pas de soucis
mise à jour faite
relance des dépendances
[2023-12-19 12:26:00] *************************************
[2023-12-19 12:26:00] * Launch install of dependencies *
[2023-12-19 12:26:00] Hit:1 http://deb.debian.org/debian buster InRelease
[2023-12-19 12:26:00] Hit:2 http://deb.debian.org/debian buster-updates InRelease
[2023-12-19 12:26:00] Hit:3 http://deb.debian.org/debian buster-backports InRelease
[2023-12-19 12:26:00] Hit:4 http://security.debian.org buster/updates InRelease
[2023-12-19 12:26:00] Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
[2023-12-19 12:26:01] Hit:6 http://xogium.performanceservers.nl/apt buster InRelease
[2023-12-19 12:26:02] Hit:7 https://packagecloud.io/ookla/speedtest-cli/debian buster InRelease
[2023-12-19 12:26:11] Reading package lists...
[2023-12-19 12:26:11] *****************************
[2023-12-19 12:26:11] Install modules using apt-get
[2023-12-19 12:26:12] Building dependency tree...
[2023-12-19 12:26:12] Reading state information...
[2023-12-19 12:26:13] python3-pip is already the newest version (18.1-5).
[2023-12-19 12:26:13] python3 is already the newest version (3.7.3-1).
[2023-12-19 12:26:13] python3-dev is already the newest version (3.7.3-1).
[2023-12-19 12:26:13] python3-venv is already the newest version (3.7.3-1).
[2023-12-19 12:26:13] python3-requests is already the newest version (2.21.0-1+deb10u1).
[2023-12-19 12:26:13] 0 upgraded, 0 newly installed, 0 to remove and 203 not upgraded.
[2023-12-19 12:26:13] *************************************
[2023-12-19 12:26:13] Creating python 3 virtual environment
[2023-12-19 12:26:18] Done
[2023-12-19 12:26:18] *************************************
[2023-12-19 12:26:18] Install the required python libraries
[2023-12-19 12:26:19] Requirement already satisfied: pip in ./venv/lib/python3.7/site-packages (23.3.2)
[2023-12-19 12:26:20] Requirement already satisfied: wheel in ./venv/lib/python3.7/site-packages (0.42.0)
[2023-12-19 12:26:22] Requirement already satisfied: aiohttp>=3.8.0 in ./venv/lib/python3.7/site-packages (from -r requirements.txt (line 1)) (3.8.6)
[2023-12-19 12:26:22] Requirement already satisfied: paho-mqtt>=1.6.0 in ./venv/lib/python3.7/site-packages (from -r requirements.txt (line 2)) (1.6.1)
ERROR: Ignored the following yanked versions: 1.25, 1.25.1, 2.0.0, 2.0.1
ERROR: Ignored the following versions that require a different python version: 2.1.0 Requires-Python >=3.8
ERROR: Could not find a version that satisfies the requirement urllib3==2.1.0 (from versions: 0.3, 1.0, 1.0.1, 1.0.2, 1.1, 1.2, 1.2.1, 1.2.2, 1.3, 1.4, 1.5, 1.6, 1.7, 1.7.1, 1.8, 1.8.2, 1.8.3, 1.9, 1.9.1, 1.10, 1.10.1, 1.10.2, 1.10.3, 1.10.4, 1.11, 1.12, 1.13, 1.13.1, 1.14, 1.15, 1.15.1, 1.16, 1.17, 1.18, 1.18.1, 1.19, 1.19.1, 1.20, 1.21, 1.21.1, 1.22, 1.23, 1.24, 1.24.1, 1.24.2, 1.24.3, 1.25.2, 1.25.3, 1.25.4, 1.25.5, 1.25.6, 1.25.7, 1.25.8, 1.25.9, 1.25.10, 1.25.11, 1.26.0, 1.26.1, 1.26.2, 1.26.3, 1.26.4, 1.26.5, 1.26.6, 1.26.7, 1.26.8, 1.26.9, 1.26.10, 1.26.11, 1.26.12, 1.26.13, 1.26.14, 1.26.15, 1.26.16, 1.26.17, 1.26.18, 2.0.0a1, 2.0.0a2, 2.0.0a3, 2.0.0a4, 2.0.2, 2.0.3, 2.0.4, 2.0.5, 2.0.6, 2.0.7)
ERROR: No matching distribution found for urllib3==2.1.0
[2023-12-19 12:26:23] ***************************
[2023-12-19 12:26:23] * Install ended *
DEMON OK
pas d’erreur
petite question un peu HS mais dans les 1er version du plugin, je pouvais programmer le lancement d’une tonte avec bordure puis une commande qui ne semble plus disponible depuis plusieurs MAJ, nous avons déjà eu un échange sur ce sujet
il n’est toujours pas possible d’avoir cette option ou une autre méthode pour forcer une tonte avec bordure ?
