Les équipements ne se remontent pas dans l'interface, erreur websocket 1002 : plugin inutilisable
Sur jeedom 4.0.56 (raspberry pi 2 sous stretch), je ne parviens pas à faire remonter les équipements. J’ai une erreur websocket en boucle :
05/29/2020 09:30:17 - Hello DeltaDore! <3
05/29/2020 09:30:17 - Unix 4.19.66.7
05/29/2020 09:30:17 - pid: 15390
05/29/2020 09:30:17 - pidFilename: /tmp/nextdom/jeedore/jeedoredaemon.pid
05/29/2020 09:30:17 - Starting with 15390
05/29/2020 09:30:20 - Jeedore Daemon is starting in local network mode...
05/29/2020 09:30:20 - Websocket connection initialization....
05/29/2020 09:30:20 - Connecting to '192.168.1.46'
05/29/2020 09:30:25 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
05/29/2020 09:30:25 - Jeedore Daemon connection has been closed...
05/29/2020 09:30:25 - Connection to DeltaDore server has been closed...
05/29/2020 09:30:25 - Server started. Listening to TCP clients at 127.0.0.1:13666
05/29/2020 09:30:25 - Starting timer Info
05/29/2020 09:30:55 - Websocket connection initialization....
05/29/2020 09:30:55 - Connecting to '192.168.1.46'
05/29/2020 09:30:57 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
05/29/2020 09:30:57 - Jeedore Daemon connection has been closed...
05/29/2020 09:30:57 - Connection to DeltaDore server has been closed...
05/29/2020 09:31:25 - Websocket connection initialization....
05/29/2020 09:31:25 - Connecting to '192.168.1.46'
05/29/2020 09:31:27 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
05/29/2020 09:31:27 - Jeedore Daemon connection has been closed...
05/29/2020 09:31:27 - Connection to DeltaDore server has been closed...
05/29/2020 09:31:55 - Websocket connection initialization....
05/29/2020 09:31:55 - Connecting to '192.168.1.46'
05/29/2020 09:31:57 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
05/29/2020 09:31:57 - Jeedore Daemon connection has been closed...
05/29/2020 09:31:57 - Connection to DeltaDore server has been closed...
05/29/2020 09:32:25 - Websocket connection initialization....
05/29/2020 09:32:25 - Connecting to '192.168.1.46'
05/29/2020 09:32:27 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
05/29/2020 09:32:27 - Jeedore Daemon connection has been closed...
05/29/2020 09:32:27 - Connection to DeltaDore server has been closed...
05/29/2020 09:32:55 - Websocket connection initialization....
05/29/2020 09:32:55 - Connecting to '192.168.1.46'
05/29/2020 09:32:57 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
05/29/2020 09:32:57 - Jeedore Daemon connection has been closed...
05/29/2020 09:32:57 - Connection to DeltaDore server has been closed...
05/29/2020 09:33:25 - Websocket connection initialization....
05/29/2020 09:33:25 - Connecting to '192.168.1.46'
05/29/2020 09:33:27 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
05/29/2020 09:33:27 - Jeedore Daemon connection has been closed...
05/29/2020 09:33:27 - Connection to DeltaDore server has been closed...
05/29/2020 09:33:55 - Websocket connection initialization....
05/29/2020 09:33:55 - Connecting to '192.168.1.46'
05/29/2020 09:33:57 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
05/29/2020 09:33:57 - Jeedore Daemon connection has been closed...
05/29/2020 09:33:57 - Connection to DeltaDore server has been closed...
05/29/2020 09:34:25 - Websocket connection initialization....
05/29/2020 09:34:25 - Connecting to '192.168.1.46'
05/29/2020 09:34:27 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
05/29/2020 09:34:27 - Jeedore Daemon connection has been closed...
05/29/2020 09:34:27 - Connection to DeltaDore server has been closed...
05/29/2020 09:34:55 - Websocket connection initialization....
05/29/2020 09:34:55 - Connecting to '192.168.1.46'
05/29/2020 09:34:57 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
05/29/2020 09:34:57 - Jeedore Daemon connection has been closed...
05/29/2020 09:34:57 - Connection to DeltaDore server has been closed...
05/29/2020 09:35:25 - Websocket connection initialization....
05/29/2020 09:35:25 - Connecting to '192.168.1.46'
05/29/2020 09:35:28 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
05/29/2020 09:35:28 - Jeedore Daemon connection has been closed...
05/29/2020 09:35:28 - Connection to DeltaDore server has been closed...
05/29/2020 09:35:55 - Websocket connection initialization....
05/29/2020 09:35:55 - Connecting to '192.168.1.46'
05/29/2020 09:35:57 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
05/29/2020 09:35:57 - Jeedore Daemon connection has been closed...
05/29/2020 09:35:57 - Connection to DeltaDore server has been closed...
05/29/2020 09:36:25 - Websocket connection initialization....
05/29/2020 09:36:25 - Connecting to '192.168.1.46'
05/29/2020 09:36:27 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
05/29/2020 09:36:27 - Jeedore Daemon connection has been closed...
05/29/2020 09:36:27 - Connection to DeltaDore server has been closed...
05/29/2020 09:36:55 - Websocket connection initialization....
05/29/2020 09:36:55 - Connecting to '192.168.1.46'
05/29/2020 09:36:57 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
05/29/2020 09:36:57 - Jeedore Daemon connection has been closed...
05/29/2020 09:36:57 - Connection to DeltaDore server has been closed...
05/29/2020 09:37:25 - Websocket connection initialization....
05/29/2020 09:37:25 - Connecting to '192.168.1.46'
05/29/2020 09:37:27 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
05/29/2020 09:37:27 - Jeedore Daemon connection has been closed...
05/29/2020 09:37:27 - Connection to DeltaDore server has been closed...
05/29/2020 09:37:55 - Websocket connection initialization....
05/29/2020 09:37:55 - Connecting to '192.168.1.46'
05/29/2020 09:37:57 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
05/29/2020 09:37:57 - Jeedore Daemon connection has been closed...
05/29/2020 09:37:57 - Connection to DeltaDore server has been closed...
05/29/2020 09:38:25 - Websocket connection initialization....
05/29/2020 09:38:25 - Connecting to '192.168.1.46'
05/29/2020 09:38:27 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
05/29/2020 09:38:27 - Jeedore Daemon connection has been closed...
05/29/2020 09:38:27 - Connection to DeltaDore server has been closed...
05/29/2020 09:38:55 - Websocket connection initialization....
05/29/2020 09:38:55 - Connecting to '192.168.1.46'
05/29/2020 09:38:57 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
05/29/2020 09:38:57 - Jeedore Daemon connection has been closed...
05/29/2020 09:38:57 - Connection to DeltaDore server has been closed...
05/29/2020 09:39:25 - Websocket connection initialization....
05/29/2020 09:39:25 - Connecting to '192.168.1.46'
05/29/2020 09:39:27 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
05/29/2020 09:39:27 - Jeedore Daemon connection has been closed...
05/29/2020 09:39:27 - Connection to DeltaDore server has been closed...
05/29/2020 09:39:55 - Websocket connection initialization....
05/29/2020 09:39:55 - Connecting to '192.168.1.46'
05/29/2020 09:39:57 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
05/29/2020 09:39:57 - Jeedore Daemon connection has been closed...
05/29/2020 09:39:57 - Connection to DeltaDore server has been closed...
05/29/2020 09:40:25 - Websocket connection initialization....
05/29/2020 09:40:25 - Connecting to '192.168.1.46'
05/29/2020 09:40:28 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
05/29/2020 09:40:28 - Jeedore Daemon connection has been closed...
05/29/2020 09:40:28 - Connection to DeltaDore server has been closed...
05/29/2020 09:40:31 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
05/29/2020 09:40:31 - Jeedore Daemon connection has been closed...
05/29/2020 09:40:31 - Connection to DeltaDore server has been closed...
05/29/2020 09:40:55 - Websocket connection initialization....
05/29/2020 09:40:55 - Connecting to '192.168.1.46'
05/29/2020 09:40:57 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
05/29/2020 09:40:57 - Jeedore Daemon connection has been closed...
05/29/2020 09:40:57 - Connection to DeltaDore server has been closed...
05/29/2020 09:41:25 - Websocket connection initialization....
05/29/2020 09:41:25 - Connecting to '192.168.1.46'
05/29/2020 09:41:27 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
05/29/2020 09:41:27 - Jeedore Daemon connection has been closed...
05/29/2020 09:41:27 - Connection to DeltaDore server has been closed...
05/29/2020 09:41:55 - Websocket connection initialization....
05/29/2020 09:41:55 - Connecting to '192.168.1.46'
05/29/2020 09:41:57 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
05/29/2020 09:41:57 - Jeedore Daemon connection has been closed...
05/29/2020 09:41:57 - Connection to DeltaDore server has been closed...
05/29/2020 09:42:25 - Websocket connection initialization....
05/29/2020 09:42:25 - Connecting to '192.168.1.46'
05/29/2020 09:42:27 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
05/29/2020 09:42:27 - Jeedore Daemon connection has been closed...
05/29/2020 09:42:27 - Connection to DeltaDore server has been closed...
05/29/2020 09:42:55 - Websocket connection initialization....
05/29/2020 09:42:55 - Connecting to '192.168.1.46'
05/29/2020 09:42:57 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
05/29/2020 09:42:57 - Jeedore Daemon connection has been closed...
05/29/2020 09:42:57 - Connection to DeltaDore server has been closed...
05/29/2020 09:43:25 - Websocket connection initialization....
05/29/2020 09:43:25 - Connecting to '192.168.1.46'
05/29/2020 09:43:27 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
05/29/2020 09:43:27 - Jeedore Daemon connection has been closed...
05/29/2020 09:43:27 - Connection to DeltaDore server has been closed...
05/29/2020 09:43:55 - Websocket connection initialization....
05/29/2020 09:43:55 - Connecting to '192.168.1.46'
05/29/2020 09:43:57 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
05/29/2020 09:43:57 - Jeedore Daemon connection has been closed...
05/29/2020 09:43:57 - Connection to DeltaDore server has been closed...
05/29/2020 09:44:25 - Websocket connection initialization....
05/29/2020 09:44:25 - Connecting to '192.168.1.46'
05/29/2020 09:44:27 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
05/29/2020 09:44:27 - Jeedore Daemon connection has been closed...
05/29/2020 09:44:27 - Connection to DeltaDore server has been closed...
05/29/2020 09:44:55 - Websocket connection initialization....
Les logs Tydom remontent bien mais avec des tokens non remplacés :
Intrusion détectée dans la zone #zones# par l'équipement #product#.
J’ai acheté le plugin hier, mais impossible d’obtenir un fonctionnement, c’est tout de même gênant… Le développeur ne répond pas à mon email jusque-là, je suppose que cette période est compliquée pour tout le monde, donc je me tourne vers la communauté.
S’il vous plait Communauté, vous êtes mon seul espoir !
Je viens d’avoir le même problème, impossible de relancer le plugin…
EDIT:
C’est relancé de mon coté, j’ai l’impression qu’il faut attendre (+ des 45secondes) avant de relancer le daemon après avoir réinstaller les dépendances.
Attends 5 min et redémarre le daemon
j’allais le dire : relancer les dépendances
Si ca peut aider a comprendre …
https://translate.googleusercontent.com/translate_c?depth=1&hl=fr&prev=search&rurl=translate.google.com&sl=en&sp=nmt4&u=https://stackoverflow.com/questions/22587438/websocket-close-code-1002&usg=ALkJrhj8FSeE5Zpjj54JwxF9EsmbPmg-rg
J’ai relancé les dépendances déjà deux fois, elles sont installées statut OK. Je peux essayer de relancer encore le démon, m’enfin j’avoue que je suis sceptique.
Bon, sans grande surprise ça ne change rien de relancer le daemon.
05/29/2020 20:13:02 - Hello DeltaDore! <3
05/29/2020 20:13:03 - Unix 4.19.66.7
05/29/2020 20:13:03 - pid: 17561
05/29/2020 20:13:03 - pidFilename: /tmp/nextdom/jeedore/jeedoredaemon.pid
05/29/2020 20:13:03 - Starting with 17561
05/29/2020 20:13:05 - Jeedore Daemon is starting in local network mode...
05/29/2020 20:13:05 - Websocket connection initialization....
05/29/2020 20:13:05 - Connecting to '192.168.1.46'
05/29/2020 20:13:10 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
05/29/2020 20:13:10 - Jeedore Daemon connection has been closed...
05/29/2020 20:13:10 - Connection to DeltaDore server has been closed...
05/29/2020 20:13:10 - Server started. Listening to TCP clients at 127.0.0.1:13666
05/29/2020 20:13:10 - Starting timer Info
05/29/2020 20:13:40 - Websocket connection initialization....
05/29/2020 20:13:40 - Connecting to '192.168.1.46'
05/29/2020 20:13:42 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
05/29/2020 20:13:42 - Jeedore Daemon connection has been closed...
05/29/2020 20:13:42 - Connection to DeltaDore server has been closed...
05/29/2020 20:14:10 - Websocket connection initialization....
05/29/2020 20:14:10 - Connecting to '192.168.1.46'
05/29/2020 20:14:12 - Websocket connection has been closed with code:1002 reason:'An error has occurred while connecting.'
05/29/2020 20:14:12 - Jeedore Daemon connection has been closed...
05/29/2020 20:14:12 - Connection to DeltaDore server has been closed...
A priori tu n’as pas attendu après avoir réinstallé les dépendances, attends au moins 5min (voir 10).
désactive le démarrage auto du deamon, et lance le bien 5 min après avoir installé les dépendances.
Bonsoir, merci pour vos réponses.
J’ai réessayé ce matin. J’ai lancé le démon manuellement plus d’un quart d’heure après la fin de l’installation des dépendances (on est d’accord, fin d’installation des dépendances, je considère que c’est lorsque c’est écrit dépendances OK dans la configuration du plugin). Ça n’a strictement rien changé.
De plus, je ne comprends pas le point d’indiquer à l’utilisateur que l’installation des dépendances est OK s’il faut attendre 5 min pour pouvoir lancer le démon. Ce n’est indiqué nulle part dans la documentation. D’ailleurs sur quoi se base cette appréciation des 5 minutes ? Sur une vitesse de téléchargement ? Sur la performance du processeur ? Parce qu’entre un raspberry pi ou une VM sur pc, c’est pas la même :wink:. Je suis sur rpi 2.
Effectivement c’est ce que j’ai rémarqué de mon coté, Jeedom est sur un Z83, donc un peu plus puissant qu’un pi2.
là faut voir ca avec @Eli.
Bon courage!
J’essaie de le solliciter depuis plusieurs jours, sans réponse jusqu’à présent. je commence à me poser des questions sur la maintenance du plugin, au pire des cas comment on demande t-on un remboursement sur le market jeedom ?
@Eli toujours aucune réponse, j’espère qu’il te sera possible de m’aider dans un futur proche ?
Je me replonge dans le code en ce moment… J’étais en train de changer la methode de cron qui sollicite trop la tydom.
Perso je fais mes tests sur un docker windows et un rpi4 avec la fibre, donc pour les tests avec les petites machines c’est un peu compliqué pour moi de tester.
L’installation des dependances, c’est le download d’un zip de 200mo env. et juste un unzip rien de foufou. Je n’ai jamais eu de retour de problème de lenteur particulier.
Je ne vois pas prquoi tu as du attendre 5min ??? etrange!
Oui on peut proceder a un remboursement si tu le souhaites, je vais t’aider mais je ressors la tete de l’eau lentement…
Eli
Merci pour ton retour @Eli, j’étais inquiet de ne pas avoir de retour ; ma priorité avant de parler remboursement reste de réussir à faire marcher ton plugin ! Si tu penses qu’avec Buster au lieu de stretch ça peut résoudre le souci, je peux tester une install, simplement je dois m’assurer que tout le reste (z-wave, autres plugins) sont bien fonctionnels.
Alors pour info, je viens de me monter un jeedom sous docker (synology). Architecture x86, debian buster, je ne suis plus sous les mêmes contraintes qu’avec le raspberry pi 2B, et donc avec le système recommandé (buster, debian 10).
Et bien figurez-vous que je rencontre exactement le même problème. Toujours cette erreur 1002.
A côté de cela, j’ai remarqué que la websocket s’ouvre sur le port 13666. Est-ce imposé par la tydom (j’ai la tydom 1.0) ? ne faut-il pas ouvrir le pare-feu sur ce port ? @Eli, y a t-il un truc à faire sur ma box tydom 1.0 ?
J’ai aussi vu sur ce post que le fait de changer le mot de passe pouvait influer apparemment, @Eli y a t-il des caractères spéciaux qui pourraient casser la connexion ? En effet mon mot de passe en contient.
Bon, je suis parvenu à faire marcher le plugin, il semble que le mélange de caractères spéciaux, majuscules et minuscules et chiffres aient perturbé le plugin. je n’ai plus l’erreur de websocket.
En revanche, l’état de l’alarme ne remonte pas bien. Dommage, c’était pour cela que j’ai acheté le plugin (é_è)
