Cela fait un moment que mon nut ne remonte pas.
Voici l’erreur. Certainement un pb avec une dépendance ou une librairie:
root@jeedom:/var/www/html# /usr/bin/python3 /var/www/html/plugins/nut/resources/nut.py -f getInfos -a 10.0.0.251 -n eaton
--- Logging error ---
File "/usr/lib/python3.9/logging/handlers.py", line 953, in emit
self.socket.send(msg)
OSError: [Errno 9] Bad file descriptor
During handling of the above exception, another exception occurred:
File "/usr/lib/python3.9/logging/handlers.py", line 874, in _connect_unixsocket
self.socket.connect(address)
FileNotFoundError: [Errno 2] No such file or directory
File "/usr/lib/python3.9/logging/handlers.py", line 956, in emit
self._connect_unixsocket(self.address)
File "/usr/lib/python3.9/logging/handlers.py", line 885, in _connect_unixsocket
Call stack:
File "/var/www/html/plugins/nut/resources/nut.py", line 29, in <module>
ups = nut3.PyNUT3Client(host=address, login=user, password=password)
File "/usr/local/lib/python3.9/dist-packages/pynut3/nut3.py", line 117, in __init__
_LOGGER.debug(f"NUT Class initialization on: {host}:{port}, Login: {login} started.")
Message: 'NUT Class initialization on: 10.0.0.251:3493, Login: None started.'
Arguments: ()
Call stack:
File "/usr/local/lib/python3.9/dist-packages/pynut3/nut3.py", line 163, in __init__
_LOGGER.debug(
Message: 'NUT Class initialization finished 2024-03-27 17:38 CET.'
Arguments: ()
File "/var/www/html/plugins/nut/resources/nut.py", line 33, in <module>
result = ups.get_dict_vars(ups=device)
AttributeError: 'PyNUT3Client' object has no attribute 'get_dict_vars'
Sur mon docker l’accès à distance fonctionne bien:
[docker@docker: ~]$ upsc eaton@10.0.0.251
Init SSL without certificate database
battery.charge: 100
battery.charge.low: 20
battery.runtime: 2525
battery.type: PbAc
device.mfr: EATON
device.model: Ellipse PRO 1600
device.serial: G363N26114
device.type: ups
driver.name: usbhid-ups
driver.parameter.pollfreq: 30
driver.parameter.pollinterval: 2
driver.parameter.port: auto
driver.parameter.synchronous: auto
driver.version: 2.8.0
driver.version.data: MGE HID 1.46
driver.version.internal: 0.47
driver.version.usb: libusb-1.0.26 (API: 0x1000109)
input.frequency: 50.0
input.transfer.high: 285
input.transfer.low: 165
input.voltage: 229.0
input.voltage.extended: no
outlet.1.desc: PowerShare Outlet 1
outlet.1.id: 2
outlet.1.status: on
outlet.1.switchable: no
outlet.2.desc: PowerShare Outlet 2
outlet.2.id: 3
outlet.2.status: on
outlet.2.switchable: no
outlet.desc: Main Outlet
outlet.id: 1
outlet.switchable: no
output.frequency: 50.0
output.frequency.nominal: 50
output.voltage: 230.0
output.voltage.nominal: 240
ups.beeper.status: enabled
ups.delay.shutdown: 20
ups.delay.start: 30
ups.firmware: 01.18.0022
ups.load: 11
ups.mfr: EATON
ups.model: Ellipse PRO 1600
ups.power: 139
ups.power.nominal: 1600
ups.productid: ffff
ups.realpower: 120
ups.serial: G363N26114
ups.status: OL
ups.timer.shutdown: -1
ups.timer.start: -1
ups.vendorid: 0463
merci
PS: j’ai essayé avec un login/pwd et memes messages
