integration de vannes thermostatiques via le plugin zigbee2mqtt - zigbeelinker se fait parfaitement mais une fois dans l’écran de visualisation les vannes sont entourées d’un cercle rouge avec un message indiquant: L’équipement n’a pas pu être complètement intégré.
Merci d’envoyer les informations ci-dessous au développeur du plugin en envoyant un message ici (cliquez sur Message direct en haut à droite de la page qui va s’ouvrir): et les informations techniques ci-dessous:
Modèle : TRVZB
Fabricant : SONOFF
### Property inconnue : "sunday. Commande : {"access":3,"label":"Sunday","name":"sunday","property":"sunday","type":"text"}
### Property inconnue : "monday. Commande : {"access":3,"label":"Monday","name":"monday","property":"monday","type":"text"}
### Property inconnue : "tuesday. Commande : {"access":3,"label":"Tuesday","name":"tuesday","property":"tuesday","type":"text"}
### Property inconnue : "wednesday. Commande : {"access":3,"label":"Wednesday","name":"wednesday","property":"wednesday","type":"text"}
### Property inconnue : "thursday. Commande : {"access":3,"label":"Thursday","name":"thursday","property":"thursday","type":"text"}
### Property inconnue : "friday. Commande : {"access":3,"label":"Friday","name":"friday","property":"friday","type":"text"}
### Property inconnue : "saturday. Commande : {"access":3,"label":"Saturday","name":"saturday","property":"saturday","type":"text"}
#### Last Payload :
{"battery":100,"child_lock":"UNLOCK","closing_steps":257,"device":{"applicationVersion":0,"dateCode":"20230811","friendlyName":"VanneSDB","ieeeAddr":"0x0cae5ffffebadc20","manufacturerID":4742,"manufacturerName":"SONOFF","model":"TRVZB","networkAddress":33626,"powerSource":"Battery","softwareBuildID":"1.1.1","type":"EndDevice","zclVersion":8},"frost_protection_temperature":7,"idle_steps":267,"linkquality":36,"local_temperature":18.5,"local_temperature_calibration":0,"occupied_heating_setpoint":19,"open_window":"ON","running_state":"heat","system_mode":"heat","update":{"installed_version":4353,"latest_version":4353,"state":"idle"},"update_available":false,"valve_closing_limit_voltage":2596,"valve_motor_running_voltage":1306,"valve_opening_limit_voltage":1334,"weekly_schedule":{"friday":"00:00/16 07:00/19 10:00/16 17:00/16 23:00/16 23:00/16","monday":"00:00/16 06:00/19 09:00/16 16:00/16 22:00/16 22:00/16","saturday":"00:00/16 07:00/20 10:00/17 23:00/16 23:00/16 23:00/16","sunday":"00:00/16 07:00/20 10:00/20 23:00/16 23:00/16 23:00/16","thursday":"00:00/16 07:00/19 10:00/16 17:00/16 23:00/16 23:00/16","tuesday":"00:00/16 06:00/19 09:00/16 16:00/16 22:00/16 22:00/16","wednesday":"00:00/16 06:00/19 09:00/16 16:00/16 22:00/16 22:00/16"}}
