02/17/2020 17:00:23 - Executing commamd to device : 'Rezolv.JeeDore.Server.DeltaDore.Request.GetDevicesData'...
02/17/2020 17:00:23 - Websocket connection initialization....
02/17/2020 17:00:23 - Connecting to '192.168.x.x'
02/17/2020 17:00:23 - Websocket connection has been closed with code:1015 reason:'An exception has occurred while connecting.'
02/17/2020 17:00:23 - Jeedore Daemon connection has been closed...
02/17/2020 17:00:23 - Connection to DeltaDore server has been closed...
02/17/2020 17:00:23 - Command 1581958823948 executed!
02/17/2020 17:00:25 - Executing commamd to device : 'Rezolv.JeeDore.Server.DeltaDore.Request.GetInfo'...
02/17/2020 17:00:25 - Websocket connection initialization....
02/17/2020 17:00:25 - Connecting to '192.168.x.x'
02/17/2020 17:00:26 - Websocket connection has been closed with code:1015 reason:'An exception has occurred while connecting.'
02/17/2020 17:00:26 - Jeedore Daemon connection has been closed...
02/17/2020 17:00:26 - Connection to DeltaDore server has been closed...
02/17/2020 17:00:26 - Command 1581958825995 executed!
02/17/2020 17:00:40 - Websocket connection initialization....
02/17/2020 17:00:40 - Connecting to '192.168.x.x'
02/17/2020 17:00:40 - Websocket connection has been closed with code:1015 reason:'An exception has occurred while connecting.'
02/17/2020 17:00:40 - Jeedore Daemon connection has been closed...
02/17/2020 17:00:40 - Connection to DeltaDore server has been closed...
Je suis sous JEEDOM 4.0.40 installé sur un RPI 3B+ sous Raspbian buster. Tous mes paquets sont à jour
J’ai trouver la solution récemment, je dois mettre à jour le framework dotnet.
Je ne sais pas à quoi cela est dû précisément mais si tu es up-to-date.
Je fini un dev qui me permettra de récupérer l’énergie en instantané et j’enchaîne sur ce sujet…
Je pense que ce sera dans la semaine.
Ya un workaround mais qui ne risque de ne pas de plaire
Ne pas utiliser un os up-to-date…
Ou si t’es vraiment chaud, et motivé, et que tu connais un minimum dotnet remplacé les dll du framework par le 3.1
J’ai testé en local le fait d’avoir le framework en 3.1 avec des sources compilées en 2.2 ca fonctionne. Peux tu me confirmer que ca fonctionne aussi chez toi stp ? et precise moi stable ou beta stp
