Ah ouais effectivement sans code
<div style="min-width:115px;min-height:100px;position: relative; top : -7px;padding:0px !important;" class="container-fluid cmd cmd-widget" data-type="info" data-subtype="numeric" data-cmd_id="#id#" data-cmd_uid="#uid#" data-version="#version#" >
<div style="width:115px;height : 90px;" class="gauge cursor"></div>
<span style="#displayHistory#" class="col-xs-12 center-block cmdStats"></span>
<span class="timeCmd#uid# center-block" style="text-align: center;font-size:12px;padding : 3px;border-radius: 4px;"></span>
<script>
// couleur(black) = "white,gray,gray,gray,#999999,white,#ccd6eb,#006ca9,gray,#fff,#006CA9,red";
// couleur(default) = "white,WhiteSmoke,WhiteSmoke,WhiteSmoke,WhiteSmoke,WhiteSmoke,WhiteSmoke,green,gray,WhiteSmoke,#006CA9,red";
testdecimal = ("#decimal#" == '#'+'decimal#');
if (testdecimal == true) {
var dec#id# = parseFloat(1);
} else {
var dec#id# = parseFloat('#decimal#');
min_max = ("#min_max#" == '#'+'min_max#');
if (min_max == true) {
var mini#id# = #minValue#;
var max#id# = #maxValue#;
} else {
var min_max = '#min_max#' ;
var min_max_liste = min_max.split(",");
var mini#id# = parseFloat(min_max_liste[0]);
var max#id# = parseFloat(min_max_liste[1]);
testinterval = ("#interval#" == '#'+'interval#');
if (testinterval == true) {
var tick_Interval#id# = Math.abs(Math.round(((#minValue# - #maxValue# )+1)/3)) ;
} else {
var tick_Interval#id# = '#interval#';
testcolor = ("#couleur#" == '#'+'couleur#');
if (testcolor == true) {
var couleur = "white,WhiteSmoke,WhiteSmoke,WhiteSmoke,WhiteSmoke,WhiteSmoke,WhiteSmoke";
} else {
var couleur = '#couleur#' ;
var couleurListe = couleur.split(",");
var color_value#id# = (couleurListe[0]) ;
var color_unite#id# = (couleurListe[1]) ;
var color_time#id# = (couleurListe[2]) ;
var color_tickColor#id# = (couleurListe[3]) ;
var color_minorTick#id# = (couleurListe[4]) ;
var color_tick_label_Color#id# = (couleurListe[5]) ;
var color_line#id# = (couleurListe[6]) ;
// tooltip
var color_bord#id# = '#006ca9'; // bordure / 6
var color_valueDate#id# = 'gray' ; // le temps en date / 7
var color_background#id# = '#fff' ; // le fond / 8
// config
var tick_Interval#id# = '3'; // default 3
testcolors = ("#couleur_jauge#" == '#'+'couleur_jauge#');
if (testcolors == true) {
var couleurs = "Cyan,green,yellow,orange,OrangeRed";
} else {
var couleurs = '#couleur_jauge#' ;
var couleursListe = couleurs.split(",");
var color_A#id# = (couleursListe[0]) ;
var color_B#id# = (couleursListe[1]) ;
var color_C#id# = (couleursListe[2]) ;
var color_D#id# = (couleursListe[3]) ;
var color_E#id# = (couleursListe[4]) ;
$('.timeCmd#uid#').css('color', color_time#id#);
// actualisation
jeedom.cmd.displayDuration(_options.valueDate, $('.cmd[data-cmd_id=#id#] .timeCmd#uid#'));
$('.cmd[data-cmd_uid=#uid#] .gauge').highcharts().series[0].points[0].update(_options.display_value);
if (is_numeric('#state#')) {
jeedom.cmd.displayDuration('#valueDate#', $('.timeCmd#uid#'));
var valueDate#id# = '#valueDate#';
$('.cmd[data-cmd_uid=#uid#] .gauge').empty().highcharts({
chart: {
events: {
click: function (event) {
if (!$.mobile && '#history#' == 'history cursor') {
$('#md_modal2').dialog({title: "Historique"});
$("#md_modal2").load('index.php?v=d&modal=cmd.history&id=#id#').dialog('open');
type: 'solidgauge',
backgroundColor: null,
height : 90,
plotBackgroundColor: null,
plotBackgroundImage: null,
title: null,
pane: {
center: ['35%', '110%'],
startAngle: -30,
endAngle: 90,
background: {
innerRadius: '',
outerRadius: '',
shape: 'arc'
yAxis: {
stops: [
[0.15, color_A#id# ],
[0.35, color_B#id# ],
[0.55, color_C#id# ],
[0.75, color_D#id# ],
[0.95, color_E#id# ],
lineWidth: 1,
lineColor: color_line#id# ,
minorTickLength: 5,
minorTickInterval: 'auto',
minorTickColor: color_minorTick#id#,
tickWidth: 2,
tickColor: color_tickColor#id# , // color bar deg
labels: {
className: 'compteur',
style: {color: color_tick_label_Color#id#,fontSize:'10px'},
enabled: true,
distance: 7,
useHTML: true,
rotation: 'auto',
min: mini#id#,
max: max#id#,
tickInterval: [tick_Interval#id#], //3
title: {
text: '<span style="color:'+color_value#id#+';font-weight: bold;font-family : Helvetica Neue,Helvetica,Arial,sans-serif;#hideCmdName#">#name_display#</span>',
y: - 48,
x: 15,
plotOptions: {
series: {
dataLabels: {
formatter: function () {
return '<span style="color:'+color_value#id#+';font-size:14px;font-family : Roboto-Light,Helvetica Neue,Arial,sans-serif;">'
+ this.point.y.toFixed(dec#id#) + '<span style="color:'+color_unite#id#+';font-size:10px;"> #unite#</span>' ;
style: {textOutline: '1'},
x: 5,
y: 13,
borderWidth: 0,
credits: {enabled: false},
exporting : {enabled: false},
tooltip: {
enabled: false
series: [{
data: [Math.round(parseFloat('#state#') * 10) / 10],
radius: '95%',
innerRadius: '90%',
exporting: {enabled:false},
else {
$('.cmd[data-cmd_uid=#uid#] .gauge').append('<center><span class="label label-danger" style="margin-top : 5px;">#state#</span></center>');
</script>
</div>
Je vais regarder merci ajja
