J’ai une serie de lampes GL-B-008Z (lampes exterieures) qui ne sont pas dans le plugin Zigbee. J’utilise a la place la GL-G-001ZS. Les commandes marchent par contre le retour d’etat ne marche pas (toujours sur 1).
Est ce qu’il serait possible de rajouter cette lampe dans le plugin?
PS : Le fait que la commande on/off soit sur 1 ci dessous alors que la lampe etait eteinte quand j’ai pris les datas me fait dire que le probleme est ailleurs, mais on ne sait jamais.
Pour l’image, meme que la GL-G-001ZS
Merci d’avance
"ieee": "00:12:4b:00:21:0f:7c:f1",
"nwk": 18767,
"status": 2,
"lqi": "None",
"rssi": "None",
"last_seen": "None",
"node_descriptor": "01:40:8e:00:00:50:a0:00:00:00:a0:00:00",
"endpoints": [
"id": 11,
"status": 1,
"device_type": 528,
"profile_id": 49246,
"manufacturer": "GLEDOPTO",
"model": "GL-B-008Z",
"output_clusters": [],
"input_clusters": [
"id": 0,
"name": "Basic",
"attributes": [
"id": 0,
"name": "zcl_version",
"value": 1
"id": 1,
"name": "app_version",
"value": 1
"id": 2,
"name": "stack_version",
"value": 2
"id": 3,
"name": "hw_version",
"value": 1
"id": 4,
"name": "manufacturer",
"value": "GLEDOPTO"
"id": 5,
"name": "model",
"value": "GL-B-008Z"
"id": 6,
"name": "date_code",
"value": "20131206"
"id": 7,
"name": "power_source",
"value": 1
"id": 16384,
"name": "sw_build_id",
"value": "3.0.0"
"id": 3,
"name": "Identify",
"attributes": []
"id": 4,
"name": "Groups",
"attributes": []
"id": 5,
"name": "Scenes",
"attributes": []
"id": 6,
"name": "On\/Off",
"attributes": [
"id": 0,
"name": "on_off",
"value": 1
"id": 8,
"name": "Level control",
"attributes": [
"id": 0,
"name": "current_level",
"value": 254
"id": 768,
"name": "Color Control",
"attributes": [
"id": 3,
"name": "current_x",
"value": 12480
"id": 4,
"name": "current_y",
"value": 47190
"id": 7,
"name": "color_temperature",
"value": 455
"signature": {
"node_desc": {
"logical_type": 1,
"reserved": 0,
"aps_flags": 0,
"frequency_band": 8,
"mac_capability_flags": 142,
"manufacturer_code": 0,
"maximum_buffer_size": 80,
"maximum_incoming_transfer_size": 160,
"server_mask": 0,
"maximum_outgoing_transfer_size": 160,
"endpoints": {
"11": {
"device_type": 528,
"input_clusters": [
0,
3,
4,
5,
6,
8,
768
"class": "zhaquirks.gledopto.soposhgu10"
