Est-ce que c’est le log demandé ?
__import__(modulename, globals(), locals(), level=0)
File "", line 983, in _find_and_load
File "", line 967, in _find_and_load_unlocked
File "", line 668, in _load_unlocked
File "", line 638, in _load_backward_compatible
File "/usr/share/python-wheels/CacheControl-0.11.7-py2.py3-none-any.whl/cachecontrol/__init__.py", line 9, in
File "/usr/share/python-wheels/CacheControl-0.11.7-py2.py3-none-any.whl/cachecontrol/wrapper.py", line 1, in
File "/usr/share/python-wheels/CacheControl-0.11.7-py2.py3-none-any.whl/cachecontrol/adapter.py", line 4, in
File "/usr/share/python-wheels/requests-2.21.0-py2.py3-none-any.whl/requests/__init__.py", line 95, in
File "/usr/share/python-wheels/urllib3-1.24.1-py2.py3-none-any.whl/urllib3/contrib/pyopenssl.py", line 46, in
File "/usr/lib/python3/dist-packages/OpenSSL/__init__.py", line 8, in
from OpenSSL import crypto, SSL
File "/usr/lib/python3/dist-packages/OpenSSL/crypto.py", line 1553, in
class X509StoreFlags(object):
File "/usr/lib/python3/dist-packages/OpenSSL/crypto.py", line 1573, in X509StoreFlags
CB_ISSUER_CHECK = _lib.X509_V_FLAG_CB_ISSUER_CHECK
AttributeError: module 'lib' has no attribute 'X509_V_FLAG_CB_ISSUER_CHECK'
+ echo 15
+ sudo pip3 install --force-reinstall --upgrade zigpy-xbee==0.15.0
File "/usr/lib/python3/dist-packages/pip/_vendor/__init__.py", line 33, in vendored
__import__(vendored_name, globals(), locals(), level=0)
ModuleNotFoundError: No module named 'pip._vendor.cachecontrol'
During handling of the above exception, another exception occurred:
File "/usr/bin/pip3", line 9, in
from pip._internal import main
File "/usr/lib/python3/dist-packages/pip/_internal/__init__.py", line 19, in
from pip._vendor.urllib3.exceptions import DependencyWarning
File "/usr/lib/python3/dist-packages/pip/_vendor/__init__.py", line 64, in
vendored("cachecontrol")
File "/usr/lib/python3/dist-packages/pip/_vendor/__init__.py", line 36, in vendored
+ echo 16
+ sudo pip3 install --force-reinstall --upgrade zigpy-deconz==0.18.1
+ echo 17
+ sudo pip3 install --force-reinstall --upgrade zigpy-zigate==0.9.2
+ echo 18
+ sudo pip3 install --force-reinstall --upgrade bellows==0.33.1
+ echo 19
+ sudo pip3 install --force-reinstall --upgrade zigpy==0.50.3
+ echo 20
+ sudo pip3 install --force-reinstall --upgrade xmodem
+ echo 21
+ sudo pip3 install --force-reinstall --upgrade pycrypto
+ echo 22
+ sudo pip3 install --force-reinstall --upgrade charset-normalizer==2.0.12
+ echo 23
+ sudo pip3 install --force-reinstall --upgrade yarl==1.4.2
+ echo 24
+ sudo chmod +x /var/www/html/core/class/../../plugins/zigbee/resources/post-install.sh
+ sudo /var/www/html/core/class/../../plugins/zigbee/resources/post-install.sh
Launch post-install of zigbee dependancy
grep: /usr/local/lib/python3.7/dist-packages/bellows/zigbee/application.py: No such file or directory
/var/www/html/core/class/../../plugins/zigbee/resources/post-install.sh: line 24: [: -eq: unary operator expected
grep: /usr/local/lib/python3.8/dist-packages/bellows/zigbee/application.py: No such file or directory
/var/www/html/core/class/../../plugins/zigbee/resources/post-install.sh: line 29: [: -eq: unary operator expected
grep: /usr/local/lib/python3.9/dist-packages/bellows/zigbee/application.py: No such file or directory
/var/www/html/core/class/../../plugins/zigbee/resources/post-install.sh: line 35: [: -eq: unary operator expected
Cleaning rustc
Everything is successfully installed!
+ echo 25
+ php /var/www/html/core/class/../php/jeecli.php plugin dependancy_end zigbee
+ rm /tmp/jeedom_install_in_progress_zigbee
