J’ai un pb que j’avais mis de coté depuis quelque temps et que je redéterre.
mon plugin speedtest ne fonctionne plus avec des dépendances non installée.
* Installation des dépendances *
***** Commande: sudo apt-get update **********
Hit:1 http://archive.raspberrypi.org/debian buster InRelease
Hit:2 http://deb.debian.org/debian buster InRelease
Hit:3 http://deb.debian.org/debian-security buster/updates InRelease
Get:4 http://deb.debian.org/debian buster-updates InRelease [51.9 kB]
Hit:5 https://deb.nodesource.com/node_14.x buster InRelease
Hit:6 https://packagecloud.io/ookla/speedtest-cli/debian buster InRelease
Fetched 51.9 kB in 3s (17.3 kB/s)
Reading package lists...
***** Commande: install python-pip**********
Building dependency tree...
Reading state information...
python-pip is already the newest version (18.1-5+rpt1).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
***** Commande: install speedtest-cli **********
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Collecting git+https://github.com/sivel/speedtest-cli.git
Cloning https://github.com/sivel/speedtest-cli.git to /tmp/pip-req-build-almk4p_i
Running command git clone --filter=blob:none -q https://github.com/sivel/speedtest-cli.git /tmp/pip-req-build-almk4p_i
Resolved https://github.com/sivel/speedtest-cli.git to commit 22210ca35228f0bbcef75a7c14587c4ecb875ab4
Preparing metadata (setup.py): started
Preparing metadata (setup.py): finished with status 'done'
WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv
* Installation terminée *
Le speedtest-cli fonctionne bien en ssh sur le serveur
Les dependances s’installent en boucle
J’ai essayer de supprimer directement sur le serveur python-pip et speedtest. il me les re-installe bien ensuite mais pas mieux.
La seule erreur que je vois, c’est ce warning mais que je n’arrive pas à enlever !!!
je suis en jeedom Beta 4.2.5 sur la derniere version debian 10 (apt-get upgrade OK)
Merci pour votre aide
