root@JeedomAtlas:/etc/apt/sources.list.d# sudo apt-get update
Hit:1 http://deb.debian.org/debian buster InRelease
Hit:2 http://deb.debian.org/debian buster-updates InRelease
Hit:3 http://deb.debian.org/debian buster-backports InRelease
Hit:4 https://download.docker.com/linux/debian buster InRelease
Get:5 http://phoscon.de/apt/deconz buster InRelease [2,869 B]
Hit:7 https://deb.nodesource.com/node_16.x buster InRelease
Err:5 http://phoscon.de/apt/deconz buster InRelease
The following signatures couldn't be verified because the public key is not available: NO_PUBKEY C9A759493D8720A
Hit:8 http://security.debian.org buster/updates InRelease
Hit:6 http://armbian.systemonachip.net/apt buster InRelease
Reading package lists... Done
W: GPG error: http://phoscon.de/apt/deconz buster InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY C9A759493D8720A
E: The repository 'http://phoscon.de/apt/deconz buster InRelease' is not signed.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
root@JeedomAtlas:/etc/apt/sources.list.d# sudo apt-get upgrade deconz
Building dependency tree
Reading state information... Done
deconz is already the newest version (2.15.03-debian-buster-stable).
Calculating upgrade... Done
il doit y avoir un problème de clé mais je ne sais pas comment le résoudre W: GPG error: http://phoscon.de/apt/deconz buster InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY C9A759493D8720A
J’ai fait la manip en SSH sur le terminal d’un mac en utilisateur root
Merci pour votre aide
j’ai tapé la commande je n’ai plu le message d’erreur. mais je suis toujours ne 2.15.03
root@JeedomAtlas:~# sudo apt-get update
Hit:3 http://security.debian.org buster/updates InRelease
Get:4 http://phoscon.de/apt/deconz buster InRelease [2,869 B]
Hit:5 https://download.docker.com/linux/debian buster InRelease
Hit:6 http://deb.debian.org/debian buster-backports InRelease
Get:9 http://phoscon.de/apt/deconz buster/main armhf Packages [732 B]
Get:10 http://phoscon.de/apt/deconz buster/main arm64 Packages [730 B]
Hit:8 https://armbian.site-meganet.com/apt buster InRelease
Fetched 1,462 B in 6s (240 B/s)
root@JeedomAtlas:~# sudo apt-get upgrade deconz
The following packages will be upgraded:
apache2 apache2-bin apache2-data apache2-utils armbian-bsp-cli-rockpi-4b armbian-config armbian-firmware armbian-zsh
base-files bind9-host containerd.io debconf debconf-utils deconz distro-info-data dnsutils docker-ce docker-ce-cli dpkg
dpkg-dev ffmpeg gzip libapache2-mod-php7.3 libavcodec58 libavdevice58 libavfilter7 libavformat58 libavresample4
libavutil56 libbind9-161 libc-bin libc-dev-bin libc-l10n libc6 libc6-dev libcups2 libdns-export1104 libdns1104
libdpkg-perl libexpat1 libexpat1-dev libflac8 libgmp10 libgssapi-krb5-2 libicu63 libirs161 libisc-export1100 libisc1100
libisccc161 libisccfg163 libk5crypto3 libkrb5-3 libkrb5support0 libldap-2.4-2 libldap-common liblwres161 liblzma5
libnss3 libntfs-3g883 libpcap0.8 libpolkit-agent-1-0 libpolkit-backend-1-0 libpolkit-gobject-1-0 libpostproc55
libsasl2-2 libsasl2-modules-db libsmbclient libssl-dev libssl1.1 libswresample3 libswscale5 libtiff5 libwavpack1
libwbclient0 libxml2 linux-dtb-current-rockchip64 linux-image-current-rockchip64 linux-libc-dev
linux-u-boot-rockpi-4b-current locales mariadb-client mariadb-client-10.3 mariadb-client-core-10.3 mariadb-common
mariadb-server mariadb-server-10.3 mariadb-server-core-10.3 nodejs ntfs-3g openssl php7.3 php7.3-cli php7.3-common
php7.3-curl php7.3-dev php7.3-gd php7.3-gmp php7.3-imap php7.3-json php7.3-ldap php7.3-mbstring php7.3-mysql
php7.3-opcache php7.3-readline php7.3-soap php7.3-xml php7.3-xmlrpc php7.3-zip policykit-1 psmisc python-lxml rsyslog
samba-common samba-libs smbclient tzdata vim vim-common vim-runtime xserver-common xvfb xxd xz-utils zlib1g zlib1g-dev
zsh zsh-common
127 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 263 MB of archives.
After this operation, 93.7 MB disk space will be freed.
Do you want to continue? [Y/n] n
Abort.
Je n’ai pas osé mettre Y de peur qu’il mette à jour les 127 upgraded
root@JeedomAtlas:~# sudo apt show deconz
Package: deconz
Version: 2.16.01-debian-buster-stable
Priority: extra
Section: non-free / misc
Maintainer: Manuel Pietschmann <manuel.pietschmann@dresden-elektronik.de>
Installed-Size: 42.8 MB
Depends: libqt5core5a, libqt5network5, libqt5widgets5, libqt5gui5, libqt5serialport5, libqt5websockets5, libqt5sql5, libqt5qml5, libcap2-bin, sqlite3, lsof, curl
Homepage: http://www.dresden-elektronik.de
Download-Size: 6,669 kB
APT-Sources: http://phoscon.de/apt/deconz buster/main arm64 Packages
Description: A generic ZigBee monitoring and control tool
The deCONZ application allows to monitor and control arbitrary ZigBee PRO based devices.
N: There is 1 additional record. Please use the '-a' switch to see it
Il me dit ette dans la dernière version alors que je n’y suis pas.
Et tu as bien fait car sur atlas je ne suis pas certain que la mise à jour soit à faire par les dépôts standards Debian…
Le paquet up to date de deconz semble être OK.
En passant par la page de configuration Deconz tu as un menu pour forcer la mise à jour de deCONZ , Installation Deconz local. As tu essayé avec cette méthode préconisée ?
Si oui et que ça n’a pas marché tu peux alors forcer l’installation d’un paquet Debian sudo apt install deconz
