Il faudrait essayer directement dans l’interface web de JPI pour commencer.
Amazon de mémoire.
Amazon de mémoire.
Bonjour dJuL,
Depuis la dernière mise à jour, je constate des coupures de PAW sans trouver de ou cela peux venir.
As-tu une idée?
Citation APP LOG
05/05/20 14:35:04 - START Streaming (Front camera - 15fps)
05/05/20 14:35:14 - PAW is offline
05/05/20 14:35:28 - PAW is offline since 14 seconds
05/05/20 14:35:38 - PAW is offline since 24 seconds
05/05/20 14:35:42 - PAW is offline since 28 seconds, try to restart PAW
05/05/20 14:35:52 - STOP Streaming
05/05/20 14:35:53 - Service stop
05/05/20 14:35:57 - Service start
05/05/20 14:35:57 - 1 cron task(s) loaded
05/05/20 14:35:58 - Reset google services impossible without root access
05/05/20 14:35:58 - START Streaming (Front camera - 15fps)
05/05/20 14:36:14 - Service stop
05/05/20 14:36:27 - Service start
05/05/20 14:36:27 - 1 cron task(s) loaded
05/05/20 14:36:27 - Reset google services impossible without root access
05/05/20 14:36:34 - START Streaming (Front camera - 15fps)
05/05/20 14:36:37 - PAW is offline
05/05/20 14:36:51 - PAW is offline since 14 seconds
05/05/20 14:37:01 - STOP Streaming
05/05/20 14:37:02 - Service stop
05/05/20 14:37:05 - Service start
05/05/20 14:37:06 - 1 cron task(s) loaded
05/05/20 14:37:06 - Reset google services impossible without root access
05/05/20 14:37:13 - START Streaming (Front camera - 15fps)
05/05/20 14:37:32 - PAW is offline
05/05/20 14:37:46 - PAW is offline since 14 seconds
05/05/20 14:37:56 - PAW is offline since 24 seconds
05/05/20 14:38:00 - PAW is offline since 28 seconds, try to restart PAW
05/05/20 14:38:10 - STOP Streaming
05/05/20 14:38:11 - Service stop
05/05/20 15:05:40 - Activity start
05/05/20 15:05:52 - Service start
05/05/20 15:05:52 - 1 cron task(s) loaded
05/05/20 15:05:52 - Reset google services impossible without root access
05/05/20 15:06:07 - START Streaming (Front camera - 15fps)
05/05/20 19:31:34 - Service stop
05/05/20 19:31:38 - Service start
05/05/20 19:31:38 - 1 cron task(s) loaded
05/05/20 19:31:38 - Reset google services impossible without root access
05/05/20 19:31:46 - START Streaming (Front camera - 15fps)
05/05/20 19:32:52 - Activity start
05/05/20 19:33:42 - Service start
05/05/20 19:33:43 - 1 cron task(s) loaded
05/05/20 19:33:43 - Reset google services impossible without root access
05/05/20 19:33:58 - START Streaming (Front camera - 15fps)
Probablement un manque de CPU ?
Essaye de baisser le framerate du streaming à 5fps pour voir si ça continue.
Selon les appareils le streaming peut être gourmand en ressources, surtout quand il y a plusieurs clients connectés dessus avec en // d’autres requêtes vers JPI.
Beaucoup d’impératifs professionnels m’empêchent d’avancer sur JPI comme je le souhaiterais…
Mais j’essaye d’avancer tout doucement.
Du coup je ne sais pas encore quand la prochaine maj va sortir.
J’ai déjà corrigé pas mal de petits bugs sur la version en cours, mais trop de fichiers sont en chantier pour que je puisse sortir une maj dans l’immédiat.
Bonjour à tous
je ne sais pas si je suis sur le bon forum
J’aimerai envoyer 1 snapshot issu d’une de mes caméras par mms
je n’ai pas trouvé ou pas compris dans le forum
Avec si peut d’information difficile de te répondre.
Mais oui JPI peut envoyer des MMS avec une pièce jointe qu’il peut aller chercher soit en local dans l’appareil ou via une url.
Bonjour dJul
Merci pour ton aide
Je voudrais à partir d’un scénario jeedom
transmettre à JPI le No de tel à appeler, le snapshot issu du plugin camera, le message.
J’arrive à envoyer des sms grace au tuto « Envoi de SMS avec JPI » de ladomopratique.com
j’ai essayé selon ce principe avec sendMms, mais sans résultat
Salut dJuL,
Même après avoir fait la modification, je rencontre toujours le problème.
Je viens de désactiver la caméra, a voir si les déconnexions persistes…
Belle journée
En admettant que tu stockes le chemin du snapshot dans une variable Jeedom nommée ‹ Snapshot ›.
Avec le framework SC tu peux faire :
//charge la librairie JPI (avec l'IP de ton JPI à la place de 192.168.100.7)
$jpi = $sc->load('jpi', 'http://192.168.0.7:8080');
//charge la librairie files
$files = $sc->load('files');
//Récupère le chemin du fichier image dans une variable Jeedom
$imagePath = $sc->getVar('Snapshot');
//génère le lien, avec une validité de 30 secondes
//(avec l'IP de Jeedom à la palce de 10.10.10.10)
$url = $files->makeDownloadUrl($imagePath, '10.10.10.10', 30);
//Envoie le MMS
$jpi->sendMms('{MY_NUMBER}', $url, 'Message de test avec photo jointe');
Sinon ça doit être également possible de mémoire avec le plugin JPI, mais là je ne peux pas t’aider.
Tu as essayé de rebooter ?
Parfois cela peut régler de nombreux problèmes…
Une question SVP
J’ai 2 tablettes avec JPI d’installé, l’une est destiné à être une tablette murale dédiée , l’autre tablette multiusage et qui me sert aussi à tester JPI.
Tout marchait bien jusqu’à hier après-midi, c’est à JPI sur les 2 tablettes et remontée dans Jeedom via le plugin
Mon problème est que j’ai une tablette qui n’est plus détectée par Jeedom et je ne sais pas pourquoi??
Sans passer par le plugin JPI sous jeedom, je teste les URL dans mon navigateur web , une tablette répond correctement et l’autre ‹ unknow error ›
Si je vais dans l’application web de JPI Executer action / générer URL , j’ai un retour correct , par contre si je fais un copier coller de l’url dans le navigateur web , j’ai unknow error , vraiment étrange , je sèche… si quelqu’un a une idée SVP
Je précise que la configuration des 2 tablettes est la même , et dernière version de JPI installée.
Bonjour , j’utilise JPI pour l’envoi de sms via Jeedom
jusque la tout va bien , ici je me retrouve avec l’envoi de sms a moi même !
j’explique lorsque j’ai mit en place le auto pour envoyé des sms , j’ai modifié le MY_Number +33 6 XXXX
pour mon numéro ode GSM. jamais rien eu.sauf que ma tablette à généré plus de 26K SMS a moi même
dans le journal des erreurs je trouve :
06/05/20 22:07:25 - ERREUR sendSms: null
07/05/20 11:20:58 - sendSMS(core) ERREUR: Impossible d’envoyer le message à +32XXXXX
il y a t’il un problème quelconque ?
je trouve dans PAW SMS : +32XXXXX (52355)
Jeedom: [Etage][Volet Bureau][Pas]. or cette fonction n’est lié a rien pour l’envoi de sms ?
j’ai vraiment besoin d’information …ou bien trouver ce qui a généré cela
merci
Faudrait voir si il y a une erreur dans le log des erreurs
Si {MY_NUMBER} est égale au numéro JPI cela fait une boucle infinie de SMS. Ce mot clef doit représenté son numéro de contact (tel mobile perso) mais surtout pas le numéro de l’appareil JPI.
Bonjour dJul
Merci pour ton aide
Je ne sais pas faire en php mais je vais tout de même essayer en me documentant…
Je vais également essayer avec le plugin JPI
et ferai retour du résultat.
Pas besoin de maîtriser le php, Tu as juste à stocker le chemin du fichier dans une variable Jeedom nommée ‹ Snapshot ›, puis en dessous, ajouter un bloc code dans ton scénario et recopier le code tel que je te l’ais donné en modifiant juste les IP de JPI et Jeedom
Aujourd’hui j’ai bien avancé sur le « plugin caméra » de JPI
Du coup j’ai fait un truc bien plus avancé que ce que l’imaginais à la base…
Il est quasi terminé ![]()
Quelques screenshots :
Bonjour et merci pour ce super plugin que j’utilise maintenant depuis plusieurs années
Malheureusement depuis la derniere mise a jour du serveur PAW j’ai un gros souci , PAW oblige le telephone a activer le wifi, or dans mon cas je ne l’utilise pas car j’utilise le telephone en modem sur la prise USB de mon routeur. Si je n’autorise pas la connection wifi, PAW se ferme. Y a t’il une solution pour pas que PAW serveur fonctionne sans le wifi et ne me demande plus de l’activer. Ca fonctionnait avant sur l’ancienne version que j’utilise donc toujours …
Super taf ! j’ai hâte.
Si tout se goupille bien, je devrais pouvoir publier une maj d’ici ce we
