Bonjour tout le monde
Suite au passage en buster de ma jeedom smart, je remarque que le plugin caméra ne fonctionne plus. Le démon se lance bien, mais aucune capture du flux vidéo ne se fait (seul le rtsp fonctionne).
Lorsque je souhaite envoyer une capture via télégram je reçois cette erreur en retour :
[camera/sendSnap] Erreur lors de l'envoi des images : [Aucun][****][Telegram Steve] => Erreur lors de l'envoi telegram : {"ok":false,"error_code":400,"description":"Bad Request: IMAGE_PROCESS_FAILED"}
J’ai remarqué aussi dans les logs, que lorsque je souhaite réinstaller les dépendances, l’erreur suivante apparait :
Launch install of camera dependancy
Hit:2 http://www.deb-multimedia.org buster InRelease
Hit:3 https://deb.nodesource.com/node_12.x buster InRelease
Hit:4 http://security.debian.org/debian-security buster/updates InRelease
Hit:5 http://ftp.uk.debian.org/debian buster InRelease
Hit:6 http://ftp.uk.debian.org/debian buster-updates InRelease
Hit:7 https://oph.mdrjr.net/meveric all InRelease
Hit:8 https://oph.mdrjr.net/meveric buster InRelease
Err:1 https://repo.jeedom.com/odroid stable InRelease
502 Bad Gateway [IP: 51.210.253.116 443]
Reading package lists...
W: Failed to fetch http://repo.jeedom.com/odroid/dists/stable/InRelease 502 Bad Gateway [IP: 51.210.253.116 443]
W: Some index files failed to download. They have been ignored, or old ones used instead.
Building dependency tree...
Reading state information...
ffmpeg is already the newest version (7:4.1.6-1~deb10u1).
0 upgraded, 0 newly installed, 0 to remove and 88 not upgraded.
Package libav-tools is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
However the following packages replace it:
ffplay ffmpeg
E: Package 'libav-tools' has no installation candidate
Package python-imaging is not available, but is referred to by another package.
python-pil
E: Package 'python-imaging' has no installation candidate
python-pil is already the newest version (5.4.1-2+deb10u2).
php-gd is already the newest version (2:7.3+69).
Everything is successfully installed!
Est ce que vous avez aussi rencontré ce genre de problème ?
En vous remerciant par avance
