A la demande d’Olive Ancien sujet, j’ouvre donc un sujet sur le support de ces lampes.
Voici le contenu des infos brutes
"ieee": "00:12:4b:00:21:0f:75:98",
"nwk": 18422,
"status": 2,
"lqi": "92",
"rssi": "-77",
"last_seen": "1638021326.055491",
"node_descriptor": "01:40:8e:00:00:50:a0:00:00:00:a0:00:00",
"endpoints": [
"id": 11,
"status": 1,
"device_type": 528,
"profile_id": 49246,
"manufacturer": "GLEDOPTO",
"model": "GL-B-008Z",
"output_clusters": [],
"input_clusters": [
"id": 0,
"name": "Basic",
"attributes": [
"id": 0,
"name": "zcl_version",
"value": 1
"id": 1,
"name": "app_version",
"value": 1
"id": 2,
"name": "stack_version",
"value": 2
"id": 3,
"name": "hw_version",
"value": 1
"id": 4,
"name": "manufacturer",
"value": "GLEDOPTO"
"id": 5,
"name": "model",
"value": "GL-B-008Z"
"id": 6,
"name": "date_code",
"value": "20131206"
"id": 7,
"name": "power_source",
"value": 1
"id": 16384,
"name": "sw_build_id",
"value": "3.0.0"
"id": 3,
"name": "Identify",
"attributes": []
"id": 4,
"name": "Groups",
"attributes": []
"id": 5,
"name": "Scenes",
"attributes": []
"id": 6,
"name": "On\/Off",
"attributes": []
"id": 8,
"name": "Level control",
"attributes": []
"id": 768,
"name": "Color Control",
"attributes": []
"signature": {
"node_desc": {
"logical_type": 1,
"reserved": 0,
"aps_flags": 0,
"frequency_band": 8,
"mac_capability_flags": 142,
"manufacturer_code": 0,
"maximum_buffer_size": 80,
"maximum_incoming_transfer_size": 160,
"server_mask": 0,
"maximum_outgoing_transfer_size": 160,
"endpoints": {
"11": {
"device_type": 528,
"input_clusters": [
0,
3,
4,
5,
6,
8,
768
"class": "zhaquirks.gledopto.soposhgu10"
Dans le log en debug, je ne vois rien de particulier
[2021-11-27 15:05:53][DEBUG] : Search attribut for 54:ef:44:10:00:10:5e:92 logicalId : 1::1029::0 => 3782 convert to 3782
[2021-11-27 15:06:23][DEBUG] : {"devices":{"54:ef:44:10:00:10:5e:92":{"1":{"1029":[{"value":"3673","cluster_name":"Relative Humidity Measurement"}]}}}}
[2021-11-27 15:06:23][DEBUG] : Search attribut for 54:ef:44:10:00:10:5e:92 logicalId : 1::1029::0 => 3673 convert to 3673
[2021-11-27 15:06:53][DEBUG] : http://127.0.0.1:8089/device/info?ieee=00%3A12%3A4b%3A00%3A21%3A0f%3A75%3A98 type : GET
[2021-11-27 15:06:53][DEBUG] : {"ieee":"00:12:4b:00:21:0f:75:98"}
[2021-11-27 15:07:01][DEBUG] : http://127.0.0.1:8089/device/rediscover type : PUT
[2021-11-27 15:07:01][DEBUG] : {"ieee":"00:12:4b:00:21:0f:75:98"}
[2021-11-27 15:07:01][DEBUG] : ""
[2021-11-27 15:07:01][DEBUG] : {"device_initialized":"00:12:4b:00:21:0f:75:98"}
[2021-11-27 15:07:23][DEBUG] : {"devices":{"54:ef:44:10:00:10:5e:92":{"1":{"1029":[{"value":"3764","cluster_name":"Relative Humidity Measurement"}],"1026":[{"value":"2296","cluster_name":"Temperature Measurement"}]}}}}
[2021-11-27 15:07:23][DEBUG] : Search attribut for 54:ef:44:10:00:10:5e:92 logicalId : 1::1029::0 => 3764 convert to 3764
[2021-11-27 15:07:23][DEBUG] : Search attribut for 54:ef:44:10:00:10:5e:92 logicalId : 1::1026::0 => 2296 convert to 2296
[2021-11-27 15:07:31][DEBUG] : http://127.0.0.1:8089/device/all?with_attributes=2 type : GET
[2021-11-27 15:07:31][DEBUG] : {"with_attributes":2}
[2021-11-27 15:07:31][DEBUG] : http://127.0.0.1:8089/device/update_specific type : PUT
[2021-11-27 15:07:31][DEBUG] : {"ieee":"00:15:8d:00:04:c0:a6:a9"}
[2021-11-27 15:07:31][DEBUG] : http://127.0.0.1:8089/group/all type : GET
[2021-11-27 15:07:31][DEBUG] : null
[2021-11-27 15:08:02][DEBUG] : {"devices":{"54:ef:44:10:00:10:5e:92":{"1":{"1029":[{"value":"3685","cluster_name":"Relative Humidity Measurement"}]}}}}
[2021-11-27 15:08:02][DEBUG] : Search attribut for 54:ef:44:10:00:10:5e:92 logicalId : 1::1029::0 => 3685 convert to 3685
[2021-11-27 15:08:32][DEBUG] : {"devices":{"54:ef:44:10:00:10:5e:92":{"1":{"1029":[{"value":"3778","cluster_name":"Relative Humidity Measurement"}]}}}}
[2021-11-27 15:08:32][DEBUG] : Search attribut for 54:ef:44:10:00:10:5e:92 logicalId : 1::1029::0 => 3778 convert to 3778
[2021-11-27 15:08:35][DEBUG] : http://127.0.0.1:8089/device/info?ieee=00%3A12%3A4b%3A00%3A21%3A0f%3A75%3A98 type : GET
[2021-11-27 15:08:35][DEBUG] : {"ieee":"00:12:4b:00:21:0f:75:98"}
[2021-11-27 15:08:44][DEBUG] : http://127.0.0.1:8089/device/get_basic_info type : PUT
[2021-11-27 15:08:44][DEBUG] : {"ieee":"00:12:4b:00:21:0f:75:98"}
[2021-11-27 15:08:47][DEBUG] : ""
[2021-11-27 15:09:12][DEBUG] : {"devices":{"54:ef:44:10:00:10:5e:92":{"1":{"1029":[{"value":"3657","cluster_name":"Relative Humidity Measurement"}]}}}}
[2021-11-27 15:09:12][DEBUG] : Search attribut for 54:ef:44:10:00:10:5e:92 logicalId : 1::1029::0 => 3657 convert to 3657
[2021-11-27 15:10:02][DEBUG] : {"devices":{"54:ef:44:10:00:10:5e:92":{"1":{"1029":[{"value":"3712","cluster_name":"Relative Humidity Measurement"}]}}}}
[2021-11-27 15:10:02][DEBUG] : Search attribut for 54:ef:44:10:00:10:5e:92 logicalId : 1::1029::0 => 3712 convert to 3712
[2021-11-27 15:10:32][DEBUG] : {"devices":{"54:ef:44:10:00:10:5e:92":{"1":{"1029":[{"value":"3785","cluster_name":"Relative Humidity Measurement"}]}}}}
[2021-11-27 15:10:32][DEBUG] : Search attribut for 54:ef:44:10:00:10:5e:92 logicalId : 1::1029::0 => 3785 convert to 3785
[2021-11-27 15:11:02][DEBUG] : {"devices":{"54:ef:44:10:00:10:5e:92":{"1":{"1029":[{"value":"3678","cluster_name":"Relative Humidity Measurement"}]}}}}
[2021-11-27 15:11:02][DEBUG] : Search attribut for 54:ef:44:10:00:10:5e:92 logicalId : 1::1029::0 => 3678 convert to 3678
Je ne sais pas faire des actions sur ce module à part des on/off depuis un inter physique.
Merci pour votre assistance.
