Oui, j’avais pas fait la mise à jour, c’est chose faite
ok, je testerais la beta, merci
EDIT : installation de la beta
2023-11-28 12:00:24 worxLandroidS [MySQL] Error code : 23000 (1062). Duplicate entry '1172-Direction' for key 'unique' : INSERT INTO `cmd` SET `id` = :id, `logicalId` = :logicalId, `generic_type` = :generic_type, `eqType` = :eqType, `name` = :name, `order` = :order, `type` = :type, `subType` = :subType, `eqLogic_id` = :eqLogic_id, `isHistorized` = :isHistorized, `unite` = :unite, `configuration` = :configuration, `template` = :template, `display` = :display, `value` = :value, `isVisible` = :isVisible, `alert` = :alert
j’ai relancé les dépendances
[2023-11-28 12:02:02] *************************************
[2023-11-28 12:02:02] * Launch install of dependencies *
[2023-11-28 12:02:03] Get:1 http://security.debian.org buster/updates InRelease [34.8 kB]
[2023-11-28 12:02:03] Hit:2 http://deb.debian.org/debian buster InRelease
[2023-11-28 12:02:03] Hit:3 http://deb.debian.org/debian buster-updates InRelease
[2023-11-28 12:02:03] Get:4 http://deb.debian.org/debian buster-backports InRelease [51.4 kB]
[2023-11-28 12:02:03] Hit:6 https://download.docker.com/linux/debian buster InRelease
[2023-11-28 12:02:03] Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
[2023-11-28 12:02:04] Hit:5 http://armbian.hosthatch.com/apt buster InRelease
[2023-11-28 12:02:04] Get:9 http://security.debian.org buster/updates/main armhf Packages [736 kB]
[2023-11-28 12:02:04] Get:10 http://security.debian.org buster/updates/main arm64 Packages [733 kB]
[2023-11-28 12:02:05] Hit:8 https://packagecloud.io/ookla/speedtest-cli/debian buster InRelease
[2023-11-28 12:02:07] Fetched 1556 kB in 4s (396 kB/s)
[2023-11-28 12:02:15] Reading package lists...
[2023-11-28 12:02:15] *****************************
[2023-11-28 12:02:15] Install modules using apt-get
[2023-11-28 12:02:16] Building dependency tree...
[2023-11-28 12:02:16] Reading state information...
[2023-11-28 12:02:17] python3-pip is already the newest version (18.1-5).
[2023-11-28 12:02:17] python3 is already the newest version (3.7.3-1).
[2023-11-28 12:02:17] python3-dev is already the newest version (3.7.3-1).
[2023-11-28 12:02:17] python3-venv is already the newest version (3.7.3-1).
[2023-11-28 12:02:17] python3-requests is already the newest version (2.21.0-1+deb10u1).
[2023-11-28 12:02:17] 0 upgraded, 0 newly installed, 0 to remove and 201 not upgraded.
[2023-11-28 12:02:17] *************************************
[2023-11-28 12:02:17] Creating python 3 virtual environment
[2023-11-28 12:02:22] Done
[2023-11-28 12:02:22] *************************************
[2023-11-28 12:02:22] Install the required python libraries
[2023-11-28 12:02:24] Requirement already satisfied: pip in ./venv/lib/python3.7/site-packages (23.3.1)
[2023-11-28 12:02:24] Requirement already satisfied: wheel in ./venv/lib/python3.7/site-packages (0.41.3)
[2023-11-28 12:02:24] Collecting wheel
[2023-11-28 12:02:24] Downloading wheel-0.42.0-py3-none-any.whl.metadata (2.2 kB)
[2023-11-28 12:02:24] Downloading wheel-0.42.0-py3-none-any.whl (65 kB)
[2023-11-28 12:02:24] ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 65.4/65.4 kB 3.5 MB/s eta 0:00:00
[2023-11-28 12:02:25] Installing collected packages: wheel
[2023-11-28 12:02:25] Attempting uninstall: wheel
[2023-11-28 12:02:25] Found existing installation: wheel 0.41.3
[2023-11-28 12:02:25] Uninstalling wheel-0.41.3:
[2023-11-28 12:02:25] Successfully uninstalled wheel-0.41.3
[2023-11-28 12:02:25] Successfully installed wheel-0.42.0
[2023-11-28 12:02:27] Requirement already satisfied: aiohttp>=3.8.0 in ./venv/lib/python3.7/site-packages (from -r requirements.txt (line 1)) (3.8.6)
[2023-11-28 12:02:27] Requirement already satisfied: paho-mqtt>=1.6.0 in ./venv/lib/python3.7/site-packages (from -r requirements.txt (line 2)) (1.6.1)
[2023-11-28 12:02:27] Requirement already satisfied: urllib3==1.26.15 in ./venv/lib/python3.7/site-packages (from -r requirements.txt (line 3)) (1.26.15)
[2023-11-28 12:02:27] Requirement already satisfied: backports.zoneinfo==0.2.1 in ./venv/lib/python3.7/site-packages (from -r requirements.txt (line 4)) (0.2.1)
[2023-11-28 12:02:27] Requirement already satisfied: attrs>=17.3.0 in ./venv/lib/python3.7/site-packages (from aiohttp>=3.8.0->-r requirements.txt (line 1)) (23.1.0)
[2023-11-28 12:02:27] Requirement already satisfied: charset-normalizer<4.0,>=2.0 in ./venv/lib/python3.7/site-packages (from aiohttp>=3.8.0->-r requirements.txt (line 1)) (3.3.2)
[2023-11-28 12:02:27] Requirement already satisfied: multidict<7.0,>=4.5 in ./venv/lib/python3.7/site-packages (from aiohttp>=3.8.0->-r requirements.txt (line 1)) (6.0.4)
[2023-11-28 12:02:27] Requirement already satisfied: async-timeout<5.0,>=4.0.0a3 in ./venv/lib/python3.7/site-packages (from aiohttp>=3.8.0->-r requirements.txt (line 1)) (4.0.3)
[2023-11-28 12:02:27] Requirement already satisfied: yarl<2.0,>=1.0 in ./venv/lib/python3.7/site-packages (from aiohttp>=3.8.0->-r requirements.txt (line 1)) (1.9.2)
[2023-11-28 12:02:27] Requirement already satisfied: frozenlist>=1.1.1 in ./venv/lib/python3.7/site-packages (from aiohttp>=3.8.0->-r requirements.txt (line 1)) (1.3.3)
[2023-11-28 12:02:27] Requirement already satisfied: aiosignal>=1.1.2 in ./venv/lib/python3.7/site-packages (from aiohttp>=3.8.0->-r requirements.txt (line 1)) (1.3.1)
[2023-11-28 12:02:27] Requirement already satisfied: asynctest==0.13.0 in ./venv/lib/python3.7/site-packages (from aiohttp>=3.8.0->-r requirements.txt (line 1)) (0.13.0)
[2023-11-28 12:02:27] Requirement already satisfied: typing-extensions>=3.7.4 in ./venv/lib/python3.7/site-packages (from aiohttp>=3.8.0->-r requirements.txt (line 1)) (4.7.1)
[2023-11-28 12:02:27] Requirement already satisfied: importlib-metadata in ./venv/lib/python3.7/site-packages (from attrs>=17.3.0->aiohttp>=3.8.0->-r requirements.txt (line 1)) (6.7.0)
[2023-11-28 12:02:27] Requirement already satisfied: idna>=2.0 in ./venv/lib/python3.7/site-packages (from yarl<2.0,>=1.0->aiohttp>=3.8.0->-r requirements.txt (line 1)) (3.4)
[2023-11-28 12:02:27] Requirement already satisfied: zipp>=0.5 in ./venv/lib/python3.7/site-packages (from importlib-metadata->attrs>=17.3.0->aiohttp>=3.8.0->-r requirements.txt (line 1)) (3.15.0)
[2023-11-28 12:02:28] ***************************
[2023-11-28 12:02:28] * Install ended *
mais toujours l’erreur
File "/var/www/html/plugins/worxLandroidS/resources/worxLandroidSd.py", line 15, in
from pyworxcloud import WorxCloud
File "/var/www/html/plugins/worxLandroidS/resources/pyworxcloud/__init__.py", line 11, in
from .api import LandroidCloudAPI
File "/var/www/html/plugins/worxLandroidS/resources/pyworxcloud/api.py", line 9, in
from .utils.requests import GET, HEADERS, POST
File "/var/www/html/plugins/worxLandroidS/resources/pyworxcloud/utils/__init__.py", line 10, in
from .mqtt import MQTT, Command
File "/var/www/html/plugins/worxLandroidS/resources/pyworxcloud/utils/mqtt.py", line 13, in
import paho.mqtt.client as mqtt
ModuleNotFoundError: No module named 'paho'
