Pac_atlantic_extensa.json.txt (12,8 Ko)
"Pac atlantic extensa": {
"name": "Pac atlantic extensa",
"eqType_name": "jMQTT",
"configuration": {
"type": "eqpt",
"createtime": "2023-12-10 11:42:18",
"auto_add_cmd": "1",
"auto_add_topic": "%s/#",
"Qos": "1",
"battery_type": "Secteur",
"commentaire": "8006 en surveillance historisé\nLISTE\nS700=0|Mode protection;S700=1|Automatique;S700=2|Réduit;S700=3|Confort",
"icone": "water-boiler",
"updatetime": "2023-12-18 10:51:06"
"category": {
"heating": "1",
"security": "0",
"energy": "0",
"light": "0",
"opening": "0",
"automatism": "0",
"multimedia": "0",
"default": "0"
"display": {
"width": "672px",
"height": "392px",
"backGraph::color": "#4572a7",
"backGraph::format": "hour",
"backGraph::type": "areaspline",
"parameters": [],
"backGraph::info": "0"
"status": {
"lastCommunication": "2023-10-26 20:06:13",
"enableDatime": "2023-10-26 20:06:13"
"cache": [],
"commands": [
"eqType": "jMQTT",
"name": "700",
"type": "info",
"subType": "string",
"isHistorized": "1",
"configuration": {
"topic": "%s/700"
"template": {
"dashboard": "default",
"mobile": "default"
"display": {
"invertBinary": "0"
"isVisible": "1",
"alert": []
"eqType": "jMQTT",
"name": "BSB-LAN",
"type": "info",
"isHistorized": "0",
"configuration": {
"topic": "%s"
"template": {
"mobile": "default"
"display": {
"invertBinary": "0"
"isVisible": "1",
"alert": []
"eqType": "jMQTT",
"name": "MQTT",
"type": "info",
"configuration": {
"topic": "%s/MQTT"
"template": {
"mobile": "default"
"display": {
"invertBinary": "0"
"isVisible": "1",
"alert": []
"eqType": "jMQTT",
"name": "status",
"type": "info",
"configuration": {
"topic": "%s/status"
"template": {
"mobile": "default"
"display": {
"invertBinary": "0"
"isVisible": "1",
"alert": []
"eqType": "jMQTT",
"name": "710",
"type": "info",
"unite": "°c",
"configuration": {
"topic": "%s/710"
"template": {
"mobile": "default"
"display": {
"invertBinary": "0"
"isVisible": "1",
"alert": []
"eqType": "jMQTT",
"name": "712",
"type": "info",
"unite": "°c",
"configuration": {
"topic": "%s/712"
"template": {
"mobile": "default"
"display": {
"invertBinary": "0"
"isVisible": "1",
"alert": []
"eqType": "jMQTT",
"name": "714",
"type": "info",
"unite": "°c",
"configuration": {
"topic": "%s/714"
"template": {
"mobile": "default"
"display": {
"invertBinary": "0"
"isVisible": "1",
"alert": []
"eqType": "jMQTT",
"name": "8000",
"type": "info",
"configuration": {
"topic": "%s/8000"
"template": {
"mobile": "default"
"display": {
"invertBinary": "0"
"isVisible": "1",
"alert": []
"eqType": "jMQTT",
"name": "8006",
"type": "info",
"configuration": {
"topic": "%s/8006"
"template": {
"mobile": "default"
"display": {
"invertBinary": "0"
"isVisible": "1",
"alert": []
"eqType": "jMQTT",
"name": "8410",
"type": "info",
"unite": "°c",
"configuration": {
"topic": "%s/8410"
"template": {
"mobile": "default"
"display": {
"invertBinary": "0"
"isVisible": "1",
"alert": []
"eqType": "jMQTT",
"name": "8411",
"type": "info",
"unite": "°c",
"configuration": {
"topic": "%s/8411"
"template": {
"mobile": "default"
"display": {
"invertBinary": "0"
"isVisible": "1",
"alert": []
"eqType": "jMQTT",
"name": "8412",
"type": "info",
"unite": "°c",
"configuration": {
"topic": "%s/8412"
"template": {
"mobile": "default"
"display": {
"invertBinary": "0"
"isVisible": "1",
"alert": []
"eqType": "jMQTT",
"name": "8413",
"type": "info",
"unite": "%",
"configuration": {
"topic": "%s/8413"
"template": {
"mobile": "default"
"display": {
"invertBinary": "0"
"isVisible": "1",
"alert": []
"eqType": "jMQTT",
"name": "8700",
"type": "info",
"unite": "°c",
"configuration": {
"topic": "%s/8700"
"template": {
"mobile": "default"
"display": {
"invertBinary": "0"
"isVisible": "1",
"alert": []
"eqType": "jMQTT",
"name": "8740",
"type": "info",
"unite": "°c",
"configuration": {
"topic": "%s/8740"
"template": {
"mobile": "default"
"display": {
"invertBinary": "0"
"isVisible": "1",
"alert": []
"eqType": "jMQTT",
"name": "Mode chauffage",
"type": "action",
"subType": "select",
"configuration": {
"topic": "%s",
"listValue": "S700=0|Mode protection;S700=1|Automatique;S700=2|Réduit;S700=3|Confort",
"retain": "0",
"autoPub": "0",
"timeline::enable": "0",
"interact::auto::disable": "0",
"actionConfirm": "0",
"actionCheckCmd": [],
"jeedomPreExecCmd": [],
"jeedomPostExecCmd": []
"template": {
"dashboard": "custom::esp",
"mobile": "custom::esp"
"display": {
"showNameOndashboard": "1",
"showNameOnmobile": "1",
"showIconAndNamedashboard": "0",
"showIconAndNamemobile": "0",
"forceReturnLineBefore": "0",
"forceReturnLineAfter": "0",
"parameters": []
"value": "700",
"isVisible": "1",
"alert": []
"eqType": "jMQTT",
"name": "Consigne",
"type": "action",
"subType": "slider",
"configuration": {
"topic": "%s",
"request": "S710=#slider#",
"minValue": "19.0",
"maxValue": "24.0",
"retain": "0",
"autoPub": "0",
"template": {
"dashboard": "core::button",
"mobile": "default"
"display": {
"parameters": {
"minValue": "19.0",
"maxValue": "24.0"
"value": "710",
"isVisible": "1",
"alert": []
donc pour la modification de temperature pour le mode confort la valeur est S710=#slider#
aussi lu sur la doc jmqtt renseigne OBLIGATOIREMENT deux lignes de paramètres optionnels widget 1. minValue ex:19 2,maxValue ex:24
sinon j’ai eu un truc bizarre la sonde règle a 4°c,
aussi par défaut le pas (step) est bien de 0.5°c donc parfait associé sur la même page avec le widget Button
A la création des commandes sur le topic BSB-LAN, une commande info bsb-lan se créé et comme on le voit, la valeur pour la commande S710, est S710=20. Puis directement après la commande passé, la commande MQTT se créé, c’est le bsb-lan qui renvoie un accusé de reception avec pour valeur ACK_Sxxx=xx
