Après avoir suivi la procédure suivante pour récupération du jeton et connexion à l’API : Collect Inverter data from Solarman API - Share your Projects! - Home Assistant Community
Et en utilisant le script mentionné dans ce sujet : Récupération info Solarman
Je vois bien dans les logs les données recherchées :
0438|[2023-09-18 15:20:27]INFO : [Solarman] json reçu => {"code":null,"msg":null,"success":true,"requestId":"38351b5689639e38","deviceSn":"SE1ES430N5R271","deviceId":228902429,"deviceType":"INVERTER","deviceState":1,"collectionTime":1695042895,"dataList":[{"key":"SN1","value":"SE1ES430N5R271","unit":null,"name":"SN"},{"key":"SS_CY1","value":"11","unit":null,"name":"Production Compliance Country"},{"key":"SYSTIM1","value":" 23-09-18 15:13:47","unit":null,"name":"System Time"},{"key":"HWv1","value":"V100","unit":null,"name":"Hardware Version"},{"key":"SWmai_v1","value":"V310","unit":null,"name":"Software Master Version"},{"key":"DSPv1","value":"V310","unit":null,"name":"DSP Version"},{"key":"DSPv2","value":"V310","unit":null,"name":"Vice DSP Version"},{"key":"DPi_t1","value":"460","unit":"W","name":"Total DC Input Power"},{"key":"AV1","value":"236.50","unit":"V","name":"AC Voltage R/U/A"},{"key":"AV2","value":"0.00","unit":"V","name":"AC Voltage S/V/B"},{"key":"AV3","value":"0.00","unit":"V","name":"AC Voltage T/W/C"},{"key":"AC1","value":"2.47","unit":"A","name":"AC Current R/U/A"},{"key":"AC2","value":"0.28","unit":"A","name":"AC Current S/V/B"},{"key":"AC3","value":"0.06","unit":"A","name":"AC Current T/W/C"},{"key":"Et_ge0","value":"31","unit":"kWh","name":"Cumulative Production (Active)"},{"key":"Etdy_ge1","value":"2.67","unit":"kWh","name":"Daily Production (Active)"},{"key":"ST_PG1","value":"Static","unit":null,"name":"Grid Status"},{"key":"PG_F1","value":"49.98","unit":"Hz","name":"Grid Frequency"},{"key":"PG_Pt1","value":"0.00","unit":"W","name":"Total Grid Power"},{"key":"t_gc1","value":"2","unit":"kWh","name":"Cumulative Grid Feed-in"},{"key":"Et_pu1","value":"87","unit":"kWh","name":"Cumulative Energy Purchased"},{"key":"t_gc_tdy1","value":"0.08","unit":"kWh","name":"Daily Grid Feed-in"},{"key":"Etdy_pu1","value":"4.17","unit":"kWh","name":"Daily Energy Purchased"},{"key":"PG_V1","value":"236.30","unit":"V","name":"Grid Voltage R/U/A"},{"key":"PG_V2","value":"0.00","unit":"V","name":"Grid Voltage S/V/B"},{"key":"PG_V3","value":"0.00","unit":"V","name":"Grid Voltage T/W/C"},{"key":"PG_C1","value":"0.70","unit":"A","name":"Grid Current R/U/A"},{"key":"PG_C2","value":"0.00","unit":"A","name":"Grid Current S/V/B"},{"key":"PG_C3","value":"0.00","unit":"A","name":"Grid Current T/W/C"},{"key":"BUS_V2","value":"376.60","unit":"V","name":"Busbar Voltage"},{"key":"E_Puse_t1","value":"290.00","unit":"W","name":"Total Consumption Power"},{"key":"Et_use1","value":"112","unit":"kWh","name":"Cumulative Consumption"},{"key":"Etdy_use1","value":"6.00","unit":"kWh","name":"Daily Consumption"},{"key":"B_ST1","value":"Charging","unit":null,"name":"Battery Status"},{"key":"B_V1","value":"50.10","unit":"V","name":"Battery Voltage"},{"key":"B_C1","value":"2.77","unit":"A","name":"Battery Current"},{"key":"B_P1","value":"-160.00","unit":"W","name":"Battery Power"},{"key":"GE_C1","value":"1.75","unit":"A","name":"Production Current"},{"key":"Pcg_dcg1","value":"140.00","unit":"W","name":"Charging/Discharging Power"},{"key":"P_INV1","value":"1000.00","unit":"W","name":"Storage Inverter Power"},{"key":"B_left_cap1","value":"40","unit":"%","name":"SoC"},{"key":"t_cd_cg_n1","value":"6","unit":null,"name":"Cumulative Charging/Discharging Time"},{"key":"t_cg_n1","value":"16","unit":"kWh","name":"Total Charging Energy"},{"key":"t_dcg_n1","value":"15","unit":"kWh","name":"Total Discharging Energy"},{"key":"Etdy_cg1","value":"1.27","unit":"kWh","name":"Daily Charging Energy"},{"key":"Etdy_dcg1","value":"0.83","unit":"kWh","name":"Daily Discharging Energy"},{"key":"INV_T0","value":"47","unit":"℃","name":"Temperature- Inverter"},{"key":"B_T1","value":"28.00","unit":"℃","name":"Temperature- Battery"},{"key":"T_RDT1","value":"40","unit":"℃","name":"Radiator Temperature"},{"key":"V_eme_o1","value":"236.20","unit":"V","name":"Emergency Output Voltage"},{"key":"P_eme_o1","value":"0.00","unit":"W","name":"Emergency Output Power"},{"key":"Etdy_ge_hou1","value":"2.65","unit":"h","name":"Daily Production Hour"},{"key":"HR_Ege_t1","value":"30","unit":"h","name":"Total Production Hour"},{"key":"CD_TIM1","value":"0.03","unit":"s","name":"Countdown Time"},{"key":"Buck_C1","value":"0.64","unit":"A","name":"Buck Current"},{"key":"LLC_BUS_V1","value":"323.00","unit":"V","name":"LLC Busbar Voltage"},{"key":"C_Dcp1","value":"0.00","unit":null,"name":"DC Component-Current"},{"key":"V_Dcp1","value":"-40.80","unit":null,"name":"DC Component-Voltage"},{"key":"INV_ST1","value":"Grid connected","unit":null,"name":"Inverter status"}]}
0439|[2023-09-18 15:20:27]INFO : [Solarman] Variable solarman_value = SE1ES430N5R271
0440|[2023-09-18 15:20:27]INFO : [Solarman] Variable solarman_name = SN
0441|[2023-09-18 15:20:27]INFO : [Solarman] Variable solarman_unit = SN
Le JSON :
"code": null,
"msg": null,
"success": true,
"requestId": "b84502161f7214ce",
"deviceSn": "SE1ES430N5R271",
"deviceId": 228902429,
"deviceType": "INVERTER",
"deviceState": 1,
"collectionTime": 1695042583,
"dataList": [{
"key": "SN1",
"value": "SE1ES430N5R271",
"unit": null,
"name": "SN"
"key": "SS_CY1",
"value": "11",
"unit": null,
"name": "Production Compliance Country"
"key": "SYSTIM1",
"value": " 23-09-18 15:09:10",
"unit": null,
"name": "System Time"
"key": "HWv1",
"value": "V100",
"unit": null,
"name": "Hardware Version"
"key": "SWmai_v1",
"value": "V310",
"unit": null,
"name": "Software Master Version"
"key": "DSPv1",
"value": "V310",
"unit": null,
"name": "DSP Version"
"key": "DSPv2",
"value": "V310",
"unit": null,
"name": "Vice DSP Version"
"key": "DPi_t1",
"value": "920",
"unit": "W",
"name": "Total DC Input Power"
"key": "AV1",
"value": "235.80",
"unit": "V",
"name": "AC Voltage R/U/A"
"key": "AV2",
"value": "0.00",
"unit": "V",
"name": "AC Voltage S/V/B"
"key": "AV3",
"value": "0.00",
"unit": "V",
"name": "AC Voltage T/W/C"
"key": "AC1",
"value": "2.09",
"unit": "A",
"name": "AC Current R/U/A"
"key": "AC2",
"value": "0.29",
"unit": "A",
"name": "AC Current S/V/B"
"key": "AC3",
"value": "0.06",
"unit": "A",
"name": "AC Current T/W/C"
"key": "Et_ge0",
"value": "31",
"unit": "kWh",
"name": "Cumulative Production (Active)"
"key": "Etdy_ge1",
"value": "2.60",
"unit": "kWh",
"name": "Daily Production (Active)"
"key": "ST_PG1",
"value": "Static",
"unit": null,
"name": "Grid Status"
"key": "PG_F1",
"value": "49.97",
"unit": "Hz",
"name": "Grid Frequency"
"key": "PG_Pt1",
"value": "0.00",
"unit": "W",
"name": "Total Grid Power"
"key": "t_gc1",
"value": "2",
"unit": "kWh",
"name": "Cumulative Grid Feed-in"
"key": "Et_pu1",
"value": "87",
"unit": "kWh",
"name": "Cumulative Energy Purchased"
"key": "t_gc_tdy1",
"value": "0.08",
"unit": "kWh",
"name": "Daily Grid Feed-in"
"key": "Etdy_pu1",
"value": "4.17",
"unit": "kWh",
"name": "Daily Energy Purchased"
"key": "PG_V1",
"value": "235.90",
"unit": "V",
"name": "Grid Voltage R/U/A"
"key": "PG_V2",
"value": "0.00",
"unit": "V",
"name": "Grid Voltage S/V/B"
"key": "PG_V3",
"value": "0.00",
"unit": "V",
"name": "Grid Voltage T/W/C"
"key": "PG_C1",
"value": "2.70",
"unit": "A",
"name": "Grid Current R/U/A"
"key": "PG_C2",
"value": "0.00",
"unit": "A",
"name": "Grid Current S/V/B"
"key": "PG_C3",
"value": "0.00",
"unit": "A",
"name": "Grid Current T/W/C"
"key": "BUS_V2",
"value": "373.20",
"unit": "V",
"name": "Busbar Voltage"
"key": "E_Puse_t1",
"value": "280.00",
"unit": "W",
"name": "Total Consumption Power"
"key": "Et_use1",
"value": "112",
"unit": "kWh",
"name": "Cumulative Consumption"
"key": "Etdy_use1",
"value": "5.98",
"unit": "kWh",
"name": "Daily Consumption"
"key": "B_ST1",
"value": "Charging",
"unit": null,
"name": "Battery Status"
"key": "B_V1",
"value": "50.00",
"unit": "V",
"name": "Battery Voltage"
"key": "B_C1",
"value": "11.92",
"unit": "A",
"name": "Battery Current"
"key": "B_P1",
"value": "-640.00",
"unit": "W",
"name": "Battery Power"
"key": "GE_C1",
"value": "4.13",
"unit": "A",
"name": "Production Current"
"key": "Pcg_dcg1",
"value": "610.00",
"unit": "W",
"name": "Charging/Discharging Power"
"key": "P_INV1",
"value": "1000.00",
"unit": "W",
"name": "Storage Inverter Power"
"key": "B_left_cap1",
"value": "38",
"unit": "%",
"name": "SoC"
"key": "t_cd_cg_n1",
"value": "6",
"unit": null,
"name": "Cumulative Charging/Discharging Time"
"key": "t_cg_n1",
"value": "16",
"unit": "kWh",
"name": "Total Charging Energy"
"key": "t_dcg_n1",
"value": "15",
"unit": "kWh",
"name": "Total Discharging Energy"
"key": "Etdy_cg1",
"value": "1.22",
"unit": "kWh",
"name": "Daily Charging Energy"
"key": "Etdy_dcg1",
"value": "0.83",
"unit": "kWh",
"name": "Daily Discharging Energy"
"key": "INV_T0",
"value": "47",
"unit": "℃",
"name": "Temperature- Inverter"
"key": "B_T1",
"value": "28.00",
"unit": "℃",
"name": "Temperature- Battery"
"key": "T_RDT1",
"value": "40",
"unit": "℃",
"name": "Radiator Temperature"
"key": "V_eme_o1",
"value": "236.10",
"unit": "V",
"name": "Emergency Output Voltage"
"key": "P_eme_o1",
"value": "0.00",
"unit": "W",
"name": "Emergency Output Power"
"key": "Etdy_ge_hou1",
"value": "2.58",
"unit": "h",
"name": "Daily Production Hour"
"key": "HR_Ege_t1",
"value": "30",
"unit": "h",
"name": "Total Production Hour"
"key": "CD_TIM1",
"value": "0.03",
"unit": "s",
"name": "Countdown Time"
"key": "Buck_C1",
"value": "2.01",
"unit": "A",
"name": "Buck Current"
"key": "LLC_BUS_V1",
"value": "325.00",
"unit": "V",
"name": "LLC Busbar Voltage"
"key": "C_Dcp1",
"value": "0.01",
"unit": null,
"name": "DC Component-Current"
"key": "V_Dcp1",
"value": "-33.50",
"unit": null,
"name": "DC Component-Voltage"
"key": "INV_ST1",
"value": "Grid connected",
"unit": null,
"name": "Inverter status"
Mais je ne comprends pas (même avec la doc du plugin Script), comment les exploiter. ![]()
Est-ce qu’un bonne âme pourra m’aider ?
Par avance, merci.
(Attention pour ceux qui voudraient faire la même chose que sur les références : l’URL de l’API a changé par rapport aux sources que j’ai utilisé, extrait de la réponse du support Solarman suite au non fonctionnement rencontré en utilisant l’ancienne URL de l’API : " If you are using the « International Data Center », we kindly remind that you use the new OPENAPI domain https://globalapi.solarmanpv.com to access the platform, replacing the previous domain https://api.solarmanpv.com. Your APPID and APPSECRET will remain the same, but you will need to obtain a new token to access the platform.")
