BASEDIR: /var/www/html/plugins/peugeotcars/core/class/../../resources
Installation des dépendances
STEP1:Upadate
STEP2:Installation python3 version 3.7
Python 3.7.3
STEP3:Installation pip3 version pour python 3.7
WARNING: Value for scheme.platlib does not match. Please report this to <https://github.com/pypa/pip/issues/9617>
distutils: /usr/local/lib/python3.7/dist-packages
sysconfig: /usr/lib/python3.7/site-packages
WARNING: Value for scheme.purelib does not match. Please report this to <https://github.com/pypa/pip/issues/9617>
WARNING: Value for scheme.headers does not match. Please report this to <https://github.com/pypa/pip/issues/9617>
distutils: /usr/local/include/python3.7/UNKNOWN
sysconfig: /usr/include/python3.7m
WARNING: Value for scheme.scripts does not match. Please report this to <https://github.com/pypa/pip/issues/9617>
distutils: /usr/local/bin
sysconfig: /usr/bin
WARNING: Value for [scheme.data](http://scheme.data/) does not match. Please report this to <https://github.com/pypa/pip/issues/9617>
sysconfig: /usr
WARNING: Additional context:
user = False
home = None
root = None
prefix = None
Requirement already satisfied: pip in /usr/local/lib/python3.7/dist-packages (21.1)
sysconfig: /usr/bin
sysconfig: /usr
user = False
home = None
root = None
prefix = None
WARNING: Running pip as root will break packages and permissions. You should install packages reliably by using venv: https://pip.pypa.io/warnings/venv
pip 21.1 from /usr/local/lib/python3.7/dist-packages/pip (python 3.7)
STEP4:Installation des librairies necessaires
python_req: /var/www/html/plugins/peugeotcars/core/class/../../resources/../3rdparty/psa_jeedom_daemon/requirements.txt
sysconfig: /usr/bin
sysconfig: /usr
user = False
home = None
root = None
prefix = None
Collecting paho-mqtt>=1.5.0
Using cached paho-mqtt-1.5.1.tar.gz (101 kB)
ERROR: Command errored out with exit status 1:
command: /usr/bin/python3 -c 'import io, os, sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-1cov53wq/paho-mqtt_7d9376940f124179b48230bad0ef5b29/[setup.py](http://setup.py/)'"'"'; __file__='"'"'/tmp/pip-install-1cov53wq/paho-mqtt_7d9376940f124179b48230bad0ef5b29/[setup.py](http://setup.py/)'"'"';f = getattr(tokenize, '"'"'open'"'"', open)(__file__) if os.path.exists(__file__) else io.StringIO('"'"'from setuptools import setup; setup()'"'"');code = [f.read](http://f.read/)().replace('"'"'
'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' egg_info --egg-base /tmp/pip-pip-egg-info-8jx9h9aj
cwd: /tmp/pip-install-1cov53wq/paho-mqtt_7d9376940f124179b48230bad0ef5b29/
Complete output (3 lines):
File "<string>", line 1, in <module>
ModuleNotFoundError: No module named 'setuptools'
WARNING: Discarding https://files.pythonhosted.org/packages/32/d3/6dcb8fd14746fcde6a556f932b5de8bea8fedcb85b3a092e0e986372c0e7/paho-mqtt-1.5.1.tar.gz#sha256=9feb068e822be7b3a116324e01fb6028eb1d66412bf98595ae72698965cb1cae (from https://pypi.org/simple/paho-mqtt/). Command errored out with exit status 1: python [setup.py](http://setup.py/) egg_info Check the logs for full command output.
Using cached paho-mqtt-1.5.0.tar.gz (99 kB)
command: /usr/bin/python3 -c 'import io, os, sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-1cov53wq/paho-mqtt_7aa8a2d266d245c3ac6258a911000e51/[setup.py](http://setup.py/)'"'"'; __file__='"'"'/tmp/pip-install-1cov53wq/paho-mqtt_7aa8a2d266d245c3ac6258a911000e51/[setup.py](http://setup.py/)'"'"';f = getattr(tokenize, '"'"'open'"'"', open)(__file__) if os.path.exists(__file__) else io.StringIO('"'"'from setuptools import setup; setup()'"'"');code = [f.read](http://f.read/)().replace('"'"'
'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' egg_info --egg-base /tmp/pip-pip-egg-info-vgzv0zmt
cwd: /tmp/pip-install-1cov53wq/paho-mqtt_7aa8a2d266d245c3ac6258a911000e51/
WARNING: Discarding https://files.pythonhosted.org/packages/59/11/1dd5c70f0f27a88a3a05772cd95f6087ac479fac66d9c7752ee5e16ddbbc/paho-mqtt-1.5.0.tar.gz#sha256=e3d286198baaea195c8b3bc221941d25a3ab0e1507fc1779bdb7473806394be4 (from https://pypi.org/simple/paho-mqtt/). Command errored out with exit status 1: python [setup.py](http://setup.py/) egg_info Check the logs for full command output.
ERROR: Could not find a version that satisfies the requirement paho-mqtt>=1.5.0 (from versions: 0.4.90, 0.4.91, 0.4.92, 0.4.94, 0.9, 0.9.1, 1.0, 1.1, 1.2, 1.2.1, 1.2.2, 1.2.3, 1.3.0, 1.3.1, 1.4.0, 1.5.0, 1.5.1)
ERROR: No matching distribution found for paho-mqtt>=1.5.0
STEP5:Configuration API
File "./app_decoder.py", line 7, in <module>
from androguard.core.bytecodes.apk import APK
ModuleNotFoundError: No module named 'androguard'
Installation des dépendances terminée !
sys.path = [
'/var/www/html/plugins/peugeotcars/3rdparty/psa_jeedom_daemon',
'/usr/lib/[python37.zip](http://python37.zip/)',
'/usr/lib/python3.7',
'/usr/lib/python3.7/lib-dynload',
'/usr/local/lib/python3.7/dist-packages',
'/usr/lib/python3/dist-packages',
USER_BASE: '/root/.local' (exists)
USER_SITE: '/root/.local/lib/python3.7/site-packages' (doesn't exist)
ENABLE_USER_SITE: True
