Retest avec celle la :
SELECT myid AS id, IF(IFNULL(istotal,0)>0 ,"Total",IF(categorie="NC",myname,categorie)) AS name_cat, isHCHP , istotal , SUM(shc) AS totalhc, SUM(shp) AS totalhp, ROUND(SUM(shp)+SUM(shc),2) AS total, ROUND(SUM(hcprix),2) AS prixhc, ROUND(SUM(hpprix),2) AS prixhp, ROUND(SUM(totalprix),2) AS prix, ROUND(SUM(shc)*100/(res.totalhc+res.totalhp),2) AS total_percent_ecq_hc, ROUND(SUM(shp)*100/(res.totalhc+res.totalhp),2) AS total_percent_ecq_hp, SUM(shc)*100/(SUM(shp)+SUM(shc)) AS percent_ecq_hc, SUM(shp)*100/(SUM(shp)+SUM(shc)) AS percent_ecq_hp, ROUND((SUM(shc)+SUM(shp))*100/(res.totalhc+res.totalhp),2) AS percent_ecq, myid FROM ( SELECT CASE WHEN configuration like '%"visibleConsumptionLight":"1"%' THEN "Lumieres" WHEN configuration like '%"visibleConsumptionElectrical":"1"%' THEN "Electromenager" WHEN configuration like '%"visibleConsumptionAutomatism":"1"%' THEN "Automatisme" WHEN configuration like '%"visibleConsumptionHeating":"1"%' THEN "Chauffage" WHEN configuration like '%"visibleConsumptionMultimedia":"1"%' THEN "Multimedia" WHEN configuration LIKE '%"visibleConsumptionVehicules":"1"%' THEN "Véhicules" WHEN configuration LIKE '%"visibleConsumptionOther":"1"%' THEN "Autres" ELSE "NC" END as categorie, id AS myid, IF(INSTR(configuration, '"type_abo":"HCHP"' )>0 , 1 , 0 ) AS isHCHP , IF(INSTR(configuration, '"total":"1"' )>0 , 1 , 0 ) AS istotal , NAME AS myname, /* MIN(j.rec_date) AS DATE,*/ periode, hc AS shc, hp AS shp, totalhp, totalhc, prix_hc * hc AS hcprix, prix_hp * hp AS hpprix, (prix_hc * hc) + (prix_hp * hp) AS totalprix, DATE_FORMAT(j.`rec_date`,"%d%c%Y") AS mois, j.`rec_date`, p.id_eq FROM conso_jour j INNER JOIN ( SELECT jo.id_eq, DATE_FORMAT(jo.`rec_date`,"%d%c%Y"), jo.rec_date, SUM(hp) AS totalhp, SUM(hc) AS totalhc, (SELECT FORMAT(hc,4) AS hc FROM conso_price WHERE type_ecq LIKE "%elect%" AND UNIX_TIMESTAMP(DATE_FORMAT(jo.rec_date , "%Y-%m-%d")) BETWEEN UNIX_TIMESTAMP( DATE_FORMAT( date_debut, "%Y-%m-%d" ) ) AND UNIX_TIMESTAMP( DATE_FORMAT( date_fin, "%Y-%m-%d" ) ) LIMIT 0,1) AS prix_hc, (SELECT FORMAT(hp,4) AS hc FROM conso_price WHERE type_ecq LIKE "%elect%" AND UNIX_TIMESTAMP(DATE_FORMAT(jo.rec_date , "%Y-%m-%d")) BETWEEN UNIX_TIMESTAMP( DATE_FORMAT( date_debut, "%Y-%m-%d" ) ) AND UNIX_TIMESTAMP( DATE_FORMAT( date_fin, "%Y-%m-%d" ) ) LIMIT 0,1 ) AS prix_hp FROM conso_jour jo INNER JOIN eqLogic eqc ON eqc.id = jo.id_eq WHERE jo.id_eq in (671,679,672,676,677,680) and DATE_FORMAT(jo.`rec_date`,"%d%c%Y") = DATE_FORMAT(CURDATE(),"%d%c%Y") AND configuration LIKE "%elect%" AND configuration LIKE '%"total":"1"%' GROUP BY DATE_FORMAT(jo.`rec_date`,"%d%c%Y"), jo.id_eq ) AS p ON DATE_FORMAT(p.`rec_date`,"%d%c%Y") = DATE_FORMAT(j.`rec_date`,"%d%c%Y") INNER JOIN eqLogic eq ON eq.id = j.id_eq AND isEnable = 1 WHERE j.id_eq in (671,679,672,676,677,680) and DATE_FORMAT(j.`rec_date`,"%d%c%Y") = DATE_FORMAT(CURDATE(),"%d%c%Y") AND configuration LIKE "%elect%" /* GROUP BY j.id_eq*/ ) AS res GROUP BY DATE_FORMAT(res.`rec_date`,"%d%c%Y"), myname ORDER BY istotal DESC
Je la découvre en même temps que toi
