allez je reboot, par contre, le fichier était vide, normal ? ca vaut le coup de copier le contenu de l’ancien dans celui-ci d’apres toi ?
Il peut pas être vide.
Fais lsblk puis dmesg
Colle aussi le fichier /etc/fstab ici
toujours en train de booter la bestiole, si ca peut aider j’ai quelques failed de services
- dhcp
- wpa
- login service
- modem manager
dès qu’il est revenu a la vie, je passe les deux commandes
pi@CHEOPSrasp:~ $ cat /etc/fstab
proc /proc proc defaults 0 0
PARTUUID=6a2eba3d-01 /boot vfat defaults 0 2
PARTUUID=6a2eba3d-02 / ext4 defaults,noatime 0 1
tmpfs /tmp/jeedom tmpfs defaults,size=256M 0 0
a swapfile is not a swap partition, no line here
use dphys-swapfile swap[on|off] for that
pi@CHEOPSrasp:~ $ lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
sda 8:0 0 111.8G 0 disk
|-sda1 8:1 0 256M 0 part /boot
`-sda2 8:2 0 111.5G 0 part /
cat /boot/config.txt
et est-ce que dmesg te mets des erreurs IO ?
pi@CHEOPSrasp:~ $ cat /boot/config.txt
####### For more options and information see
####### http://rpf.io/configtxt
####### Some settings may impact device functionality. See link above for details
####### uncomment if you get no picture on HDMI for a default "safe" mode
#######hdmi_safe=1
####### uncomment this if your display has a black border of unused pixels visible
####### and your display can output without overscan
#######disable_overscan=1
####### uncomment the following to adjust overscan. Use positive numbers if console
####### goes off screen, and negative if there is too much border
#######overscan_left=16
#######overscan_right=16
#######overscan_top=16
#######overscan_bottom=16
#######uncomment to force a console size. By default it will be display's size minus
####### overscan.
#######framebuffer_width=1280
#######framebuffer_height=720
####### uncomment if hdmi display is not detected and composite is being output
#######hdmi_force_hotplug=1
#######uncomment to force a specific HDMI mode (this will force VGA)
#######hdmi_group=1
#######hdmi_mode=1
####### uncomment to force a HDMI mode rather than DVI. This can make audio work in
####### DMT (computer monitor) modes
#######hdmi_drive=2
#######uncomment to increase signal to HDMI, if you have interference, blanking, or
####### no display
#######config_hdmi_boost=4
####### uncomment for composite PAL
#######sdtv_mode=2
#######uncomment to overclock the arm. 700 MHz is the default.
#######arm_freq=800
####### Uncomment some or all of these to enable the optional hardware interfaces
#######dtparam=i2c_arm=on
#######dtparam=i2s=on
#######dtparam=spi=on
####### Uncomment this to enable infrared communication.
#######dtoverlay=gpio-ir,gpio_pin=17
#######dtoverlay=gpio-ir-tx,gpio_pin=18
####### Additional overlays and parameters are documented /boot/overlays/README
####### Enable audio (loads snd_bcm2835)
dtparam=audio=on
[pi4]
####### Enable DRM VC4 V3D driver on top of the dispmanx display stack
dtoverlay=vc4-fkms-v3d
max_framebuffers=2
[all]
#######dtoverlay=vc4-fkms-v3d
####### Enable USB Boot for Jeedom
program_usb_boot_mode=1
Tu as bien tapé ?
yes, y’a pas bcp de chose en non commentaires
au niveau I/O j’ai bcp de chose comme ca:
[ 252.656567] sd 0:0:0:0: [sda] tag#17 uas_eh_abort_handler 0 uas-tag 14 inflight: CMD IN
[ 252.656578] sd 0:0:0:0: [sda] tag#17 CDB: opcode=0x28 28 00 00 00 26 81 00 00 01 00
[ 252.656689] sd 0:0:0:0: [sda] tag#16 uas_eh_abort_handler 0 uas-tag 13 inflight: CMD IN
Quand j’y pense ta version de raspbian doit être trop vieille pour le boot usb, c’est buster ?
Essaye de repartir à zéro avec une image neuve propre (la tienne est corrompue ou mal instalée sur le ssd). Après tu réinjecte un backup jeedom que tu devrais trouver sur la sd sous /var/www/html/backup
Yes c’est buster, du coup tu me conseille quoi comme image ? si buster du mois d’Aout est pas bonne
Elle est bonne, re-télécharge la.
Essaye aussi avec un autre ssd
oki je tente ca demain, merci bcp bcp
Ah oui ton ssd a un problème, j’avais pas vu le dmesg
du coup je le format et ce serait bon tu pense ? ou retour chez amazon avec un vrai ssd pcq le crucial jme suis dit que ca passerait mais vu le prix voilà aussi
Prends absolument du msata sinon tu vas galérer.
Regarde sur ali tu peux trouver ça à 30 ou 35 euro le msata et le boitier usb ou mieux une carte x857.
Si tu es un peu plus riche regarde les msata transcend.
tu penses à ca ? Amazon.fr
Je mets pas autant dedans mais si tu as les moyens pourquoi pas…
Par contre 64Go suffiront même si le 128 va probablement un peu plus vite.
Perso j’utilise des 16Go chinois à 15 euros et ils ont tous eu une longue vie sans problèmes de santé jusqu’ici
