Je n’arrive toujours pas à me connecter en 4G avec la box. J’ai une SIM FREE. J’utilise pour l’instant le plugin en beta (j’ai essayé en stable aussi).
Par contre le plugin SMS fonctionne bien.
Quelqu’un à déja reussi à faire fonctionner la data et le SMS en même temps ?
Screen plugin :
Log plugin :
[2024-04-18 18:57:35][DEBUG] : [{"UUID":"c2ca914a-9f55-366c-a874-3c72d958363a","name":"Wired connection 1","type":"802-3-ethernet","metric":"100"}]
[2024-04-18 18:57:35][DEBUG] : [{"UUID":"c2ca914a-9f55-366c-a874-3c72d958363a","name":"Wired connection 1","type":"802-3-ethernet","metric":"100"},{"UUID":"26b1c7ad-d0cf-47c3-ace3-d7f728b1a954","name":"tun0","type":"tun","metric":"-1"}]
[2024-04-18 18:57:36][DEBUG] : [{"UUID":"c2ca914a-9f55-366c-a874-3c72d958363a","name":"Wired connection 1","type":"802-3-ethernet","metric":"100"},{"UUID":"26b1c7ad-d0cf-47c3-ace3-d7f728b1a954","name":"tun0","type":"tun","metric":"-1"},{"UUID":"","name":null,"type":null,"metric":""}]
[2024-04-18 18:57:36][DEBUG] : OK
[2024-04-18 18:57:36][DEBUG] : Modem >
[2024-04-18 18:57:36][DEBUG] : IMEI >
[2024-04-18 18:57:36][DEBUG] : OPERATOR NAME >
[2024-04-18 18:57:36][DEBUG] : SIGNAL PERCENT >
[2024-04-18 18:57:36][DEBUG] : STATE >
[2024-04-18 18:57:36][DEBUG] : STATE FAILED REASON >
[2024-04-18 18:57:36][DEBUG] : UNLOCK REQUIRED >
[2024-04-18 18:57:36][DEBUG] : UNLOCK RETRIES >
[2024-04-18 18:57:39][DEBUG] : JSON VOLUME > trouvé
[2024-04-18 18:57:39][DEBUG] : Wifi enabled : sudo nmcli -f SSID,SIGNAL,SECURITY,CHAN -t -m tabular dev wifi list ifname wlan-1
[2024-04-18 18:57:39][DEBUG] : [{"UUID":"c2ca914a-9f55-366c-a874-3c72d958363a","name":"Wired connection 1","type":"802-3-ethernet","active":"yes","device":"eth0"}]
[2024-04-18 18:57:40][DEBUG] : [{"UUID":"c2ca914a-9f55-366c-a874-3c72d958363a","name":"Wired connection 1","type":"802-3-ethernet","active":"yes","device":"eth0"},{"UUID":"26b1c7ad-d0cf-47c3-ace3-d7f728b1a954","name":"tun0","type":"tun","active":"yes","device":"tun0"}]
[2024-04-18 18:57:40][DEBUG] : [{"UUID":"c2ca914a-9f55-366c-a874-3c72d958363a","name":"Wired connection 1","type":"802-3-ethernet","active":"yes","device":"eth0"},{"UUID":"26b1c7ad-d0cf-47c3-ace3-d7f728b1a954","name":"tun0","type":"tun","active":"yes","device":"tun0"},{"UUID":"77d0bed0-06f8-4385-8917-7a5698d1c5d7","name":"Freebox-65057A Iot","type":"802-11-wireless","active":"no","device":"wlan0"}]
[2024-04-18 18:57:40][DEBUG] : [{"UUID":"c2ca914a-9f55-366c-a874-3c72d958363a","name":"Wired connection 1","type":"802-3-ethernet","active":"yes","device":"eth0"},{"UUID":"26b1c7ad-d0cf-47c3-ace3-d7f728b1a954","name":"tun0","type":"tun","active":"yes","device":"tun0"},{"UUID":"77d0bed0-06f8-4385-8917-7a5698d1c5d7","name":"Freebox-65057A Iot","type":"802-11-wireless","active":"no","device":"wlan0"},{"UUID":"4a65c31c-a7f0-4076-94bb-5d083084eb8a","name":"JeedomLTE","type":"gsm","active":"no","device":""}]
[2024-04-18 18:57:40][DEBUG] : [{"UUID":"c2ca914a-9f55-366c-a874-3c72d958363a","name":"Wired connection 1","type":"802-3-ethernet","active":"yes","device":"eth0"},{"UUID":"26b1c7ad-d0cf-47c3-ace3-d7f728b1a954","name":"tun0","type":"tun","active":"yes","device":"tun0"},{"UUID":"77d0bed0-06f8-4385-8917-7a5698d1c5d7","name":"Freebox-65057A Iot","type":"802-11-wireless","active":"no","device":"wlan0"},{"UUID":"4a65c31c-a7f0-4076-94bb-5d083084eb8a","name":"JeedomLTE","type":"gsm","active":"no","device":""},{"UUID":"","name":null,"type":null,"active":null,"device":""}]
[2024-04-18 18:57:43][DEBUG] : OK
[2024-04-18 18:57:43][DEBUG] : CONFIG JSON LTE1
[2024-04-18 18:57:43][DEBUG] : APN > free
[2024-04-18 18:57:43][DEBUG] : USER >
[2024-04-18 18:57:43][DEBUG] : PASSWORD >
[2024-04-18 18:57:43][DEBUG] : EXISTE > 1
[2024-04-18 18:57:44][DEBUG] : Fin de la configuration LTE > proxy.pac-script: --
[2024-04-18 18:57:44][DEBUG] : Activation LTE
[2024-04-18 18:57:45][DEBUG] : [{"UUID":"c2ca914a-9f55-366c-a874-3c72d958363a","name":"Wired connection 1","type":"802-3-ethernet","metric":"100"}]
[2024-04-18 18:57:45][DEBUG] : [{"UUID":"c2ca914a-9f55-366c-a874-3c72d958363a","name":"Wired connection 1","type":"802-3-ethernet","metric":"100"},{"UUID":"26b1c7ad-d0cf-47c3-ace3-d7f728b1a954","name":"tun0","type":"tun","metric":"-1"}]
[2024-04-18 18:57:46][DEBUG] : [{"UUID":"c2ca914a-9f55-366c-a874-3c72d958363a","name":"Wired connection 1","type":"802-3-ethernet","metric":"100"},{"UUID":"26b1c7ad-d0cf-47c3-ace3-d7f728b1a954","name":"tun0","type":"tun","metric":"-1"},{"UUID":"","name":null,"type":null,"metric":""}]
[2024-04-18 18:57:46][DEBUG] : OK
[2024-04-18 18:57:46][DEBUG] : Modem >
[2024-04-18 18:57:46][DEBUG] : IMEI >
[2024-04-18 18:57:46][DEBUG] : OPERATOR NAME >
[2024-04-18 18:57:46][DEBUG] : SIGNAL PERCENT >
[2024-04-18 18:57:46][DEBUG] : STATE >
[2024-04-18 18:57:46][DEBUG] : STATE FAILED REASON >
[2024-04-18 18:57:46][DEBUG] : UNLOCK REQUIRED >
[2024-04-18 18:57:46][DEBUG] : UNLOCK RETRIES >
[2024-04-18 18:57:49][DEBUG] : JSON VOLUME > trouvé
[2024-04-18 18:57:49][DEBUG] : Wifi enabled : sudo nmcli -f SSID,SIGNAL,SECURITY,CHAN -t -m tabular dev wifi list ifname wlan-1
[2024-04-18 18:57:50][DEBUG] : Wifi enabled : sudo nmcli -f SSID,SIGNAL,SECURITY,CHAN -t -m tabular dev wifi list ifname wlan-1
[2024-04-18 18:57:50][DEBUG] : [{"UUID":"c2ca914a-9f55-366c-a874-3c72d958363a","name":"Wired connection 1","type":"802-3-ethernet","active":"yes","device":"eth0"}]
[2024-04-18 18:57:50][DEBUG] : [{"UUID":"c2ca914a-9f55-366c-a874-3c72d958363a","name":"Wired connection 1","type":"802-3-ethernet","active":"yes","device":"eth0"},{"UUID":"26b1c7ad-d0cf-47c3-ace3-d7f728b1a954","name":"tun0","type":"tun","active":"yes","device":"tun0"}]
[2024-04-18 18:57:50][DEBUG] : [{"UUID":"c2ca914a-9f55-366c-a874-3c72d958363a","name":"Wired connection 1","type":"802-3-ethernet","active":"yes","device":"eth0"},{"UUID":"26b1c7ad-d0cf-47c3-ace3-d7f728b1a954","name":"tun0","type":"tun","active":"yes","device":"tun0"},{"UUID":"77d0bed0-06f8-4385-8917-7a5698d1c5d7","name":"Freebox-65057A Iot","type":"802-11-wireless","active":"no","device":"wlan0"}]
[2024-04-18 18:57:50][DEBUG] : [{"UUID":"c2ca914a-9f55-366c-a874-3c72d958363a","name":"Wired connection 1","type":"802-3-ethernet","active":"yes","device":"eth0"},{"UUID":"26b1c7ad-d0cf-47c3-ace3-d7f728b1a954","name":"tun0","type":"tun","active":"yes","device":"tun0"},{"UUID":"77d0bed0-06f8-4385-8917-7a5698d1c5d7","name":"Freebox-65057A Iot","type":"802-11-wireless","active":"no","device":"wlan0"},{"UUID":"4a65c31c-a7f0-4076-94bb-5d083084eb8a","name":"JeedomLTE","type":"gsm","active":"no","device":""}]
[2024-04-18 18:57:50][DEBUG] : [{"UUID":"c2ca914a-9f55-366c-a874-3c72d958363a","name":"Wired connection 1","type":"802-3-ethernet","active":"yes","device":"eth0"},{"UUID":"26b1c7ad-d0cf-47c3-ace3-d7f728b1a954","name":"tun0","type":"tun","active":"yes","device":"tun0"},{"UUID":"77d0bed0-06f8-4385-8917-7a5698d1c5d7","name":"Freebox-65057A Iot","type":"802-11-wireless","active":"no","device":"wlan0"},{"UUID":"4a65c31c-a7f0-4076-94bb-5d083084eb8a","name":"JeedomLTE","type":"gsm","active":"no","device":""},{"UUID":"","name":null,"type":null,"active":null,"device":""}]
[2024-04-18 18:57:51][DEBUG] : [{"UUID":"c2ca914a-9f55-366c-a874-3c72d958363a","name":"Wired connection 1","type":"802-3-ethernet","active":"yes","device":"eth0"},{"UUID":"26b1c7ad-d0cf-47c3-ace3-d7f728b1a954","name":"tun0","type":"tun","active":"yes","device":"tun0"},{"UUID":"77d0bed0-06f8-4385-8917-7a5698d1c5d7","name":"Freebox-65057A Iot","type":"802-11-wireless","active":"no","device":"wlan0"},{"UUID":"4a65c31c-a7f0-4076-94bb-5d083084eb8a","name":"JeedomLTE","type":"gsm","active":"no","device":""},{"UUID":"","name":null,"type":null,"active":null,"device":""}]
