Depuis plusieurs jours, j’ai une veilleuse led commandée par une prise zigbee sous DeconZ qui s’allume puis s’éteint tout de suite…
Je viens de faire le test directement avec la commande ON sous Deconz et elle s’allume de 1 à3s (état qui passe à 1) puis s’éteint…
Etrange…
Le log en debug:
0000|[2023-03-23 22:52:18]DEBUG : {"00212EFFFF05AB6C":{"attr":{"id":"11","lastannounced":null,"lastseen":"2023-03-23T21:52Z","manufacturername":"_TZ3000_2putqrmw","modelid":"TS011F","name":"On\/Off plug-in unit 11","swversion":"1.0.13","type":"On\/Off plug-in unit","uniqueid":"a4:c1:38:15:50:01:bf:72-01"},"e":"changed","id":"11","r":"lights","t":"event","uniqueid":"a4:c1:38:15:50:01:bf:72-01"}}
0001|[2023-03-23 22:52:24]DEBUG : Execute commande : lights/21/state whith parameters : {"on":true}
0002|[2023-03-23 22:52:24]DEBUG : 127.0.0.1:8484/api/BE38D7042D/lights/21/state type : PUT
0003|[2023-03-23 22:52:24]DEBUG : {"00212EFFFF05AB6C":{"e":"changed","id":"21","r":"lights","state":{"alert":"none","on":true,"reachable":true},"t":"event","uniqueid":"84:fd:27:ff:fe:c2:28:fb-01"}}
0004|[2023-03-23 22:52:25]DEBUG : {"00212EFFFF05AB6C":{"attr":{"id":"21","lastannounced":"2022-07-25T20:43:02Z","lastseen":"2023-03-23T21:52Z","manufacturername":"_TZ3000_cphmq0q7","modelid":"TS011F","name":"On\/Off plug-in unit 21","swversion":"67","type":"On\/Off plug-in unit","uniqueid":"84:fd:27:ff:fe:c2:28:fb-01"},"e":"changed","id":"21","r":"lights","t":"event","uniqueid":"84:fd:27:ff:fe:c2:28:fb-01"}}
0005|[2023-03-23 22:52:28]DEBUG : {"00212EFFFF05AB6C":{"attr":{"colorcapabilities":31,"ctmax":666,"ctmin":125,"id":"5","lastannounced":"2023-03-22T02:08:11Z","lastseen":"2023-03-23T21:52Z","manufacturername":"OSRAM","modelid":"LIGHTIFY Indoor Flex RGBW","name":"Extended color light 5","swversion":"V1.04.90","type":"Extended color light","uniqueid":"7c:b0:3e:aa:0a:00:82:c5-03"},"e":"changed","id":"5","r":"lights","t":"event","uniqueid":"7c:b0:3e:aa:0a:00:82:c5-03"}}
0006|[2023-03-23 22:52:29]DEBUG : {"00212EFFFF05AB6C":{"attr":{"id":"15","lastannounced":"2023-03-23T21:51:46Z","lastseen":"2023-03-23T21:52Z","manufacturername":"ORVIBO","modelid":"CM10ZW","name":"Door Lock Unit 15","swversion":"v3.1.06","type":"Door Lock Unit","uniqueid":"00:12:4b:00:22:ce:2d:55-01"},"e":"changed","id":"15","r":"lights","t":"event","uniqueid":"00:12:4b:00:22:ce:2d:55-01"}}
0007|[2023-03-23 22:52:29]DEBUG : {"00212EFFFF05AB6C":{"e":"changed","id":"21","r":"lights","state":{"alert":"none","on":false,"reachable":true},"t":"event","uniqueid":"84:fd:27:ff:fe:c2:28:fb-01"}}
0008|[2023-03-23 22:52:30]DEBUG : {"00212EFFFF05AB6C":{"attr":{"id":"14","lastannounced":"2023-03-23T21:51:46Z","lastseen":"2023-03-23T21:52Z","manufacturername":"ORVIBO","modelid":"CM10ZW","name":"Door Lock Unit 14","swversion":"v3.1.06","type":"Door Lock Unit","uniqueid":"00:12:4b:00:22:ce:2d:55-02"},"e":"changed","id":"14","r":"lights","t":"event","uniqueid":"00:12:4b:00:22:ce:2d:55-02"}}
0009|[2023-03-23 22:52:31]DEBUG : {"00212EFFFF05AB6C":{"attr":{"id":"13","lastannounced":"2023-03-23T21:51:46Z","lastseen":"2023-03-23T21:52Z","manufacturername":"ORVIBO","modelid":"CM10ZW","name":"Door Lock Unit 13","swversion":"v3.1.06","type":"Door Lock Unit","uniqueid":"00:12:4b:00:22:ce:2d:55-03"},"e":"changed","id":"13","r":"lights","t":"event","uniqueid":"00:12:4b:00:22:ce:2d:55-03"}}
0010|[2023-03-23 22:52:32]DEBUG : {"00212EFFFF05AB6C":{"attr":{"id":"80","lastannounced":null,"lastseen":"2023-03-23T21:52Z","manufacturername":"_TZ3000_2putqrmw","modelid":"TS011F","name":"Power 80","swversion":"1.0.13","type":"ZHAPower","uniqueid":"a4:c1:38:15:50:01:bf:72-01-0b04"},"e":"changed","id":"80","r":"sensors","t":"event","uniqueid":"a4:c1:38:15:50:01:bf:72-01-0b04"}}
0011|[2023-03-23 22:52:32]DEBUG : {"00212EFFFF05AB6C":{"e":"changed","id":"80","r":"sensors","state":{"current":0,"lastupdated":"2023-03-23T21:52:32.946","power":0,"voltage":228},"t":"event","uniqueid":"a4:c1:38:15:50:01:bf:72-01-0b04"}}
0012|[2023-03-23 22:52:32]DEBUG : {"00212EFFFF05AB6C":{"attr":{"id":"79","lastannounced":null,"lastseen":"2023-03-23T21:52Z","manufacturername":"_TZ3000_2putqrmw","modelid":"TS011F","name":"Consumption 79","swversion":"1.0.13","type":"ZHAConsumption","uniqueid":"a4:c1:38:15:50:01:bf:72-01-0702"},"e":"changed","id":"79","r":"sensors","t":"event","uniqueid":"a4:c1:38:15:50:01:bf:72-01-0702"}}
0013|[2023-03-23 22:52:33]DEBUG : {"00212EFFFF05AB6C":{"e":"changed","id":"80","r":"sensors","state":{"current":0,"lastupdated":"2023-03-23T21:52:32.955","power":0,"voltage":228},"t":"event","uniqueid":"a4:c1:38:15:50:01:bf:72-01-0b04"}}
0014|[2023-03-23 22:52:42]DEBUG : {"00212EFFFF05AB6C":{"attr":{"id":"67","lastannounced":"2022-12-06T19:02:11Z","lastseen":"2023-03-23T21:52Z","manufacturername":"ADEO","modelid":"LDSENK02F","name":"Power 67","swversion":"2.6","type":"ZHAPower","uniqueid":"80:4b:50:ff:fe:e2:92:cd-01-0b04"},"e":"changed","id":"67","r":"sensors","t":"event","uniqueid":"80:4b:50:ff:fe:e2:92:cd-01-0b04"}}
0015|[2023-03-23 22:52:42]DEBUG : {"00212EFFFF05AB6C":{"attr":{"id":"68","lastannounced":"2022-12-06T19:02:11Z","lastseen":"2023-03-23T21:52Z","manufacturername":"ADEO","modelid":"LDSENK02F","name":"Consumption 68","swversion":"2.6","type":"ZHAConsumption","uniqueid":"80:4b:50:ff:fe:e2:92:cd-01-0702"},"e":"changed","id":"68","r":"sensors","t":"event","uniqueid":"80:4b:50:ff:fe:e2:92:cd-01-0702"}}
0016|[2023-03-23 22:52:42]DEBUG : {"00212EFFFF05AB6C":{"e":"changed","id":"68","r":"sensors","state":{"consumption":6318,"lastupdated":"2023-03-23T21:52:42.556","power":0},"t":"event","uniqueid":"80:4b:50:ff:fe:e2:92:cd-01-0702"}}
0017|[2023-03-23 22:52:48]DEBUG : {"00212EFFFF05AB6C":{"attr":{"id":"8","lastannounced":"2023-03-20T17:52:18Z","lastseen":"2023-03-23T21:52Z","manufacturername":"LUMI","modelid":"lumi.plug.maeu01","name":"Smart plug 8","swversion":"09-10-2019","type":"Smart plug","uniqueid":"04:cf:8c:df:3c:89:d2:32-01"},"e":"changed","id":"8","r":"lights","t":"event","uniqueid":"04:cf:8c:df:3c:89:d2:32-01"}}
0018|[2023-03-23 22:52:52]DEBUG : {"00212EFFFF05AB6C":{"attr":{"id":"19","lastannounced":"2023-03-23T21:52:52Z","lastseen":"2023-03-23T21:51Z","manufacturername":"ORVIBO","modelid":"CM10ZW","name":"Door Lock Unit 19","swversion":"v3.1.06","type":"Door Lock Unit","uniqueid":"00:12:4b:00:22:ce:33:0c-01"},"e":"changed","id":"19","r":"lights","t":"event","uniqueid":"00:12:4b:00:22:ce:33:0c-01"}}
0019|[2023-03-23 22:52:52]DEBUG : {"00212EFFFF05AB6C":{"attr":{"id":"18","lastannounced":"2023-03-23T21:52:52Z","lastseen":"2023-03-23T21:51Z","manufacturername":"ORVIBO","modelid":"CM10ZW","name":"Door Lock Unit 18","swversion":"v3.1.06","type":"Door Lock Unit","uniqueid":"00:12:4b:00:22:ce:33:0c-02"},"e":"changed","id":"18","r":"lights","t":"event","uniqueid":"00:12:4b:00:22:ce:33:0c-02"}}
0020|[2023-03-23 22:52:52]DEBUG : {"00212EFFFF05AB6C":{"attr":{"id":"17","lastannounced":"2023-03-23T21:52:52Z","lastseen":"2023-03-23T21:51Z","manufacturername":"ORVIBO","modelid
Auncun scenario lié ou action venant d’ailleurs possible…
