has been closed...
Ce n’est pas les balises </>
J’ai rebooté ma box et reinstallé les dépendances + daemon
et j’obtiens ça:
11/14/2023 21:47:59 - Hello DeltaDore! <3
11/14/2023 21:47:59 - Unix 5.10.43.64
11/14/2023 21:47:59 - pid: 8476
11/14/2023 21:47:59 - pidFilename: /tmp/jeedom/jeedore/jeedoredaemon.pid
11/14/2023 21:47:59 - Starting with 8476
11/14/2023 21:47:59 - Jeedore Daemon is starting in local network mode...
11/14/2023 21:47:59 - Websocket connection initialization....
11/14/2023 21:47:59 - Connecting to '192.168.1.31'
11/14/2023 21:48:05 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
11/14/2023 21:48:05 - Jeedore Daemon connection has been closed...
11/14/2023 21:48:05 - Connection to DeltaDore server has been closed...
11/14/2023 21:48:05 - Server started. Listening to TCP clients at 127.0.0.1:13666
11/14/2023 21:48:05 - Starting timer Info
11/14/2023 21:48:12 - Executing command to device : 'Rezolv.JeeDore.Server.DeltaDore.Request.GetEqLogic'...
11/14/2023 21:48:12 - Websocket connection initialization....
11/14/2023 21:48:12 - Connecting to '192.168.1.31'
11/14/2023 21:48:16 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
11/14/2023 21:48:16 - Jeedore Daemon connection has been closed...
11/14/2023 21:48:16 - Connection to DeltaDore server has been closed...
11/14/2023 21:48:16 - Command 1699994892038 executed!
11/14/2023 21:48:18 - Executing command to device : 'Rezolv.JeeDore.Server.DeltaDore.Request.GetCommands'...
11/14/2023 21:48:18 - Websocket connection initialization....
11/14/2023 21:48:18 - Connecting to '192.168.1.31'
11/14/2023 21:48:23 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
11/14/2023 21:48:23 - Jeedore Daemon connection has been closed...
11/14/2023 21:48:23 - Connection to DeltaDore server has been closed...
11/14/2023 21:48:23 - Command 1699994898929 executed!
11/14/2023 21:48:25 - Executing command to device : 'Rezolv.JeeDore.Server.DeltaDore.Request.GetDevicesCMeta'...
11/14/2023 21:48:25 - Websocket connection initialization....
11/14/2023 21:48:25 - Connecting to '192.168.1.31'
11/14/2023 21:48:30 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
11/14/2023 21:48:30 - Jeedore Daemon connection has been closed...
11/14/2023 21:48:30 - Connection to DeltaDore server has been closed...
11/14/2023 21:48:30 - Command 1699994905820 executed!
11/14/2023 21:48:32 - Executing command to device : 'Rezolv.JeeDore.Server.DeltaDore.Request.GetDevicesData'...
11/14/2023 21:48:32 - Websocket connection initialization....
11/14/2023 21:48:32 - Connecting to '192.168.1.31'
11/14/2023 21:48:37 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
11/14/2023 21:48:37 - Jeedore Daemon connection has been closed...
11/14/2023 21:48:37 - Connection to DeltaDore server has been closed...
11/14/2023 21:48:37 - Command 1699994912856 executed!
11/14/2023 21:48:39 - Executing command to device : 'Rezolv.JeeDore.Server.DeltaDore.Request.GetInfo'...
11/14/2023 21:48:42 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
11/14/2023 21:48:42 - Jeedore Daemon connection has been closed...
11/14/2023 21:48:42 - An error with websocket connection has occured...
11/14/2023 21:48:42 - Error websocket : 'An error has occurred in sending data.
11/14/2023 21:48:42 - Jeedore Daemon has received a DeltaDore error...
11/14/2023 21:48:47 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
11/14/2023 21:48:47 - Jeedore Daemon connection has been closed...
11/14/2023 21:48:47 - Sending command 1699994919744 to DeltaDore....
11/14/2023 21:48:47 - An error with websocket connection has occured...
11/14/2023 21:48:47 - Error websocket : 'An error has occurred in sending data.
11/14/2023 21:48:47 - Jeedore Daemon has received a DeltaDore error...
11/14/2023 21:48:47 - Command 1699994919744 executed!
11/14/2023 21:49:05 - Websocket connection initialization....
11/14/2023 21:49:05 - Connecting to '192.168.1.31'
11/14/2023 21:49:10 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
11/14/2023 21:49:10 - Jeedore Daemon connection has been closed...
11/14/2023 21:49:10 - Connection to DeltaDore server has been closed...
Page santé jeedom
Passage en debug du demon et log lors du restart de celui-ci
voici
11/14/2023 21:54:41 - Hello DeltaDore! <3
11/14/2023 21:54:41 - Unix 5.10.43.64
11/14/2023 21:54:41 - pid: 19809
11/14/2023 21:54:41 - pidFilename: /tmp/jeedom/jeedore/jeedoredaemon.pid
11/14/2023 21:54:41 - Starting with 19809
11/14/2023 21:54:41 - Jeedore Daemon is starting in local network mode...
11/14/2023 21:54:41 - Websocket connection initialization....
11/14/2023 21:54:41 - Connecting to '192.168.1.31'
11/14/2023 21:54:47 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
11/14/2023 21:54:47 - Jeedore Daemon connection has been closed...
11/14/2023 21:54:47 - Connection to DeltaDore server has been closed...
11/14/2023 21:54:47 - Server started. Listening to TCP clients at 127.0.0.1:13666
11/14/2023 21:54:47 - Starting timer Info
11/14/2023 21:55:17 - Websocket connection initialization....
11/14/2023 21:55:17 - Connecting to '192.168.1.31'
11/14/2023 21:55:22 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
11/14/2023 21:55:22 - Jeedore Daemon connection has been closed...
11/14/2023 21:55:22 - Connection to DeltaDore server has been closed...
Ton jeedom est il sur le meme reseau que ton tydom sinon il faut utilisé le mode remote
A la place de localhost as tu mis l’ip de ton jeedom ?
oui mon jeedom est sur le meme réseau que ma tydom, les 2 connectés à ma freebox en ethernet
Hello
Petites questions :
Comment l’as-tu défini ? Par une ancienne version de l’app Tydom ?
Sinon jettes un oeil ici :
Quel modèle de Tydom ? 1, 2, Home, Pro ?
Comment est installé ton Jeedom ? box, docker ?
PS: Pour des raisons de sécurité, il est préférable de masquer les 6 derniers caractères de l’adresse MAC de ton Tydom :wink:
J’ai une Tydom Home et j’ai compris que ce n’était finalement pas supporté par l’application? cela pourrait expliquer mon problème, qu’en pensez vous?
moi j’ai un tydom pro et ca fonctionne ton avec le home ca doit fonctionner !!
ok bonne nouvelle et un pb de MDP? car j’ai compris que c’était l’origine du problème…
oui mais tydom pro c’est différent de tydom home !
non c’est la même chose juste le format qui change
Merci et pour le MDP comment faire avez vous fait une manipulation particulière? merci
Bonjour à tous.
Pour ceux qui sont dans le même cas et on pas de possibilité de changer de mot de passe suite à la nouvelle version, j’ai préparer une page web qui permets de récupérer les infos du compte DeltaDore.
Cordialement
