J’y ai cru…
WARNING: Error parsing requirements for voluptuous: [Errno 2] No such file or directory: '/usr/local/lib/python3.7/dist-packages/voluptuous-0.13.1.dist-info/METADATA'
Installing collected packages: pyserial, crccheck, zipp, voluptuous, typing-extensions, pyserial-asyncio, pyrsistent, pycparser, pkgutil-resolve-name, multidict, idna, humanfriendly, frozenlist, charset-normalizer, asynctest, yarl, importlib-resources, importlib-metadata, coloredlogs, cffi, async-timeout, aiosqlite, aiosignal, cryptography, attrs, jsonschema, aiohttp, zigpy, zigpy-znp
Attempting uninstall: pyserial
Found existing installation: pyserial 3.5
Uninstalling pyserial-3.5:
Successfully uninstalled pyserial-3.5
Attempting uninstall: crccheck
Found existing installation: crccheck 1.3.0
Uninstalling crccheck-1.3.0:
Successfully uninstalled crccheck-1.3.0
Attempting uninstall: zipp
Found existing installation: zipp 3.15.0
Uninstalling zipp-3.15.0:
Successfully uninstalled zipp-3.15.0
Attempting uninstall: voluptuous
WARNING: No metadata found in /usr/local/lib/python3.7/dist-packages
Found existing installation: voluptuous 0.13.1
ERROR: Cannot uninstall voluptuous 0.13.1, RECORD file not found. You might be able to recover from this via: 'pip install --force-reinstall --no-deps voluptuous==0.13.1'.
+ echo 15
+ sudo pip3 install --force-reinstall --upgrade zigpy-xbee==0.15.0
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Collecting zigpy-xbee==0.15.0
Downloading https://www.piwheels.org/simple/zigpy-xbee/zigpy_xbee-0.15.0-py3-none-any.whl (40 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 40.9/40.9 kB 1.4 MB/s eta 0:00:00
Collecting pyserial-asyncio (from zigpy-xbee==0.15.0)
Using cached https://www.piwheels.org/simple/pyserial-asyncio/pyserial_asyncio-0.6-py3-none-any.whl (7.5 kB)
Collecting zigpy>=0.47.0 (from zigpy-xbee==0.15.0)
Using cached https://www.piwheels.org/simple/zigpy/zigpy-0.51.6-py3-none-any.whl (153 kB)
Collecting aiohttp (from zigpy>=0.47.0->zigpy-xbee==0.15.0)
Using cached aiohttp-3.8.6-cp37-cp37m-manylinux_2_17_aarch64.manylinux2014_aarch64.whl.metadata (7.7 kB)
Collecting aiosqlite>=0.16.0 (from zigpy>=0.47.0->zigpy-xbee==0.15.0)
Using cached https://www.piwheels.org/simple/aiosqlite/aiosqlite-0.19.0-py3-none-any.whl (15 kB)
Collecting crccheck (from zigpy>=0.47.0->zigpy-xbee==0.15.0)
Using cached https://www.piwheels.org/simple/crccheck/crccheck-1.3.0-py3-none-any.whl (21 kB)
Collecting cryptography (from zigpy>=0.47.0->zigpy-xbee==0.15.0)
Using cached cryptography-41.0.7-cp37-abi3-manylinux_2_28_aarch64.whl.metadata (5.2 kB)
Collecting voluptuous (from zigpy>=0.47.0->zigpy-xbee==0.15.0)
Using cached https://www.piwheels.org/simple/voluptuous/voluptuous-0.14.1-py3-none-any.whl (30 kB)
Collecting yarl (from zigpy>=0.47.0->zigpy-xbee==0.15.0)
Using cached yarl-1.9.4-cp37-cp37m-manylinux_2_17_aarch64.manylinux2014_aarch64.whl.metadata (31 kB)
Collecting pyserial (from pyserial-asyncio->zigpy-xbee==0.15.0)
Using cached https://www.piwheels.org/simple/pyserial/pyserial-3.5-py2.py3-none-any.whl (90 kB)
Collecting typing_extensions>=4.0 (from aiosqlite>=0.16.0->zigpy>=0.47.0->zigpy-xbee==0.15.0)
Using cached https://www.piwheels.org/simple/typing-extensions/typing_extensions-4.7.1-py3-none-any.whl (33 kB)
Collecting attrs>=17.3.0 (from aiohttp->zigpy>=0.47.0->zigpy-xbee==0.15.0)
Using cached https://www.piwheels.org/simple/attrs/attrs-23.2.0-py3-none-any.whl (60 kB)
Collecting charset-normalizer<4.0,>=2.0 (from aiohttp->zigpy>=0.47.0->zigpy-xbee==0.15.0)
Using cached charset_normalizer-3.3.2-cp37-cp37m-manylinux_2_17_aarch64.manylinux2014_aarch64.whl.metadata (33 kB)
Collecting multidict<7.0,>=4.5 (from aiohttp->zigpy>=0.47.0->zigpy-xbee==0.15.0)
Using cached multidict-6.0.4-cp37-cp37m-manylinux_2_17_aarch64.manylinux2014_aarch64.whl (96 kB)
Collecting async-timeout<5.0,>=4.0.0a3 (from aiohttp->zigpy>=0.47.0->zigpy-xbee==0.15.0)
Using cached https://www.piwheels.org/simple/async-timeout/async_timeout-4.0.3-py3-none-any.whl (5.7 kB)
Collecting frozenlist>=1.1.1 (from aiohttp->zigpy>=0.47.0->zigpy-xbee==0.15.0)
Using cached frozenlist-1.3.3-cp37-cp37m-manylinux_2_17_aarch64.manylinux2014_aarch64.whl (147 kB)
Collecting aiosignal>=1.1.2 (from aiohttp->zigpy>=0.47.0->zigpy-xbee==0.15.0)
Using cached https://www.piwheels.org/simple/aiosignal/aiosignal-1.3.1-py3-none-any.whl (7.6 kB)
Collecting asynctest==0.13.0 (from aiohttp->zigpy>=0.47.0->zigpy-xbee==0.15.0)
Using cached https://www.piwheels.org/simple/asynctest/asynctest-0.13.0-py3-none-any.whl (26 kB)
Collecting idna>=2.0 (from yarl->zigpy>=0.47.0->zigpy-xbee==0.15.0)
Using cached https://www.piwheels.org/simple/idna/idna-3.6-py3-none-any.whl (61 kB)
Collecting cffi>=1.12 (from cryptography->zigpy>=0.47.0->zigpy-xbee==0.15.0)
Using cached cffi-1.15.1-cp37-cp37m-manylinux_2_17_aarch64.manylinux2014_aarch64.whl (435 kB)
Collecting importlib-metadata (from attrs>=17.3.0->aiohttp->zigpy>=0.47.0->zigpy-xbee==0.15.0)
Using cached https://www.piwheels.org/simple/importlib-metadata/importlib_metadata-6.7.0-py3-none-any.whl (22 kB)
Collecting pycparser (from cffi>=1.12->cryptography->zigpy>=0.47.0->zigpy-xbee==0.15.0)
Using cached https://www.piwheels.org/simple/pycparser/pycparser-2.21-py2.py3-none-any.whl (119 kB)
Collecting zipp>=0.5 (from importlib-metadata->attrs>=17.3.0->aiohttp->zigpy>=0.47.0->zigpy-xbee==0.15.0)
Using cached https://www.piwheels.org/simple/zipp/zipp-3.15.0-py3-none-any.whl (6.8 kB)
Using cached aiohttp-3.8.6-cp37-cp37m-manylinux_2_17_aarch64.manylinux2014_aarch64.whl (990 kB)
Using cached yarl-1.9.4-cp37-cp37m-manylinux_2_17_aarch64.manylinux2014_aarch64.whl (286 kB)
Using cached cryptography-41.0.7-cp37-abi3-manylinux_2_28_aarch64.whl (4.1 MB)
Using cached charset_normalizer-3.3.2-cp37-cp37m-manylinux_2_17_aarch64.manylinux2014_aarch64.whl (133 kB)
WARNING: Error parsing requirements for idna: [Errno 2] No such file or directory: '/usr/local/lib/python3.7/dist-packages/idna-3.3.dist-info/METADATA'
WARNING: Error parsing requirements for pyudev: [Errno 2] No such file or directory: '/usr/local/lib/python3.7/dist-packages/pyudev-0.23.2.dist-info/METADATA'
Installing collected packages: pyserial, crccheck, zipp, voluptuous, typing_extensions, pyserial-asyncio, pycparser, multidict, idna, frozenlist, charset-normalizer, asynctest, yarl, importlib-metadata, cffi, async-timeout, aiosqlite, aiosignal, cryptography, attrs, aiohttp, zigpy, zigpy-xbee
+ echo 16
+ sudo pip3 install --force-reinstall --upgrade zigpy-deconz==0.18.1
Collecting zigpy-deconz==0.18.1
Downloading https://www.piwheels.org/simple/zigpy-deconz/zigpy_deconz-0.18.1-py3-none-any.whl (31 kB)
Collecting pyserial-asyncio (from zigpy-deconz==0.18.1)
Collecting zigpy>=0.47.0 (from zigpy-deconz==0.18.1)
Collecting aiohttp (from zigpy>=0.47.0->zigpy-deconz==0.18.1)
Collecting aiosqlite>=0.16.0 (from zigpy>=0.47.0->zigpy-deconz==0.18.1)
Collecting crccheck (from zigpy>=0.47.0->zigpy-deconz==0.18.1)
Collecting cryptography (from zigpy>=0.47.0->zigpy-deconz==0.18.1)
Collecting voluptuous (from zigpy>=0.47.0->zigpy-deconz==0.18.1)
Collecting yarl (from zigpy>=0.47.0->zigpy-deconz==0.18.1)
Collecting pyserial (from pyserial-asyncio->zigpy-deconz==0.18.1)
Collecting typing_extensions>=4.0 (from aiosqlite>=0.16.0->zigpy>=0.47.0->zigpy-deconz==0.18.1)
Collecting attrs>=17.3.0 (from aiohttp->zigpy>=0.47.0->zigpy-deconz==0.18.1)
Collecting charset-normalizer<4.0,>=2.0 (from aiohttp->zigpy>=0.47.0->zigpy-deconz==0.18.1)
Collecting multidict<7.0,>=4.5 (from aiohttp->zigpy>=0.47.0->zigpy-deconz==0.18.1)
Collecting async-timeout<5.0,>=4.0.0a3 (from aiohttp->zigpy>=0.47.0->zigpy-deconz==0.18.1)
Collecting frozenlist>=1.1.1 (from aiohttp->zigpy>=0.47.0->zigpy-deconz==0.18.1)
Collecting aiosignal>=1.1.2 (from aiohttp->zigpy>=0.47.0->zigpy-deconz==0.18.1)
Collecting asynctest==0.13.0 (from aiohttp->zigpy>=0.47.0->zigpy-deconz==0.18.1)
Collecting idna>=2.0 (from yarl->zigpy>=0.47.0->zigpy-deconz==0.18.1)
Collecting cffi>=1.12 (from cryptography->zigpy>=0.47.0->zigpy-deconz==0.18.1)
Collecting importlib-metadata (from attrs>=17.3.0->aiohttp->zigpy>=0.47.0->zigpy-deconz==0.18.1)
Collecting pycparser (from cffi>=1.12->cryptography->zigpy>=0.47.0->zigpy-deconz==0.18.1)
Collecting zipp>=0.5 (from importlib-metadata->attrs>=17.3.0->aiohttp->zigpy>=0.47.0->zigpy-deconz==0.18.1)
Installing collected packages: pyserial, crccheck, zipp, voluptuous, typing_extensions, pyserial-asyncio, pycparser, multidict, idna, frozenlist, charset-normalizer, asynctest, yarl, importlib-metadata, cffi, async-timeout, aiosqlite, aiosignal, cryptography, attrs, aiohttp, zigpy, zigpy-deconz
+ echo 17
+ sudo pip3 install --force-reinstall --upgrade zigpy-zigate==0.9.2
Collecting zigpy-zigate==0.9.2
Downloading https://www.piwheels.org/simple/zigpy-zigate/zigpy_zigate-0.9.2-py3-none-any.whl (39 kB)
Collecting pyserial>=3.5 (from zigpy-zigate==0.9.2)
Collecting pyusb>=1.1.0 (from zigpy-zigate==0.9.2)
Downloading https://www.piwheels.org/simple/pyusb/pyusb-1.2.1-py3-none-any.whl (58 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 58.4/58.4 kB 490.3 kB/s eta 0:00:00
Collecting zigpy>=0.47.0 (from zigpy-zigate==0.9.2)
Collecting gpiozero (from zigpy-zigate==0.9.2)
Downloading https://www.piwheels.org/simple/gpiozero/gpiozero-2.0-py3-none-any.whl (150 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 150.5/150.5 kB 1.3 MB/s eta 0:00:00
Collecting pyserial-asyncio>=0.5 (from zigpy-zigate==0.9.2)
Collecting aiohttp (from zigpy>=0.47.0->zigpy-zigate==0.9.2)
Collecting aiosqlite>=0.16.0 (from zigpy>=0.47.0->zigpy-zigate==0.9.2)
Collecting crccheck (from zigpy>=0.47.0->zigpy-zigate==0.9.2)
Collecting cryptography (from zigpy>=0.47.0->zigpy-zigate==0.9.2)
Collecting voluptuous (from zigpy>=0.47.0->zigpy-zigate==0.9.2)
Collecting yarl (from zigpy>=0.47.0->zigpy-zigate==0.9.2)
Collecting colorzero (from gpiozero->zigpy-zigate==0.9.2)
Downloading https://www.piwheels.org/simple/colorzero/colorzero-2.0-py2.py3-none-any.whl (26 kB)
Collecting typing_extensions>=4.0 (from aiosqlite>=0.16.0->zigpy>=0.47.0->zigpy-zigate==0.9.2)
Collecting attrs>=17.3.0 (from aiohttp->zigpy>=0.47.0->zigpy-zigate==0.9.2)
Collecting charset-normalizer<4.0,>=2.0 (from aiohttp->zigpy>=0.47.0->zigpy-zigate==0.9.2)
Collecting multidict<7.0,>=4.5 (from aiohttp->zigpy>=0.47.0->zigpy-zigate==0.9.2)
Collecting async-timeout<5.0,>=4.0.0a3 (from aiohttp->zigpy>=0.47.0->zigpy-zigate==0.9.2)
Collecting frozenlist>=1.1.1 (from aiohttp->zigpy>=0.47.0->zigpy-zigate==0.9.2)
Collecting aiosignal>=1.1.2 (from aiohttp->zigpy>=0.47.0->zigpy-zigate==0.9.2)
Collecting asynctest==0.13.0 (from aiohttp->zigpy>=0.47.0->zigpy-zigate==0.9.2)
Collecting idna>=2.0 (from yarl->zigpy>=0.47.0->zigpy-zigate==0.9.2)
Collecting setuptools (from colorzero->gpiozero->zigpy-zigate==0.9.2)
Using cached https://www.piwheels.org/simple/setuptools/setuptools-68.0.0-py3-none-any.whl (804 kB)
Collecting cffi>=1.12 (from cryptography->zigpy>=0.47.0->zigpy-zigate==0.9.2)
Collecting importlib-metadata (from attrs>=17.3.0->aiohttp->zigpy>=0.47.0->zigpy-zigate==0.9.2)
Collecting pycparser (from cffi>=1.12->cryptography->zigpy>=0.47.0->zigpy-zigate==0.9.2)
Collecting zipp>=0.5 (from importlib-metadata->attrs>=17.3.0->aiohttp->zigpy>=0.47.0->zigpy-zigate==0.9.2)
Installing collected packages: pyserial, crccheck, zipp, voluptuous, typing_extensions, setuptools, pyusb, pyserial-asyncio, pycparser, multidict, idna, frozenlist, charset-normalizer, asynctest, yarl, importlib-metadata, colorzero, cffi, async-timeout, aiosqlite, aiosignal, gpiozero, cryptography, attrs, aiohttp, zigpy, zigpy-zigate
+ echo 18
+ sudo pip3 install --force-reinstall --upgrade bellows==0.33.1
Collecting bellows==0.33.1
Downloading https://www.piwheels.org/simple/bellows/bellows-0.33.1-py3-none-any.whl (194 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 194.2/194.2 kB 610.6 kB/s eta 0:00:00
Collecting click (from bellows==0.33.1)
Downloading https://www.piwheels.org/simple/click/click-8.1.7-py3-none-any.whl (97 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 97.9/97.9 kB 4.6 MB/s eta 0:00:00
Collecting click-log>=0.2.1 (from bellows==0.33.1)
Downloading https://www.piwheels.org/simple/click-log/click_log-0.4.0-py2.py3-none-any.whl (4.5 kB)
Collecting pure-pcapy3==1.0.1 (from bellows==0.33.1)
Downloading https://www.piwheels.org/simple/pure-pcapy3/pure_pcapy3-1.0.1-py3-none-any.whl (6.1 kB)
Collecting pyserial (from bellows==0.33.1)
Collecting pyserial-asyncio (from bellows==0.33.1)
Collecting voluptuous (from bellows==0.33.1)
Collecting zigpy>=0.50.0 (from bellows==0.33.1)
Collecting setuptools (from pure-pcapy3==1.0.1->bellows==0.33.1)
Collecting aiohttp (from zigpy>=0.50.0->bellows==0.33.1)
Collecting aiosqlite>=0.16.0 (from zigpy>=0.50.0->bellows==0.33.1)
Collecting crccheck (from zigpy>=0.50.0->bellows==0.33.1)
Collecting cryptography (from zigpy>=0.50.0->bellows==0.33.1)
Collecting yarl (from zigpy>=0.50.0->bellows==0.33.1)
Collecting importlib-metadata (from click->bellows==0.33.1)
Collecting typing_extensions>=4.0 (from aiosqlite>=0.16.0->zigpy>=0.50.0->bellows==0.33.1)
Collecting attrs>=17.3.0 (from aiohttp->zigpy>=0.50.0->bellows==0.33.1)
Collecting charset-normalizer<4.0,>=2.0 (from aiohttp->zigpy>=0.50.0->bellows==0.33.1)
Collecting multidict<7.0,>=4.5 (from aiohttp->zigpy>=0.50.0->bellows==0.33.1)
Collecting async-timeout<5.0,>=4.0.0a3 (from aiohttp->zigpy>=0.50.0->bellows==0.33.1)
Collecting frozenlist>=1.1.1 (from aiohttp->zigpy>=0.50.0->bellows==0.33.1)
Collecting aiosignal>=1.1.2 (from aiohttp->zigpy>=0.50.0->bellows==0.33.1)
Collecting asynctest==0.13.0 (from aiohttp->zigpy>=0.50.0->bellows==0.33.1)
Collecting idna>=2.0 (from yarl->zigpy>=0.50.0->bellows==0.33.1)
Collecting cffi>=1.12 (from cryptography->zigpy>=0.50.0->bellows==0.33.1)
Collecting zipp>=0.5 (from importlib-metadata->click->bellows==0.33.1)
Collecting pycparser (from cffi>=1.12->cryptography->zigpy>=0.50.0->bellows==0.33.1)
Installing collected packages: pyserial, crccheck, zipp, voluptuous, typing_extensions, setuptools, pyserial-asyncio, pycparser, multidict, idna, frozenlist, charset-normalizer, asynctest, yarl, pure-pcapy3, importlib-metadata, cffi, async-timeout, aiosqlite, aiosignal, cryptography, click, attrs, click-log, aiohttp, zigpy, bellows
+ echo 19
+ sudo pip3 install --force-reinstall --upgrade zigpy==0.50.3
Collecting zigpy==0.50.3
Downloading https://www.piwheels.org/simple/zigpy/zigpy-0.50.3-py3-none-any.whl (143 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 143.1/143.1 kB 443.7 kB/s eta 0:00:00
