Bonjour à vous et merci pour l’initative du plugin !!
j’avais installer la plugin Dreame sur Jeedom en v4.3.15 ; j’avais réussi à remonter et detecter mon W10
j’ai du faire une reinstalle à neuf dernièrement et charger mon backup et faite toutes les mise à jour avec la dernière version de jeedom v4.3.17
cette fois je n’ai plus la main dessus, j’ai tenté reinstall ; desinstall reinstall du plugin
suppression du robot, il ne le detecte plus même en changeant les serveurs
si je change le serveur pour Germany et que je retrourne dans configuration n’est pas pris en compte et revient sur default
mon log Dreame_packages
+ touch /tmp/jeedom_install_in_progress_dreame
+ echo 1
+ echo 2
+ sudo chmod +x /var/www/html/core/class/../../plugins/dreame/resources/pre-install.sh
+ sudo /var/www/html/core/class/../../plugins/dreame/resources/pre-install.sh
Launch pre-install of dreame dependency
Reading package lists...
Building dependency tree...
Reading state information...
Package 'rustc' is not installed, so not removed
0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
Package 'cargo' is not installed, so not removed
Installing rustup
info: downloading installer
warning: it looks like you have an existing installation of Rust at:
warning: /usr/bin
warning: rustup should not be installed alongside Rust. Please uninstall your existing Rust first.
warning: Otherwise you may have confusion unless you are careful with your PATH
warning: If you are sure that you want both rustup and your already installed Rust
warning: then please reply `y' or `yes' or set RUSTUP_INIT_SKIP_PATH_CHECK to yes
warning: or pass `-y' to ignore all ignorable checks.
error: cannot install while Rust is installed
warning: continuing (because the -y flag is set and the error is ignorable)
info: profile set to 'default'
info: default host triple is armv7-unknown-linux-gnueabihf
warning: Updating existing toolchain, profile choice will be ignored
info: syncing channel updates for 'stable-armv7-unknown-linux-gnueabihf'
info: default toolchain set to 'stable-armv7-unknown-linux-gnueabihf'
stable-armv7-unknown-linux-gnueabihf unchanged - rustc 1.68.2 (9eb3afe9e 2023-03-27)
Rust is installed now. Great!
To get started you need Cargo's bin directory ($HOME/.cargo/bin) in your PATH
environment variable. This has not been done automatically.
To configure your current shell, run:
source "$HOME/.cargo/env"
Updating rustup to version 1.48.0
/var/www/html/core/class/../../plugins/dreame/resources/pre-install.sh: line 29: rustup: command not found
ln: failed to create symbolic link '/usr/bin/rustc': File exists
ln: failed to create symbolic link '/usr/bin/cargo': File exists
Setting executable permissions for rustc and cargo
Installing python-miio from git master branch
Looking in links: /tmp/tmpagx1tkxd
Requirement already satisfied: setuptools in /usr/local/lib/python3.8/site-packages (67.6.1)
Requirement already satisfied: pip in /usr/local/lib/python3.8/site-packages (23.0.1)
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv
Collecting git+https://github.com/rytilahti/python-miio.git@master
Cloning https://github.com/rytilahti/python-miio.git (to revision master) to /tmp/pip-req-build-vfps0ifd
Running command git clone --filter=blob:none --quiet https://github.com/rytilahti/python-miio.git /tmp/pip-req-build-vfps0ifd
Resolved https://github.com/rytilahti/python-miio.git to commit 788df486a5d87008664570972d2f665a0a8705bb
Installing build dependencies: started
Installing build dependencies: finished with status 'done'
Getting requirements to build wheel: started
Getting requirements to build wheel: finished with status 'done'
Preparing metadata (pyproject.toml): started
Preparing metadata (pyproject.toml): finished with status 'done'
Requirement already satisfied: PyYAML<7,>=5 in /usr/local/lib/python3.8/site-packages (from python-miio==0.6.0.dev0) (6.0)
Requirement already satisfied: construct<3.0.0,>=2.10.56 in /usr/local/lib/python3.8/site-packages (from python-miio==0.6.0.dev0) (2.10.68)
Requirement already satisfied: pytz in /usr/local/lib/python3.8/site-packages (from python-miio==0.6.0.dev0) (2023.3)
Requirement already satisfied: pydantic in /usr/local/lib/python3.8/site-packages (from python-miio==0.6.0.dev0) (1.10.7)
Requirement already satisfied: zeroconf<1,>=0 in /usr/local/lib/python3.8/site-packages (from python-miio==0.6.0.dev0) (0.56.0)
Requirement already satisfied: tqdm<5,>=4 in /usr/local/lib/python3.8/site-packages (from python-miio==0.6.0.dev0) (4.65.0)
Requirement already satisfied: cryptography>=35 in /usr/local/lib/python3.8/site-packages (from python-miio==0.6.0.dev0) (40.0.1)
Requirement already satisfied: appdirs<2,>=1 in /usr/local/lib/python3.8/site-packages (from python-miio==0.6.0.dev0) (1.4.4)
Requirement already satisfied: defusedxml<1,>=0 in /usr/local/lib/python3.8/site-packages (from python-miio==0.6.0.dev0) (0.7.1)
Requirement already satisfied: click>=8 in /usr/local/lib/python3.8/site-packages (from python-miio==0.6.0.dev0) (8.1.3)
Requirement already satisfied: attrs in /usr/local/lib/python3.8/site-packages (from python-miio==0.6.0.dev0) (22.2.0)
Requirement already satisfied: micloud>=0.6 in /usr/local/lib/python3.8/site-packages (from python-miio==0.6.0.dev0) (0.6)
Requirement already satisfied: croniter>=1 in /usr/local/lib/python3.8/site-packages (from python-miio==0.6.0.dev0) (1.3.10)
Requirement already satisfied: python-dateutil in /usr/local/lib/python3.8/site-packages (from croniter>=1->python-miio==0.6.0.dev0) (2.8.2)
Requirement already satisfied: cffi>=1.12 in /usr/local/lib/python3.8/site-packages (from cryptography>=35->python-miio==0.6.0.dev0) (1.15.1)
Requirement already satisfied: tzlocal in /usr/local/lib/python3.8/site-packages (from micloud>=0.6->python-miio==0.6.0.dev0) (4.3)
Requirement already satisfied: pycryptodome in /usr/local/lib/python3.8/site-packages (from micloud>=0.6->python-miio==0.6.0.dev0) (3.17)
Requirement already satisfied: requests in /usr/local/lib/python3.8/site-packages (from micloud>=0.6->python-miio==0.6.0.dev0) (2.28.2)
Requirement already satisfied: ifaddr>=0.1.7 in /usr/local/lib/python3.8/site-packages (from zeroconf<1,>=0->python-miio==0.6.0.dev0) (0.2.0)
Requirement already satisfied: async-timeout>=3.0.0 in /usr/local/lib/python3.8/site-packages (from zeroconf<1,>=0->python-miio==0.6.0.dev0) (4.0.2)
Requirement already satisfied: typing-extensions>=4.2.0 in /usr/local/lib/python3.8/site-packages (from pydantic->python-miio==0.6.0.dev0) (4.5.0)
Requirement already satisfied: pycparser in /usr/local/lib/python3.8/site-packages (from cffi>=1.12->cryptography>=35->python-miio==0.6.0.dev0) (2.21)
Requirement already satisfied: six>=1.5 in /usr/local/lib/python3.8/site-packages (from python-dateutil->croniter>=1->python-miio==0.6.0.dev0) (1.16.0)
Requirement already satisfied: charset-normalizer<4,>=2 in /usr/local/lib/python3.8/site-packages (from requests->micloud>=0.6->python-miio==0.6.0.dev0) (3.1.0)
Requirement already satisfied: urllib3<1.27,>=1.21.1 in /usr/local/lib/python3.8/site-packages (from requests->micloud>=0.6->python-miio==0.6.0.dev0) (1.26.15)
Requirement already satisfied: certifi>=2017.4.17 in /usr/local/lib/python3.8/site-packages (from requests->micloud>=0.6->python-miio==0.6.0.dev0) (2022.12.7)
Requirement already satisfied: idna<4,>=2.5 in /usr/local/lib/python3.8/site-packages (from requests->micloud>=0.6->python-miio==0.6.0.dev0) (3.4)
Requirement already satisfied: backports.zoneinfo in /usr/local/lib/python3.8/site-packages (from tzlocal->micloud>=0.6->python-miio==0.6.0.dev0) (0.2.1)
Requirement already satisfied: pytz-deprecation-shim in /usr/local/lib/python3.8/site-packages (from tzlocal->micloud>=0.6->python-miio==0.6.0.dev0) (0.1.0.post0)
Requirement already satisfied: tzdata in /usr/local/lib/python3.8/site-packages (from pytz-deprecation-shim->tzlocal->micloud>=0.6->python-miio==0.6.0.dev0) (2023.3)
WARNING: Skipping pycrypto as it is not installed.
Usage:
/usr/local/bin/python3.8 -m pip install [options] <requirement specifier> [package-index-options] ...
/usr/local/bin/python3.8 -m pip install [options] -r <requirements file> [package-index-options] ...
/usr/local/bin/python3.8 -m pip install [options] [-e] <vcs project url> ...
/usr/local/bin/python3.8 -m pip install [options] [-e] <local project path> ...
/usr/local/bin/python3.8 -m pip install [options] <archive url/path> ...
no such option: --yes
Found existing installation: micloud 0.6
Uninstalling micloud-0.6:
Would remove:
/usr/local/bin/micloud
/usr/local/lib/python3.8/site-packages/micloud-0.6.dist-info/*
/usr/local/lib/python3.8/site-packages/micloud/*
Proceed (Y/n)? ERROR: Exception:
File "/usr/local/lib/python3.8/site-packages/pip/_internal/cli/base_command.py", line 160, in exc_logging_wrapper
status = run_func(*args)
File "/usr/local/lib/python3.8/site-packages/pip/_internal/commands/uninstall.py", line 105, in run
uninstall_pathset = req.uninstall(
File "/usr/local/lib/python3.8/site-packages/pip/_internal/req/req_install.py", line 664, in uninstall
uninstalled_pathset.remove(auto_confirm, verbose)
File "/usr/local/lib/python3.8/site-packages/pip/_internal/req/req_uninstall.py", line 367, in remove
if auto_confirm or self._allowed_to_proceed(verbose):
File "/usr/local/lib/python3.8/site-packages/pip/_internal/req/req_uninstall.py", line 407, in _allowed_to_proceed
return ask("Proceed (Y/n)? ", ("y", "n", "")) != "n"
File "/usr/local/lib/python3.8/site-packages/pip/_internal/utils/misc.py", line 191, in ask
response = input(message)
EOFError: EOF when reading a line
Requirement already satisfied: micloud in /usr/local/lib/python3.8/site-packages (0.6)
Requirement already satisfied: pycryptodome in /usr/local/lib/python3.8/site-packages (from micloud) (3.17)
Requirement already satisfied: click in /usr/local/lib/python3.8/site-packages (from micloud) (8.1.3)
Requirement already satisfied: tzlocal in /usr/local/lib/python3.8/site-packages (from micloud) (4.3)
Requirement already satisfied: requests in /usr/local/lib/python3.8/site-packages (from micloud) (2.28.2)
Requirement already satisfied: certifi>=2017.4.17 in /usr/local/lib/python3.8/site-packages (from requests->micloud) (2022.12.7)
Requirement already satisfied: idna<4,>=2.5 in /usr/local/lib/python3.8/site-packages (from requests->micloud) (3.4)
Requirement already satisfied: urllib3<1.27,>=1.21.1 in /usr/local/lib/python3.8/site-packages (from requests->micloud) (1.26.15)
Requirement already satisfied: charset-normalizer<4,>=2 in /usr/local/lib/python3.8/site-packages (from requests->micloud) (3.1.0)
Requirement already satisfied: pytz-deprecation-shim in /usr/local/lib/python3.8/site-packages (from tzlocal->micloud) (0.1.0.post0)
Requirement already satisfied: backports.zoneinfo in /usr/local/lib/python3.8/site-packages (from tzlocal->micloud) (0.2.1)
Requirement already satisfied: tzdata in /usr/local/lib/python3.8/site-packages (from pytz-deprecation-shim->tzlocal->micloud) (2023.3)
+ echo 3
+ sudo chmod +x /var/www/html/core/class/../../plugins/dreame/resources/post-install.sh
chmod: cannot access '/var/www/html/core/class/../../plugins/dreame/resources/post-install.sh': No such file or directory
+ sudo /var/www/html/core/class/../../plugins/dreame/resources/post-install.sh
sudo: /var/www/html/core/class/../../plugins/dreame/resources/post-install.sh: command not found
+ echo 4
+ php /var/www/html/core/class/../php/jeecli.php plugin dependancy_end dreame
+ rm /tmp/jeedom_install_in_progress_dreame
fichier « Dreame » ( en mode debug )
[2023-04-11 09:43:00][DEBUG] : ["Traceback (most recent call last):"," File \"\/usr\/local\/bin\/micloud\", line 5, in <module>"," from micloud.cli import cli"," File \"\/usr\/local\/lib\/python3.8\/site-packages\/micloud\/__init__.py\", line 1, in <module>"," from .micloud import MiCloud"," File \"\/usr\/local\/lib\/python3.8\/site-packages\/micloud\/micloud.py\", line 16, in <module>"," from micloud import miutils"," File \"\/usr\/local\/lib\/python3.8\/site-packages\/micloud\/miutils.py\", line 15, in <module>"," from Crypto.Cipher import ARC4"," File \"\/usr\/local\/lib\/python3.8\/site-packages\/Crypto\/Cipher\/ARC4.py\", line 119, in <module>"," key_size = xrange(1,256+1)","NameError: name 'xrange' is not defined"]
[2023-04-11 09:43:00][DEBUG] : ============================ DISCOVER ============================
