Intégration module Tuya-Zigbee TZ3000 (Eclairage 1,2,3,4 gang)
Bonjour, je voudrai rajouter si possible à la bibliothèque des équipements Zigbee 4 modules de commutation TUYA :
TZ3000 - TS0001
[https://fr.aliexpress.com/item/1005002034544511.html?gatewayAdapt=glo2fra&spm=a2g0o.9042311.0.0.6d466c37Lx6hOZ]
Module zigbee - TS0001
    "ieee": "a4:c1:38:32:8f:83:eb:8d",
    "nwk": 3719,
    "status": 2,
    "lqi": "None",
    "rssi": "None",
    "last_seen": "None",
    "node_descriptor": "01:40:8e:41:11:42:42:00:00:2a:42:00:00",
    "endpoints": [
            "id": 1,
            "status": 1,
            "device_type": 256,
            "profile_id": 260,
            "manufacturer": "_TZ3000_tqlv4ug4",
            "model": "TS0001",
            "output_clusters": [
                    "id": 10,
                    "name": "Time",
                    "attributes": []
                    "id": 25,
                    "name": "Ota",
                    "attributes": []
            "input_clusters": [
                    "id": 0,
                    "name": "Basic",
                    "attributes": [
                            "id": 0,
                            "name": "zcl_version",
                            "value": 3
                            "id": 1,
                            "name": "app_version",
                            "value": 67
                            "id": 2,
                            "name": "stack_version",
                            "value": 0
                            "id": 3,
                            "name": "hw_version",
                            "value": 1
                            "id": 4,
                            "name": "manufacturer",
                            "value": "_TZ3000_tqlv4ug4"
                            "id": 5,
                            "name": "model",
                            "value": "TS0001"
                            "id": 6,
                            "name": "date_code",
                            "value": ""
                            "id": 7,
                            "name": "power_source",
                            "value": 1
                    "id": 3,
                    "name": "Identify",
                    "attributes": []
                    "id": 4,
                    "name": "Groups",
                    "attributes": []
                    "id": 5,
                    "name": "Scenes",
                    "attributes": []
                    "id": 6,
                    "name": "On\/Off",
                    "attributes": [
                            "id": 0,
                            "name": "on_off",
                            "value": 1
                    "id": 57344,
                    "name": "Tuya Manufacturer Specific",
                    "attributes": []
                    "id": 57345,
                    "name": "Tuya External Switch Type Cluster",
                    "attributes": []
    "signature": {
        "model": "TS0001",
        "node_desc": {
            "logical_type": 1,
            "reserved": 0,
            "aps_flags": 0,
            "frequency_band": 8,
            "mac_capability_flags": 142,
            "manufacturer_code": 4417,
            "maximum_buffer_size": 66,
            "maximum_incoming_transfer_size": 66,
            "server_mask": 10752,
            "maximum_outgoing_transfer_size": 66,
        "endpoints": {
            "1": {
                "profile_id": 260,
                "device_type": 256,
                "input_clusters": [
                    0,
                    3,
                    4,
                    5,
                    6,
                    57344,
                    57345
                    10,
                    25
    "class": "zhaquirks.tuya.ts000x"
TZ3000 - TS0002
Module Zigbee - TS0002
    "ieee": "a4:c1:38:b4:0f:c0:24:e1",
    "nwk": 18268,
    "status": 2,
    "lqi": "None",
    "rssi": "None",
    "endpoints": [
            "id": 1,
            "status": 1,
            "device_type": 256,
            "profile_id": 260,
            "manufacturer": "_TZ3000_bvrlqyj7",
            "model": "TS0002",
                    "id": 10,
                    "name": "Time",
                    "attributes": []
                    "id": 25,
                    "name": "Ota",
                    "attributes": []
            "input_clusters": [
                    "id": 0,
                    "name": "Basic",
                    "attributes": [
                            "id": 0,
                            "value": 3
                            "id": 1,
                            "value": 67
                            "id": 2,
                            "value": 0
                            "id": 3,
                            "value": 1
                            "id": 4,
                            "value": "_TZ3000_bvrlqyj7"
                            "id": 5,
                            "name": "model",
                            "value": "TS0002"
                            "id": 6,
                            "value": ""
                            "id": 7,
                            "value": 1
                    "id": 3,
                    "name": "Identify",
                    "attributes": []
                    "id": 4,
                    "name": "Groups",
                    "attributes": []
                    "id": 5,
                    "name": "Scenes",
                    "attributes": []
                    "id": 6,
                    "name": "On\/Off",
                    "attributes": []
                    "id": 57344,
                    "attributes": []
                    "id": 57345,
                    "attributes": []
            "id": 2,
            "status": 1,
            "device_type": 256,
            "profile_id": 260,
            "manufacturer": null,
            "model": null,
            "output_clusters": [],
            "input_clusters": [
                    "id": 4,
                    "name": "Groups",
                    "attributes": []
                    "id": 5,
                    "name": "Scenes",
                    "attributes": []
                    "id": 6,
                    "name": "On\/Off",
                    "attributes": []
                    "id": 57345,
                    "attributes": []
            "id": 242,
            "status": 1,
            "device_type": 97,
            "profile_id": 41440,
            "model": null,
                    "id": 33,
                    "name": "GreenPowerProxy",
                    "attributes": []
            "input_clusters": []
    "signature": {
        "model": "TS0002",
        "node_desc": {
            "logical_type": 1,
            "reserved": 0,
            "aps_flags": 0,
        "endpoints": {
            "1": {
                "profile_id": 260,
                "device_type": 256,
                "input_clusters": [
                    0,
                    3,
                    4,
                    5,
                    6,
                    57344,
                    57345
                    10,
                    25
            "2": {
                "profile_id": 260,
                "device_type": 256,
                "input_clusters": [
                    4,
                    5,
                    6,
                    57345
            "242": {
                "device_type": 97,
                "input_clusters": [],
                    33
TZ3000 - TS0003
Module Zigbee - TS0003
    "ieee": "a4:c1:38:04:6f:88:36:48",
    "nwk": 34585,
    "status": 2,
    "lqi": "None",
    "rssi": "None",
    "endpoints": [
            "id": 1,
            "status": 1,
            "device_type": 256,
            "profile_id": 260,
            "manufacturer": "_TZ3000_odzoiovu",
            "model": "TS0003",
                    "id": 10,
                    "name": "Time",
                    "attributes": []
                    "id": 25,
                    "name": "Ota",
                    "attributes": []
            "input_clusters": [
                    "id": 0,
                    "name": "Basic",
                    "attributes": [
                            "id": 0,
                            "value": 3
                            "id": 1,
                            "value": 67
                            "id": 2,
                            "value": 0
                            "id": 3,
                            "value": 1
                            "id": 4,
                            "value": "_TZ3000_odzoiovu"
                            "id": 5,
                            "name": "model",
                            "value": "TS0003"
                            "id": 6,
                            "value": ""
                            "id": 7,
                            "value": 1
                    "id": 3,
                    "name": "Identify",
                    "attributes": []
                    "id": 4,
                    "name": "Groups",
                    "attributes": []
                    "id": 5,
                    "name": "Scenes",
                    "attributes": []
                    "id": 6,
                    "name": "On\/Off",
                    "attributes": [
                            "id": 0,
                            "name": "on_off",
                            "value": 0
                            "id": 16385,
                            "name": "on_time",
                            "value": 0
                            "id": 16386,
                            "name": "off_wait_time",
                            "value": 0
                            "id": 32770,
                            "name": "power_on_state",
                            "value": 1
                    "id": 57344,
                    "attributes": []
                    "id": 57345,
                    "attributes": [
                            "id": 53296,
                            "name": "external_switch_type",
                            "value": 0
            "id": 2,
            "status": 1,
            "device_type": 256,
            "profile_id": 260,
            "model": null,
            "input_clusters": [
                    "id": 4,
                    "name": "Groups",
                    "attributes": []
                    "id": 5,
                    "name": "Scenes",
                    "attributes": []
                    "id": 6,
                    "name": "On\/Off",
                    "attributes": [
                            "id": 0,
                            "name": "on_off",
                            "value": 1
                            "id": 16385,
                            "name": "on_time",
                            "value": 0
                            "id": 16386,
                            "value": 0
                    "id": 57345,
                    "attributes": []
            "id": 3,
            "status": 1,
            "device_type": 256,
            "profile_id": 260,
            "model": null,
            "input_clusters": [
                    "id": 4,
                    "name": "Groups",
                    "attributes": []
                    "id": 5,
                    "name": "Scenes",
                    "attributes": []
                    "id": 6,
                    "name": "On\/Off",
                    "attributes": [
                            "id": 0,
                            "name": "on_off",
                            "value": 1
                            "id": 16385,
                            "name": "on_time",
                            "value": 0
                            "id": 16386,
                            "value": 0
                    "id": 57345,
                    "attributes": []
            "id": 242,
            "status": 1,
            "device_type": 97,
            "model": null,
                    "id": 33,
                    "attributes": []
    "signature": {
        "model": "TS0003",
        "node_desc": {
            "logical_type": 1,
            "reserved": 0,
            "aps_flags": 0,
        "endpoints": {
            "1": {
                "profile_id": 260,
                "device_type": 256,
                "input_clusters": [
                    0,
                    3,
                    4,
                    5,
                    6,
                    57344,
                    57345
                    10,
                    25
            "2": {
                "profile_id": 260,
                "device_type": 256,
                "input_clusters": [
                    4,
                    5,
                    6,
                    57345
            "3": {
                "profile_id": 260,
                "device_type": 256,
                "input_clusters": [
                    4,
                    5,
                    6,
                    57345
            "242": {
                "device_type": 97,
                    33
TZ3000 - TS0004
Module Zigbee - TS0004
    "ieee": "a4:c1:38:35:2f:d2:4f:fe",
    "nwk": 23441,
    "status": 2,
    "lqi": "None",
    "rssi": "None",
    "endpoints": [
            "id": 1,
            "status": 1,
            "device_type": 256,
            "profile_id": 260,
            "manufacturer": "_TZ3000_ltt60asa",
            "model": "TS0004",
                    "id": 25,
                    "name": "Ota",
                    "attributes": []
                    "id": 10,
                    "name": "Time",
                    "attributes": []
            "input_clusters": [
                    "id": 3,
                    "name": "Identify",
                    "attributes": []
                    "id": 4,
                    "name": "Groups",
                    "attributes": []
                    "id": 5,
                    "name": "Scenes",
                    "attributes": []
                    "id": 6,
                    "name": "On\/Off",
                    "attributes": [
                            "id": 0,
                            "name": "on_off",
                            "value": 0
                            "id": 16385,
                            "name": "on_time",
                            "value": 0
                            "id": 16386,
                            "value": 0
                    "id": 57344,
                    "name": "Cluster",
                    "attributes": []
                    "id": 57345,
                    "name": "Cluster",
                    "attributes": []
                    "id": 0,
                    "name": "Basic",
                    "attributes": [
                            "id": 0,
                            "value": 3
                            "id": 1,
                            "value": 67
                            "id": 2,
                            "value": 0
                            "id": 3,
                            "value": 1
                            "id": 4,
                            "value": "_TZ3000_ltt60asa"
                            "id": 5,
                            "name": "model",
                            "value": "TS0004"
                            "id": 6,
                            "value": ""
                            "id": 7,
                            "value": 1
            "id": 2,
            "status": 1,
            "device_type": 256,
            "profile_id": 260,
            "model": null,
            "input_clusters": [
                    "id": 4,
                    "name": "Groups",
                    "attributes": []
                    "id": 5,
                    "name": "Scenes",
                    "attributes": []
                    "id": 6,
                    "name": "On\/Off",
                    "attributes": [
                            "id": 0,
                            "name": "on_off",
                            "value": 1
                            "id": 16385,
                            "name": "on_time",
                            "value": 0
                            "id": 16386,
                            "value": 0
                    "id": 57345,
                    "name": "Cluster",
                    "attributes": []
            "id": 3,
            "status": 1,
            "device_type": 256,
            "profile_id": 260,
            "model": null,
            "input_clusters": [
                    "id": 4,
                    "name": "Groups",
                    "attributes": []
                    "id": 5,
                    "name": "Scenes",
                    "attributes": []
                    "id": 6,
                    "name": "On\/Off",
                    "attributes": [
                            "id": 0,
                            "name": "on_off",
                            "value": 1
                            "id": 16385,
                            "name": "on_time",
                            "value": 0
                            "id": 16386,
                            "value": 0
                    "id": 57345,
                    "name": "Cluster",
                    "attributes": []
            "id": 4,
            "status": 1,
            "device_type": 256,
            "profile_id": 260,
            "model": null,
            "input_clusters": [
                    "id": 4,
                    "name": "Groups",
                    "attributes": []
                    "id": 5,
                    "name": "Scenes",
                    "attributes": []
                    "id": 6,
                    "name": "On\/Off",
                    "attributes": [
                            "id": 0,
                            "name": "on_off",
                            "value": 1
                            "id": 16385,
                            "name": "on_time",
                            "value": 0
                            "id": 16386,
                            "value": 0
                    "id": 57345,
                    "name": "Cluster",
                    "attributes": []
            "id": 242,
            "status": 1,
            "device_type": 97,
            "model": null,
                    "id": 33,
                    "attributes": []
    "signature": {
        "model": "TS0004",
        "node_desc": {
            "logical_type": 1,
            "reserved": 0,
            "aps_flags": 0,
        "endpoints": {
            "1": {
                "profile_id": 260,
                "device_type": 256,
                "input_clusters": [
                    3,
                    4,
                    5,
                    6,
                    57344,
                    57345,
                    0
                    25,
                    10
            "2": {
                "profile_id": 260,
                "device_type": 256,
                "input_clusters": [
                    4,
                    5,
                    6,
                    57345
            "3": {
                "profile_id": 260,
                "device_type": 256,
                "input_clusters": [
                    4,
                    5,
                    6,
                    57345
            "4": {
                "profile_id": 260,
                "device_type": 256,
                "input_clusters": [
                    4,
                    5,
                    6,
                    57345
            "242": {
                "device_type": 97,
                    33
    "class": "zigpy.device"
Merci pour cette demande d’ajout de ces 4 appareils, mais serait il possible d’avoir les images recadrées et sans fond blanc (pour ce qui utilisent un dashboard en dark), sinon la demande risque de ne pas être traitée.
Je viens de recadrer les images.
Normalement j’avais déjà retouché avec gimp la transparence sur chacune des images.
Merci pour votre retour
J’ai acheté plusieurs de ces module en 4 gang. J’en ai intégré 4 il y à environ 3 ou 4 semaine sans auccun problème, mais hier j’ai voulu en intégrer 3 de plus et ils ne fonctionnement pas correctement.
Si je met en marche ou arrete une sortie, sela allume ou éteint toutes les sorties. Si j’appuis sur ON2, cela active 1, 2, 3 et 4, avec retour etat 1= 1, etat 2=1,etc (seulement depuis jeedom). Les sortie sont bien indépendante si je les commande par les interrupteurs physique.
Il y a eu des mise à jour jeddom et sur le plugin Zigbee entre les deux intégration.
Si je regarde la configuration des module, je vois les informations Modèle, Fabricant, Classe et alimentation sont vide sur les 3 module que j’ai intégré hier et bien remplis sur les 4 module qui étaient déja intégré.
Comment puis-je corriger cela ?
Merci à vous par avance.
Bonjour, je rencontre le même souci avec un module 2 relais. Les informations fabricants etc… sont vides, et le comportement des commandes est le même que celui signalé dans le message précédent. Merci de votre aide.
Bonjour @philjeedom et @CarProtectHome
C’est normale le produit est reconnu pour 1 module d’ensemble.
Si vous voulez activer individuellement les relais du module, il faut créer des virtuels pour chaque gang.
N’oublier pas de définir dans les commandes du virtuel, dans configuration - type générique - si c’est une lumière ou autre. Sinon Alexa ne reconnaitra pas le produit.
Cordialement
Je me suis procuré d’autre module identique entre temps et ceux-ci fonctionnement correctement.
Les informations remontent bien et les commandes sont bien séparées.
En regardant de plus près, j’ai remarqué que les modules qui ne fonctionnent pas correctement sont en version 70 alors que ceux qui fonctionnent correctement sont en version 68.
Je ne sais pas comment remédier au problème sur les V.70.
Si quelqu’un a une idée…
Bonsoir.
@tofn1 merci pour le conseil mais ce n’est pas normal et le fait d’utiliser un virtuel pour déclencher les commandes ne permettra pas de les séparer car le souci est que chacune des commandes commande les deux relais à la fois.
D’accord avec @CarProtectHome, je pense que même si les boîtiers sont identiques, il s’agit d’une version différente du module: le nom de l’équipement contient TZ3000_zmy4lslw et une « recherche internet » sur ce code montre que de nouveaux pilotes sont demandés pour plein de plate formes différentes. Pour le module 2 relais dont je dispose les informations brutes sont:
    "ieee": "a4:c1:38:cd:8c:c5:ca:51",
    "nwk": 62390,
    "status": 2,
    "lqi": "255",
    "rssi": "-76",
    "last_seen": "1667681089.055811",
    "endpoints": [
            "id": 1,
            "status": 1,
            "device_type": 256,
            "profile_id": 260,
            "manufacturer": "_TZ3000_zmy4lslw",
            "model": "TS0002",
                    "id": 25,
                    "name": "Ota",
                    "attributes": []
                    "id": 10,
                    "name": "Time",
                    "attributes": []
            "input_clusters": [
                    "id": 3,
                    "name": "Identify",
                    "attributes": []
                    "id": 4,
                    "name": "Groups",
                    "attributes": []
                    "id": 5,
                    "name": "Scenes",
                    "attributes": []
                    "id": 6,
                    "name": "On\/Off",
                    "attributes": [
                            "id": 0,
                            "name": "on_off",
                            "value": 0
                            "id": 16385,
                            "name": "on_time",
                            "value": 0
                            "id": 16386,
                            "value": 0
                    "id": 1794,
                    "name": "Metering",
                    "attributes": [
                            "id": 0,
                            "name": "current_summ_delivered",
                            "value": 0
                    "id": 2820,
                    "name": "Electrical Measurement",
                    "attributes": [
                            "id": 1285,
                            "name": "rms_voltage",
                            "value": 0
                            "id": 1288,
                            "name": "rms_current",
                            "value": 0
                            "id": 1291,
                            "name": "active_power",
                            "value": 0
                    "id": 57344,
                    "name": "Cluster",
                    "attributes": []
                    "id": 57345,
                    "name": "Cluster",
                    "attributes": []
                    "id": 0,
                    "name": "Basic",
                    "attributes": [
                            "id": 0,
                            "value": 3
                            "id": 1,
                            "value": 70
                            "id": 2,
                            "value": 0
                            "id": 3,
                            "value": 1
                            "id": 4,
                            "value": "_TZ3000_zmy4lslw"
                            "id": 5,
                            "name": "model",
                            "value": "TS0002"
                            "id": 6,
                            "value": ""
                            "id": 7,
                            "value": 1
            "id": 2,
            "status": 1,
            "device_type": 256,
            "profile_id": 260,
            "model": null,
            "input_clusters": [
                    "id": 4,
                    "name": "Groups",
                    "attributes": []
                    "id": 5,
                    "name": "Scenes",
                    "attributes": []
                    "id": 6,
                    "name": "On\/Off",
                    "attributes": [
                            "id": 0,
                            "name": "on_off",
                            "value": 0
                            "id": 16385,
                            "name": "on_time",
                            "value": 0
                            "id": 16386,
                            "value": 0
            "id": 242,
            "status": 1,
            "device_type": 97,
            "model": null,
                    "id": 33,
                    "attributes": []
    "signature": {
        "model": "TS0002",
        "node_desc": {
            "logical_type": 1,
            "reserved": 0,
            "aps_flags": 0,
        "endpoints": {
            "1": {
                "profile_id": 260,
                "device_type": 256,
                "input_clusters": [
                    3,
                    4,
                    5,
                    6,
                    1794,
                    2820,
                    57344,
                    57345,
                    0
                    25,
                    10
            "2": {
                "profile_id": 260,
                "device_type": 256,
                "input_clusters": [
                    4,
                    5,
                    6
            "242": {
                "device_type": 97,
                    33
Faut il faire un ticket particulier pour qu’il soit ajouté dans Jeedom ? Merci d’avance.
Il faudrait modifier ton post en utilisant le bouton </> sur le contenu de ton code pour une meilleure lisibilité .
Je viens de le faire: c’est mieux ?
Je vois dans les info : « id »: 1,
« name »: « app_version »,
« value »: 70
Comme sur ceux qui me posent problème.
Cela me confirme que le soucis viens de cette version.
Si quelqu’un savais comment installer un firmware différent dans ce type de module ce serai TOP. J’ai cherché un peut mais je n’ai pas trouvé;
Bonsoir.
Il est question de ce comportement « en groupe » de tous les relais d’un module dans ce forum de la « concurrence » zigpy/zha-device-handlers, il paraît que certains modules Tuya ou Lidl doivent recevoir un « magic spell » pour que les relais se comportent individuellement. Je ne comprends pas vraiment ce dont il est question: si quelqu’un avait une solution pour Jeedom… Merci d’avance !
Je confirme, pareil ici avec un module TS0003, apparemment déjà connu du plugin zigbee, mais moi je l’ai aussi en v70:
    "ieee": "a4:c1:38:ef:c7:9b:ab:6c",
    "nwk": 3197,
    "status": 2,
    "lqi": "None",
    "rssi": "None",
    "last_seen": "1668630682.042564",
    "endpoints": [
            "id": 1,
            "status": 1,
            "device_type": 256,
            "profile_id": 260,
            "model": "TS0003",
                    "id": 25,
                    "name": "Ota",
                    "attributes": []
                    "id": 10,
                    "name": "Time",
                    "attributes": []
            "input_clusters": [
                    "id": 3,
                    "name": "Identify",
                    "attributes": []
                    "id": 4,
                    "name": "Groups",
                    "attributes": []
                    "id": 5,
                    "name": "Scenes",
                    "attributes": []
                    "id": 6,
                    "name": "On\/Off",
                    "attributes": [
                            "id": 0,
                            "name": "on_off",
                            "value": 0
                            "id": 16385,
                            "name": "on_time",
                            "value": 0
                            "id": 16386,
                            "value": 0
                    "id": 1794,
                    "name": "Metering",
                    "attributes": []
                    "id": 2820,
                    "attributes": [
                            "id": 1291,
                            "value": 0
                    "id": 57344,
                    "name": "Cluster",
                    "attributes": []
                    "id": 57345,
                    "name": "Cluster",
                    "attributes": []
                    "id": 0,
                    "name": "Basic",
                    "attributes": [
                            "id": 0,
                            "value": 3
                            "id": 1,
                            "value": 70
                            "id": 2,
                            "value": 0
                            "id": 3,
                            "value": 1
                            "id": 4,
                            "id": 5,
                            "name": "model",
                            "value": "TS0003"
                            "id": 6,
                            "value": ""
                            "id": 7,
                            "value": 1
            "id": 2,
            "status": 1,
            "device_type": 256,
            "profile_id": 260,
            "model": null,
            "input_clusters": [
                    "id": 4,
                    "name": "Groups",
                    "attributes": []
                    "id": 5,
                    "name": "Scenes",
                    "attributes": []
                    "id": 6,
                    "name": "On\/Off",
                    "attributes": [
                            "id": 0,
                            "name": "on_off",
                            "value": 0
                            "id": 16385,
                            "name": "on_time",
                            "value": 0
                            "id": 16386,
                            "value": 0
            "id": 3,
            "status": 1,
            "device_type": 256,
            "profile_id": 260,
            "model": null,
            "input_clusters": [
                    "id": 4,
                    "name": "Groups",
                    "attributes": []
                    "id": 5,
                    "name": "Scenes",
                    "attributes": []
                    "id": 6,
                    "name": "On\/Off",
                    "attributes": [
                            "id": 0,
                            "name": "on_off",
                            "value": 0
                            "id": 16385,
                            "name": "on_time",
                            "value": 0
                            "id": 16386,
                            "value": 0
            "id": 242,
            "status": 1,
            "device_type": 97,
            "model": null,
                    "id": 33,
                    "attributes": []
    "signature": {
        "model": "TS0003",
        "node_desc": {
            "logical_type": 1,
            "reserved": 0,
            "aps_flags": 0,
        "endpoints": {
            "1": {
                "profile_id": 260,
                "device_type": 256,
                "input_clusters": [
                    3,
                    4,
                    5,
                    6,
                    1794,
                    2820,
                    57344,
                    57345,
                    0
                    25,
                    10
            "2": {
                "profile_id": 260,
                "device_type": 256,
                "input_clusters": [
                    4,
                    5,
                    6
            "3": {
                "profile_id": 260,
                "device_type": 256,
                "input_clusters": [
                    4,
                    5,
                    6
            "242": {
                "device_type": 97,
                    33
Le « Magic Spell » c’est du code python présent dans le package zha-quirks, qui fait partie des dépendances installées par le plugin:
/usr/local/lib/python3.7/dist-packages/zhaquirks/tuya/mcu $ tail -15  __init__.py
class EnchantedDevice(CustomDevice):
    """Class for enchanted Tuya devices which needs to be unlocked by casting a 'spell'."""
    def __init__(self, *args, **kwargs):
        """Initialize with task."""
        super().__init__(*args, **kwargs)
        self._init_device_task = asyncio.create_task(self.spell())
    async def spell(self) -> None:
        """Initialize device so that all endpoints become available."""
        attr_to_read = [4, 0, 1, 5, 7, 0xFFFE]
        basic_cluster = self.endpoints[1].in_clusters[0]
        await basic_cluster.read_attributes(attr_to_read)
et cette classe est héritée par les quirks de ces devices:
jeedom@jeedom:/usr/local/lib/python3.7/dist-packages/zhaquirks/tuya $ grep Enchanted ts000x.py
from zhaquirks.tuya.mcu import EnchantedDevice
class Switch_1G_GPP(EnchantedDevice, CustomDevice):
class Switch_1G_Metering(EnchantedDevice, CustomDevice):
class Switch_2G_GPP(EnchantedDevice, CustomDevice):
class Switch_2G_Metering(EnchantedDevice, CustomDevice):
class Switch_3G_GPP(EnchantedDevice, TuyaSwitch):
class Switch_4G_GPP(EnchantedDevice, CustomDevice):
Je comprends le code, mais je ne suis pas dev à proprement parler. Je ne sais pas quel serait le step suivant, si ce code ( ces « quirks » qui sont, si j’ai bien compris, des adaptations pour que ce que renvoit le device colle à la norme ) est bien utilisé dans notre cas, si des modifications sont nécessaires pour ces devices en v70, …
Si un dev peut quelque chose pour moi, je teste tout ce que vous voulez :slight_smile:
Pour compléter, nouveaux modules reçus:
un TS0002 ( 2-gang ), on arrive bien à utiliser les deux voies séparément depuis jeedom. Bizarrement, il n’a pas été « reconnu » à l’inclusion et j’ai du indiquer manuellement que c’était un Tuya TS0002:
    "ieee": "a4:c1:38:78:65:ab:dc:04",
    "nwk": 5675,
    "status": 2,
    "lqi": "96",
    "rssi": "-76",
    "last_seen": "1669050196.053588",
    "endpoints": [
            "id": 1,
            "status": 1,
            "device_type": 256,
            "profile_id": 260,
            "model": "TS0002",
                    "id": 10,
                    "name": "Time",
                    "attributes": []
                    "id": 25,
                    "name": "Ota",
                    "attributes": []
            "input_clusters": [
                    "id": 0,
                    "name": "Basic",
                    "attributes": [
                            "id": 0,
                            "value": 3
                            "id": 1,
                            "value": 70
                            "id": 2,
                            "value": 0
                            "id": 3,
                            "value": 1
                            "id": 4,
                            "id": 5,
                            "name": "model",
                            "value": "TS0002"
                            "id": 6,
                            "value": ""
                            "id": 7,
                            "value": 1
                            "id": 65534,
                            "name": "attr_reporting_status",
                            "value": 0
                    "id": 3,
                    "name": "Identify",
                    "attributes": []
                    "id": 4,
                    "name": "Groups",
                    "attributes": []
                    "id": 5,
                    "name": "Scenes",
                    "attributes": []
                    "id": 6,
                    "name": "On\/Off",
                    "attributes": [
                            "id": 0,
                            "name": "on_off",
                            "value": 0
                            "id": 16385,
                            "name": "on_time",
                            "value": 0
                            "id": 16386,
                            "value": 0
                            "id": 32770,
                            "value": 2
                    "id": 1794,
                    "name": "TuyaZBMeteringCluster",
                    "attributes": []
                    "id": 2820,
                    "attributes": []
                    "id": 57344,
                    "attributes": []
                    "id": 57345,
                    "attributes": [
                            "id": 53296,
                            "value": 0
            "id": 2,
            "status": 1,
            "device_type": 256,
            "profile_id": 260,
            "model": null,
            "input_clusters": [
                    "id": 4,
                    "name": "Groups",
                    "attributes": []
                    "id": 5,
                    "name": "Scenes",
                    "attributes": []
                    "id": 6,
                    "name": "On\/Off",
                    "attributes": [
                            "id": 0,
                            "name": "on_off",
                            "value": 0
                            "id": 16385,
                            "name": "on_time",
                            "value": 0
                            "id": 16386,
                            "value": 0
            "id": 242,
            "status": 1,
            "device_type": 97,
            "model": null,
                    "id": 33,
                    "attributes": []
    "signature": {
        "model": "TS0002",
        "node_desc": {
            "logical_type": 1,
            "reserved": 0,
            "aps_flags": 0,
        "endpoints": {
            "1": {
                "profile_id": 260,
                "device_type": 256,
                "input_clusters": [
                    0,
                    3,
                    4,
                    5,
                    6,
                    1794,
                    2820,
                    57344,
                    57345
                    10,
                    25
            "2": {
                "profile_id": 260,
                "device_type": 256,
                "input_clusters": [
                    4,
                    5,
                    6
            "242": {
                "device_type": 97,
                    33
Je note que la classe est différente: mon TS0003 KO est de class « zigpy.device » et celui-ci de classe « zhaquirks.tuya.ts000x », ce qui semble se réfèrer au ficher que je mentionnais plus haut.
un autre module, 4-gang celui-là, dont les 4 canaux ne commutent pas indépendamment depuis jeedom, mais bien reconnu à l’inclusion et de classe « zigpy.device »:
    "ieee": "a4:c1:38:4d:da:be:d6:e0",
    "nwk": 20455,
    "status": 2,
    "lqi": "112",
    "rssi": "-72",
    "last_seen": "1669049347.257129",
    "endpoints": [
            "id": 1,
            "status": 1,
            "device_type": 256,
            "profile_id": 260,
            "model": "TS0004",
                    "id": 25,
                    "name": "Ota",
                    "attributes": []
                    "id": 10,
                    "name": "Time",
                    "attributes": []
            "input_clusters": [
                    "id": 3,
                    "name": "Identify",
                    "attributes": []
                    "id": 4,
                    "name": "Groups",
                    "attributes": []
                    "id": 5,
                    "name": "Scenes",
                    "attributes": []
                    "id": 6,
                    "name": "On\/Off",
                    "attributes": [
                            "id": 0,
                            "name": "on_off",
                            "value": 1
                            "id": 16385,
                            "name": "on_time",
                            "value": 0
                            "id": 16386,
                            "value": 0
                    "id": 1794,
                    "name": "Metering",
                    "attributes": []
                    "id": 2820,
                    "attributes": []
                    "id": 57344,
                    "name": "Cluster",
                    "attributes": []
                    "id": 57345,
                    "name": "Cluster",
                    "attributes": []
                    "id": 0,
                    "name": "Basic",
                    "attributes": [
                            "id": 0,
                            "value": 3
                            "id": 1,
                            "value": 70
                            "id": 2,
                            "value": 0
                            "id": 3,
                            "value": 1
                            "id": 4,
                            "id": 5,
                            "name": "model",
                            "value": "TS0004"
                            "id": 6,
                            "value": ""
                            "id": 7,
                            "value": 1
            "id": 2,
            "status": 1,
            "device_type": 256,
            "profile_id": 260,
            "model": null,
            "input_clusters": [
                    "id": 4,
                    "name": "Groups",
                    "attributes": []
                    "id": 5,
                    "name": "Scenes",
                    "attributes": []
                    "id": 6,
                    "name": "On\/Off",
                    "attributes": [
                            "id": 0,
                            "name": "on_off",
                            "value": 1
                            "id": 16385,
                            "name": "on_time",
                            "value": 0
                            "id": 16386,
                            "value": 0
            "id": 3,
            "status": 1,
            "device_type": 256,
            "profile_id": 260,
            "model": null,
            "input_clusters": [
                    "id": 4,
                    "name": "Groups",
                    "attributes": []
                    "id": 5,
                    "name": "Scenes",
                    "attributes": []
                    "id": 6,
                    "name": "On\/Off",
                    "attributes": [
                            "id": 0,
                            "name": "on_off",
                            "value": 1
                            "id": 16385,
                            "name": "on_time",
                            "value": 0
                            "id": 16386,
                            "value": 0
            "id": 4,
            "status": 1,
            "device_type": 256,
            "profile_id": 260,
            "model": null,
            "input_clusters": [
                    "id": 4,
                    "name": "Groups",
                    "attributes": []
                    "id": 5,
                    "name": "Scenes",
                    "attributes": []
                    "id": 6,
                    "name": "On\/Off",
                    "attributes": [
                            "id": 0,
                            "name": "on_off",
                            "value": 1
                            "id": 16385,
                            "name": "on_time",
                            "value": 0
                            "id": 16386,
                            "value": 0
            "id": 242,
            "status": 1,
            "device_type": 97,
            "model": null,
                    "id": 33,
                    "attributes": []
    "signature": {
        "model": "TS0004",
        "node_desc": {
            "logical_type": 1,
            "reserved": 0,
            "aps_flags": 0,
        "endpoints": {
            "1": {
                "profile_id": 260,
                "device_type": 256,
                "input_clusters": [
                    3,
                    4,
                    5,
                    6,
                    1794,
                    2820,
                    57344,
                    57345,
                    0
                    25,
                    10
            "2": {
                "profile_id": 260,
                "device_type": 256,
                "input_clusters": [
                    4,
                    5,
                    6
            "3": {
                "profile_id": 260,
                "device_type": 256,
                "input_clusters": [
                    4,
                    5,
                    6
            "4": {
                "profile_id": 260,
                "device_type": 256,
                "input_clusters": [
                    4,
                    5,
                    6
            "242": {
                "device_type": 97,
                    33
Si quelqu’un comprend mieux que moi …
Bonjour, je viens d’acheter ce type de modules (2 gang) (TZ3000_zmy4lslw TS0002) et j’ai le même problème, les deux contacteurs fonctionnent en même temps.
Ci-joint les données brutes de mon modèle
    "ieee": "a4:c1:38:32:81:a7:7a:21",
    "nwk": 48110,
    "status": 2,
    "lqi": "96",
    "rssi": "-76",
    "last_seen": "1669052923.624552",
    "endpoints": [
            "id": 1,
            "status": 1,
            "device_type": 256,
            "profile_id": 260,
            "model": "TS0002",
                    "id": 25,
                    "name": "Ota",
                    "attributes": []
                    "id": 10,
                    "name": "Time",
                    "attributes": []
            "input_clusters": [
                    "id": 3,
                    "name": "Identify",
                    "attributes": []
                    "id": 4,
                    "name": "Groups",
                    "attributes": []
                    "id": 5,
                    "name": "Scenes",
                    "attributes": []
                    "id": 6,
                    "name": "On\/Off",
                    "attributes": [
                            "id": 0,
                            "name": "on_off",
                            "value": 0
                            "id": 16385,
                            "name": "on_time",
                            "value": 0
                            "id": 16386,
                            "value": 0
                    "id": 1794,
                    "name": "Metering",
                    "attributes": []
                    "id": 2820,
                    "attributes": []
                    "id": 57344,
                    "name": "Cluster",
                    "attributes": []
                    "id": 57345,
                    "name": "Cluster",
                    "attributes": []
                    "id": 0,
                    "name": "Basic",
                    "attributes": [
                            "id": 0,
                            "value": 3
                            "id": 1,
                            "value": 70
                            "id": 2,
                            "value": 0
                            "id": 3,
                            "value": 1
                            "id": 4,
                            "id": 5,
                            "name": "model",
                            "value": "TS0002"
                            "id": 6,
                            "value": ""
                            "id": 7,
                            "value": 1
            "id": 2,
            "status": 1,
            "device_type": 256,
            "profile_id": 260,
            "model": null,
            "input_clusters": [
                    "id": 4,
                    "name": "Groups",
                    "attributes": []
                    "id": 5,
                    "name": "Scenes",
                    "attributes": []
                    "id": 6,
                    "name": "On\/Off",
                    "attributes": [
                            "id": 0,
                            "name": "on_off",
                            "value": 0
                            "id": 16385,
                            "name": "on_time",
                            "value": 0
                            "id": 16386,
                            "value": 0
            "id": 242,
            "status": 1,
            "device_type": 97,
            "model": null,
                    "id": 33,
                    "attributes": []
    "signature": {
        "model": "TS0002",
        "node_desc": {
            "logical_type": 1,
            "reserved": 0,
            "aps_flags": 0,
        "endpoints": {
            "1": {
                "profile_id": 260,
                "device_type": 256,
                "input_clusters": [
                    3,
                    4,
                    5,
                    6,
                    1794,
                    2820,
                    57344,
                    57345,
                    0
                    25,
                    10
            "2": {
                "profile_id": 260,
                "device_type": 256,
                "input_clusters": [
                    4,
                    5,
                    6
            "242": {
                "device_type": 97,
                    33
}`Texte préformaté`
Je viens de recevoir des modules 2 canaux. Le json brut est identique à celui de BOB73: _TZ3000_zmy4lslw en v70, de class zigpy.device.
Ils ne sont pas reconnu au moment de l’association. J’ai été obligé de renseigner manuellement le fabriquant: Tuya, et l’équipement :Tuya Zigbee - Switches 2 voies TS0001.
Curieusement le libellé indique TS0001 mais le json des infos brutes ainsi que je json de configuration des commandes indique bien TS0002. Ce doit donc être une simple erreur dans le libellé.
J’observe le même comportement tel que décrit dans les messages précédents : les 2 relais commutent en ON ou OFF simultanément sur les cde individuelles on, off, et toogle des voies 1 ou 2.
Je me joins donc à vous pour trouver une solution.
Je me demande si je ne devrais pas demander l’intégration du module en version 70. Vous en pensez quoi?
Donc ça semble etre exactement le même que le mien, mais le votre est vu en zigpy.device > KO, et le mien vu en zhaquirks.tuya.ts000x > OK. c’est très étonnant.
les « infos brutes » du votre sont les mêmes que sur le mien ? ( mis à part la « classe » naturellement ? )
Si vous pouvez les poster, je ferai la comparaison au besoin :slight_smile:
J’ai comparé nos deux « infos brutes », à part la classe, quelques différences dans des libellés qui me font penser que c’est bien le fait que mon module « passe » dans le code du module python zha-quirks qui fait la différence, en particulier
124c68
<                     "name": "TuyaZBMeteringCluster",
>                     "name": "Metering",
134c78
<                     "name": "Tuya Manufacturer Specific",
>                     "name": "Cluster",
Je ne sais pas aller plus loin que ça malheureusement. pas assez dev …
Merci beaucoup pour votre analyse, même si pour moi tout n’est pas compréhensible facilement. Du coup je ne sais quelle suite à donner pour faire fonctionner mon module. :joy:
