La version 1.23 de z2m apporte l’OTA pour certains dispositifs Legrand:
#85 Support OTA for Legrand 067646, 064888 and 067775/741811
Il faut enlever l’alimentation, enlever la pile ou couper le secteur avant de faire la mise à jour. Cela rend le module receptif aux mises à jour pendant une dizaine de minutes.
Mise a jour 1.23
Donc c’est installé et 067775/741811 se retrouve bien dans la liste des mises à jour OTA du frontend.
Une mise a jour est disponible.
Mais quand je la lance elle ne fonctionne pas.
info Updating 'Salon_Pri_Leg01' to latest firmware
info MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"message":"Updating 'Salon_Pri_Leg01' to latest firmware","meta":{"device":"Salon_Pri_Leg01","status":"update_in_progress"},"type":"ota_update"}'
info MQTT publish: topic 'zigbee2mqtt/Salon_Pri_Leg01', payload '{"device":{"applicationVersion":0,"dateCode":" \u000020210527\u0000\u0000\u0000\u0000\u0000","friendlyName":"Salon_Pri_Leg01","hardwareVersion":2,"ieeeAddr":"0x0004740000117405","manufacturerID":4129,"manufacturerName":" Legrand\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","model":"067775/741811","networkAddress":15425,"powerSource":"Mains (single phase)","softwareBuildID":"0023","stackVersion":66,"type":"Router","zclVersion":2},"linkquality":84,"power":7,"state":"ON","update":{"state":"available"},"update_available":true}'
info MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"message":"Update of 'Salon_Pri_Leg01' failed (Device didn't respond to OTA request)","meta":{"device":"Salon_Pri_Leg01","status":"update_failed"},"type":"ota_update"}'
info MQTT publish: topic 'zigbee2mqtt/bridge/response/device/ota_update/update', payload '{"data":{"id":"Salon_Pri_Leg01"},"error":"Update of 'Salon_Pri_Leg01' failed (Device didn't respond to OTA request)","status":"error","transaction":"1azgv-13"}'
error Update of 'Salon_Pri_Leg01' failed (Device didn't respond to OTA request)
sa version 0023 du 20210527 Voici pour le moment où j’en suis
Bonne soirée à tous
Un retour sur cette mise à jour. J’ai deux modules type 064888 que je n’arrive pas à mettre à jour depuis que la version 1.23.0 est sortie.
Je teste régulièrement et j’avais noté qu’une fois, l’OTA avait affichée 0.00% puis c’était arrêtée aussitôt. Pour ce faire, j’avais joué avec le module, allumage puis extinction ou rafraichissement dans la partie expose puis state du module.
Ce soir, j’ai retenté et pour un des deux la mise à jour à vraiment débutée. Environ 20% actuellement.
Donc si vous avez le courage, faire une demande de mise à jour puis essayer de faire des on/off pour que le module soit à l’écoute mais sans garantie de succès. Pour le deuxième, je n’y arrive toujours pas.
Merci pour l’information
de mon côté pour prise 067775/741811 toujours le même message on-off ,ou coupures alimentation comme c’est conseiller sur le git.
Toujours le même message
Wait and see
j’ai ça comme version de firmware : 003e pour des 067775/741811.
J’ai fais les mises à jours fin janvier de mémoire via le contrôleur Legrand pour activer la remonté de la consomation, avant de les basculer définitivement sur zigbee2mqtt.
Par contre, pour la même version du firmware j’ai des dates différentes sur mes prises et qui sont en 2019 et 2018. Etrange.
Merci @loic69
avec cette version, je suis passé de 004a à 0051 et ils ont la même date, sur prise murale Legrand 067775/741811. avant la mise à jour se lançait mais ne fonctionnait pas jusqu’au bout.
