Fabrice,
lorsque j’ai monté la nouvelle VM, à la première installation des dépendances j’ai eu ces logs :
* Installation des dépendances *
Hit:1 http://security.debian.org/debian-security buster/updates InRelease
Hit:2 http://ftp.fr.debian.org/debian buster InRelease
Hit:3 http://ftp.fr.debian.org/debian buster-updates InRelease
Reading package lists...
Building dependency tree...
Reading state information...
lsb-release is already the newest version (10.2019051400).
0 upgraded, 0 newly installed, 0 to remove and 2 not upgraded.
Nodejs non installé
KO, version obsolète à upgrader
Suppression du Nodejs existant et installation du paquet recommandé
Package 'nodejs' is not installed, so not removed
Package 'npm' is not installed, so not removed
/var/www/html/plugins/ikealight/core/class/../../resources/install_apt.sh: line 31: $LOG: ambiguous redirect
Utilisation du dépot officiel
## Installing the NodeSource Node.js 12.x repo...
## Populating apt-get cache...
+ apt-get update
Hit:1 http://ftp.fr.debian.org/debian buster InRelease
Hit:2 http://ftp.fr.debian.org/debian buster-updates InRelease
Hit:3 http://security.debian.org/debian-security buster/updates InRelease
## Confirming "buster" is supported...
+ curl -sLf -o /dev/null 'https://deb.nodesource.com/node_12.x/dists/buster/Release'
## Adding the NodeSource signing key to your keyring...
+ curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | gpg --dearmor | tee /usr/share/keyrings/nodesource.gpg >/dev/null
## Creating apt sources list file for the NodeSource Node.js 12.x repo...
+ echo 'deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_12.x buster main' > /etc/apt/sources.list.d/nodesource.list
+ echo 'deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_12.x buster main' >> /etc/apt/sources.list.d/nodesource.list
## Running `apt-get update` for you...
+ apt-get update
Get:4 https://deb.nodesource.com/node_12.x buster InRelease [4584 B]
Get:5 https://deb.nodesource.com/node_12.x buster/main amd64 Packages [767 B]
Fetched 5351 B in 2s (2169 B/s)
## Run `sudo apt-get install -y nodejs` to install Node.js 12.x and npm
## You may also need development tools to build native addons:
sudo apt-get install gcc g++ make
## To install the Yarn package manager, run:
curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | gpg --dearmor | sudo tee /usr/share/keyrings/yarnkey.gpg >/dev/null
echo "deb [signed-by=/usr/share/keyrings/yarnkey.gpg] https://dl.yarnpkg.com/debian stable main" | sudo tee /etc/apt/sources.list.d/yarn.list
sudo apt-get update && sudo apt-get install yarn
nodejs
0 upgraded, 1 newly installed, 0 to remove and 2 not upgraded.
Need to get 18.2 MB of archives.
After this operation, 93.6 MB of additional disk space will be used.
Get:1 https://deb.nodesource.com/node_12.x buster/main amd64 nodejs amd64 12.22.0-1nodesource1 [18.2 MB]
debconf: unable to initialize frontend: Dialog
debconf: (Dialog frontend will not work on a dumb terminal, an emacs shell buffer, or without a controlling terminal.)
debconf: falling back to frontend: Readline
debconf: unable to initialize frontend: Readline
debconf: (This frontend requires a controlling tty.)
debconf: falling back to frontend: Teletype
dpkg-preconfigure: unable to re-open stdin:
Fetched 18.2 MB in 5s (3531 kB/s)
Selecting previously unselected package nodejs.
(Reading database ...
(Reading database ... 5%
(Reading database ... 10%
(Reading database ... 15%
(Reading database ... 20%
(Reading database ... 25%
(Reading database ... 30%
(Reading database ... 35%
(Reading database ... 40%
(Reading database ... 45%
(Reading database ... 50%
(Reading database ... 55%
(Reading database ... 60%
(Reading database ... 65%
(Reading database ... 70%
(Reading database ... 75%
(Reading database ... 80%
(Reading database ... 85%
(Reading database ... 90%
(Reading database ... 95%
(Reading database ... 100%
(Reading database ... 59813 files and directories currently installed.)
Preparing to unpack .../nodejs_12.22.0-1nodesource1_amd64.deb ...
Unpacking nodejs (12.22.0-1nodesource1) ...
Setting up nodejs (12.22.0-1nodesource1) ...
Processing triggers for man-db (2.8.5-2) ...
Version actuelle : v12.22.0
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
npm : Depends: nodejs (>= 6.11~) but it is not going to be installed
Depends: node-abbrev (>= 1.1.1~) but it is not going to be installed
Depends: node-ansi-regex (>= 3.0~) but it is not going to be installed
Depends: node-ansistyles (>= 0.1.3~) but it is not going to be installed
Depends: node-aproba (>= 1.2~) but it is not going to be installed
Depends: node-archy (>= 1.0~) but it is not going to be installed
Depends: node-cacache (>= 10.0.4~) but it is not going to be installed
Depends: node-bluebird (>= 3.5.1~) but it is not going to be installed
Depends: node-call-limit (>= 1.1~) but it is not going to be installed
Depends: node-chownr (>= 1.0.1~) but it is not going to be installed
Depends: node-config-chain (>= 1.1.11~) but it is not going to be installed
Depends: node-detect-indent (>= 5.0~) but it is not going to be installed
Depends: node-detect-newline (>= 2.1~) but it is not going to be installed
Depends: node-editor (>= 1.0~) but it is not going to be installed
Depends: node-fs-vacuum (>= 1.2.10~) but it is not going to be installed
Depends: node-fs-write-stream-atomic (>= 1.0.10~) but it is not going to be installed
Depends: node-glob (>= 7.1.2~) but it is not going to be installed
Depends: node-graceful-fs (>= 4.1.11~) but it is not going to be installed
Depends: node-has-unicode (>= 2.0.1~) but it is not going to be installed
Depends: node-hosted-git-info (>= 2.6~) but it is not going to be installed
Depends: node-iferr (>= 0.1.5~) but it is not going to be installed
Depends: node-inflight (>= 1.0.6~) but it is not going to be installed
Depends: node-inherits (>= 2.0.3~) but it is not going to be installed
Depends: node-ini (>= 1.3.5~) but it is not going to be installed
Depends: node-npm-package-arg but it is not going to be installed
Depends: node-promzard but it is not going to be installed
Depends: node-jsonstream (>= 1.3.2~) but it is not going to be installed
Depends: node-json-parse-better-errors (>= 1.0.1~) but it is not going to be installed
Depends: node-lazy-property (>= 1.0~) but it is not going to be installed
Depends: node-libnpx (>= 10.0.1~) but it is not going to be installed
Depends: node-lockfile (>= 1.0.3~) but it is not going to be installed
Depends: node-lru-cache (>= 4.1.1~) but it is not going to be installed
Depends: node-mississippi (>= 3.0~) but it is not going to be installed
Depends: node-mkdirp (>= 0.3.3) but it is not going to be installed
Depends: node-move-concurrently (>= 1.0.1~) but it is not going to be installed
Depends: node-nopt but it is not going to be installed
Depends: node-normalize-package-data (>= 2.4~) but it is not going to be installed
Depends: node-gyp (>= 3.6.2~) but it is not going to be installed
Depends: node-resolve-from (>= 4.0~) but it is not going to be installed
Depends: node-encoding but it is not going to be installed
Depends: node-errno but it is not going to be installed
Depends: node-npmlog (>= 4.1.2~) but it is not going to be installed
Depends: node-once (>= 1.4~) but it is not going to be installed
Depends: node-opener (>= 1.4.3~) but it is not going to be installed
Depends: node-osenv (>= 0.1.5~) but it is not going to be installed
Depends: node-path-is-inside (>= 1.0.2~) but it is not going to be installed
Depends: node-promise-inflight (>= 1.0.1~) but it is not going to be installed
Depends: node-ansi but it is not going to be installed
Depends: node-qw (>= 1.0.1~) but it is not going to be installed
Depends: node-read (>= 1.0.7~) but it is not going to be installed
Depends: node-read-package-json (>= 2.0.13~) but it is not going to be installed
Depends: node-request (>= 2.83~) but it is not going to be installed
Depends: node-retry (>= 0.10.1~) but it is not going to be installed
Depends: node-rimraf (>= 2.6.2~) but it is not going to be installed
Depends: node-safe-buffer (>= 5.1.1~) but it is not going to be installed
Depends: node-semver (>= 5.5~) but it is not going to be installed
Depends: node-sha (>= 2.0.1~) but it is not going to be installed
Depends: node-slide (>= 1.1.6~) but it is not going to be installed
Depends: node-sorted-object (>= 2.0.1~) but it is not going to be installed
Depends: node-from2 but it is not going to be installed
Depends: node-stream-iterate but it is not going to be installed
Depends: node-ssri (>= 5.2.4~) but it is not going to be installed
Depends: node-strip-ansi (>= 4.0~) but it is not going to be installed
Depends: node-tar (>= 4.4~) but it is not going to be installed
Depends: node-text-table (>= 0.2~) but it is not going to be installed
Depends: node-uid-number (>= 0.0.6~) but it is not going to be installed
Depends: node-unique-filename (>= 1.1~) but it is not going to be installed
Depends: node-unpipe (>= 1.0~) but it is not going to be installed
Depends: node-boxen (>= 1.2.1~) but it is not going to be installed
Depends: node-import-lazy but it is not going to be installed
Depends: node-is-npm (>= 1.0~) but it is not going to be installed
Depends: node-latest-version (>= 3.0~) but it is not going to be installed
Depends: node-semver-diff (>= 2.0~) but it is not going to be installed
Depends: node-xdg-basedir (>= 3.0~) but it is not going to be installed
Depends: node-validate-npm-package-name (>= 3.0~) but it is not going to be installed
Depends: node-which (>= 1.3~) but it is not going to be installed
Depends: node-wrappy (>= 1.0.2~) but it is not going to be installed
Depends: node-write-file-atomic (>= 2.3~) but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
> node-aead-crypto@2.2.0 preinstall /var/www/html/plugins/ikealight/resources/ikealightd/node_modules/node-aead-crypto
> node lib/preinstall.js
node-aead-crypto not needed on this system, since all ciphers are natively supported
npm WARN saveError ENOENT: no such file or directory, open '/var/www/html/plugins/ikealight/resources/ikealightd/package.json'
npm WARN notsup Unsupported engine for node-aead-crypto@2.2.0: wanted: {"node":">4 <10"} (current: {"node":"12.22.0","npm":"6.14.11"})
npm WARN notsup Not compatible with your version of node/npm: node-aead-crypto@2.2.0
npm WARN enoent ENOENT: no such file or directory, open '/var/www/html/plugins/ikealight/resources/ikealightd/package.json'
npm WARN ikealightd No description
npm WARN ikealightd No repository field.
npm WARN ikealightd No README data
npm WARN ikealightd No license field.
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: node-aead-crypto@2.2.0 (node_modules/node-aead-crypto):
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: node-aead-crypto@2.2.0 preinstall: `node lib/preinstall.js`
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
+ node-tradfri-client@2.2.0
added 14 packages from 16 contributors and audited 78 packages in 136.07s
6 packages are looking for funding
run `npm fund` for details
found 0 vulnerabilities
+ fs@0.0.1-security
added 1 package and audited 87 packages in 14.944s
npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
npm WARN deprecated har-validator@5.1.5: this library is no longer supported
+ request@2.88.2
added 46 packages from 57 contributors and audited 131 packages in 42.317s
7 packages are looking for funding
+ express@4.17.1
added 55 packages from 35 contributors and audited 204 packages in 114.903s
* Installation terminée *
Ensuite, lorsque j’ai rebooté et que le daemon est tombé, j’ai relancé l’installation des dépendances et j’ai obtenu cela :
Get:2 http://ftp.fr.debian.org/debian buster-updates InRelease [51.9 kB]
Hit:3 https://deb.nodesource.com/node_14.x buster InRelease
Hit:4 http://security.debian.org/debian-security buster/updates InRelease
Fetched 51.9 kB in 2s (29.2 kB/s)
Version actuelle : 14
Ok, version suffisante
npm WARN notsup Unsupported engine for node-aead-crypto@2.2.0: wanted: {"node":">4 <10"} (current: {"node":"14.16.0","npm":"6.14.11"})
added 14 packages from 16 contributors and audited 78 packages in 17.888s
+ fs@0.0.1-security
added 1 package and audited 87 packages in 6.607s
+ request@2.88.2
added 46 packages from 57 contributors and audited 131 packages in 11.359s
+ express@4.17.1
added 55 packages from 35 contributors and audited 204 packages in 13.426s
J’ai l’impression que les sources d’installation du plugin sont comme obsolètes.
Je n’arrive pas à comprendre d’où cela peut venir.
