Merci @Loic
Je viens de faire la mise à jour, et je t’avoue que j’ai très peur et que j’ai multiplié les sauvegardes… et c’est la première fois que je télécharge le backup sur mon ordinateur lol.
Cela ne fonctionne pas chez moi le deamon ne fonctionne pas.
Déjà Interface z2m Ici je n’ai rien au bout.
Voici les logs :
Z2M :
[2023-09-27 20:27:11]INFO : Arrêt du démon z2m
[2023-09-27 20:27:12]INFO : Démarrage du démon Z2M : ZIGBEE2MQTT_DATA=/var/www/html/plugins/z2m/core/class/../../data npm start --prefix /var/www/html/plugins/z2m/resources/zigbee2mqtt
Z2Md :
> zigbee2mqtt@1.33.0 start
> node index.js
Zigbee2MQTT:debug 2023-09-27 20:27:14: Loaded state from file /var/www/html/plugins/z2m/data/state.json
Zigbee2MQTT:info 2023-09-27 20:27:14: Logging to console and directory: '/var/www/html/plugins/z2m/data/log/2023-09-27.20-27-14' filename: log.txt
Zigbee2MQTT:debug 2023-09-27 20:27:14: Removing old log directory '/var/www/html/plugins/z2m/data/log/2023-09-24.21-10-05'
Zigbee2MQTT:info 2023-09-27 20:27:14: Starting Zigbee2MQTT version 1.33.0 (commit #4d53ac4)
Zigbee2MQTT:info 2023-09-27 20:27:14: Starting zigbee-herdsman (0.18.5)
Zigbee2MQTT:debug 2023-09-27 20:27:14: Using zigbee-herdsman with settings: '{"adapter":{"concurrent":null,"delay":null,"disableLED":false},"backupPath":"/var/www/html/plugins/z2m/data/coordinator_backup.json","databaseBackupPath":"/var/www/html/plugins/z2m/data/database.db.backup","databasePath":"/var/www/html/plugins/z2m/data/database.db","network":{"channelList":[11],"extendedPanID":[221,221,221,221,221,221,221,221],"networkKey":"HIDDEN","panID":6754},"serialPort":{"adapter":"zstack","path":"/dev/ttyACM0"}}'
Zigbee2MQTT:error 2023-09-27 20:27:34: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2023-09-27 20:27:34: Failed to start zigbee
Zigbee2MQTT:error 2023-09-27 20:27:34: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
Zigbee2MQTT:error 2023-09-27 20:27:34: Exiting...
Zigbee2MQTT:error 2023-09-27 20:27:34: Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
at ZStackAdapter.start (/var/www/html/plugins/z2m/resources/zigbee2mqtt/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:103:27)
at Controller.start (/var/www/html/plugins/z2m/resources/zigbee2mqtt/node_modules/zigbee-herdsman/src/controller/controller.ts:132:29)
at Zigbee.start (/var/www/html/plugins/z2m/resources/zigbee2mqtt/lib/zigbee.ts:60:27)
at Controller.start (/var/www/html/plugins/z2m/resources/zigbee2mqtt/lib/controller.ts:101:27)
at start (/var/www/html/plugins/z2m/resources/zigbee2mqtt/index.js:107:5)
J’ai remis ma sauvegarde précieusement réalisée
Tout fonctionne à merveille.
Si jamais tu veux gratter pour éventuellement trouver quelque chose, jeedom support activer mon user market est Micka260
Tu as le temps, ne te presse pas, je sais que tu fais ça en supplément, c’est déjà très sympathique. Les services sont opérationnels via l’ancienne version.
