Juste pour tester un truc, as-tu un autre device z-wave?
non j’ai acheté la smart et un door/winndow pour faire un essai
Voici le log de openzwave :
2020-12-28 11:39:07][INFO] : Lancement démon openzwave : /usr/bin/python /var/www/html/plugins/openzwave/core/class/../../resources/openzwaved/openzwaved.py --device /dev/ttyS1 --loglevel info --port 8083 --config_folder /var/www/html/plugins/openzwave/core/class/../../resources/openzwaved/config --data_folder /var/www/html/plugins/openzwave/core/class/../../data --callback http://127.0.0.1:80/plugins/openzwave/core/php/jeeZwave.php --apikey *********************************** --suppressRefresh 0 --cycle 0.3 --pid /tmp/jeedom/openzwave/deamon.pid
[2020-12-28 10:39:09][INFO] : Start openzwaved
[2020-12-28 10:39:09][INFO] : Log level : info
[2020-12-28 10:39:09][INFO] : Device : /dev/ttyS1
[2020-12-28 10:39:09][INFO] : Callback : http://127.0.0.1:80/plugins/openzwave/core/php/jeeZwave.php
[2020-12-28 10:39:09][INFO] : Cycle : 0.3
[2020-12-28 10:39:09][INFO] : Check if the port REST server available
[2020-12-28 10:39:09][INFO] : --> pass
[2020-12-28 10:39:09][INFO] : Check OpenZWave Devices Database
[2020-12-28 10:39:09][INFO] : Validate zwcfg configuration file(s)
[2020-12-28 10:39:09][INFO] : ... check: /var/www/html/plugins/openzwave/core/class/../../data/zwcfg_0xf3e6277e.xml
[2020-12-28 10:39:09][INFO] : ... check: /var/www/html/plugins/openzwave/core/class/../../data/zwcfg_0xe3a7b132.xml
[2020-12-28 10:39:09][INFO] : ... check: /var/www/html/plugins/openzwave/core/class/../../data/zwcfg_0xe0ddd0f1.xml
[2020-12-28 10:39:09][INFO] : ... check: /var/www/html/plugins/openzwave/core/class/../../data/zwcfg_0xd776d73c.xml
[2020-12-28 10:39:09][INFO] : ... check: /var/www/html/plugins/openzwave/core/class/../../data/zwcfg_0xcc4a366b.xml
[2020-12-28 10:39:09][INFO] : ******** The ZWave network is being started ********
[2020-12-28 10:39:09][INFO] : Start Openzwave network.
[2020-12-28 10:39:09][INFO] : OpenZwave Library Version 1.4.0
[2020-12-28 10:39:09][INFO] : Python-OpenZwave Wrapper Version 0.3.1
[2020-12-28 10:39:09][INFO] : Waiting for network to become ready
[2020-12-28 10:39:09][INFO] : Driver ready using library Static Controller version Z-Wave 3.99
[2020-12-28 10:39:09][INFO] : home_id 0xcc4a366b, controller node id is 1
[2020-12-28 10:39:09][INFO] : Openzwave network are started with homeId cc4a366b.
[2020-12-28 10:39:09][INFO] : A node has been added to OpenZWave list id:[1] model:[UZB Z-Wave USB Adapter].
[2020-12-28 10:39:09][INFO] : All the initialisation queries on a node have been completed. id:[1] model:[UZB Z-Wave USB Adapter].
[2020-12-28 10:39:09][INFO] : Openzwave network is ready with 1 nodes (0 are sleeping). All nodes are queried, the network is fully functional.
[2020-12-28 10:39:09][INFO] : ZWave configuration written to user directory.
[2020-12-28 10:39:09][INFO] : write configuration file
[2020-12-28 11:39:10][INFO] : Démon openzwave lancé
[2020-12-28 10:40:17][INFO] : 200 GET /network?type=info&info=getStatus&apikey=*********************************** (127.0.0.1) 4.54ms
[2020-12-28 10:40:24][INFO] : Start the Inclusion Process to add a Node to the Network with Security CC if the node is supports it
[2020-12-28 10:40:24][INFO] : The command is starting. (Starting)
[2020-12-28 10:40:24][INFO] : 200 GET /controller?type=addNode&security=1&apikey=*********************************** (127.0.0.1) 4.14ms
[2020-12-28 10:40:24][INFO] : Controller is waiting for a user action. (Waiting)
[2020-12-28 10:44:34][INFO] : 200 GET /network?type=info&info=getStatus&apikey=*********************************** (127.0.0.1) 2.59ms
[2020-12-28 10:45:03][INFO] : 200 GET /network?type=info&info=getStatus&apikey=*********************************** (127.0.0.1) 3.64ms
[2020-12-28 10:45:38][INFO] : Controller action cancelCommand
[2020-12-28 10:45:38][INFO] : 200 GET /controller?type=action&action=cancelCommand&apikey=*********************************** (127.0.0.1) 3.24ms
[2020-12-28 10:45:38][INFO] : The command was cancelled. (Cancel)
[2020-12-28 10:45:38][INFO] : The command has completed successfully. (Completed)
[2020-12-28 10:46:44][INFO] : 200 GET /network?type=info&info=getStatus&apikey=*********************************** (127.0.0.1) 2.59ms
[2020-12-28 10:46:50][INFO] : Start the Inclusion Process to add a Node to the Network with Security CC if the node is supports it
[2020-12-28 10:46:50][INFO] : The command is starting. (Starting)
[2020-12-28 10:46:50][INFO] : 200 GET /controller?type=addNode&security=1&apikey=*********************************** (127.0.0.1) 3.42ms
[2020-12-28 10:46:50][INFO] : Controller is waiting for a user action. (Waiting)
[2020-12-28 10:46:56][INFO] : Controller action cancelCommand
[2020-12-28 10:46:56][INFO] : 200 GET /controller?type=action&action=cancelCommand&apikey=*********************************** (127.0.0.1) 3.02ms
[2020-12-28 10:46:56][INFO] : The command was cancelled. (Cancel)
[2020-12-28 10:46:56][INFO] : The command has completed successfully. (Completed)
De ce que je lis, tu as lancé une inclusion qui n’a pas abouti et tu as annulé l’inclusion parce que pas de résultat.
C’est bien ça
oui, je l’ai lancée plusieurs fois pour voir si le log l’enregistrait, je constate 1 heure de décallage sur l’heure d’enregistrement
L’heure de décalage c’est connu sur smart et ça n’a pas d’importance.
Je n’ai pas su bien tout lire car sur téléphone mais la dernière tentative d’inclusion était en mode sécurisé et n’est restée que 6s. Ce n’est pas assez.
Fait l’inclusion en mode non sécurisé, fait la à moins d’un mètre du contrôleur et appui bien rapidement 3x sur le bouton
Et puis attend. Ça peut prendre 30s ou plus avant que le module soit détecté.
j’ai refait une demande d’inclusion, j’ai la led bleue du capteur Figaro qui clignote plusieurs fois lentement, le log est en mode waiting
voici le log
[2020-12-28 11:06:45][INFO] : 200 GET /network?type=info&info=getStatus&apikey=hLZNE3UvLTeavWF9Mr94f64Yu79hfD3e (127.0.0.1) 2.53ms
[2020-12-28 11:06:51][INFO] : Start the Inclusion Process to add a Node to the Network
[2020-12-28 11:06:51][INFO] : The command is starting. (Starting)
[2020-12-28 11:06:51][INFO] : 200 GET /controller?type=addNode&security=0&apikey=hLZNE3UvLTeavWF9Mr94f64Yu79hfD3e (127.0.0.1) 4.21ms
[2020-12-28 11:06:51][INFO] : Controller is waiting for a user action. (Waiting)
[2020-12-28 11:10:20][INFO] : 200 GET /network?type=info&info=getStatus&apikey=hLZNE3UvLTeavWF9Mr94f64Yu79hfD3e (127.0.0.1) 2.49ms
Avez-vous mis le mode debug sur le log? je n’ai pas l’impression.
Là on ne voit rien de relevant.
Relance le démon après l’avoir mis en mode debug et sauvegarder.
VOICI
2020-12-28 12:36:05][INFO] : Lancement démon openzwave : /usr/bin/python /var/www/html/plugins/openzwave/core/class/../../resources/openzwaved/openzwaved.py --device /dev/ttyS1 --loglevel debug --port 8083 --config_folder /var/www/html/plugins/openzwave/core/class/../../resources/openzwaved/config --data_folder /var/www/html/plugins/openzwave/core/class/../../data --callback http://127.0.0.1:80/plugins/openzwave/core/php/jeeZwave.php --apikey hLZNE3UvLTeavWF9Mr94f64Yu79hfD3e --suppressRefresh 0 --cycle 0.3 --pid /tmp/jeedom/openzwave/deamon.pid
[2020-12-28 11:36:06][INFO] : Start openzwaved
[2020-12-28 11:36:06][INFO] : Log level : debug
[2020-12-28 11:36:06][DEBUG] : PID file : /tmp/jeedom/openzwave/deamon.pid
[2020-12-28 11:36:06][INFO] : Device : /dev/ttyS1
[2020-12-28 11:36:06][DEBUG] : Apikey : hLZNE3UvLTeavWF9Mr94f64Yu79hfD3e
[2020-12-28 11:36:06][INFO] : Callback : http://127.0.0.1:80/plugins/openzwave/core/php/jeeZwave.php
[2020-12-28 11:36:06][INFO] : Cycle : 0.3
[2020-12-28 11:36:06][DEBUG] : Initial disabled nodes list: []
[2020-12-28 11:36:06][DEBUG] : Init request module v2.12.4
[2020-12-28 11:36:06][DEBUG] : Starting new HTTP connection (1): 127.0.0.1
[2020-12-28 11:36:06][DEBUG] : http://127.0.0.1:80 "GET /plugins/openzwave/core/php/jeeZwave.php?apikey=hLZNE3UvLTeavWF9Mr94f64Yu79hfD3e HTTP/1.1" 200 0
[2020-12-28 11:36:06][INFO] : Check if the port REST server available
[2020-12-28 11:36:06][INFO] : --> pass
[2020-12-28 11:36:06][INFO] : Check OpenZWave Devices Database
[2020-12-28 11:36:06][INFO] : Validate zwcfg configuration file(s)
[2020-12-28 11:36:06][INFO] : ... check: /var/www/html/plugins/openzwave/core/class/../../data/zwcfg_0xf3e6277e.xml
[2020-12-28 11:36:06][INFO] : ... check: /var/www/html/plugins/openzwave/core/class/../../data/zwcfg_0xe3a7b132.xml
[2020-12-28 11:36:06][INFO] : ... check: /var/www/html/plugins/openzwave/core/class/../../data/zwcfg_0xe0ddd0f1.xml
[2020-12-28 11:36:06][INFO] : ... check: /var/www/html/plugins/openzwave/core/class/../../data/zwcfg_0xd776d73c.xml
[2020-12-28 11:36:06][INFO] : ... check: /var/www/html/plugins/openzwave/core/class/../../data/zwcfg_0xcc4a366b.xml
[2020-12-28 11:36:06][DEBUG] : Create network object.
[2020-12-28 11:36:06][DEBUG] : Use sqlite version : (u'3.16.2',)
[2020-12-28 11:36:06][DEBUG] : connect to the louie dispatcher
[2020-12-28 11:36:06][INFO] : ******** The ZWave network is being started ********
[2020-12-28 11:36:06][INFO] : Start Openzwave network.
[2020-12-28 11:36:06][INFO] : OpenZwave Library Version 1.4.0
[2020-12-28 11:36:06][INFO] : Python-OpenZwave Wrapper Version 0.3.1
[2020-12-28 11:36:06][INFO] : Waiting for network to become ready
[2020-12-28 11:36:06][DEBUG] : Writing PID 28074 to /tmp/jeedom/openzwave/deamon.pid
[2020-12-28 11:36:06][DEBUG] : notif_callback : new notification
[2020-12-28 11:36:06][DEBUG] : notif_callback : Notification type : 18, nodeId : 1
[2020-12-28 11:36:06][DEBUG] : notif_callback : call callback context
[2020-12-28 11:36:06][DEBUG] : zwcallback args=[{'homeId': 3427415659, 'notificationType': 'DriverReady', 'nodeId': 1}]
[2020-12-28 11:36:06][DEBUG] : Z-Wave Notification DriverReady : {'homeId': 3427415659, 'notificationType': 'DriverReady', 'nodeId': 1}
[2020-12-28 11:36:06][DEBUG] : Create object node (node_id:1)
[2020-12-28 11:36:06][INFO] : Driver ready using library Static Controller version Z-Wave 3.99
[2020-12-28 11:36:06][INFO] : home_id 0xcc4a366b, controller node id is 1
[2020-12-28 11:36:06][DEBUG] : Network home_id: [0xcc4a366b] controller: [home_id: [0xcc4a366b] id: [1] name: [1Z-Wave Plus USB Controller] product: [UZB Z-Wave USB Adapter] capabilities: set(['primaryController']) library: [Static Controller version Z-Wave 3.99]]
[2020-12-28 11:36:06][INFO] : Openzwave network are started with homeId cc4a366b.
[2020-12-28 11:36:06][DEBUG] : notif_callback : end
[2020-12-28 11:36:06][DEBUG] : notif_callback : Notification type : 6, nodeId : 1
[2020-12-28 11:36:06][DEBUG] : zwcallback args=[{'homeId': 3427415659, 'notificationType': 'NodeAdded', 'nodeId': 1}]
[2020-12-28 11:36:06][DEBUG] : Z-Wave Notification NodeAdded : {'homeId': 3427415659, 'notificationType': 'NodeAdded', 'nodeId': 1}
[2020-12-28 11:36:06][INFO] : A node has been added to OpenZWave list id:[1] model:[UZB Z-Wave USB Adapter].
[2020-12-28 11:36:06][DEBUG] : Z-Wave Notification Node : home_id: [0xcc4a366b] id: [1] name: [1Z-Wave Plus USB Controller] model: [UZB Z-Wave USB Adapter]
[2020-12-28 11:36:06][DEBUG] : notif_callback : Notification type : 8, nodeId : 1
[2020-12-28 11:36:06][DEBUG] : zwcallback args=[{'homeId': 3427415659, 'notificationType': 'NodeProtocolInfo', 'nodeId': 1}]
[2020-12-28 11:36:06][DEBUG] : Z-Wave Notification NodeProtocolInfo : {'homeId': 3427415659, 'notificationType': 'NodeProtocolInfo', 'nodeId': 1}
[2020-12-28 11:36:06][DEBUG] : notif_callback : Notification type : 21, nodeId : 1
[2020-12-28 11:36:06][DEBUG] : zwcallback args=[{'homeId': 3427415659, 'notificationType': 'EssentialNodeQueriesComplete', 'nodeId': 1}]
[2020-12-28 11:36:06][DEBUG] : Z-Wave Notification EssentialNodeQueriesComplete : {'homeId': 3427415659, 'notificationType': 'EssentialNodeQueriesComplete', 'nodeId': 1}
[2020-12-28 11:36:06][DEBUG] : notif_callback : Notification type : 0, nodeId : 1
[2020-12-28 11:36:06][DEBUG] : addValueId : ValueID : 72057594055229441
[2020-12-28 11:36:06][DEBUG] : addValueId : GetCommandClassId : 32, GetType : 1
[2020-12-28 11:36:06][DEBUG] : addValueId : Notification : {'homeId': 3427415659, 'valueId': {'index': 0, 'units': None, 'type': 'Byte', 'nodeId': 1, 'value': None, 'commandClass': 'COMMAND_CLASS_BASIC', 'instance': 1, 'readOnly': False, 'homeId': 3427415659, 'label': None, 'genre': '', 'id': 72057594055229441L}, 'notificationType': 'ValueAdded', 'nodeId': 1}
[2020-12-28 11:36:06][DEBUG] : zwcallback args=[{'homeId': 3427415659, 'valueId': {'index': 0, 'units': None, 'type': 'Byte', 'nodeId': 1, 'value': None, 'commandClass': 'COMMAND_CLASS_BASIC', 'instance': 1, 'readOnly': False, 'homeId': 3427415659, 'label': None, 'genre': '', 'id': 72057594055229441L}, 'notificationType': 'ValueAdded', 'nodeId': 1}]
[2020-12-28 11:36:06][DEBUG] : Z-Wave Notification ValueAdded : {'homeId': 3427415659, 'valueId': {'index': 0, 'units': None, 'type': 'Byte', 'nodeId': 1, 'value': None, 'commandClass': 'COMMAND_CLASS_BASIC', 'instance': 1, 'readOnly': False, 'homeId': 3427415659, 'label': None, 'genre': '', 'id': 72057594055229441L}, 'notificationType': 'ValueAdded', 'nodeId': 1}
[2020-12-28 11:36:06][DEBUG] : Create object value (valueId:72057594055229441)
[2020-12-28 11:36:06][DEBUG] : notif_callback : Notification type : 9, nodeId : 1
[2020-12-28 11:36:06][DEBUG] : zwcallback args=[{'homeId': 3427415659, 'notificationType': 'NodeNaming', 'nodeId': 1}]
[2020-12-28 11:36:06][DEBUG] : Z-Wave Notification NodeNaming : {'homeId': 3427415659, 'notificationType': 'NodeNaming', 'nodeId': 1}
[2020-12-28 11:36:06][DEBUG] : notif_callback : Notification type : 22, nodeId : 1
[2020-12-28 11:36:06][DEBUG] : zwcallback args=[{'homeId': 3427415659, 'notificationType': 'NodeQueriesComplete', 'nodeId': 1}]
[2020-12-28 11:36:06][DEBUG] : Z-Wave Notification NodeQueriesComplete : {'homeId': 3427415659, 'notificationType': 'NodeQueriesComplete', 'nodeId': 1}
[2020-12-28 11:36:06][INFO] : All the initialisation queries on a node have been completed. id:[1] model:[UZB Z-Wave USB Adapter].
[2020-12-28 11:36:06][DEBUG] : notif_callback : Notification type : 25, nodeId : 255
[2020-12-28 11:36:06][DEBUG] : zwcallback args=[{'homeId': 3427415659, 'notificationType': 'AllNodesQueried', 'nodeId': 255}]
[2020-12-28 11:36:06][DEBUG] : Z-Wave Notification AllNodesQueried : {'homeId': 3427415659, 'notificationType': 'AllNodesQueried', 'nodeId': 255}
[2020-12-28 11:36:06][INFO] : Openzwave network is ready with 1 nodes (0 are sleeping). All nodes are queried, the network is fully functional.
[2020-12-28 11:36:06][INFO] : ZWave configuration written to user directory.
[2020-12-28 11:36:06][INFO] : write configuration file
[2020-12-28 11:36:06][DEBUG] : Send to jeedom : {'network': {'state': {'value': 5}}}
[2020-12-28 11:36:06][DEBUG] : http://127.0.0.1:80 "POST /plugins/openzwave/core/php/jeeZwave.php?apikey=hLZNE3UvLTeavWF9Mr94f64Yu79hfD3e HTTP/1.1" 200 0
[2020-12-28 12:36:07][INFO] : Démon openzwave lancé
[2020-12-28 11:36:07][DEBUG] : notif_callback : end
[2020-12-28 11:36:07][DEBUG] : Send to jeedom : {'network': {'state': {'value': 10}}}
[2020-12-28 11:36:07][DEBUG] : Starting new HTTP connection (1): 127.0.0.1
[2020-12-28 11:36:08][DEBUG] : http://127.0.0.1:80 "POST /plugins/openzwave/core/php/jeeZwave.php?apikey=hLZNE3UvLTeavWF9Mr94f64Yu79hfD3e HTTP/1.1" 200 0
[2020-12-28 11:36:30][INFO] : 200 GET /network?type=info&info=getStatus&apikey=hLZNE3UvLTeavWF9Mr94f64Yu79hfD3e (127.0.0.1) 4.13ms
[2020-12-28 11:36:36][INFO] : Start the Inclusion Process to add a Node to the Network
[2020-12-28 11:36:36][DEBUG] : notif_callback : new notification
[2020-12-28 11:36:36][DEBUG] : notif_callback : Notification type : 28, nodeId : 0
[2020-12-28 11:36:36][DEBUG] : notif_callback : call callback context
[2020-12-28 11:36:36][DEBUG] : zwcallback args=[{'controllerState': 'Starting', 'controllerError': 'None', 'controllerErrorInt': 0, 'notificationType': 'ControllerCommand', 'nodeId': 0, 'controllerStateInt': 1, 'controllerErrorDoc': 'None.', 'homeId': 3427415659, 'controllerStateDoc': 'The command is starting.'}]
[2020-12-28 11:36:36][DEBUG] : Z-Wave ControllerCommand : {'controllerState': 'Starting', 'controllerError': 'None', 'controllerErrorInt': 0, 'notificationType': 'ControllerCommand', 'nodeId': 0, 'controllerStateInt': 1, 'controllerErrorDoc': 'None.', 'homeId': 3427415659, 'controllerStateDoc': 'The command is starting.'}
[2020-12-28 11:36:36][INFO] : The command is starting. (Starting)
[2020-12-28 11:36:36][DEBUG] : The controller is busy ? True
[2020-12-28 11:36:36][DEBUG] : notif_callback : end
[2020-12-28 11:36:36][INFO] : 200 GET /controller?type=addNode&security=0&apikey=hLZNE3UvLTeavWF9Mr94f64Yu79hfD3e (127.0.0.1) 3.82ms
[2020-12-28 11:36:36][DEBUG] : zwcallback args=[{'controllerState': 'Waiting', 'controllerError': 'None', 'controllerErrorInt': 0, 'notificationType': 'ControllerCommand', 'nodeId': 0, 'controllerStateInt': 4, 'controllerErrorDoc': 'None.', 'homeId': 3427415659, 'controllerStateDoc': 'Controller is waiting for a user action.'}]
[2020-12-28 11:36:36][DEBUG] : Z-Wave ControllerCommand : {'controllerState': 'Waiting', 'controllerError': 'None', 'controllerErrorInt': 0, 'notificationType': 'ControllerCommand', 'nodeId': 0, 'controllerStateInt': 4, 'controllerErrorDoc': 'None.', 'homeId': 3427415659, 'controllerStateDoc': 'Controller is waiting for a user action.'}
[2020-12-28 11:36:36][INFO] : Controller is waiting for a user action. (Waiting)
[2020-12-28 11:36:36][DEBUG] : Send to jeedom : {'controller': {'state': {'value': 1}}}
[2020-12-28 11:36:36][DEBUG] : Starting new HTTP connection (1): 127.0.0.1
[2020-12-28 11:36:36][DEBUG] : http://127.0.0.1:80 "POST /plugins/openzwave/core/php/jeeZwave.php?apikey=hLZNE3UvLTeavWF9Mr94f64Yu79hfD3e HTTP/1.1" 200 0
[2020-12-28 11:37:39][INFO] : 200 GET /network?type=info&info=getStatus&apikey=hLZNE3UvLTeavWF9Mr94f64Yu79hfD3e (127.0.0.1) 2.53ms
As-tu essayé d’inclure ton module parce que là je ne le vois pas?
Oui de la même façon que les autres fois, 3 appuis sur le bouton
je viens de la refaire et pas de nouvelle ligne dans le log
Où as-tu acheté ton device ? Je ne vois rien de spécial dans le log.
chez amazon c’est un Fibaro Door/window FGK-10x
Tu peux l’échanger ?
C’est quand même bizarre que la clé ne détecte pas de demande d’inclusion.
Tu fais bien ton inclusion en NON sécurisée ? Quoique là je ne vois pas ce que ça changerait avec un seul device.
oui j’ai essayé les 2 modes, il est bien identifié Zwave plus et il était sous blister plastique
je n’ai envoyé que les log du openzwave, faut il aussi ceux du openzwaved ? Ci dessous :
2020-12-28 11:36:06.713 Always, OpenZwave Version 1.4.0 Starting Up
2020-12-28 11:36:06.718 Info, Setting Up Provided Network Key for Secure Communications
2020-12-28 11:36:06.719 Info, mgr, Added driver for controller /dev/ttyS1
2020-12-28 11:36:06.719 Info, Opening controller /dev/ttyS1
2020-12-28 11:36:06.719 Info, Trying to open serial port /dev/ttyS1 (attempt 1)
2020-12-28 11:36:06.719 Info, Serial port /dev/ttyS1 opened (attempt 1)
2020-12-28 11:36:06.720 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2020-12-28 11:36:06.720 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2020-12-28 11:36:06.720 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2020-12-28 11:36:06.720 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2020-12-28 11:36:06.720 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2020-12-28 11:36:06.720 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x15) - FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2020-12-28 11:36:06.722 Detail, contrlr, Received: 0x01, 0x10, 0x01, 0x15, 0x5a, 0x2d, 0x57, 0x61, 0x76, 0x65, 0x20, 0x33, 0x2e, 0x39, 0x39, 0x00, 0x01, 0x95
2020-12-28 11:36:06.723 Detail,
2020-12-28 11:36:06.723 Info, contrlr, Received reply to FUNC_ID_ZW_GET_VERSION:
2020-12-28 11:36:06.723 Info, contrlr, Static Controller library, version Z-Wave 3.99
2020-12-28 11:36:06.723 Detail, Node045, Expected reply was received
2020-12-28 11:36:06.723 Detail, Node045, Message transaction complete
2020-12-28 11:36:06.723 Detail, contrlr, Removing current message
2020-12-28 11:36:06.723 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x20) - FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2020-12-28 11:36:06.725 Detail, contrlr, Received: 0x01, 0x08, 0x01, 0x20, 0xcc, 0x4a, 0x36, 0x6b, 0x01, 0x0c
2020-12-28 11:36:06.725 Info, contrlr, Received reply to FUNC_ID_ZW_MEMORY_GET_ID. Home ID = 0xcc4a366b. Our node ID = 1
2020-12-28 11:36:06.725 Detail, Node074, Expected reply was received
2020-12-28 11:36:06.725 Detail, Node074, Message transaction complete
2020-12-28 11:36:06.725 Detail, contrlr, Removing current message
2020-12-28 11:36:06.725 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x05) - FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2020-12-28 11:36:06.726 Detail, contrlr, Received: 0x01, 0x04, 0x01, 0x05, 0x20, 0xdf
2020-12-28 11:36:06.727 Detail,
2020-12-28 11:36:06.727 Info, contrlr, Received reply to FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES:
2020-12-28 11:36:06.727 Info, contrlr, There is no SUC ID Server (SIS) in this network.
2020-12-28 11:36:06.727 Info, contrlr, The PC controller is a primary controller.
2020-12-28 11:36:06.727 Detail, Node223, Expected reply was received
2020-12-28 11:36:06.727 Detail, Node223, Message transaction complete
2020-12-28 11:36:06.727 Detail, contrlr, Removing current message
2020-12-28 11:36:06.727 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x07) - FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2020-12-28 11:36:06.732 Detail, contrlr, Received: 0x01, 0x2b, 0x01, 0x07, 0x04, 0x1a, 0x00, 0x00, 0x00, 0x01, 0x00, 0x01, 0xfe, 0x81, 0xfe, 0x88, 0xcf, 0x1f, 0x00, 0x00, 0xfb, 0x9f, 0x7d, 0xa0, 0x67, 0x00, 0x80, 0x80, 0x00, 0x80, 0x86, 0x00, 0x00, 0x00, 0xe0, 0x73, 0x00, 0x00, 0x0e, 0x00, 0x00, 0x60, 0x00, 0x00, 0x30
2020-12-28 11:36:06.732 Info, contrlr, Received reply to FUNC_ID_SERIAL_API_GET_CAPABILITIES
2020-12-28 11:36:06.732 Info, contrlr, Serial API Version: 4.26
2020-12-28 11:36:06.732 Info, contrlr, Manufacturer ID: 0x0000
2020-12-28 11:36:06.732 Info, contrlr, Product Type: 0x0001
2020-12-28 11:36:06.732 Info, contrlr, Product ID: 0x0001
2020-12-28 11:36:06.732 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_RANDOM: 0x01, 0x04, 0x00, 0x1c, 0x20, 0xc7
2020-12-28 11:36:06.732 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_GET_INIT_DATA: 0x01, 0x03, 0x00, 0x02, 0xfe
2020-12-28 11:36:06.732 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_SET_TIMEOUTS: 0x01, 0x05, 0x00, 0x06, 0x64, 0x0f, 0x97
2020-12-28 11:36:06.732 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_APPL_NODE_INFORMATION: 0x01, 0x07, 0x00, 0x03, 0x01, 0x02, 0x01, 0x00, 0xf9
2020-12-28 11:36:06.732 Detail, Node026, Expected reply was received
2020-12-28 11:36:06.732 Detail, Node026, Message transaction complete
2020-12-28 11:36:06.732 Detail, contrlr, Removing current message
2020-12-28 11:36:06.732 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x56) - FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2020-12-28 11:36:06.734 Detail, contrlr, Received: 0x01, 0x04, 0x01, 0x56, 0x00, 0xac
2020-12-28 11:36:06.734 Info, contrlr, Received reply to GET_SUC_NODE_ID. Node ID = 0
2020-12-28 11:36:06.734 Info, Controller Does not Support SUC - Cannot Setup Controller as SUC Node
2020-12-28 11:36:06.734 Detail, Node172, Expected reply was received
2020-12-28 11:36:06.734 Detail, Node172, Message transaction complete
2020-12-28 11:36:06.734 Detail, contrlr, Removing current message
2020-12-28 11:36:06.734 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x1c) - FUNC_ID_ZW_GET_RANDOM: 0x01, 0x04, 0x00, 0x1c, 0x20, 0xc7
2020-12-28 11:36:06.787 Detail, contrlr, Received: 0x01, 0x25, 0x01, 0x1c, 0x01, 0x20, 0x66, 0xa5, 0xfd, 0x86, 0x75, 0xde, 0xeb, 0x53, 0x20, 0x77, 0xd4, 0x94, 0x0a, 0xff, 0x7d, 0xca, 0xf9, 0x79, 0x03, 0x28, 0x17, 0x54, 0x4e, 0xa9, 0x69, 0x9c, 0xcf, 0xb1, 0x3d, 0xe4, 0x68, 0xd0, 0xfd
2020-12-28 11:36:06.787 Info, contrlr, Received reply to FUNC_ID_ZW_GET_RANDOM: true
2020-12-28 11:36:06.787 Detail, Node032, Expected reply was received
2020-12-28 11:36:06.787 Detail, Node032, Message transaction complete
2020-12-28 11:36:06.787 Detail, contrlr, Removing current message
2020-12-28 11:36:06.787 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x02) - FUNC_ID_SERIAL_API_GET_INIT_DATA: 0x01, 0x03, 0x00, 0x02, 0xfe
2020-12-28 11:36:06.845 Detail, contrlr, Received: 0x01, 0x25, 0x01, 0x02, 0x05, 0x00, 0x1d, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x05, 0x00, 0xc5
2020-12-28 11:36:06.845 Info, mgr, Driver with Home ID of 0xcc4a366b is now ready.
2020-12-28 11:36:06.846 Info, contrlr, Received reply to FUNC_ID_SERIAL_API_GET_INIT_DATA:
2020-12-28 11:36:06.846 Info, contrlr, Node 001 - Known
2020-12-28 11:36:06.846 Detail, Node001, AdvanceQueries queryPending=0 queryRetries=0 queryStage=CacheLoad live=1
2020-12-28 11:36:06.846 Detail, Node001, QueryStage_CacheLoad
2020-12-28 11:36:06.846 Info, Node001, Node Identity Codes: 0000:0001:0001
2020-12-28 11:36:06.846 Detail, Node001, QueryStage_Associations
2020-12-28 11:36:06.846 Detail, Node001, QueryStage_Neighbors
2020-12-28 11:36:06.846 Detail, contrlr, Requesting routing info (neighbor list) for Node 1
2020-12-28 11:36:06.846 Detail, Node001, Queuing (Command) Get Routing Info (Node=1): 0x01, 0x07, 0x00, 0x80, 0x01, 0x00, 0x00, 0x03, 0x7a
2020-12-28 11:36:06.846 Detail, Node001, Queuing (Query) Query Stage Complete (Neighbors)
2020-12-28 11:36:06.846 Detail, Expected reply was received
2020-12-28 11:36:06.846 Detail, Message transaction complete
2020-12-28 11:36:06.846 Detail, contrlr, Removing current message
2020-12-28 11:36:06.846 Detail, Node001, Notification: DriverReady
2020-12-28 11:36:06.854 Detail, Node001, Notification: NodeAdded
2020-12-28 11:36:06.857 Detail, Node001, Notification: NodeProtocolInfo
2020-12-28 11:36:06.859 Detail, Node001, Notification: EssentialNodeQueriesComplete
2020-12-28 11:36:06.861 Detail, Node001, Notification: ValueAdded
2020-12-28 11:36:06.865 Detail, Node001, Notification: NodeNaming
2020-12-28 11:36:06.867 Detail,
2020-12-28 11:36:06.867 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x06) - FUNC_ID_SERIAL_API_SET_TIMEOUTS: 0x01, 0x05, 0x00, 0x06, 0x64, 0x0f, 0x97
2020-12-28 11:36:06.868 Detail, contrlr, Received: 0x01, 0x05, 0x01, 0x06, 0x64, 0x0f, 0x96
2020-12-28 11:36:06.868 Info, contrlr, Received reply to FUNC_ID_SERIAL_API_SET_TIMEOUTS
2020-12-28 11:36:06.868 Detail, Node015, Expected reply was received
2020-12-28 11:36:06.868 Detail, Node015, Message transaction complete
2020-12-28 11:36:06.869 Detail,
2020-12-28 11:36:06.869 Detail, contrlr, Removing current message
2020-12-28 11:36:06.869 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x00) - FUNC_ID_SERIAL_API_APPL_NODE_INFORMATION: 0x01, 0x07, 0x00, 0x03, 0x01, 0x02, 0x01, 0x00, 0xf9
2020-12-28 11:36:06.870 Detail, contrlr, Removing current message
2020-12-28 11:36:06.870 Info, Node001, Sending (Command) message (Callback ID=0x00, Expected Reply=0x80) - Get Routing Info (Node=1): 0x01, 0x07, 0x00, 0x80, 0x01, 0x00, 0x00, 0x03, 0x7a
2020-12-28 11:36:06.875 Detail, Node001, Received: 0x01, 0x20, 0x01, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x5e
2020-12-28 11:36:06.875 Info, Node001, Received reply to FUNC_ID_ZW_GET_ROUTING_INFO
2020-12-28 11:36:06.875 Info, Node001, Neighbors of this node are:
2020-12-28 11:36:06.875 Info, Node001, (none reported)
2020-12-28 11:36:06.875 Detail, Expected reply was received
2020-12-28 11:36:06.875 Detail, Message transaction complete
2020-12-28 11:36:06.875 Detail, Node001, Removing current message
2020-12-28 11:36:06.875 Detail, Node001, Query Stage Complete (Neighbors)
2020-12-28 11:36:06.875 Detail, Node001, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Session live=1
2020-12-28 11:36:06.875 Detail, Node001, QueryStage_Session
2020-12-28 11:36:06.875 Detail, Node001, QueryStage_Dynamic
2020-12-28 11:36:06.875 Detail, Node001, QueryStage_Configuration
2020-12-28 11:36:06.875 Detail, Node001, QueryStage_Complete
2020-12-28 11:36:06.875 Warning, CheckCompletedNodeQueries m_allNodesQueried=0 m_awakeNodesQueried=0
2020-12-28 11:36:06.875 Warning, CheckCompletedNodeQueries all=1, deadFound=0 sleepingOnly=1
2020-12-28 11:36:06.875 Info, Node query processing complete.
2020-12-28 11:36:06.875 Detail, Node001, Notification: NodeQueriesComplete
2020-12-28 11:36:06.878 Detail, contrlr, Notification: AllNodesQueried
2020-12-28 11:36:06.881 Info, mgr, Manager::WriteConfig completed for driver with home ID of 0xcc4a366b
2020-12-28 11:36:36.268 Detail, Queuing (Controller) Add Device
2020-12-28 11:36:36.268 Info, Add Device
2020-12-28 11:36:36.268 Detail, contrlr, Queuing (Command) ControllerCommand_AddDevice: 0x01, 0x05, 0x00, 0x4a, 0xc1, 0x0a, 0x7b
2020-12-28 11:36:36.268 Detail, Notification: ControllerCommand - Starting
2020-12-28 11:36:36.272 Detail,
2020-12-28 11:36:36.272 Info, contrlr, Sending (Command) message (Callback ID=0x0a, Expected Reply=0x4a) - ControllerCommand_AddDevice: 0x01, 0x05, 0x00, 0x4a, 0xc1, 0x0a, 0x7b
2020-12-28 11:36:36.275 Detail, contrlr, Received: 0x01, 0x07, 0x00, 0x4a, 0x0a, 0x01, 0x00, 0x00, 0xb9
2020-12-28 11:36:36.275 Info, contrlr, FUNC_ID_ZW_ADD_NODE_TO_NETWORK:
2020-12-28 11:36:36.275 Info, contrlr, ADD_NODE_STATUS_LEARN_READY
2020-12-28 11:36:36.275 Detail, Node001, Expected callbackId was received
2020-12-28 11:36:36.275 Detail, Node001, Expected reply was received
2020-12-28 11:36:36.275 Detail, Node001, Message transaction complete
2020-12-28 11:36:36.275 Detail, contrlr, Removing current message
2020-12-28 11:36:36.275 Detail, Notification: ControllerCommand - Waiting
2020-12-28 11:56:44.644 Info, Cancel Add Node
2020-12-28 11:56:44.644 Detail, contrlr, Queuing (Command) Add Node Stop: 0x01, 0x04, 0x00, 0x4a, 0x05, 0xb4
2020-12-28 11:56:44.648 Detail, Notification: ControllerCommand - Canceled
2020-12-28 11:56:44.651 Detail,
2020-12-28 11:56:44.651 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x4a) - Add Node Stop: 0x01, 0x04, 0x00, 0x4a, 0x05, 0xb4
2020-12-28 11:56:44.703 Detail, contrlr, Received: 0x01, 0x07, 0x00, 0x4a, 0x0a, 0x06, 0x00, 0x00, 0xbe
2020-12-28 11:56:44.703 Info, contrlr, FUNC_ID_ZW_ADD_NODE_TO_NETWORK:
2020-12-28 11:56:44.703 Info, contrlr, ADD_NODE_STATUS_DONE
2020-12-28 11:56:44.703 Detail, Node006, Expected reply was received
2020-12-28 11:56:44.703 Detail, Node006, Message transaction complete
2020-12-28 11:56:44.703 Detail, contrlr, Removing current message
2020-12-28 11:56:44.703 Detail, Notification: ControllerCommand - Completed
2020-12-28 11:56:51.997 Detail, Queuing (Controller) Add Device
2020-12-28 11:56:51.997 Info, Add Device
2020-12-28 11:56:51.997 Detail, contrlr, Queuing (Command) ControllerCommand_AddDevice: 0x01, 0x05, 0x00, 0x4a, 0xc1, 0x0b, 0x7a
2020-12-28 11:56:51.997 Detail, Notification: ControllerCommand - Starting
2020-12-28 11:56:52.004 Detail,
2020-12-28 11:56:52.004 Info, contrlr, Sending (Command) message (Callback ID=0x0b, Expected Reply=0x4a) - ControllerCommand_AddDevice: 0x01, 0x05, 0x00, 0x4a, 0xc1, 0x0b, 0x7a
2020-12-28 11:56:52.007 Detail, contrlr, Received: 0x01, 0x07, 0x00, 0x4a, 0x0b, 0x01, 0x00, 0x00, 0xb8
2020-12-28 11:56:52.007 Info, contrlr, FUNC_ID_ZW_ADD_NODE_TO_NETWORK:
2020-12-28 11:56:52.007 Info, contrlr, ADD_NODE_STATUS_LEARN_READY
2020-12-28 11:56:52.007 Detail, Node001, Expected callbackId was received
2020-12-28 11:56:52.007 Detail, Node001, Expected reply was received
2020-12-28 11:56:52.007 Detail, Node001, Message transaction complete
2020-12-28 11:56:52.007 Detail, contrlr, Removing current message
2020-12-28 11:56:52.007 Detail, Notification: ControllerCommand - Waiting
Franchement, je ne vois pas.
Ton log ne signale rien de spécial ou alors je suis passé à côté.
Une inclusion est demandée mais rien ne remonte.
Ta clé est correctement vue.
Peut-être un périphérique défectueux mais sans plus de conviction.
Ce n’est parce qu’il est sous blister qu’il fonctionne forcément. Il faut tester pour en être sûr.
Tu peux également ouvrir un ticket au support technique pour ta smart, peut-être auront-ils une idée.
Désolé
